commit f03dca0c9e2297c84a018e306f8a9cd534ee4287 upstream.
devm_regmap_init may return error which caused by like out of memory,
this will results in null pointer dereference later when reading
or writing register:
general protection fault in encx24j600_spi_probe
KASAN: null-ptr-deref in range [0x0000000000000090-0x0000000000000097]
CPU: 0 PID: 286 Comm: spi-encx24j600- Not tainted 5.15.0-rc2-00142-g9978db750e31-dirty #11 9c53a778c1306b1b02359f3c2bbedc0222cba652
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.13.0-1ubuntu1.1 04/01/2014
RIP: 0010:regcache_cache_bypass drivers/base/regmap/regcache.c:540
Code: 54 41 89 f4 55 53 48 89 fb 48 83 ec 08 e8 26 94 a8 fe 48 8d bb a0 00 00 00 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <80> 3c 02 00 0f 85 4a 03 00 00 4c 8d ab b0 00 00 00 48 8b ab a0 00
RSP: 0018:ffffc900010476b8 EFLAGS: 00010207
RAX: dffffc0000000000 RBX: fffffffffffffff4 RCX: 0000000000000000
RDX: 0000000000000012 RSI: ffff888002de0000 RDI: 0000000000000094
RBP: ffff888013c9a000 R08: 0000000000000000 R09: fffffbfff3f9cc6a
R10: ffffc900010476e8 R11: fffffbfff3f9cc69 R12: 0000000000000001
R13: 000000000000000a R14: ffff888013c9af54 R15: ffff888013c9ad08
FS: 00007ffa984ab580(0000) GS:ffff88801fe00000(0000) knlGS:0000000000000000
CR2: 000055a6384136c8 CR3: 000000003bbe6003 CR4: 0000000000770ef0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
PKRU: 55555554
Call Trace:
encx24j600_spi_probe drivers/net/ethernet/microchip/encx24j600.c:459
spi_probe drivers/spi/spi.c:397
really_probe drivers/base/dd.c:517
__driver_probe_device drivers/base/dd.c:751
driver_probe_device drivers/base/dd.c:782
__device_attach_driver drivers/base/dd.c:899
bus_for_each_drv drivers/base/bus.c:427
__device_attach drivers/base/dd.c:971
bus_probe_device drivers/base/bus.c:487
device_add drivers/base/core.c:3364
__spi_add_device drivers/spi/spi.c:599
spi_add_device drivers/spi/spi.c:641
spi_new_device drivers/spi/spi.c:717
new_device_store+0x18c/0x1f1 [spi_stub 4e02719357f1ff33f5a43d00630982840568e85e]
dev_attr_store drivers/base/core.c:2074
sysfs_kf_write fs/sysfs/file.c:139
kernfs_fop_write_iter fs/kernfs/file.c:300
new_sync_write fs/read_write.c:508 (discriminator 4)
vfs_write fs/read_write.c:594
ksys_write fs/read_write.c:648
do_syscall_64 arch/x86/entry/common.c:50
entry_SYSCALL_64_after_hwframe arch/x86/entry/entry_64.S:113
Add error check in devm_regmap_init_encx24j600 to avoid this situation.
Fixes: 04fbfce7a222 ("net: Microchip encx24j600 driver")
Signed-off-by: Nanyong Sun <sunnanyong@huawei.com>
Link: https://lore.kernel.org/r/20211012125901.3623144-1-sunnanyong@huawei.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
commit 427f974d9727ca681085ddcd0530c97ab5811ae0 upstream.
Fix the following build/link error by adding a dependency on the CRC32
routines:
ld: drivers/net/ethernet/korina.o: in function `korina_multicast_list':
korina.c:(.text+0x1af): undefined reference to `crc32_le'
Fixes: ef11291bcd5f9 ("Add support the Korina (IDT RC32434) Ethernet MAC")
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Florian fainelli <f.fainelli@gmail.com>
Link: https://lore.kernel.org/r/20211012152509.21771-1-vegard.nossum@oracle.com
commit e599ee234ad4fdfe241d937bbabd96e0d8f9d868 upstream.
routines:
ld: drivers/net/ethernet/arc/emac_main.o: in function `arc_emac_set_rx_mode':
emac_main.c:(.text+0xb11): undefined reference to `crc32_le'
The crc32_le() call comes through the ether_crc_le() call in
arc_emac_set_rx_mode().
[v2: moved the select to ARC_EMAC_CORE; the Makefile is a bit confusing,
but the error comes from emac_main.o, which is part of the arc_emac module,
which in turn is enabled by CONFIG_ARC_EMAC_CORE. Note that arc_emac is
different from emac_arc...]
Fixes: 775dd682e2b0ec ("arc_emac: implement promiscuous mode and multicast filtering")
Link: https://lore.kernel.org/r/20211012093446.1575-1-vegard.nossum@oracle.com
[ Upstream commit 857b6c6f665cca9828396d9743faf37fd09e9ac3 ]
The loop in i40e_get_capabilities can never end. The problem is that
although i40e_aq_discover_capabilities returns with an error if there's
a firmware problem, the returned error is not checked. There is a check for
pf->hw.aq.asq_last_status but that value is set to I40E_AQ_RC_OK on most
firmware problems.
When i40e_aq_discover_capabilities encounters a firmware problem, it will
encounter the same problem on its next invocation. As the result, the loop
becomes endless. We hit this with I40E_ERR_ADMIN_QUEUE_TIMEOUT but looking
at the code, it can happen with a range of other firmware errors.
I don't know what the correct behavior should be: whether the firmware
should be retried a few times, or whether pf->hw.aq.asq_last_status should
be always set to the encountered firmware error (but then it would be
pointless and can be just replaced by the i40e_aq_discover_capabilities
return value). However, the current behavior with an endless loop under the
rtnl mutex(!) is unacceptable and Intel has not submitted a fix, although we
explained the bug to them 7 months ago.
This may not be the best possible fix but it's better than hanging the whole
system on a firmware bug.
Fixes: 56a62fc86895 ("i40e: init code and hardware support")
Tested-by: Stefan Assmann <sassmann@redhat.com>
Signed-off-by: Jiri Benc <jbenc@redhat.com>
Reviewed-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Dave Switzer <david.switzer@intel.com>
Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com>
[ Upstream commit ca6e11c337daf7925ff8a2aac8e84490a8691905 ]
Syzbot reported memory leak in MDIO bus interface, the problem was in
wrong state logic.
MDIOBUS_ALLOCATED indicates 2 states:
1. Bus is only allocated
2. Bus allocated and __mdiobus_register() fails, but
device_register() was called
In case of device_register() has been called we should call put_device()
to correctly free the memory allocated for this device, but mdiobus_free()
calls just kfree(dev) in case of MDIOBUS_ALLOCATED state
To avoid this behaviour we need to set bus->state to MDIOBUS_UNREGISTERED
_before_ calling device_register(), because put_device() should be
called even in case of device_register() failure.
Link: https://lore.kernel.org/netdev/YVMRWNDZDUOvQjHL@shell.armlinux.org.uk/
Fixes: 46abc02175b3 ("phylib: give mdio buses a device tree presence")
Reported-and-tested-by: syzbot+398e7dc692ddbbb4cfec@syzkaller.appspotmail.com
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Pavel Skripkin <paskripkin@gmail.com>
Link: https://lore.kernel.org/r/eceae1429fbf8fa5c73dd2a0d39d525aa905074d.1633024062.git.paskripkin@gmail.com
[ Upstream commit 3ede7f84c7c21f93c5eac611d60eba3f2c765e0f ]
When re-entering the main loop of xenvif_tx_check_gop() a 2nd time, the
special considerations for the head of the SKB no longer apply. Don't
mistakenly report ERROR to the frontend for the first entry in the list,
even if - from all I can tell - this shouldn't matter much as the overall
transmit will need to be considered failed anyway.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Paul Durrant <paul@xen.org>
[ Upstream commit 51032e6f17ce990d06123ad7307f258c50d25aa7 ]
The e100_get_regs function is used to implement a simple register dump
for the e100 device. The data is broken into a couple of MAC control
registers, and then a series of PHY registers, followed by a memory dump
buffer.
The total length of the register dump is defined as (1 + E100_PHY_REGS)
* sizeof(u32) + sizeof(nic->mem->dump_buf).
The logic for filling in the PHY registers uses a convoluted inverted
count for loop which counts from E100_PHY_REGS (0x1C) down to 0, and
assigns the slots 1 + E100_PHY_REGS - i. The first loop iteration will
fill in [1] and the final loop iteration will fill in [1 + 0x1C]. This
is actually one more than the supposed number of PHY registers.
The memory dump buffer is then filled into the space at
[2 + E100_PHY_REGS] which will cause that memcpy to assign 4 bytes past
the total size.
The end result is that we overrun the total buffer size allocated by the
kernel, which could lead to a panic or other issues due to memory
corruption.
It is difficult to determine the actual total number of registers
here. The only 8255x datasheet I could find indicates there are 28 total
MDI registers. However, we're reading 29 here, and reading them in
reverse!
In addition, the ethtool e100 register dump interface appears to read
the first PHY register to determine if the device is in MDI or MDIx
mode. This doesn't appear to be documented anywhere within the 8255x
datasheet. I can only assume it must be in register 28 (the extra
register we're reading here).
Lets not change any of the intended meaning of what we copy here. Just
extend the space by 4 bytes to account for the extra register and
continue copying the data out in the same order.
Change the E100_PHY_REGS value to be the correct total (29) so that the
total register dump size is calculated properly. Fix the offset for
where we copy the dump buffer so that it doesn't overrun the total size.
Re-write the for loop to use counting up instead of the convoluted
down-counting. Correct the mdio_read offset to use the 0-based register
offsets, but maintain the bizarre reverse ordering so that we have the
ABI expected by applications like ethtool. This requires and additional
subtraction of 1. It seems a bit odd but it makes the flow of assignment
into the register buffer easier to follow.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: Felicitas Hetzelt <felicitashetzelt@gmail.com>
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Tested-by: Jacob Keller <jacob.e.keller@intel.com>
[ Upstream commit 4329c8dc110b25d5f04ed20c6821bb60deff279f ]
commit abf9b902059f ("e100: cleanup unneeded math") tried to simplify
e100_get_regs_len and remove a double 'divide and then multiply'
calculation that the e100_reg_regs_len function did.
This change broke the size calculation entirely as it failed to account
for the fact that the numbered registers are actually 4 bytes wide and
not 1 byte. This resulted in a significant under allocation of the
register buffer used by e100_get_regs.
Fix this by properly multiplying the register count by u32 first before
adding the size of the dump buffer.
Fixes: abf9b902059f ("e100: cleanup unneeded math")
[ Upstream commit 3c0d2a46c0141913dc6fd126c57d0615677d946e ]
tx timeout and slot time are currently specified in units of HZ. On
Alpha, HZ is defined as 1024. When building alpha:allmodconfig, this
results in the following error message.
drivers/net/hamradio/6pack.c: In function 'sixpack_open':
drivers/net/hamradio/6pack.c:71:41: error:
unsigned conversion from 'int' to 'unsigned char'
changes value from '256' to '0'
In the 6PACK protocol, tx timeout is specified in units of 10 ms and
transmitted over the wire:
https://www.linux-ax25.org/wiki/6PACK
Defining a value dependent on HZ doesn't really make sense, and
presumably comes from the (very historical) situation where HZ was
originally 100.
Note that the SIXP_SLOTTIME use explicitly is about 10ms granularity:
mod_timer(&sp->tx_t, jiffies + ((when + 1) * HZ) / 100);
and the SIXP_TXDELAY walue is sent as a byte over the wire.
[ Upstream commit dff2d13114f0beec448da9b3716204eb34b0cf41 ]
gcc 11.x reports the following compiler warning/error.
drivers/net/ethernet/i825xx/82596.c: In function 'i82596_probe':
arch/m68k/include/asm/string.h:72:25: error:
'__builtin_memcpy' reading 6 bytes from a region of size 0 [-Werror=stringop-overread]
Use absolute_pointer() to work around the problem.
Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org>
[ Upstream commit fdbccea419dc782079ce5881d2705cc9e3881480 ]
Driver doesn't support aRFS for encapsulated packets, return early error
in such a case.
Fixes: 1eb8c695bda9 ("net/mlx4_en: Add accelerated RFS support")
Signed-off-by: Aya Levin <ayal@nvidia.com>
Signed-off-by: Tariq Toukan <tariqt@nvidia.com>
commit e8f69b16ee776da88589b5271e3f46020efc8f6c upstream.
If resource allocation and registration fail for a muxed tty device
(e.g. if there are no more minor numbers) the driver should not try to
deregister the never-registered (or already-deregistered) tty.
Fix up the error handling to avoid dereferencing a NULL pointer when
attempting to remove the character device.
Fixes: 72dc1c096c70 ("HSO: add option hso driver")
Cc: stable@vger.kernel.org # 2.6.27
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 0341d5e3d1ee2a36dd5a49b5bef2ce4ad1cfa6b4 ]
The cur_tx counter must be incremented after TACT bit of
txdesc->status was set. However, a CPU is possible to reorder
instructions and/or memory accesses between cur_tx and
txdesc->status. And then, if TX interrupt happened at such a
timing, the sh_eth_tx_free() may free the descriptor wrongly.
So, add wmb() before cur_tx++.
Otherwise NETDEV WATCHDOG timeout is possible to happen.
Fixes: 86a74ff21a7a ("net: sh_eth: add support for Renesas SuperH Ethernet")
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit 9ddbc2a00d7f63fa9748f4278643193dac985f2d ]
Previous commit 68233c583ab4 removes the qlcnic_rom_lock()
in qlcnic_pinit_from_rom(), but remains its corresponding
unlock function, which is odd. I'm not very sure whether the
lock is missing, or the unlock is redundant. This bug is
suggested by a static analysis tool, please advise.
Fixes: 68233c583ab4 ("qlcnic: updated reset sequence")
Signed-off-by: Dinghao Liu <dinghao.liu@zju.edu.cn>
[ Upstream commit 7db8263a12155c7ae4ad97e850f1e499c73765fc ]
When adapter->registered_device_map is NULL, the value of err is
uncertain, we set err to -EINVAL to avoid ambiguity.
Clean up smatch warning:
drivers/net/ethernet/chelsio/cxgb/cxgb2.c:1114 init_one() warn: missing
error code 'err'
Reported-by: Abaci Robot <abaci@linux.alibaba.com>
Signed-off-by: Yang Li <yang.lee@linux.alibaba.com>
commit e3f0cc1a945fcefec0c7c9d9dfd028a51daa1846 upstream.
A number of users have reported that they were not able to get the PHY
to successfully link up, especially after commit c36757eb9dee ("net:
phy: consider AN_RESTART status when reading link status") where we
stopped reading just BMSR, but we also read BMCR to determine the link
status.
Andrius at NetBSD did a wonderful job at debugging the problem
and found out that the MDIO bus clock frequency would be incorrectly set
back to its default value which would prevent the MDIO bus controller
from reading PHY registers properly. Back when we only read BMSR, if we
read all 1s, we could falsely indicate a link status, though in general
there is a cable plugged in, so this went unnoticed. After a second read
of BMCR was added, a wrong read will lead to the inability to determine
a link UP condition which is when it started to be visibly broken, even
if it was long before that.
The fix consists in restoring the value of the MD_CSR register that was
set prior to the MAC reset.
Link: http://gnats.netbsd.org/cgi-bin/query-pr-single.pl?number=53494
Fixes: 90f750a81a29 ("r6040: consolidate MAC reset to its own function")
Reported-by: Andrius V <vezhlys@gmail.com>
Reported-by: Darek Strugacz <darek.strugacz@op.pl>
Tested-by: Darek Strugacz <darek.strugacz@op.pl>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 7366c23ff492ad260776a3ee1aaabba9fc773a8b upstream.
Building dp83640.c on arch/parisc/ produces a build warning for
PAGE0 being redefined. Since the macro is not used in the dp83640
driver, just make it a comment for documentation purposes.
In file included from ../drivers/net/phy/dp83640.c:23:
../drivers/net/phy/dp83640_reg.h:8: warning: "PAGE0" redefined
8 | #define PAGE0 0x0000
from ../drivers/net/phy/dp83640.c:11:
../arch/parisc/include/asm/page.h:187: note: this is the location of the previous definition
187 | #define PAGE0 ((struct zeropage *)__PAGE_OFFSET)
Fixes: cb646e2b02b2 ("ptp: Added a clock driver for the National Semiconductor PHYTER.")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Richard Cochran <richard.cochran@omicron.at>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Heiner Kallweit <hkallweit1@gmail.com>
Cc: Russell King <linux@armlinux.org.uk>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lore.kernel.org/r/20210913220605.19682-1-rdunlap@infradead.org
commit 52ce14c134a003fee03d8fc57442c05a55b53715 upstream.
This function is called to enable SR-IOV when available,
not enabling interfaces without VFs was a regression.
Fixes: 65161c35554f ("bnx2x: Fix missing error code in bnx2x_iov_init_one()")
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Reported-by: YunQiang Su <wzssyqa@gmail.com>
Tested-by: YunQiang Su <wzssyqa@gmail.com>
Acked-by: Shai Malin <smalin@marvell.com>
Link: https://lore.kernel.org/r/20210912190523.27991-1-bunk@kernel.org
[ Upstream commit 23151b9ae79e3bc4f6a0c4cd3a7f355f68dad128 ]
Bad header can have large length field which can cause OOB.
cptr is the last bytes for read, and the eeprom is parsed
from high to low address. The OOB, triggered by the condition
length > cptr could cause memory error with a read on
negative index.
There are some sanity check around length, but it is not
compared with cptr (the remaining bytes). Here, the
corrupted/bad EEPROM can cause panic.
I was able to reproduce the crash, but I cannot find the
log and the reproducer now. After I applied the patch, the
bug is no longer reproducible.
Signed-off-by: Zekun Shen <bruceshenzk@gmail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Link: https://lore.kernel.org/r/YM3xKsQJ0Hw2hjrc@Zekuns-MBP-16.fios-router.home
[ Upstream commit fd6729ec534cffbbeb3917761e6d1fe6a412d3fe ]
This error path is unlikely because of it checked for NULL and
returned -ENOMEM earlier in the function. But it should return
an error code here as well if we ever do hit it because of a
race condition or something.
Fixes: bdcd81707973 ("Add ath6kl cleaned up driver")
Link: https://lore.kernel.org/r/20210813113438.GB30697@kili
commit ce03b94ba682a67e8233c9ee3066071656ded58f upstream.
Fixes: f63963411942 ("net: ll_temac: Avoid ndo_start_xmit returning NETDEV_TX_BUSY")
Signed-off-by: Esben Haabendal <esben@geanix.com>
commit ca2848022c12789685d3fab3227df02b863f9696 upstream.
Do not delete a key cache entry that is still being referenced by
pending frames in TXQs. This avoids reuse of the key cache entry while a
frame might still be transmitted using it.
To avoid having to do any additional operations during the main TX path
operations, track pending key cache entries in a new bitmap and check
whether any pending entries can be deleted before every new key
add/remove operation. Also clear any remaining entries when stopping the
interface.
Signed-off-by: Jouni Malinen <jouni@codeaurora.org>
Link: https://lore.kernel.org/r/20201214172118.18100-6-jouni@codeaurora.org
commit 144cd24dbc36650a51f7fe3bf1424a1432f1f480 upstream.
tkip_keymap can be used internally to avoid the reference to key->cipher
and with this, only the key index value itself is needed. This allows
ath_key_delete() call to be postponed to be handled after the upper
layer STA and key entry have already been removed. This is needed to
make ath9k key cache management safer.
Link: https://lore.kernel.org/r/20201214172118.18100-5-jouni@codeaurora.org
commit d2d3e36498dd8e0c83ea99861fac5cf9e8671226 upstream.
ath9k is going to use this for safer management of key cache entries.
Link: https://lore.kernel.org/r/20201214172118.18100-4-jouni@codeaurora.org
commit 73488cb2fa3bb1ef9f6cf0d757f76958bd4deaca upstream.
Now that ath/key.c may not be explicitly clearing keys from the key
cache, clear all key cache entries when disabling hardware to make sure
no keys are left behind beyond this point.
Link: https://lore.kernel.org/r/20201214172118.18100-3-jouni@codeaurora.org
commit 56c5485c9e444c2e85e11694b6c44f1338fc20fd upstream.
It is possible for there to be pending frames in TXQs with a reference
to the key cache entry that is being deleted. If such a key cache entry
is cleared, those pending frame in TXQ might get transmitted without
proper encryption. It is safer to leave the previously used key into the
key cache in such cases. Instead, only clear the MAC address to prevent
RX processing from using this key cache entry.
This is needed in particularly in AP mode where the TXQs cannot be
flushed on station disconnection. This change alone may not be able to
address all cases where the key cache entry might get reused for other
purposes immediately (the key cache entry should be released for reuse
only once the TXQs do not have any remaining references to them), but
this makes it less likely to get unprotected frames and the more
complete changes may end up being significantly more complex.
Link: https://lore.kernel.org/r/20201214172118.18100-2-jouni@codeaurora.org
[ Upstream commit e543468869e2532f5d7926e8f417782b48eca3dc ]
Thanks to Kees Cook who detected the problem of memset that starting
from not the first member, but sized for the whole struct.
The better change will be to remove the redundant memset and to clear
only the msix_cnt member.
Signed-off-by: Prabhakar Kushwaha <pkushwaha@marvell.com>
Signed-off-by: Ariel Elior <aelior@marvell.com>
Signed-off-by: Shai Malin <smalin@marvell.com>
Reported-by: Kees Cook <keescook@chromium.org>
[ Upstream commit 359f4cdd7d78fdf8c098713b05fee950a730f131 ]
According to Armada XP datasheet bit at 0 position is corresponding for
TxInProg indication.
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit")
Signed-off-by: Maxim Kiselev <bigunclemax@gmail.com>
[ Upstream commit 44a13a5d99c71bf9e1676d9e51679daf4d7b3d73 ]
We should decode the latency and the max_latency before directly compare.
The latency should be presented as lat_enc = scale x value:
lat_enc_d = (lat_enc & 0x0x3ff) x (1U << (5*((max_ltr_enc & 0x1c00)
>> 10)))
Fixes: cf8fb73c23aa ("e1000e: add support for LTR on I217/I218")
Suggested-by: Yee Li <seven.yi.lee@gmail.com>
Signed-off-by: Sasha Neftin <sasha.neftin@intel.com>
Tested-by: Dvora Fuxbrumer <dvorax.fuxbrumer@linux.intel.com>
and TX error counters
commit 044012b52029204900af9e4230263418427f4ba4 upstream.
This patch fixes the interchanged fetch of the CAN RX and TX error
counters from the ESD_EV_CAN_ERROR_EXT message. The RX error counter
is really in struct rx_msg::data[2] and the TX error counter is in
struct rx_msg::data[3].
Fixes: 96d8e90382dc ("can: Add driver for esd CAN-USB/2 device")
Link: https://lore.kernel.org/r/20210825215227.4947-2-stefan.maetje@esd.eu
Signed-off-by: Stefan Mätje <stefan.maetje@esd.eu>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 0a298d133893c72c96e2156ed7cb0f0c4a306a3e ]
qlcnic_83xx_unlock_flash() is called on all paths after we call
qlcnic_83xx_lock_flash(), except for one error path on failure
of QLCRD32(), which may cause a deadlock. This bug is suggested
Fixes: 81d0aeb0a4fff ("qlcnic: flash template based firmware reset recovery")
Link: https://lore.kernel.org/r/20210816131405.24024-1-dinghao.liu@zju.edu.cn
[ Upstream commit 19d1532a187669ce86d5a2696eb7275310070793 ]
Syzbot reported slab-out-of bounds write in decode_data().
The problem was in missing validation checks.
Syzbot's reproducer generated malicious input, which caused
decode_data() to be called a lot in sixpack_decode(). Since
rx_count_cooked is only 400 bytes and noone reported before,
that 400 bytes is not enough, let's just check if input is malicious
and complain about buffer overrun.
Fail log:
BUG: KASAN: slab-out-of-bounds in drivers/net/hamradio/6pack.c:843
Write of size 1 at addr ffff888087c5544e by task kworker/u4:0/7
CPU: 0 PID: 7 Comm: kworker/u4:0 Not tainted 5.6.0-rc3-syzkaller #0
Workqueue: events_unbound flush_to_ldisc
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x197/0x210 lib/dump_stack.c:118
print_address_description.constprop.0.cold+0xd4/0x30b mm/kasan/report.c:374
__kasan_report.cold+0x1b/0x32 mm/kasan/report.c:506
kasan_report+0x12/0x20 mm/kasan/common.c:641
__asan_report_store1_noabort+0x17/0x20 mm/kasan/generic_report.c:137
decode_data.part.0+0x23b/0x270 drivers/net/hamradio/6pack.c:843
decode_data drivers/net/hamradio/6pack.c:965 [inline]
sixpack_decode drivers/net/hamradio/6pack.c:968 [inline]
Reported-and-tested-by: syzbot+fc8cd9a673d4577fb2e4@syzkaller.appspotmail.com
commit d0d62baa7f505bd4c59cd169692ff07ec49dde37 upstream.
Printing kernel pointers is discouraged because they might leak kernel
memory layout. This fixes smatch warning:
drivers/net/ethernet/xilinx/xilinx_emaclite.c:1191 xemaclite_of_probe() warn:
argument 4 to %08lX specifier is cast from pointer
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Signed-off-by: Pavel Machek (CIP) <pavel@denx.de>
ql_adapter_reset
[ Upstream commit 92766c4628ea349c8ddab0cd7bd0488f36e5c4ce ]
When calling the 'ql_wait_for_drvr_lock' and 'ql_adapter_reset', the driver
has already acquired the spin lock, so the driver should not call 'ssleep'
in atomic context.
This bug can be fixed by using 'mdelay' instead of 'ssleep'.
Reported-by: Letu Ren <fantasquex@gmail.com>
Signed-off-by: Letu Ren <fantasquex@gmail.com>
[ Upstream commit 942e560a3d3862dd5dee1411dbdd7097d29b8416 ]
Smatch says:
drivers/net/ethernet/neterion/vxge/vxge-main.c:3518 vxge_device_unregister() error: Using vdev after free_{netdev,candev}(dev);
drivers/net/ethernet/neterion/vxge/vxge-main.c:3520 vxge_device_unregister() error: Using vdev after free_{netdev,candev}(dev);
Since vdev pointer is netdev private data accessing it after free_netdev()
call can cause use-after-free bug. Fix it by moving free_netdev() call at
the end of the function
Fixes: 6cca200362b4 ("vxge: cleanup probe error paths")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit af35fc37354cda3c9c8cc4961b1d24bdc9d27903 ]
Syzbot reported uninit value pegasus_probe(). The problem was in missing
error handling.
get_interrupt_interval() internally calls read_eprom_word() which can
fail in some cases. For example: failed to receive usb control message.
These cases should be handled to prevent uninit value bug, since
read_eprom_word() will not initialize passed stack variable in case of
internal failure.
Fail log:
BUG: KMSAN: uninit-value in get_interrupt_interval drivers/net/usb/pegasus.c:746 [inline]
BUG: KMSAN: uninit-value in pegasus_probe+0x10e7/0x4080 drivers/net/usb/pegasus.c:1152
CPU: 1 PID: 825 Comm: kworker/1:1 Not tainted 5.12.0-rc6-syzkaller #0
Workqueue: usb_hub_wq hub_event
Call Trace:
__dump_stack lib/dump_stack.c:79 [inline]
dump_stack+0x24c/0x2e0 lib/dump_stack.c:120
kmsan_report+0xfb/0x1e0 mm/kmsan/kmsan_report.c:118
__msan_warning+0x5c/0xa0 mm/kmsan/kmsan_instr.c:197
Local variable ----data.i@pegasus_probe created at:
get_interrupt_interval drivers/net/usb/pegasus.c:1151 [inline]
pegasus_probe+0xe57/0x4080 drivers/net/usb/pegasus.c:1152
Reported-and-tested-by: syzbot+02c9f70f3afae308464a@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20210804143005.439-1-paskripkin@gmail.com
[ Upstream commit fb653827c758725b149b5c924a5eb50ab4812750 ]
Set the error code if bnx2x_alloc_fw_stats_mem() fails. The current
code returns success.
Fixes: ad5afc89365e ("bnx2x: Separate VF and PF logic")
[ Upstream commit 7fe74dfd41c428afb24e2e615470832fa997ff14 ]
Replace pci_enable_device() with pcim_enable_device(),
pci_disable_device() and pci_release_regions() will be
called in release automatically.
Signed-off-by: Wang Hai <wanghai38@huawei.com>
[ Upstream commit 9c23aa51477a37f8b56c3c40192248db0663c196 ]
rtl8152_close() takes the refcount via usb_autopm_get_interface() but
it doesn't release when RTL8152_UNPLUG test hits. This may lead to
the imbalance of PM refcount. This patch addresses it.
Link: https://bugzilla.suse.com/show_bug.cgi?id=1186194
[ Upstream commit 89fb62fde3b226f99b7015280cf132e2a7438edf ]
[ Upstream commit 76a16be07b209a3f507c72abe823bd3af1c8661a ]
[ Upstream commit 7e4960b3d66d7248b23de3251118147812b42da2 ]
The error code is missing in this code scenario, add the error code
'-EINVAL' to the return value 'err'.
Eliminate the follow smatch warning:
drivers/net/ethernet/mellanox/mlx4/main.c:3538 mlx4_load_one() warn:
missing error code 'err'.
Fixes: 7ae0e400cd93 ("net/mlx4_core: Flexible (asymmetric) allocation of EQs and MSI-X vectors for PF/VFs")
Signed-off-by: Jiapeng Chong <jiapeng.chong@linux.alibaba.com>
Reviewed-by: Tariq Toukan <tariqt@nvidia.com>
commit 15bbf8bb4d4ab87108ecf5f4155ec8ffa3c141d6 upstream.
Commit 7930742d6, reverting 26fd962, missed out on reverting an incorrect
change to a return value. The niu_pci_vpd_scan_props(..) == 1 case appears
to be a normal path - treating it as an error and return -EINVAL was
breaking VPD_SCAN and causing the driver to fail to load.
Fix, so my Neptune card works again.
Cc: Kangjie Lu <kjlu@umn.edu>
Cc: Shannon Nelson <shannon.lee.nelson@gmail.com>
Cc: stable <stable@vger.kernel.org>
Fixes: 7930742d ('Revert "niu: fix missing checks of niu_pci_eeprom_read"')
Signed-off-by: Paul Jakma <paul@jakma.org>
commit 928150fad41ba16df7fcc9f7f945747d0f56cbb6 upstream.
In esd_usb2_setup_rx_urbs() MAX_RX_URBS coherent buffers are allocated
and there is nothing, that frees them:
1) In callback function the urb is resubmitted and that's all
2) In disconnect function urbs are simply killed, but URB_FREE_BUFFER
is not set (see esd_usb2_setup_rx_urbs) and this flag cannot be used
with coherent buffers.
So, all allocated buffers should be freed with usb_free_coherent()
explicitly.
Side note: This code looks like a copy-paste of other can drivers. The
same patch was applied to mcba_usb driver and it works nice with real
hardware. There is no change in functionality, only clean-up code for
coherent buffers.
Link: https://lore.kernel.org/r/b31b096926dcb35998ad0271aac4b51770ca7cc8.1627404470.git.paskripkin@gmail.com
Cc: linux-stable <stable@vger.kernel.org>
commit 9969e3c5f40c166e3396acc36c34f9de502929f6 upstream.
In ems_usb_start() MAX_RX_URBS coherent buffers are allocated and
is not set (see ems_usb_start) and this flag cannot be used with
coherent buffers.
explicitly.
coherent buffers.
Fixes: 702171adeed3 ("ems_usb: Added support for EMS CPC-USB/ARM7 CAN/USB interface")
Link: https://lore.kernel.org/r/59aa9fbc9a8cbf9af2bbd2f61a659c480b415800.1627404470.git.paskripkin@gmail.com
commit 0e865f0c31928d6a313269ef624907eec55287c4 upstream.
In usb_8dev_start() MAX_RX_URBS coherent buffers are allocated and
is not set (see usb_8dev_start) and this flag cannot be used with
coherent buffers.
explicitly.
coherent buffers.
Fixes: 0024d8ad1639 ("can: usb_8dev: Add support for USB2CAN interface from 8 devices")
Link: https://lore.kernel.org/r/d39b458cd425a1cf7f512f340224e6e9563b07bd.1627404470.git.paskripkin@gmail.com
commit 5a3c680aa2c12c90c44af383fe6882a39875ab81 upstream.
Setting the EXT_ENERGY_DET_MASK bit allows the port energy detection
logic of the internal PHY to prevent the system from sleeping. Some
internal PHYs will report that energy is detected when the network
interface is closed which can prevent the system from going to sleep
if WoL is enabled when the interface is brought down.
Since the driver does not support waking the system on this logic,
this commit clears the bit whenever the internal PHY is powered up
and the other logic for manipulating the bit is removed since it
serves no useful function.
Fixes: 1c1008c793fa ("net: bcmgenet: add main driver file")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 6c19d772618fea40d9681f259368f284a330fd90 ]
Ensure that the adapter->q_vector[MAX_Q_VECTORS] array isn't accessed
beyond its size. It was fixed by using a local variable num_q_vectors
as a limit for loop index, and ensure that num_q_vectors is not bigger
than MAX_Q_VECTORS.
Fixes: 047e0030f1e6 ("igb: add new data structure for handling interrupts and NAPI")
Signed-off-by: Aleksandr Loktionov <aleksandr.loktionov@intel.com>
Reviewed-by: Grzegorz Siwik <grzegorz.siwik@intel.com>
Reviewed-by: Arkadiusz Kubalewski <arkadiusz.kubalewski@intel.com>
Reviewed-by: Slawomir Laba <slawomirx.laba@intel.com>
Reviewed-by: Sylwester Dziedziuch <sylwesterx.dziedziuch@intel.com>
Reviewed-by: Mateusz Palczewski <mateusz.placzewski@intel.com>
Tested-by: Tony Brelinski <tonyx.brelinski@intel.com>
[ Upstream commit af30cbd2f4d6d66a9b6094e0aa32420bc8b20e08 ]
If an error occurs after a 'pci_enable_pcie_error_reporting()' call, it
must be undone by a corresponding 'pci_disable_pcie_error_reporting()'
call, as already done in the remove function.
Fixes: 5eae00c57f5e ("i40evf: main driver core")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
commit 0336f8ffece62f882ab3012820965a786a983f70 upstream.
priv is netdev private data and it cannot be
used after free_netdev() call. Using priv after free_netdev()
can cause UAF bug. Fix it by moving free_netdev() at the end of the
function.
Fixes: 1e0a8b13d355 ("tlan: cancel work at remove path")
