pn544 seems to be slow in handling I2C read/write requests.
Even though pn544 acks the read/write but next operation fails.
Bug: 915848
Bug: 914700
Bug: 914691
Bug: 915598
Change-Id: I7851d0d4b7c24810ad27f3e0fbd4542b52dc8a5e
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/72867
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
control firmware download and VEN using gpio
Bug 846684
Bug 873017
Change-Id: I58391ac60e1b9cf440a186c155f993c9293f8223
Reviewed-on: http://git-master/r/62702
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R74ce3100c395b696c347fce4b4c9f5913aae3717
1. Code cleaning so it can compile
2. changes in pn544 driver to condition use of
firmware download gpio
bug 846684
bug 873017
Reviewed-on: http://git-master/r/57329
(cherry picked from commit ddde05ce297da3038a770d575bc27bdfe7444c35)
Change-Id: I1381fca040bd4bcc51a6a6a43cd33297a697c27e
Reviewed-on: http://git-master/r/62699
Rebase-Id: R2b25ef5ee689076ebca99d13e5a23b1f0cc4da98
Bug 846684
Bug 873017
Reviewed-on: http://git-master/r/55880
(cherry picked from commit 9ed3de486a47dfc8598e73157bccd76ff518048b)
Change-Id: If85503592945bd5967e03ab429f5973dac0c65f7
Reviewed-on: http://git-master/r/62696
Rebase-Id: R75e0a2682ffd4d007722eaabe19c9cb20d27a9b7
We freed "dev" on the line before.
Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
The NFC subsystem core is responsible for providing the device driver
interface. It is also responsible for providing an interface to the control
operations and data exchange.
The regulator framework is used for power management. The regulators are
only named in the driver code, the actual control stuff is in the board
file for each architecture or use case.
The PN544 chip has three regulators that can be controlled or not -
depending on the architecture where the chip is being used. So some of
the regulators may not be controllable. In our current case the third
regulator, which was missing from the code, went unnoticed because we
didn't need to control it. To be as general as possible - in this respect
- the driver needs to list all regulators. Then the board file can be
used to actually set the usage.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
Spell out the NFC acronym when it's shown for the first time.
Fix these:
drivers/nfc/pn544.c: In function 'pn544_read':
drivers/nfc/pn544.c:356: warning: comparison of distinct pointer types lacks a cast
drivers/nfc/pn544.c:377: warning: comparison of distinct pointer types lacks a cast
drivers/nfc/pn544.c: In function 'pn544_write':
drivers/nfc/pn544.c:463: warning: comparison of distinct pointer types lacks a cast
drivers/nfc/pn544.c:485: warning: comparison of distinct pointer types lacks a cast
Cc: "Matti J. Aaltonen" <matti.j.aaltonen@nokia.com>
Creates a new "Near Field Communication" subsystem in drivers/nfc.
http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;)
This is a driver for the pn544 NFC device. The driver transfers
ETSI messages between the device and the user space.
