Add support for the network interface message level settings for
determining whether to issue some of the driver messages. Make
use of the netif_* interface where appropriate.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Add additional/extended statistics beyond what is provided by the
hardware to be reported via ethtool. The new stats focus on the
calls into ndo_start_xmit and the napi_poll routine.
The dwmac-generic replaces the driver inside the stmmac
platform code. This turns stmmac platform into a library
used by drivers for common platform driver functions.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Convert platform glue layer into a proper platform
driver and add it to the build system.
Create a new driver around the generic device tree match strings
in the stmmac platform code. This driver is intended to be used
by all platforms that doesn't require any platform specific code
to function or is using platform data.
Prepare the stmmac platform code to support standalone drivers
by exporting the need functions and having of_match_device use
the match table reference already present in the driver struct.
This will allow us to reuse the platform driver functions from
this code easily in other stand alone platform drivers.
Add support for Ethernet on NXP LPC18xx and LPC43xx using the
dwmac driver. This glue is required to setup phy interface
mode, MII or RMII, on the SoC.
Current code does not lock anything when calculating the TX and RX stats.
As a result, the RX and TX data reported by ifconfig are not accuracy in a
system with high network throughput and multiple CPUs (in my test,
RX/TX = 83% between 2 HyperV VM nodes which have 8 vCPUs and 40G Ethernet).
This patch fixed the above issue by using per_cpu stats.
netvsc_get_stats64() summarizes TX and RX data by iterating over all CPUs
to get their respective stats.
This v2 patch addressed David's comments on the cleanup path when
netdev_alloc_pcpu_stats() failed.
Signed-off-by: Simon Xiao <sixiao@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
This also changes mii_bus.phy_mask to u32 for consistency.
Signed-off-by: Bert Vermeulen <bert@biot.com>
None of those drivers uses last_rx for its own needs.
See 4dc89133f49b8cfd77ba7e83f5960aed63aaa99e ("net: add a comment on
netdev->last_rx") for reference.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Zhangfei Gao <zhangfei.gao@linaro.org>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Wingman Kwok <w-kwok2@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Update mdiobb_read() to read whether the PHY has a broken turn-around,
and if it does, ignore it to make the read succeeed.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
OS2BMC feature will allow the server to communicate with the on-board
BMC/idrac (Baseboard Management Controller) over the LOM via
standard Ethernet.
When OS2BMC feature is enabled, the LOM will filter traffic coming
from the host. If the destination MAC address matches the iDRAC MAC
address, it will forward the packet to the NC-SI side band interface
for iDRAC processing. Otherwise, it would send it out on the wire to
the external network. Broadcast and multicast packets are sent on the
side-band NC-SI channel and on the wire as well. Some of the packet
filters are not supported in the NIC and hence driver will identify
such packets and will hint the NIC to send those packets to the BMC.
This is done by duplicating packets on the management ring. Packets
are sent to the management ring, by setting mgmt bit in the wrb header.
The NIC will forward the packets on the management ring to the BMC
through the side-band NC-SI channel.
Please refer to this online document for more details,
http://www.dell.com/downloads/global/products/pedge/
os_to_bmc_passthrough_a_new_chapter_in_system_management.pdf
Signed-off-by: Venkat Duvvuru <VenkatKumar.Duvvuru@Emulex.com>
happens.
When an error (related to HW or FW) is detected on a function, the driver
must pro-actively report a "link down" to the stack so that a possible
failover can be initiated. This is being done currently only for some
HW errors. This patch reports a "link down" even for fatal FW errors and
EEH errors.
Ethtool statistics is not the right place to display board temperature.
This patch adds support to export die temperature of devices supported
by be2net driver via the sysfs hwmon interface.
The bitwise tests are always true here because it uses '|' where '&' is
intended.
Fixes: 98b5a0f4a228 ('net: macb: Add support for jumbo frames')
This is an initial implementation of a netdev driver for GENEVE
tunnels. This implementation uses a fixed UDP port, and only supports
point-to-point links with specific partner endpoints. Only IPv4
links are supported at this time.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
add couple of empty lines on the way.
Also, remove a needless netif_err() from efx_ptp_update_stats() - if the
MCDI fails it'll print its own error message, we don't need another that
adds no information.
Signed-off-by: Edward Cree <ecree@solarflare.com>
Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
Fix missing copy_from_user in macvtap SIOCSIFHWADDR ioctl.
Signed-off-by: Justin Cormack <justin@netbsd.org>
Older gcc versions (e.g. gcc version 4.4.6) don't like anonymous unions
which was causing build issues on the newly added switchdev attr/obj
structs. Fix this by using named union on structs.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Reported-by: Or Gerlitz <ogerlitz@mellanox.com>
And let driver convert it to host-byte order as needed.
Commit e2c6544829f moved pm_qos_req to e1000_adapter. Add the header file
that defines the struct.
Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Thomas Graf <tgraf@suug.ch>
Don't do clock-mode-select if clk == NULL,
since when building without CONFIG_HAVE_CLK,
clk_get returns NULL and clk_get_rate returns 0.
Doing clock-mode-select in this cause causes kszphy_probe to
return -EINVAL and thus prevents the device from being probed.
The original code (before regression) would return 0
when building without CONFIG_HAVE_CLK.
Cc: stable <stable@vger.kernel.org> # 3.18+
Fixes: 1fadee0c3645 ("net/phy: micrel: Add clock support for
KSZ8021/KSZ8031")
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Niklas Cassel <niklass@axis.com>
DMA allocates skb->len instead of headlen
which is used for DMA.
Cleanup few MACROS left out in t4_hw.h to be consistent with the
existing ones. Also replace few hardcoded values with MACROS. Also
update comments for some code
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
Based on the information given to this driver (via the xmit_more skb flag),
we can defer signaling the host if more packets are on the way. This will help
make the host more efficient since it can potentially process a larger batch of
packets. Implement this optimization.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Similarly to the TX path, allow the RX path to be configured with both
'rx-frames' and 'rx-usecs' coalescing parameters.
Add the ability to configure both 'tx-frames' which controls how many frames
are doing to trigger a single interrupt and 'tx-usecs' which dictates how long
to wait before an interrupt should be services.
Since our timer resolution is close to 8.192 us, we round up to the nearest
value the 'tx-usecs' timeout value.
The macvtap driver tries to emulate all the ioctls supported by a normal
tun/tap driver, however it was missing the generic SIOCGIFHWADDR and
SIOCSIFHWADDR ioctls to get and set the mac address that are supported
by tun/tap. This patch adds these.
Well almost clean: ignore the CHECKs for space after cast operator and some
longer-than-80 char cases where for readability it's better to keep as-is.
Acked-by: Jiri Pirko <jiri@resnulli.us>
Roopa said remove the feature flag for this series and she'll work on
bringing it back if needed at a later date.
The IPv4 FIB ops convert nicely to the switchdev objs and we're left with
only four switchdev ops: port get/set and port add/del. Other objs will
follow, such as FDB. So go ahead and convert IPv4 FIB over to switchdev
obj for consistency, anticipating more objs to come.
Rocker, bonding and team and switch over to the new
switchdev_port_bridge_dellink to avoid duplicating code in each driver.
Rocker, bonding, and team can now use the switchdev bridge setlink to parse
raw netlink; no need to duplicate this code in each driver.
rocker: use switchdev get/set attr for bridge port flags
STP update is just a settable port attribute, so convert
switchdev_port_stp_update to an attr set.
For DSA, the prepare phase is skipped and STP updates are only done in the
commit phase. This is because currently the DSA drivers don't need to
allocate any memory for STP updates and the STP update will not fail to HW
(unless something horrible goes wrong on the MDIO bus, in which case the
prepare phase wouldn't have been able to predict anyway).
For rocker, support prepare-commit transaction model for setting attributes
(and for adding objects). This requires rocker to preallocate memory
needed for the commit up front in the prepare phase. Since rtnl_lock is
held between prepare-commit, store the allocated memory on a queue hanging
off of the rocker_port. Also, in prepare phase, do everything right up to
calling into HW. The same code paths are tranversed in the driver for both
prepare and commit phases. In some cases, any state modified in the
prepare phase must be reverted before returning so the commit phase makes
the same decisions.
As a consequence of holding rtnl_lock in process context for all attr sets
(and obj adds), all memory is GFP_KERNEL allocated and we don't need to
busy spin waiting for the device to complete the command. So the bulk of
this patch is simplifying the memory allocations to only use GFP_KERNEL and
to remove the nowait flag and busy spin loop.
Switch ID is just a gettable port attribute. Convert switchdev op
switchdev_parent_id_get to a switchdev attr.
Note: for sysfs and netlink interfaces, SWITCHDEV_ATTR_PORT_PARENT_ID is
called with SWITCHDEV_F_NO_RECUSE to limit switch ID user-visiblity to only
port netdevs. So when a port is stacked under bond/bridge, the user can
only query switch id via the switch ports, but not via the upper devices
Turned out that "switchdev" sticks. So just unify all related terms to use
this prefix.
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com>
