commit d4a41d10b2cb5890aeda6b2912973b2a754b05b1 upstream.
i2c_master_send may return many negative values different than
-EREMOTEIO.
In case an i2c transaction is NACK'ed, on raspberry pi B+
kernel 3.18, -EIO is generated instead.
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
NFCEE_DISCOVER_CMD is a specified NCI command used to discover
NFCEE IDs.
Move nci_nfcee_discover() call to nci_discover_se() in order to
guarantee:
- NFCEE_DISCOVER_CMD run when the NCI state machine is initialized
- NFCEE_DISCOVER_CMD is not run in case there is not discover_se
hook defined by a NFC device driver.
conn_info is currently allocated only after nfcee_discovery_ntf
which is not generic enough for logical connection other than
NFCEE. The corresponding conn_info is now created in
nci_core_conn_create_rsp().
The current implementation limits nci_core_conn_create_req()
to only manage NCI_DESTINATION_NFCEE.
Add new parameters to nci_core_conn_create() to support all
destination types described in the NCI specification.
Because there are some parameters with variable size dynamic
buffer allocation is needed.
The transaction notifies the host (DH) that an action
is required to manage a specific Secure Element application.
The st21nfcb chipset has 3 SWP (Single Wire Protocol) lines and
supports up to 3 secure elements (UICC/eSE and µSD in the future).
Some st21nfcb firmware does not support the nci command
nci_nfcee_mode_set(NCI_NFCEE_DISABLE). For this reason, we assume
2 secures elements are always present (UICC and eSE).
They will be added to the SE list once successfully activated and
they will be available only after running through enable_se
handler or when the poll in listen mode is started.
During initialization, the white_list will be always set assuming
both UICC & eSE are present.
On eSE activation, the ATR bytes are fetched to build the command
exchange timeout.
The se_io hook will allow to transfer data over SWP. 2 kind of
events may appear data is sent over:
- ST21NFCB_EVT_TRANSMIT_DATA when receiving an apdu answer
- ST21NFCB_EVT_WTX_REQUEST when the secure element needs more time
than expected to process a command. If this timeout expires, we
send a software reset, and then a hardware one if it still fails.
Currently there is no support for ACPI.
This patch uses the following configuration:
- Device id: NXP5440
- Pin mapping:
- 0 IRQ pin
- 1 enable pin
- 2 firmware pin
Signed-off-by: Robert Dolca <robert.dolca@intel.com>
gpio_set_value was replaced with gpio_set_value_cansleep in order
to allow GPIO access that may sleep. This is particularelly useful
when GPIO is accessed using busses like I2C, SPI, USB
st21nfca has 1 physical SWP line and can support up to 2 secure elements
(UICC & eSE) thanks to an external switch managed with a gpio.
The platform integrator needs to specify thanks to 2 initialization
properties, uicc-present and ese-present, if it is suppose to have uicc
and/or ese. Of course if the platform does not have an external switch,
only one kind of secure element can be supported. Those parameters are
under platform integrator responsibilities.
During initialization, the white_list will be set according to those
parameters.
The discovery_se function will assume a secure element is physically
present according to uicc-present and ese-present values and will add it
to the secure element list. On ese activation, the atr is retrieved to
calculate a command exchange timeout based on the first atr(TB) value.
The se_io will allow to transfer data over SWP. 2 kind of events may appear
after a data is sent over:
- ST21NFCA_EVT_TRANSMIT_DATA when receiving an apdu answer
- ST21NFCA_EVT_WTX_REQUEST when the secure element needs more time than
expected to compute a command. If this timeout expired, a first recovery
tentative consist to send a simple software reset proprietary command.
If this tentative still fail, a second recovery tentative consist to send
a hardware reset proprietary command.
This function is only relevant for eSE like secure element.
This patch also change the way a pipe is referenced. There can be
different pipe connected to the same gate with different host destination
(ex: CONNECTIVITY). In order to keep host information every pipe are
reference with a tuple (gate, host). In order to reduce changes, we are
keeping unchanged the way a gate is addressed on the Terminal Host.
However, this is working because we consider the apdu reader gate is only
present on the eSE slot also the connectivity gate cannot give a reliable
value; it will give the latest stored pipe value.
The below event_received hci handler has change the gate parameter to pipe.
When the platform with CONFIG_ST21NFCB_I2C=y without any st21nfcb component
physically connected a:
"Unable to handle kernel NULL pointer dereference at virtual address" may
show up at driver initialization phase.
Fix some memory leaks after some nfc_hci_get_param calls.
memory' message
Remove unnecessary memory allocation message already shown by devm_kzalloc.
This remove a warning when running scripts/checkpatch.
skb_pipe_list and skb_pipe_info are allocated in nfc_hci_send_cmd.
alloc_skb on those buffer are then useless.
Do not insert in send queue the skb that contains unknown Packet Control
Byte
Acked-by: Christophe Ricard <christophe-h.ricard@st.com>
Signed-off-by: Anda-Maria Nicolae <anda-maria.nicolae@intel.com>
kfree_skb(skb) in st21nfca_hci_event_received is never reach.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
ndlc pointer got allocated with devm_kzalloc in ndlc_probe function.
This gives this error message:
drivers/nfc/st21nfcb/ndlc.c:296:1-6: WARNING: invalid free of devm_ allocated data.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Other drivers are following the following compatible string format for dts:
s/_/-/
Because some devices may still use the previous string, the new corrected
string is added to the of_device_id table.
s/_/-/
Pull more ACPI and power management updates from Rafael Wysocki:
"These are regression fixes (leds-gpio, ACPI backlight driver,
operating performance points library, ACPI device enumeration
messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device
PM), some cleanups in the operating performance points (OPP)
framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of
minor intel_pstate driver changes, a new MAINTAINERS entry for it and
an ACPI fan driver change needed for better support of thermal
management in user space.
Specifics:
- Fix a regression in leds-gpio introduced by a recent commit that
inadvertently changed the name of one of the properties used by the
driver (Fabio Estevam).
- Fix a regression in the ACPI backlight driver introduced by a
recent fix that missed one special case that had to be taken into
account (Aaron Lu).
- Drop the level of some new kernel messages from the ACPI core
introduced by a recent commit to KERN_DEBUG which they should have
used from the start and drop some other unuseful KERN_ERR messages
printed by ACPI (Rafael J Wysocki).
- Revert an incorrect commit modifying the cpupower tool (Prarit
Bhargava).
- Fix two regressions introduced by recent commits in the OPP library
and clean up some existing minor issues in that code (Viresh
Kumar).
- Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the
tree (or drop it where that can be done) in order to make it
possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf
Hansson, Ludovic Desroches).
There will be one more "CONFIG_PM_RUNTIME removal" batch after this
one, because some new uses of it have been introduced during the
current merge window, but that should be sufficient to finally get
rid of it.
- Make the ACPI EC driver more robust against race conditions related
to GPE handler installation failures (Lv Zheng).
- Prevent the ACPI device PM core code from attempting to disable
GPEs that it has not enabled which confuses ACPICA and makes it
report errors unnecessarily (Rafael J Wysocki).
- Add a "force" command line switch to the intel_pstate driver to
make it possible to override the blacklisting of some systems in
that driver if needed (Ethan Zhao).
- Improve intel_pstate code documentation and add a MAINTAINERS entry
for it (Kristen Carlson Accardi).
- Make the ACPI fan driver create cooling device interfaces witn
names that reflect the IDs of the ACPI device objects they are
associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B").
That's necessary for user space thermal management tools to be able
to connect the fans with the parts of the system they are supposed
to be cooling properly. From Srinivas Pandruvada"
* tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
MAINTAINERS: add entry for intel_pstate
ACPI / video: update the skip case for acpi_video_device_in_dod()
power / PM: Eliminate CONFIG_PM_RUNTIME
NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / EC: Fix unexpected ec_remove_handlers() invocations
Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()"
tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c
PM: Remove the SET_PM_RUNTIME_PM_OPS() macro
mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro
PM / Kconfig: Replace PM_RUNTIME with PM in dependencies
ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM
ACPI / PM: Do not disable wakeup GPEs that have not been enabled
ACPI / utils: Drop error messages from acpi_evaluate_reference()
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM in drivers/nfc/trf7970a.c.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Report error returned by devm_gpio_request_one instead of -ENODEV.
Reported-by: Dmitry Torokhov <dtor@chromium.org>
Report error returned by devm_gpio_request_one or
st21nfca_hci_platform_init instead of -ENODEV.
- pr_info in st21nfcb_nci_i2c_disable is not necessary
In ndlc_probe function we initialize timers. They are not started.
gate.
As many event with the same id can come from several gates,
it will be easier to manage each of them by gate.
- phy->gpio_irq is never done out of the request resources.
- irq_of_parse_and_map is already done in the i2c core so client->irq is
already set when entering in st21nfcb_hci_i2c_of_request_resources
- In case of static platform configuration client->irq can be set directly.
- It simplifies the code a bit.
When CONFIG_OF is define add of_st21nfcb_i2c_match to
MODULE_DEVICE_TABLE
already set when entering in st21nfca_hci_i2c_of_request_resources
When CONFIG_OF is define add of_st21nfca_i2c_match to
MODULE_DEVICE_TABLE.
This is a specific implementation, <asm/unaligned.h> is the
multiplexer that has the arch-specific knowledge of which
of the implementations needs to be used, so include that.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
John W. Linville says:
pull request: wireless-next 2014-10-03
Please pull tihs batch of updates intended for the 3.18 stream!
For the iwlwifi bits, Emmanuel says:
"I have here a few things that depend on the latest mac80211's changes:
RRM, TPC, Quiet Period etc... Eyal keeps improving our rate control
and we have a new device ID. This last patch should probably have
gone to wireless.git, but at that stage, I preferred to send it to
-next and CC stable."
For (most of) the Atheros bits, Kalle says:
"The only new feature is testmode support from me. Ben added a new method
to crash the firmware with an assert for debug purposes. As usual, we
have lots of smaller fixes from Michal. Matteo fixed a Kconfig
dependency with debugfs. I fixed some warnings recently added to
checkpatch."
For the NFC bits, Samuel says:
"We've had major updates for TI and ST Microelectronics drivers, and a
few NCI related changes.
For TI's trf7970a driver:
- Target mode support for trf7970a
- Suspend/resume support for trf7970a
- DT properties additions to handle different quirks
- A bunch of fixes for smartphone IOP related issues
For ST Microelectronics' ST21NFCA and ST21NFCB drivers:
- ISO15693 support for st21nfcb
- checkpatch and sparse related warning fixes
- Code cleanups and a few minor fixes
Finally, Marvell added ISO15693 support to the NCI stack, together with a
couple of NCI fixes."
For the Bluetooth bits, Johan says:
"This 3.18 pull request replaces the one I did on Monday ("bluetooth-next
2014-09-22", which hasn't been pulled yet). The additions since the last
request are:
- SCO connection fix for devices not supporting eSCO
- Cleanups regarding the SCO establishment logic
- Remove unnecessary return value from logging functions
- Header compression fix for 6lowpan
- Cleanups to the ieee802154/mrf24j40 driver
Here's a copy from previous request that this one replaces:
Here are some more patches for 3.18. They include various fixes to the
btusb HCI driver, a fix for LE SMP, as well as adding Jukka to the
MAINTAINERS file for generic 6LoWPAN (as requested by Alexander Aring).
I've held on to this pull request a bit since we were waiting for a SCO
related fix to get sorted out first. However, since the merge window is
getting closer I decided not to wait for it. If we do get the fix sorted
out there'll probably be a second small pull request later this week.
And,
"Unless 3.17 gets delayed this will probably be our last -next pull request for
3.18. We've got:
- New Marvell hardware supportr
- Multicast support for 6lowpan
- Several of 6lowpan fixes & cleanups
- Fix for a (false-positive) lockdep warning in L2CAP
- Minor btusb cleanup"
On top of all that comes the usual sort of updates to ath5k, ath9k,
ath10k, brcmfmac, mwifiex, and wil6210. This time around there are
also a number of rtlwifi updates to enable some new hardware and
to reconcile the in-kernel drivers with some newer releases of the
Realtek vendor drivers. Also of note is some device tree work for
the bcma bus.
Please let me know if there are problems!
skb is already freed in st21nfca_tx_work and was freed also in
st21nfca_im_send_psl_req.
"skb" can be NULL here but it can't be an ERR_PTR:
- IS_ERR(NULL) return false and skb migth be NULL.
- skb cannot be a ERR_PTR as nfc_hci_send_cmd_async it never using such cast.
!skb is more appropriate at those places.
In case we are not able to read out the NDLC/NCI header, we do not
consider this as an issue and we will give a later chance.
The NDLC layer will handle errors thanks to its internal timers.
Add support for ISO/IEC 15693 RF technology and Type 5 tags.
In NFC Forum NCI specification, some RF Protocol values are
reserved for proprietary use (from 0x80 to 0xfe).
Some CLF vendor may need to use one value within this range
for specific technology.
Furthermore, some CLF may not becompliant with NFC Froum NCI
specification 2.0 and therefore will not support RF Protocol
value 0x06 for PROTOCOL_T5T as mention in a draft specification
and in a recent push.
Adding get_rf_protocol handle to the nci_ops structure will
help to set the correct technology to target.
T2 was never started when sending a command.
Start it when sending a command for the first attempt
and stop it once we receive the answer.
On st21nfcb the irq line might be kept to active state because of other
interfaces activity. This may generate i2c read tentative resulting in
i2c NACK.
This fix will currently let NDLC upper layer to decide when it is relevent
to signal to the physical layer when the chip as muted.
This patch fix a previous patch introduce by commit 0a91e8ac240a12ac3a03581deb8cd531788c63d4
It is actually fixing a double free mistake in all st21nfca_tm_* function.
We decide to return directly in case of successful execution because skb
got already freed. In st21nfca_tm_recv_dep_req it got freed by nfc_tm_data_received.
After a unsuccessful call to nfc_hci_send_event the skb was not
freed and might lead to memory leak.
Fix few conding style issue such as useless line return or tab.
The recently added _trf7970a_tg_listen() routine
has some return paths that don't unlock the mutex
that is locked when the routine is entered. Fix
this by always unlocking the mutex before returning.
Signed-off-by: Mark A. Greer <mgreer@animalcreek.com>
Recent changes to trf7970a_irq() added a couple return
paths that don't unlock the mutex that is locked when
the routine is entered. Fix this by ensuring the mutex
is always unlocked before returning.
There is no need to initialize the 'ret' variable
in trf7970a_resume().
The trf7970a_suspend() routine always returns
zero so don't use a local return variable to
hold the return value. This fixes up a smatch
warning.
