[ Upstream commit fcd91dd449867c6bfe56a81cabba76b829fd05cd ]
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally. This recursion
counter is put in the GRO CB, but could be turned into a percpu counter
if we run out of space in the CB.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Tom Herbert <tom@herbertland.com>
[ Upstream commit b82d44d78480faff7456e9e0999acb9d38666057 ]
If the mac address origin is not dt, you can only safely assign a mac
address after "link up" of the device. If the link is off the clocks are
disabled and because of issues assigning registers when clocks are off the
new mac address cannot be written in .ndo_set_mac_address() on some soc's.
This fix sets the mac address unconditionally in fec_restart(...) and
ensures consistency between fec registers and the network layer.
Signed-off-by: Gavin Schenk <g.schenk@eckelmann.de>
Acked-by: Fugang Duan <fugang.duan@nxp.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Fixes: 9638d19e4816 ("net: fec: add netif status check before set mac address")
[ Upstream commit 1b0ff89852d79354e8a091c81a88df21f5aa9f0a ]
While the driver is probing the adapter, an error may occur before the
netdev structure is allocated and attached to pci_dev. In this case,
not only netdev isn't available, but the tg3 private structure is also
not available as it is just math from the NULL pointer, so dereferences
must be skipped.
The following trace is seen when the error is triggered:
[1.402247] Unable to handle kernel paging request for data at address 0x00001a99
[1.402410] Faulting instruction address: 0xc0000000007e33f8
[1.402450] Oops: Kernel access of bad area, sig: 11 [#1]
[1.402481] SMP NR_CPUS=2048 NUMA PowerNV
[1.402513] Modules linked in:
[1.402545] CPU: 0 PID: 651 Comm: eehd Not tainted 4.4.0-36-generic #55-Ubuntu
[1.402591] task: c000001fe4e42a20 ti: c000001fe4e88000 task.ti: c000001fe4e88000
[1.402742] NIP: c0000000007e33f8 LR: c0000000007e3164 CTR: c000000000595ea0
[1.402787] REGS: c000001fe4e8b790 TRAP: 0300 Not tainted (4.4.0-36-generic)
[1.402832] MSR: 9000000100009033 <SF,HV,EE,ME,IR,DR,RI,LE> CR: 28000422 XER: 20000000
[1.403058] CFAR: c000000000008468 DAR: 0000000000001a99 DSISR: 42000000 SOFTE: 1
GPR00: c0000000007e3164 c000001fe4e8ba10 c0000000015c5e00 0000000000000000
GPR04: 0000000000000001 0000000000000000 0000000000000039 0000000000000299
GPR08: 0000000000000000 0000000000000001 c000001fe4e88000 0000000000000006
GPR12: 0000000000000000 c00000000fb40000 c0000000000e6558 c000003ca1bffd00
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 0000000000000000 0000000000000000 0000000000000000 c000000000d52768
GPR24: c000000000d52740 0000000000000100 c000003ca1b52000 0000000000000002
GPR28: 0000000000000900 0000000000000000 c00000000152a0c0 c000003ca1b52000
[1.404226] NIP [c0000000007e33f8] tg3_io_error_detected+0x308/0x340
[1.404265] LR [c0000000007e3164] tg3_io_error_detected+0x74/0x340
This patch avoids the NULL pointer dereference by moving the access after
the netdev NULL pointer check on tg3_io_error_detected(). Also, we add a
check for netdev being NULL on tg3_io_resume() [suggested by Michael Chan].
Fixes: 0486a063b1ff ("tg3: prevent ifup/ifdown during PCI error recovery")
Fixes: dfc8f370316b ("net/tg3: Release IRQs on permanent error")
Tested-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Signed-off-by: Milton Miller <miltonm@us.ibm.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Acked-by: Michael Chan <michael.chan@broadcom.com>
commit e3ebd894f084255fde19116955ba7054858ff5d6 upstream.
The smc91x driver defines a macro that compares its argument to
itself, apparently to get a true result while using its argument
to avoid a warning about unused local variables.
Unfortunately, this triggers a warning with gcc-6, as the comparison
is obviously useless:
drivers/net/ethernet/smsc/smc91x.c: In function 'smc_hardware_send_pkt':
drivers/net/ethernet/smsc/smc91x.c:563:14: error: self-comparison always evaluates to true [-Werror=tautological-compare]
if (!smc_special_trylock(&lp->lock, flags)) {
This replaces the macro with another one that behaves similarly,
with a cast to (void) to ensure the argument is used, and using
a literal 'true' as its value.
commit b64db1b252e9974a43a51ba083fa7d03e4716167 upstream.
AID gets updated during TDLS setup, but modified value isn't reflected
in "priv->assoc_rsp_buf". This causes TDLS setup failure. The problem is
fixed here.
Fixes: 4aff53ef18e4a4 ("mwifiex: parsing aid while receiving..")
Signed-off-by: Xinming Hu <huxm@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit ded89912156b1a47d940a0c954c43afbabd0c42c upstream.
User-space can choose to omit NL80211_ATTR_SSID and only provide raw
IE TLV data. When doing so it can provide SSID IE with length exceeding
the allowed size. The driver further processes this IE copying it
into a local variable without checking the length. Hence stack can be
corrupted and used as exploit.
Reported-by: Daxing Guo <freener.gdx@gmail.com>
Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieter-paul.giesberts@broadcom.com>
Reviewed-by: Franky Lin <franky.lin@broadcom.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit 6e5224224faa50ec4c8949dcefadf895e565f0d1 upstream.
The VF administrative mac addresses (stored in the PF driver) are
initialized to zero when the PF driver starts up.
These addresses may be modified in the PF driver through ndo calls
initiated by iproute2 or libvirt.
While we allow the PF/host to change the VF admin mac address from zero
to a valid unicast mac, we do not allow restoring the VF admin mac to
zero. We currently only allow changing this mac to a different unicast mac.
This leads to problems when libvirt scripts are used to deal with
VF mac addresses, and libvirt attempts to revoke the mac so this
host will not use it anymore.
Fix this by allowing resetting a VF administrative MAC back to zero.
Fixes: 8f7ba3ca12f6 ('net/mlx4: Add set VF mac address support')
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reported-by: Moshe Levi <moshele@mellanox.com>
commit 1e6bb1a3540fec3ef112b9a89dda88e684c3ff59 upstream.
Not all adapters have FC-NPIV configured. If bnx2fc is used with such an
adapter, driver would read irrelevant data from the the nvram and log
"FC-NPIV table with bad length..." In system logs.
Simply accept that reading '0' as the feature offset in nvram indicates
the feature isn't there and return.
Reported-by: Andrew Patterson <andrew.patterson@hpe.com>
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
commit 0c9d3491530773858ff9d705ec2a9c382f449230 upstream.
Some RTL8821AE devices sold in Great Britain have the country code of
0x25 encoded in their EEPROM. This value is not tested in the routine
that establishes the regulatory info for the chip. The fix is to set
this code to have the same capabilities as the EU countries. In addition,
the channels allowed for COUNTRY_CODE_ETSI were more properly suited
for China and Israel, not the EU. This problem has also been fixed.
commit 23e9c128adb2038c27a424a5f91136e7fa3e0dc6 upstream.
This function is called from get_station callback which means that every
time user space was getting/dumping station(s) we were leaking 2 KiB.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Fixes: 1f0dc59a6de ("brcmfmac: rework .get_station() callback")
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
commit edfc23ee3e0ebbb6713d7574ab1b00abff178f6c upstream.
Although rare, it's possible to hit PCI error early on device
probe, meaning possibly some structs are not entirely initialized,
and some might even be completely uninitialized, leading to NULL
pointer dereference.
The i40e driver currently presents a "bad" behavior if device hits
such early PCI error: firstly, the struct i40e_pf might not be
attached to pci_dev yet, leading to a NULL pointer dereference on
access to pf->state.
Even checking if the struct is NULL and avoiding the access in that
case isn't enough, since the driver cannot recover from PCI error
that early; in our experiments we saw multiple failures on kernel
log, like:
[549.664] i40e 0007:01:00.1: Initial pf_reset failed: -15
[549.664] i40e: probe of 0007:01:00.1 failed with error -15
[871.644] i40e 0007:01:00.1: The driver for the device stopped because the
device firmware failed to init. Try updating your NVM image.
[871.644] i40e: probe of 0007:01:00.1 failed with error -32
[872.516] i40e 0007:01:00.0: ARQ: Unknown event 0x0000 ignored
Between the first probe failure (error -15) and the second (error -32)
another PCI error happened due to the first bad probe. Also, driver
started to flood console with those ARQ event messages.
This patch will prevent these issues by allowing error recovery
mechanism to remove the failed device from the system instead of
trying to recover from early PCI errors during device probe.
Signed-off-by: Guilherme G Piccoli <gpiccoli@linux.vnet.ibm.com>
Acked-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
commit f823a2aa8f4674c095a5413b9e3ba12d82df06f2 upstream.
wlc_phy_txpower_get_current() does a logical OR of power->flags, which
presumes that power.flags was initiliazed earlier by the caller,
unfortunately, this is not the case, so make sure we zero out the struct
tx_power before calling into wlc_phy_txpower_get_current().
Reported-by: coverity (CID 146011)
Fixes: 5b435de0d7868 ("net: wireless: add brcm80211 drivers")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 5c5fa1f464ac954982df1d96b9f9a5103d21aedd upstream.
In case dma_mapping_error() returns an error in dma_rxfill, we would be
leaking a packet that we allocated with brcmu_pkt_buf_get_skb().
Reported-by: coverity (CID 1081819)
Fixes: 67d0cf50bd32 ("brcmsmac: Fix WARNING caused by lack of calls to dma_mapping_error()")
Acked-by: Arend van Spriel <arend@broadcom.com>
commit 3bdae810721b33061d2e541bd78a70f86ca42af3 upstream.
In case brcmf_sdiod_recv_chain() cannot complete a succeful call to
brcmf_sdiod_buffrw, we would be leaking glom_skb and not free it as we
should, fix this.
Reported-by: coverity (CID 1164856)
Fixes: a413e39a38573 ("brcmfmac: fix brcmf_sdcard_recv_chain() for host without sg support")
commit aaab50fcea78ae3414c3afc25aae8d0603df34d0 upstream.
The function ar9003_hw_apply_minccapwr_thresh takes as second parameter not
a pointer to the channel but a boolean value describing whether the channel
is 2.4GHz or not. This broke (according to the origin commit) the ETSI
regulatory compliance on 5GHz channels.
Fixes: 3533bf6b15a0 ("ath9k: Fix regulatory compliance")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Cc: Simon Wunderlich <sw@simonwunderlich.de>
Cc: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit 849a9627299100ae3f0ce573fc87d2b476f3bb59 upstream.
Currently the state sent in SF configuration is always
FULL_ON.
This commit sets the correct state (e.g. INIT_OFF
when station is not associated).
Fixes: commit f4a3ee493e69 ("iwlwifi: mvm: Always enable the smart FIFO")
Signed-off-by: Shaul Triebitz <shaul.triebitz@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
commit ff6e58e648ed5f3cc43891767811d5c3c88bbd41 upstream.
fw-dbg code return ret but that variable was either 0
or not initialised. Return 0 always.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Fixes: 6a95126763fb ("iwlwifi: mvm: send dbg config hcmds to fw if set in tlv")
commit d5d0689aefc59c6a5352ca25d7e6d47d03f543ce upstream.
This fixes a pretty ancient bug that hasn't manifested itself
until now.
The scratchbuf for command queue is allocated only for 32 slots
but is accessed with the queue write pointer - which can be
up to 256.
Since the scratch buf size was 16 and there are up to 256 TFDs
we never passed a page boundary when accessing the scratch buffer,
but when attempting to increase the size of the scratch buffer a
panic was quick to follow when trying to access the address resulted
in a page boundary.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Fixes: 38c0f334b359 ("iwlwifi: use coherent DMA memory for command header")
commit cd956722167ba4fdba9c1ce3eed251b04ea2e10f upstream.
In function i40e_debug_aq parameter desc is assumed to be
possibly NULL. Do not dereference it before checking the
value.
Fixes: f905dd62be88 ("i40e/i40evf: add max buf len to aq debug print helper")
commit 280a3efa82fccc9532c968a77e5162cb9f0af497 upstream.
My cleanup in "iwlwifi: prepare for higher API/CAPA bits" accidentally
inverted a few tests - fix them.
Fixes: 859d914c8f5c ("iwlwifi: prepare for higher API/CAPA bits")
Reported-by: Sara Sharon <sara.sharon@intel.com>
commit 9abefcb1aaa58b9d5aa40a8bb12c87d02415e4c8 upstream.
A timer was used to restart after the bus-off state, leading to a
relatively large can_restart() executed in an interrupt context,
which in turn sets up pinctrl. When this happens during system boot,
there is a high probability of grabbing the pinctrl_list_mutex,
which is locked already by the probe() of other device, making the
kernel suspect a deadlock condition [1].
To resolve this issue, the restart_timer is replaced by a delayed
work.
[1] https://github.com/victronenergy/venus/issues/24
Signed-off-by: Sergei Miroshnichenko <sergeimir@emcraft.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 4de349e786a3a2d51bd02d56f3de151bbc3c3df9 upstream.
On a imx6ul-pico board the following error is seen during system suspend:
dpm_run_callback(): platform_pm_resume+0x0/0x54 returns -110
PM: Device 2090000.flexcan failed to resume: error -110
The reason for this suspend error is because when the CAN interface is not
active the clocks are disabled and then flexcan_chip_enable() will
always fail due to a timeout error.
In order to fix this issue, only call flexcan_chip_enable/disable()
when the CAN interface is active.
Based on a patch from Dong Aisheng in the NXP kernel.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit 2fb04fdf30192ff1e2b5834e9b7745889ea8bbcb ]
Commit b70661c70830 ("net: smc91x: use run-time configuration on all ARM
machines") broke some ARM platforms through several mistakes. Firstly,
the access size must correspond to the following rule:
(a) at least one of 16-bit or 8-bit access size must be supported
(b) 32-bit accesses are optional, and may be enabled in addition to
the above.
Secondly, it provides no emulation of 16-bit accesses, instead blindly
making 16-bit accesses even when the platform specifies that only 8-bit
is supported.
Reorganise smc91x.h so we can make use of the existing 16-bit access
emulation already provided - if 16-bit accesses are supported, use
16-bit accesses directly, otherwise if 8-bit accesses are supported,
use the provided 16-bit access emulation. If neither, BUG(). This
exactly reflects the driver behaviour prior to the commit being fixed.
Since the conversion incorrectly cut down the available access sizes on
several platforms, we also need to go through every platform and fix up
the overly-restrictive access size: Arnd assumed that if a platform can
perform 32-bit, 16-bit and 8-bit accesses, then only a 32-bit access
size needed to be specified - not so, all available access sizes must
be specified.
This likely fixes some performance regressions in doing this: if a
platform does not support 8-bit accesses, 8-bit accesses have been
emulated by performing a 16-bit read-modify-write access.
Tested on the Intel Assabet/Neponset platform, which supports only 8-bit
accesses, which was broken by the original commit.
Fixes: b70661c70830 ("net: smc91x: use run-time configuration on all ARM machines")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit c3e70edd7c2eed6acd234627a6007627f5c76e8e ]
This reverts:
commit 33c133cc7598 ("phy: IRQ cannot be shared")
On hardware with multiple PHY devices hooked up to the same IRQ line, allow
them to share it.
Sergei Shtylyov says:
"I'm not sure now what was the reason I concluded that the IRQ sharing
was impossible... most probably I thought that the kernel IRQ handling
code exited the loop over the IRQ actions once IRQ_HANDLED was returned
-- which is obviously not so in reality..."
Signed-off-by: Xander Huff <xander.huff@ni.com>
Signed-off-by: Nathan Sullivan <nathan.sullivan@ni.com>
[ Upstream commit 4f101c47791cdcb831b3ef1f831b1cc51e4fe03c ]
We kept shadow copies of which interrupt sources we have enabled and
disabled, but due to an order bug in how intrl2_mask_clear was defined,
we could run into the following scenario:
CPU0 CPU1
intrl2_1_mask_clear(..)
sets INTRL2_CPU_MASK_CLEAR
bcm_sf2_switch_1_isr
read INTRL2_CPU_STATUS and masks with stale
irq1_mask value
updates irq1_mask value
Which would make us loop again and again trying to process and interrupt
we are not clearing since our copy of whether it was enabled before
still indicates it was not. Fix this by updating the shadow copy first,
and then unasking at the HW level.
Fixes: 246d7f773c13 ("net: dsa: add Broadcom SF2 switch driver")
[ Upstream commit 2c0f8ce1b584a4d7b8ff53140d21dfed99834940 ]
Set and verify signature calculates the signature for each of the
mailbox nodes, even for those that are unused (from cache). Added
a missing length check to set and verify only those which are used.
While here, also moved the setting of msg's nodes token to where we
already go over them. This saves a pass because checksum is disabled,
and the only useful thing remaining that set signature does is setting
the token.
Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB
adapters')
Signed-off-by: Paul Blakey <paulb@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 24b27fc4cdf9e10c5e79e5923b6b7c2c5c95096c ]
Following few steps will crash kernel -
(a) Create bonding master
> modprobe bonding miimon=50
(b) Create macvlan bridge on eth2
> ip link add link eth2 dev mvl0 address aa:0:0:0:0:01 \
type macvlan
(c) Now try adding eth2 into the bond
> echo +eth2 > /sys/class/net/bond0/bonding/slaves
<crash>
Bonding does lots of things before checking if the device enslaved is
busy or not.
In this case when the notifier call-chain sends notifications, the
bond_netdev_event() assumes that the rx_handler /rx_handler_data is
registered while the bond_enslave() hasn't progressed far enough to
register rx_handler for the new slave.
This patch adds a rx_handler check that can be performed right at the
beginning of the enslave code to avoid getting into this situation.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
commit 2cce76c3fab410520610a7d2f52faebc3cfcf843 upstream.
gcc-6 warns about code in il3945_hw_txq_ctx_free() being
somewhat ambiguous:
drivers/net/wireless/intel/iwlegacy/3945.c:1022:5: warning: suggest explicit braces to avoid ambiguous 'else' [-Wparentheses]
This adds a set of curly braces to avoid the warning.
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 362210e0dff4eb7bb36a9b34dbef3b39d779d95e upstream.
A cleanup patch in linux-3.18 moved around some code in the ath9k
driver and left some code to be indented in a misleading way,
made worse by the addition of some new code for p2p mode, as
discovered by a new gcc-6 warning:
drivers/net/wireless/ath/ath9k/init.c: In function 'ath9k_set_hw_capab':
drivers/net/wireless/ath/ath9k/init.c:851:4: warning: statement is indented as if it were guarded by... [-Wmisleading-indentation]
hw->wiphy->iface_combinations = if_comb;
drivers/net/wireless/ath/ath9k/init.c:847:3: note: ...this 'if' clause, but it is not
if (ath9k_is_chanctx_enabled())
The code is in fact correct, but the indentation is not, so I'm
reformatting it as it should have been after the original cleanup.
Fixes: 499afaccf6f3 ("ath9k: Isolate ath9k_use_chanctx module parameter")
Fixes: eb61f9f623f7 ("ath9k: advertise p2p dev support when chanctx")
commit 8f57e4d930d48217268315898212518d4d3e0773 upstream.
Rewrite abs() so that its return type does not depend on the
architecture and no unexpected type conversion happen inside of it. The
only conversion is from unsigned to signed type. char is left as a
return type but treated as a signed type regradless of it's actual
signedness.
With the old version, int arguments were promoted to long and depending
on architecture a long argument might result in s64 or long return type
(which may or may not be the same).
This came after some back and forth with Nicolas. The current macro has
different return type (for the same input type) depending on
architecture which might be midly iritating.
An alternative version would promote to int like so:
#define abs(x) __abs_choose_expr(x, long long, \
__abs_choose_expr(x, long, \
__builtin_choose_expr( \
sizeof(x) <= sizeof(int), \
({ int __x = (x); __x<0?-__x:__x; }), \
((void)0))))
I have no preference but imagine Linus might. :] Nicolas argument against
is that promoting to int causes iconsistent behaviour:
int main(void) {
unsigned short a = 0, b = 1, c = a - b;
unsigned short d = abs(a - b);
unsigned short e = abs(c);
printf("%u %u\n", d, e); // prints: 1 65535
Then again, no sane person expects consistent behaviour from C integer
arithmetic. ;)
Note:
__builtin_types_compatible_p(unsigned char, char) is always false, and
__builtin_types_compatible_p(signed char, char) is also always false.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 7711aaf08ad3fc4d0e937eec1de0a63620444ce7 upstream.
A station pointer can be passed to the driver on tx, before it has been
marked as associated. Since ath9k_sta_state was initializing the entry
too late, it resulted in some spurious crashes.
Fixes: df3c6eb34da5 ("ath9k: Use sta_state() callback")
Signed-off-by: Felix Fietkau <nbd@nbd.name>
commit 1423661fed2c40d6d71b5e2e3aa390f85157f9d5 upstream.
The ethtool_ops .get_regs function attempts to read the nonexistent
register NIC_QSET_SQ_0_7_CNM_CHG, which produces a "bus error" type
OOPs.
Fix by not attempting to read, and removing the definition of,
NIC_QSET_SQ_0_7_CNM_CHG. A zero is written into the register dump to
keep the layout unchanged.
Signed-off-by: David Daney <david.daney@cavium.com>
[ Upstream commit 3f4c68cfde30caa1f6d8368fd19590671411ade2 ]
Check for SMU RX local/remote faults along with SPU LINK
status. Otherwise at times link is UP at our end but DOWN
at link partner's side. Also due to an issue in BGX it's
rarely seen that initialization doesn't happen properly
and SMU RX reports faults with everything fine at SPU.
This patch tries to reinitialize LMAC to fix it.
Also fixed LMAC disable sequence to properly bring down link.
Signed-off-by: Sunil Goutham <sgoutham@cavium.com>
Signed-off-by: Tao Wang <tao.wang@cavium.com>
[ Upstream commit ad2ecebd67d8a80fe5412d11df375a5ed2db7cd1 ]
Counting rx packets for every CQE_RX in CQ irq handler is incorrect.
Synchronization is missing when multiple queues are receiving packets
simultaneously. Like transmit packet stats use HW stats here.
Also removed unused 'cqe_type' parameter in nicvf_rcv_pkt_handler().
[ Upstream commit 6a9bab79bb79bd9b2eda16f0aba1b4c43f677be9 ]
When a interface is assigned morethan 8 queues and the logical interface
is toggled i.e down & up, additional queues or qsets are not initialized
as secondary qset count is being set to zero while tearing down.
[ Upstream commit 2fcb92fbd04eef26dfe7e67839da6262d83d6b65 ]
Calling mlx5e_set_coalesce while the interface is down will result in
modifying CQs that don't exist.
Fixes: f62b8bb8f2d3 ('net/mlx5: Extend mlx5_core to support ConnectX-4
Ethernet functionality')
Signed-off-by: Gal Pressman <galp@mellanox.com>
[ Upstream commit 7524a5d88b94afef8397a79f1e664af5b7052c22 ]
If CQ moderation is not supported by the device, print a warning on
netdevice load, and return error when trying to modify/query cq
moderation via ethtool.
[ Upstream commit 4c0b6eaf373a5323f03a3a20c42fc435715b073d ]
On Thunderx pass 1.x and pass2 due to a HW errata default CQ
DROP_LEVEL of 0x80 is not sufficient to avoid CQ_WR_FULL Qset
error when packets are being received at >20Mpps resulting in
complete stall of packet reception.
This patch will configure it to 0x100 which is what is expected
by HW on Thunderx. On future passes of thunderx and other chips
HW default/reset value will be 0x100 or higher hence not overwritten.
Signed-off-by: Jerin Jacob <jerin.jacob@caviumnetworks.com>
[ Upstream commit 6e35c04cf633e55648acb9ccabff42aa37bd4044 ]
This patch fixes the Hash PCTYPE enable for X722 since it supports
a broader selection of PCTYPES for TCP and UDP.
This patch also fixes a bug in XL710, X710, X722 support for RSS,
as of now we cannot reduce the (4)tuple for RSS for TCP/IPv4/IPV6 or
UDP/IPv4/IPv6 packets since this requires a product feature change
that comes in a later release.
A VF should never be allowed to change the tuples for RSS for any
PCTYPE since that's a global setting for the device in case of i40e
devices.
Change-ID: I0ee7203c9b24813260f58f3220798bc9d9ac4a12
Signed-off-by: Anjali Singhai Jain <anjali.singhai@intel.com>
[ Upstream commit 19a6d156a7bd080f3a855a40a4a08ab475e34b4a ]
smatch detected a suspicious looking bitop condition:
drivers/net/ethernet/cavium/liquidio/lio_main.c:2529
handle_timestamp() warn: suspicious bitop condition
(skb_shinfo(skb)->tx_flags | SKBTX_IN_PROGRESS is always non-zero,
so the logic is definitely not correct. Use & to mask the correct
bit.
[ Upstream commit e00e23bceba48a8f0c94fefe26948404cbd43d0a ]
This patch addresses two issues.
First is the fact that the fm10k_mbx_free_irq was assuming msix_entries was
valid and that will not always be the case. As such we need to add a check
for if it is NULL.
Second is the fact that we weren't freeing the IRQ if the mailbox API
returned an error on trying to connect.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Reviewed-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Krishneil Singh <Krishneil.k.singh@intel.com>
[ Upstream commit 587731e684dcf3522215194a02357d26b9bc7277 ]
If the q_vector allocation fails we should free the resources associated
with the MSI-X vector table.
[ Upstream commit 875328e4bce696e85edcda3c4b0ec80fd525e3a3 ]
The init_hw function may fail, and in the case of VFs, it might change
the number of maximum queues available. Thus, for every flow which
checks init_hw, we need to ensure that we clear the queue scheme before,
and initialize it after. The fm10k_io_slot_reset path will end up
triggering a reset so fm10k_reinit needs this change. The
fm10k_io_error_detected and fm10k_io_resume also need to properly clear
and reinitialize the queue scheme.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
[ Upstream commit 1343c65f70ee1b1f968a08b30e1836a4e37116cd ]
A recent change modified init_hw in some flows the function may fail on
VF devices. For example, if a VF doesn't yet own its own queues.
However, many callers of init_hw didn't bother to check the error code.
Other callers checked but only displayed diagnostic messages without
actually handling the consequences.
Fix this by (a) always returning and preventing the netdevice from going
up, and (b) printing the diagnostic in every flow for consistency. This
should resolve an issue where VF drivers would attempt to come up
before the PF has finished assigning queues.
In addition, change the dmesg output to explicitly show the actual
function that failed, instead of combining reset_hw and init_hw into a
single check, to help for future debugging.
Fixes: 1d568b0f6424 ("fm10k: do not assume VF always has 1 queue")
[ Upstream commit 0e8d5b5975401c83641efd5d4595e6cdbe9e9e2f ]
VF drivers must detect how many queues are available. Previously, the
driver assumed that each VF has at minimum 1 queue. This assumption is
incorrect, since it is possible that the PF has not yet assigned the
queues to the VF by the time the VF checks. To resolve this, we added a
check first to ensure that the first queue is infact owned by the VF at
init_hw_vf time. However, the code flow did not reset hw->mac.max_queues
to 0. In some cases, such as during reinit flows, we call init_hw_vf
without clearing the previous value of hw->mac.max_queues. Due to this,
when init_hw_vf errors out, if its error code is not properly handled
the VF driver may still believe it has queues which no longer belong to
it. Fix this by clearing the hw->mac.max_queues on exit due to errors.
[ Upstream commit 9f872986479b6e0543eb5c615e5f9491bb04e5c1 ]
This patch corrects an issue in which the polling routine would increase
the budget for Rx to at least 1 per queue if multiple queues were present.
This would result in Rx packets being processed when the budget was 0 which
is meant to indicate that no Rx can be handled.
[ Upstream commit 8c7ee6d2cacc7794a91875ef5fd8284b4a900d8c ]
Based on hardware testing, the host interface supports up to 15368 bytes
as the maximum frame size. To determine the correct MTU, we subtract 8
for the internal switch tag, 14 for the L2 header, and 4 for the
appended FCS header, resulting in 15342 bytes of payload for our maximum
MTU on jumbo frames.
Signed-off-by: Matthew Vick <matthew.vick@intel.com>
Acked-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Krishneil Singh <krishneil.k.singh@intel.com>
[ Upstream commit 1340181fe435ccb8ca2f996b8680bd9566860619 ]
It is possible that the PF has not yet assigned resources to the VF.
Although rare, this could result in the VF attempting to read queues it
does not own and result in FUM or THI faults in the PF. To prevent this,
check queue 0 before we continue in init_hw_vf.
[ Upstream commit b77ac46bbae862dcb3f51296825c940404c69b0f ]
This patch fixes possible division by zero in receive
interrupt handler when working without adaptive interrupt
moderation.
The adaptive interrupt moderation mechanism is typically
disabled on jumbo MTUs.
Signed-off-by: Dmitry Fleytman <dmitry@daynix.com>
Signed-off-by: Leonid Bloch <leonid@daynix.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 9eab46b7cb8d0b0dcf014bf7b25e0e72b9e4d929 ]
e1000_clean_tx_irq cleans buffers and sets tx_ring->next_to_clean,
then e1000_xmit_frame reuses the cleaned buffers. But there are no
memory barriers when buffers gets recycled, so the recycled buffers
can be corrupted.
Use smp_store_release to update tx_ring->next_to_clean and
smp_load_acquire to read tx_ring->next_to_clean to properly
hand off buffers from e1000_clean_tx_irq to e1000_xmit_frame.
The data race was found with KernelThreadSanitizer (KTSAN).
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
