path: root/drivers/nfc
2018-10-23NFC: nfcmrvl_uart: fix OF child-node lookupJohan Hovold
Use the new of_get_compatible_child() helper to lookup the nfc child node instead of using of_find_compatible_node(), which searches the entire tree from a given start node and thus can return an unrelated (i.e. non-child) node. This also addresses a potential use-after-free (e.g. after probe deferral) as the tree-wide helper drops a reference to its first argument (i.e. the parent node). Fixes: e097dc624f78 ("NFC: nfcmrvl: add UART driver") Fixes: d8e018c0b321 ("NFC: nfcmrvl: update device tree bindings for Marvell NFC") Cc: stable <stable@vger.kernel.org> # 4.2 Cc: Vincent Cuissard <cuissard@marvell.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Rob Herring <robh@kernel.org>
2018-07-02Merge 4.18-rc3 into usb-nextGreg Kroah-Hartman
We want the USB and other fixes in here as well to make merges and testing easier. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-28NFC: nfcmrvl_usb: use irqsave() in USB's complete callbackSebastian Andrzej Siewior
The USB completion callback does not disable interrupts while acquiring the lock. We want to remove the local_irq_disable() invocation from __usb_hcd_giveback_urb() and therefore it is required for the callback handler to disable the interrupts while acquiring the lock. The callback may be invoked either in IRQ or BH context depending on the USB host controller. Use the _irqsave() variant of the locking primitives. Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: linux-wireless@vger.kernel.org Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-25NFC: pn533: Fix wrong GFP flag usageHans de Goede
pn533_recv_response() is an urb completion handler, so it must use GFP_ATOMIC. pn533_usb_send_frame() OTOH runs from a regular sleeping context, so the pn533_submit_urb_for_response() there (and only there) can use the regular GFP_KERNEL flags. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1514134 Fixes: 9815c7cf22da ("NFC: pn533: Separate physical layer from ...") Cc: Michael Thalmeier <michael.thalmeier@hale.at> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-12treewide: devm_kmalloc() -> devm_kmalloc_array()Kees Cook
The devm_kmalloc() function has a 2-factor argument form, devm_kmalloc_array(). This patch replaces cases of: devm_kmalloc(handle, a * b, gfp) with: devm_kmalloc_array(handle, a * b, gfp) as well as handling cases of: devm_kmalloc(handle, a * b * c, gfp) with: devm_kmalloc(handle, array3_size(a, b, c), gfp) as it's slightly less ugly than: devm_kmalloc_array(handle, array_size(a, b), c, gfp) This does, however, attempt to ignore constant size factors like: devm_kmalloc(handle, 4 * 1024, gfp) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. Some manual whitespace fixes were needed in this patch, as Coccinelle really liked to write "=devm_kmalloc..." instead of "= devm_kmalloc...". The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ expression HANDLE; type TYPE; expression THING, E; @@ ( devm_kmalloc(HANDLE, - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | devm_kmalloc(HANDLE, - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression HANDLE; expression COUNT; typedef u8; typedef __u8; @@ ( devm_kmalloc(HANDLE, - sizeof(u8) * (COUNT) + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(__u8) * (COUNT) + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(char) * (COUNT) + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(unsigned char) * (COUNT) + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(u8) * COUNT + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(__u8) * COUNT + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(char) * COUNT + COUNT , ...) | devm_kmalloc(HANDLE, - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ expression HANDLE; type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * (COUNT_ID) + COUNT_ID, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * COUNT_ID + COUNT_ID, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * (COUNT_CONST) + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * COUNT_CONST + COUNT_CONST, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * (COUNT_ID) + COUNT_ID, sizeof(THING) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * COUNT_ID + COUNT_ID, sizeof(THING) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * (COUNT_CONST) + COUNT_CONST, sizeof(THING) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * COUNT_CONST + COUNT_CONST, sizeof(THING) , ...) ) // 2-factor product, only identifiers. @@ expression HANDLE; identifier SIZE, COUNT; @@ - devm_kmalloc + devm_kmalloc_array (HANDLE, - SIZE * COUNT + COUNT, SIZE , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression HANDLE; expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( devm_kmalloc(HANDLE, - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression HANDLE; expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( devm_kmalloc(HANDLE, - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kmalloc(HANDLE, - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | devm_kmalloc(HANDLE, - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ expression HANDLE; identifier STRIDE, SIZE, COUNT; @@ ( devm_kmalloc(HANDLE, - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | devm_kmalloc(HANDLE, - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products, // when they're not all constants... @@ expression HANDLE; expression E1, E2, E3; constant C1, C2, C3; @@ ( devm_kmalloc(HANDLE, C1 * C2 * C3, ...) | devm_kmalloc(HANDLE, - (E1) * E2 * E3 + array3_size(E1, E2, E3) , ...) | devm_kmalloc(HANDLE, - (E1) * (E2) * E3 + array3_size(E1, E2, E3) , ...) | devm_kmalloc(HANDLE, - (E1) * (E2) * (E3) + array3_size(E1, E2, E3) , ...) | devm_kmalloc(HANDLE, - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants, // keeping sizeof() as the second factor argument. @@ expression HANDLE; expression THING, E1, E2; type TYPE; constant C1, C2, C3; @@ ( devm_kmalloc(HANDLE, sizeof(THING) * C2, ...) | devm_kmalloc(HANDLE, sizeof(TYPE) * C2, ...) | devm_kmalloc(HANDLE, C1 * C2 * C3, ...) | devm_kmalloc(HANDLE, C1 * C2, ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * (E2) + E2, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(TYPE) * E2 + E2, sizeof(TYPE) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * (E2) + E2, sizeof(THING) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - sizeof(THING) * E2 + E2, sizeof(THING) , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - (E1) * E2 + E1, E2 , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - (E1) * (E2) + E1, E2 , ...) | - devm_kmalloc + devm_kmalloc_array (HANDLE, - E1 * E2 + E1, E2 , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org>
2018-05-31NFC: pn533: don't send USB data off of the stackGreg Kroah-Hartman
It's amazing that this driver ever worked, but now that x86 doesn't allow USB data to be sent off of the stack, it really does not work at all. Fix this up by properly allocating the data for the small "commands" that get sent to the device off of the stack. We do this for one command by having a whole urb just for ack messages, as they can be submitted in interrupt context, so we can not use usb_bulk_msg(). But the poweron command can sleep (and does), so use usb_bulk_msg() for that transfer. Reported-by: Carlos Manuel Santos <cmmpsantos@gmail.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: stable <stable@vger.kernel.org> Reviewed-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21treewide: setup_timer() -> timer_setup() (2 field)Kees Cook
This converts all remaining setup_timer() calls that use a nested field to reach a struct timer_list. Coccinelle does not have an easy way to match multiple fields, so a new script is needed to change the matches of "&_E->_timer" into "&_E->_field1._timer" in all the rules. spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/timer_setup-2fields.cocci @fix_address_of depends@ expression e; @@ setup_timer( -&(e) +&e , ...) // Update any raw setup_timer() usages that have a NULL callback, but // would otherwise match change_timer_function_usage, since the latter // will update all function assignments done in the face of a NULL // function initialization in setup_timer(). @change_timer_function_usage_NULL@ expression _E; identifier _field1; identifier _timer; type _cast_data; @@ ( -setup_timer(&_E->_field1._timer, NULL, _E); +timer_setup(&_E->_field1._timer, NULL, 0); | -setup_timer(&_E->_field1._timer, NULL, (_cast_data)_E); +timer_setup(&_E->_field1._timer, NULL, 0); | -setup_timer(&_E._field1._timer, NULL, &_E); +timer_setup(&_E._field1._timer, NULL, 0); | -setup_timer(&_E._field1._timer, NULL, (_cast_data)&_E); +timer_setup(&_E._field1._timer, NULL, 0); ) @change_timer_function_usage@ expression _E; identifier _field1; identifier _timer; struct timer_list _stl; identifier _callback; type _cast_func, _cast_data; @@ ( -setup_timer(&_E->_field1._timer, _callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, &_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, &_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)&_callback, _E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, &_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, &_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)&_E); +timer_setup(&_E._field1._timer, _callback, 0); | _E->_field1._timer@_stl.function = _callback; | _E->_field1._timer@_stl.function = &_callback; | _E->_field1._timer@_stl.function = (_cast_func)_callback; | _E->_field1._timer@_stl.function = (_cast_func)&_callback; | _E._field1._timer@_stl.function = _callback; | _E._field1._timer@_stl.function = &_callback; | _E._field1._timer@_stl.function = (_cast_func)_callback; | _E._field1._timer@_stl.function = (_cast_func)&_callback; ) // callback(unsigned long arg) @change_callback_handle_cast depends on change_timer_function_usage@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; identifier _handle; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { ( ... when != _origarg _handletype *_handle = -(_handletype *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle = -(void *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(_handletype *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(void *)_origarg; +from_timer(_handle, t, _field1._timer); ... when != _origarg ) } // callback(unsigned long arg) without existing variable @change_callback_handle_cast_no_arg depends on change_timer_function_usage && !change_callback_handle_cast@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { + _handletype *_origarg = from_timer(_origarg, t, _field1._timer); + ... when != _origarg - (_handletype *)_origarg + _origarg ... when != _origarg } // Avoid already converted callbacks. @match_callback_converted depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier t; @@ void _callback(struct timer_list *t) { ... } // callback(struct something *handle) @change_callback_handle_arg depends on change_timer_function_usage && !match_callback_converted && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; @@ void _callback( -_handletype *_handle +struct timer_list *t ) { + _handletype *_handle = from_timer(_handle, t, _field1._timer); ... } // If change_callback_handle_arg ran on an empty function, remove // the added handler. @unchange_callback_handle_arg depends on change_timer_function_usage && change_callback_handle_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; identifier t; @@ void _callback(struct timer_list *t) { - _handletype *_handle = from_timer(_handle, t, _field1._timer); } // We only want to refactor the setup_timer() data argument if we've found // the matching callback. This undoes changes in change_timer_function_usage. @unchange_timer_function_usage depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg && !change_callback_handle_arg@ expression change_timer_function_usage._E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type change_timer_function_usage._cast_data; @@ ( -timer_setup(&_E->_field1._timer, _callback, 0); +setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E); | -timer_setup(&_E._field1._timer, _callback, 0); +setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E); ) // If we fixed a callback from a .function assignment, fix the // assignment cast now. @change_timer_function_assignment depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression change_timer_function_usage._E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_func; typedef TIMER_FUNC_TYPE; @@ ( _E->_field1._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -&_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -(_cast_func)_callback; +(TIMER_FUNC_TYPE)_callback ; | _E->_field1._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -&_callback; +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -(_cast_func)_callback +(TIMER_FUNC_TYPE)_callback ; | _E._field1._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; ) // Sometimes timer functions are called directly. Replace matched args. @change_timer_function_calls depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression _E; identifier change_timer_function_usage._field1; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_data; @@ _callback( ( -(_cast_data)_E +&_E->_field1._timer | -(_cast_data)&_E +&_E._field1._timer | -_E +&_E->_field1._timer ) ) // If a timer has been configured without a data argument, it can be // converted without regard to the callback argument, since it is unused. @match_timer_function_unused_data@ expression _E; identifier _field1; identifier _timer; identifier _callback; @@ ( -setup_timer(&_E->_field1._timer, _callback, 0); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, 0L); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E->_field1._timer, _callback, 0UL); +timer_setup(&_E->_field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0L); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_E._field1._timer, _callback, 0UL); +timer_setup(&_E._field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0L); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(&_field1._timer, _callback, 0UL); +timer_setup(&_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0); +timer_setup(_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0L); +timer_setup(_field1._timer, _callback, 0); | -setup_timer(_field1._timer, _callback, 0UL); +timer_setup(_field1._timer, _callback, 0); ) @change_callback_unused_data depends on match_timer_function_unused_data@ identifier match_timer_function_unused_data._callback; type _origtype; identifier _origarg; @@ void _callback( -_origtype _origarg +struct timer_list *unused ) { ... when != _origarg } Signed-off-by: Kees Cook <keescook@chromium.org>
2017-11-21treewide: setup_timer() -> timer_setup()Kees Cook
This converts all remaining cases of the old setup_timer() API into using timer_setup(), where the callback argument is the structure already holding the struct timer_list. These should have no behavioral changes, since they just change which pointer is passed into the callback with the same available pointers after conversion. It handles the following examples, in addition to some other variations. Casting from unsigned long: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... setup_timer(&ptr->my_timer, my_callback, ptr); and forced object casts: void my_callback(struct something *ptr) { ... } ... setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr); become: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... timer_setup(&ptr->my_timer, my_callback, 0); Direct function assignments: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... ptr->my_timer.function = my_callback; have a temporary cast added, along with converting the args: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback; And finally, callbacks without a data assignment: void my_callback(unsigned long data) { ... } ... setup_timer(&ptr->my_timer, my_callback, 0); have their argument renamed to verify they're unused during conversion: void my_callback(struct timer_list *unused) { ... } ... timer_setup(&ptr->my_timer, my_callback, 0); The conversion is done with the following Coccinelle script: spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/timer_setup.cocci @fix_address_of@ expression e; @@ setup_timer( -&(e) +&e , ...) // Update any raw setup_timer() usages that have a NULL callback, but // would otherwise match change_timer_function_usage, since the latter // will update all function assignments done in the face of a NULL // function initialization in setup_timer(). @change_timer_function_usage_NULL@ expression _E; identifier _timer; type _cast_data; @@ ( -setup_timer(&_E->_timer, NULL, _E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E->_timer, NULL, (_cast_data)_E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E._timer, NULL, &_E); +timer_setup(&_E._timer, NULL, 0); | -setup_timer(&_E._timer, NULL, (_cast_data)&_E); +timer_setup(&_E._timer, NULL, 0); ) @change_timer_function_usage@ expression _E; identifier _timer; struct timer_list _stl; identifier _callback; type _cast_func, _cast_data; @@ ( -setup_timer(&_E->_timer, _callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | _E->_timer@_stl.function = _callback; | _E->_timer@_stl.function = &_callback; | _E->_timer@_stl.function = (_cast_func)_callback; | _E->_timer@_stl.function = (_cast_func)&_callback; | _E._timer@_stl.function = _callback; | _E._timer@_stl.function = &_callback; | _E._timer@_stl.function = (_cast_func)_callback; | _E._timer@_stl.function = (_cast_func)&_callback; ) // callback(unsigned long arg) @change_callback_handle_cast depends on change_timer_function_usage@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; identifier _handle; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { ( ... when != _origarg _handletype *_handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg ) } // callback(unsigned long arg) without existing variable @change_callback_handle_cast_no_arg depends on change_timer_function_usage && !change_callback_handle_cast@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { + _handletype *_origarg = from_timer(_origarg, t, _timer); + ... when != _origarg - (_handletype *)_origarg + _origarg ... when != _origarg } // Avoid already converted callbacks. @match_callback_converted depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier t; @@ void _callback(struct timer_list *t) { ... } // callback(struct something *handle) @change_callback_handle_arg depends on change_timer_function_usage && !match_callback_converted && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; @@ void _callback( -_handletype *_handle +struct timer_list *t ) { + _handletype *_handle = from_timer(_handle, t, _timer); ... } // If change_callback_handle_arg ran on an empty function, remove // the added handler. @unchange_callback_handle_arg depends on change_timer_function_usage && change_callback_handle_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; identifier t; @@ void _callback(struct timer_list *t) { - _handletype *_handle = from_timer(_handle, t, _timer); } // We only want to refactor the setup_timer() data argument if we've found // the matching callback. This undoes changes in change_timer_function_usage. @unchange_timer_function_usage depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg && !change_callback_handle_arg@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type change_timer_function_usage._cast_data; @@ ( -timer_setup(&_E->_timer, _callback, 0); +setup_timer(&_E->_timer, _callback, (_cast_data)_E); | -timer_setup(&_E._timer, _callback, 0); +setup_timer(&_E._timer, _callback, (_cast_data)&_E); ) // If we fixed a callback from a .function assignment, fix the // assignment cast now. @change_timer_function_assignment depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_func; typedef TIMER_FUNC_TYPE; @@ ( _E->_timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -&_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)_callback; +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -&_callback; +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; ) // Sometimes timer functions are called directly. Replace matched args. @change_timer_function_calls depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression _E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_data; @@ _callback( ( -(_cast_data)_E +&_E->_timer | -(_cast_data)&_E +&_E._timer | -_E +&_E->_timer ) ) // If a timer has been configured without a data argument, it can be // converted without regard to the callback argument, since it is unused. @match_timer_function_unused_data@ expression _E; identifier _timer; identifier _callback; @@ ( -setup_timer(&_E->_timer, _callback, 0); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0L); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0UL); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0L); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0UL); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_timer, _callback, 0); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0L); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0UL); +timer_setup(&_timer, _callback, 0); | -setup_timer(_timer, _callback, 0); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0L); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0UL); +timer_setup(_timer, _callback, 0); ) @change_callback_unused_data depends on match_timer_function_unused_data@ identifier match_timer_function_unused_data._callback; type _origtype; identifier _origarg; @@ void _callback( -_origtype _origarg +struct timer_list *unused ) { ... when != _origarg } Signed-off-by: Kees Cook <keescook@chromium.org>
2017-11-21treewide: init_timer() -> setup_timer()Kees Cook
This mechanically converts all remaining cases of ancient open-coded timer setup with the old setup_timer() API, which is the first step in timer conversions. This has no behavioral changes, since it ultimately just changes the order of assignment to fields of struct timer_list when finding variations of: init_timer(&t); f.function = timer_callback; t.data = timer_callback_arg; to be converted into: setup_timer(&t, timer_callback, timer_callback_arg); The conversion is done with the following Coccinelle script, which is an improved version of scripts/cocci/api/setup_timer.cocci, in the following ways: - assignments-before-init_timer() cases - limit the .data case removal to the specific struct timer_list instance - handling calls by dereference (timer->field vs timer.field) spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/setup_timer.cocci @fix_address_of@ expression e; @@ init_timer( -&(e) +&e , ...) // Match the common cases first to avoid Coccinelle parsing loops with // "... when" clauses. @match_immediate_function_data_after_init_timer@ expression e, func, da; @@ -init_timer +setup_timer ( \(&e\|e\) +, func, da ); ( -\(e.function\|e->function\) = func; -\(e.data\|e->data\) = da; | -\(e.data\|e->data\) = da; -\(e.function\|e->function\) = func; ) @match_immediate_function_data_before_init_timer@ expression e, func, da; @@ ( -\(e.function\|e->function\) = func; -\(e.data\|e->data\) = da; | -\(e.data\|e->data\) = da; -\(e.function\|e->function\) = func; ) -init_timer +setup_timer ( \(&e\|e\) +, func, da ); @match_function_and_data_after_init_timer@ expression e, e2, e3, e4, e5, func, da; @@ -init_timer +setup_timer ( \(&e\|e\) +, func, da ); ... when != func = e2 when != da = e3 ( -e.function = func; ... when != da = e4 -e.data = da; | -e->function = func; ... when != da = e4 -e->data = da; | -e.data = da; ... when != func = e5 -e.function = func; | -e->data = da; ... when != func = e5 -e->function = func; ) @match_function_and_data_before_init_timer@ expression e, e2, e3, e4, e5, func, da; @@ ( -e.function = func; ... when != da = e4 -e.data = da; | -e->function = func; ... when != da = e4 -e->data = da; | -e.data = da; ... when != func = e5 -e.function = func; | -e->data = da; ... when != func = e5 -e->function = func; ) ... when != func = e2 when != da = e3 -init_timer +setup_timer ( \(&e\|e\) +, func, da ); @r1 exists@ expression t; identifier f; position p; @@ f(...) { ... when any init_timer@p(\(&t\|t\)) ... when any } @r2 exists@ expression r1.t; identifier g != r1.f; expression e8; @@ g(...) { ... when any \(t.data\|t->data\) = e8 ... when any } // It is dangerous to use setup_timer if data field is initialized // in another function. @script:python depends on r2@ p << r1.p; @@ cocci.include_match(False) @r3@ expression r1.t, func, e7; position r1.p; @@ ( -init_timer@p(&t); +setup_timer(&t, func, 0UL); ... when != func = e7 -t.function = func; | -t.function = func; ... when != func = e7 -init_timer@p(&t); +setup_timer(&t, func, 0UL); | -init_timer@p(t); +setup_timer(t, func, 0UL); ... when != func = e7 -t->function = func; | -t->function = func; ... when != func = e7 -init_timer@p(t); +setup_timer(t, func, 0UL); ) Signed-off-by: Kees Cook <keescook@chromium.org>
2017-11-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Maintain the TCP retransmit queue using an rbtree, with 1GB windows at 100Gb this really has become necessary. From Eric Dumazet. 2) Multi-program support for cgroup+bpf, from Alexei Starovoitov. 3) Perform broadcast flooding in hardware in mv88e6xxx, from Andrew Lunn. 4) Add meter action support to openvswitch, from Andy Zhou. 5) Add a data meta pointer for BPF accessible packets, from Daniel Borkmann. 6) Namespace-ify almost all TCP sysctl knobs, from Eric Dumazet. 7) Turn on Broadcom Tags in b53 driver, from Florian Fainelli. 8) More work to move the RTNL mutex down, from Florian Westphal. 9) Add 'bpftool' utility, to help with bpf program introspection. From Jakub Kicinski. 10) Add new 'cpumap' type for XDP_REDIRECT action, from Jesper Dangaard Brouer. 11) Support 'blocks' of transformations in the packet scheduler which can span multiple network devices, from Jiri Pirko. 12) TC flower offload support in cxgb4, from Kumar Sanghvi. 13) Priority based stream scheduler for SCTP, from Marcelo Ricardo Leitner. 14) Thunderbolt networking driver, from Amir Levy and Mika Westerberg. 15) Add RED qdisc offloadability, and use it in mlxsw driver. From Nogah Frankel. 16) eBPF based device controller for cgroup v2, from Roman Gushchin. 17) Add some fundamental tracepoints for TCP, from Song Liu. 18) Remove garbage collection from ipv6 route layer, this is a significant accomplishment. From Wei Wang. 19) Add multicast route offload support to mlxsw, from Yotam Gigi" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2177 commits) tcp: highest_sack fix geneve: fix fill_info when link down bpf: fix lockdep splat net: cdc_ncm: GetNtbFormat endian fix openvswitch: meter: fix NULL pointer dereference in ovs_meter_cmd_reply_start netem: remove unnecessary 64 bit modulus netem: use 64 bit divide by rate tcp: Namespace-ify sysctl_tcp_default_congestion_control net: Protect iterations over net::fib_notifier_ops in fib_seq_sum() ipv6: set all.accept_dad to 0 by default uapi: fix linux/tls.h userspace compilation error usbnet: ipheth: prevent TX queue timeouts when device not ready vhost_net: conditionally enable tx polling uapi: fix linux/rxrpc.h userspace compilation errors net: stmmac: fix LPI transitioning for dwmac4 atm: horizon: Fix irq release error net-sysfs: trigger netlink notification on ifalias change via sysfs openvswitch: Using kfree_rcu() to simplify the code openvswitch: Make local function ovs_nsh_key_attr_size() static openvswitch: Fix return value check in ovs_meter_cmd_features() ...
2017-11-15Merge branch 'for-linus' of ↵Linus Torvalds
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual rocket-science from trivial tree for 4.15" * 'for-linus' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: MAINTAINERS: relinquish kconfig MAINTAINERS: Update my email address treewide: Fix typos in Kconfig kfifo: Fix comments init/Kconfig: Fix module signing document location misc: ibmasm: Return error on error path HID: logitech-hidpp: fix mistake in printk, "feeback" -> "feedback" MAINTAINERS: Correct path to uDraw PS3 driver tracing: Fix doc mistakes in trace sample tracing: Kconfig text fixes for CONFIG_HWLAT_TRACER MIPS: Alchemy: Remove reverted CONFIG_NETLINK_MMAP from db1xxx_defconfig mm/huge_memory.c: fixup grammar in comment lib/xz: Add fall-through comments to a switch statement
2017-11-06NFC: fdp: make struct nci_ops staticColin Ian King
The structure nci_ops is local to the source and does not need to be in global scope, so make it static. Cleans up sparse warning: symbol 'nci_ops' was not declared. Should it be static? Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-11-06nfc: s3fwrn5: make array match static constColin Ian King
Don't populate the read-only array match on the stack, instead make it static const. Makes the object code smaller by over 310 bytes: Before: text data bss dec hex filename 8304 1084 128 9516 252c drivers/nfc/s3fwrn5/firmware.o After: text data bss dec hex filename 7894 1180 128 9202 23f2 drivers/nfc/s3fwrn5/firmware.o Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-11-06nfc: st21nfca: constify i2c_device_idArvind Yadav
i2c_device_id are not supposed to change at runtime. All functions working with i2c_device_id provided by <linux/i2c.h> work with const i2c_device_id. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-11-06nfc: st-nci: constify i2c_device_idArvind Yadav
2017-11-06nfc: s3fwrn5: constify i2c_device_idArvind Yadav
2017-11-06nfc: pn544: constify i2c_device_idArvind Yadav
2017-11-06nfc: pn533: constify i2c_device_idArvind Yadav
2017-11-06nfc: nxp-nci: constify i2c_device_idArvind Yadav
2017-11-06nfc: nfcmrvl: constify i2c_device_idArvind Yadav
2017-11-06nfc: microread: constify i2c_device_idArvind Yadav
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12treewide: Fix typos in KconfigMasanari Iida
This patch fixes some spelling typos found in Kconfig files. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2017-07-01Merge tag 'nfc-next-4.13-1' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/nfc-next Samuel Ortiz says: ==================== NFC 4.13 pull request This is the NFC pull requesy for 4.13. We have: - A conversion to unified device and GPIO APIs for the fdp, pn544, and st{21,-nci} drivers. - A fix for NFC device IDs allocation. - A fix for the nfcmrvl driver firmware download mechanism. - A trf7970a DT and GPIO cleanup and clock setting fix. - A few fixes for potential overflows in the digital and LLCP code. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-28NFC: trf7970a: Correct register settings for 27MHz clockGeoff Lansberry
In prior commits the selected clock frequency does not propagate correctly to what is written to the TRF7970A_MODULATOR_SYS_CLK_CTRL register. Signed-off-by: Geoff Lansberry <geoff@kuvee.com> Acked-by: Mark Greer <mgreer@animalcreek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-23NFC: add NULL checks to avoid potential NULL pointer dereferenceGustavo A. R. Silva
NULL checks at line 457: if (!link0 || !link1) {, implies that both pointers link0 and link1 might be NULL. Function nfcsim_link_free() dereference pointers link0 and link1. Add NULL checks before calling nfcsim_link_free() to avoid a potential NULL pointer dereference. Addresses-Coverity-ID: 1364857 Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-23Revert "NFC: trf7970a: Handle extra byte in response to Type 5 RMB commands"Mark Greer
This reverts commit ab714817d7e891608d31f6996b1e4c43cf2bf342. The original commit was designed to handle a bug in the trf7970a NFC controller where an extra byte was returned in Read Multiple Blocks (RMB) command responses. However, it has become less clear whether it is a bug in the trf7970a or in the tag. In addition, it was assumed that the extra byte was always returned but it turns out that is not always the case. The result is that a byte of good data is trimmed off when the extra byte is not present ultimately causing the neard deamon to fail the read. Since the trf7970a driver does not have the context to know when to trim the byte or not, remove the code from the trf7970a driver all together (and move it up to the neard daemon). This has the added benefit of simplifying the kernel driver and putting the extra complexity into userspace. CC: Rob Herring <robh@kernel.org> CC: devicetree@vger.kernel.org Signed-off-by: Mark Greer <mgreer@animalcreek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: trf7970a: fix check of clock frequencies, use && instead of ||Colin Ian King
The "or" condition (clk_freq != TRF7970A_27MHZ_CLOCK_FREQUENCY) || (clk_freq != TRF7970A_13MHZ_CLOCK_FREQUE) will always be true because clk_freq cannot be equal to two different values at the same time. Use the && operator instead of || to fix this. Detected by CoverityScan, CID#1430468 ("Constant expression result") Fixes: 837eb4d21ecde7 ("NFC: trf7970a: add device tree option for 27MHz clock") Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Geoff Lansberry <geoff@kuvee.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Get rid of code duplication in ->probe()Andy Shevchenko
Since OF and ACPI case almost the same get rid of code duplication by moving gpiod_get() calls directly to ->probe(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Add GPIO ACPI mapping tableAndy Shevchenko
In order to make GPIO ACPI library stricter prepare users of gpiod_get_index() to correctly behave when there no mapping is provided by firmware. Here we add explicit mapping between _CRS GpioIo() resources and their names used in the driver. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Use unified device properties API meaningfullyAndy Shevchenko
Use unified device properties API in meaningful way. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Covert to use GPIO descriptorAndy Shevchenko
Since we got rid of platform data, the driver may use GPIO descriptor directly. Looking deeply to the use of the GPIO pin it looks like it should be a GPIO based reset control rather than custom GPIO handling. But this is out of scope of the change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Get rid of "interesting" use of interrupt polarityAndy Shevchenko
I2C and SPI frameworks followed by IRQ framework do set interrupt polarity correctly if it's properly specified in firmware (ACPI or DT). Get rid of the redundant trick when requesting interrupt. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st-nci: Get rid of platform dataAndy Shevchenko
Legacy platform data must go away. We are on the safe side here since there are no users of it in the kernel. If anyone by any odd reason needs it the GPIO lookup tables and built-in device properties at your service. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: fdp: Add GPIO ACPI mapping tableAndy Shevchenko
2017-06-22NFC: fdp: Convert to use devres APIAndy Shevchenko
It looks like there are two leftovers, at least one of which can leak the resource (IRQ). Convert both places to use managed variants of the functions. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: fdp: Convert I2C driver to ->probe_new()Andy Shevchenko
There is no platform code that uses i2c module table. Remove it altogether and adjust ->probe() to be ->probe_new(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-22NFC: st21nfca: Get rid of code duplication in ->probe()Andy Shevchenko
2017-06-22NFC: st21nfca: Add GPIO ACPI mapping tableAndy Shevchenko
2017-06-22NFC: pn544: Switch to devm_acpi_dev_add_driver_gpios()Andy Shevchenko
Switch to use managed variant of acpi_dev_add_driver_gpios() to simplify error path and fix potentially wrong assignment if ->probe() fails. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-20net: manual clean code which call skb_put_[data:zero]yuan linyu
Signed-off-by: yuan linyu <Linyu.Yuan@alcatel-sbell.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-18NFC: nfcmrvl: allow gpio 0 for reset signallingJohan Hovold
Allow gpio 0 to be used for reset signalling, and instead use negative errnos to disable the reset functionality. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl_usb: use interface as phy deviceJohan Hovold
Use the USB-interface rather than parent USB-device device, which is what this driver binds to, when registering the nci device. Note that using the right device is important when dealing with device- managed resources as the interface can be unbound independently of the parent device. Also note that private device pointer had already been set by nfcmrvl_nci_register_dev() so the redundant assignment can therefore be removed. Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl_uart: fix device-node leak during probeJohan Hovold
Make sure to release the device-node reference when done parsing the node. Fixes: e097dc624f78 ("NFC: nfcmrvl: add UART driver") Cc: Vincent Cuissard <cuissard@marvell.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl: fix firmware-management initialisationJohan Hovold
The nci-device was never deregistered in the event that fw-initialisation failed. Fix this by moving the firmware initialisation before device registration since the firmware work queue should be available before registering. Note that this depends on a recent fix that moved device-name initialisation back to to nci_allocate_device() as the firmware-workqueue name is now derived from the nfc-device name. Fixes: 3194c6870158 ("NFC: nfcmrvl: add firmware download support") Cc: stable <stable@vger.kernel.org> # 4.4 Cc: Vincent Cuissard <cuissard@marvell.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl: use nfc-device for firmware downloadJohan Hovold
Use the nfc- rather than phy-device in firmware-management code that needs a valid struct device. This specifically fixes a NULL-pointer dereference in nfcmrvl_fw_dnld_init() during registration when the underlying tty is one end of a Unix98 pty. Note that the driver still uses the phy device for any debugging, which is fine for now. Fixes: 3194c6870158 ("NFC: nfcmrvl: add firmware download support") Cc: stable <stable@vger.kernel.org> # 4.4 Cc: Vincent Cuissard <cuissard@marvell.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl: do not use device-managed resourcesJohan Hovold
This specifically fixes resource leaks in the registration error paths. Device-managed resources is a bad fit for this driver as devices can be registered from the n_nci line discipline. Firstly, a tty may not even have a corresponding device (should it be part of a Unix98 pty) something which would lead to a NULL-pointer dereference when registering resources. Secondly, if the tty has a class device, its lifetime exceeds that of the line discipline, which means that resources would leak every time the line discipline is closed (or if registration fails). Currently, the devres interface was only being used to request a reset gpio despite the fact that it was already explicitly freed in nfcmrvl_nci_unregister_dev() (along with the private data), something which also prevented the resource leak at close. Note that the driver treats gpio number 0 as invalid despite it being perfectly valid. This will be addressed in a follow-up patch. Fixes: b2fe288eac72 ("NFC: nfcmrvl: free reset gpio") Fixes: 4a2b947f56b3 ("NFC: nfcmrvl: add chip reset management") Cc: stable <stable@vger.kernel.org> # 4.2: b2fe288eac72 Cc: Vincent Cuissard <cuissard@marvell.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: nfcmrvl_uart: add missing tty-device sanity checkJohan Hovold
Make sure to check the tty-device pointer before trying to access the parent device to avoid dereferencing a NULL-pointer when the tty is one end of a Unix98 pty. Fixes: e097dc624f78 ("NFC: nfcmrvl: add UART driver") Cc: stable <stable@vger.kernel.org> # 4.2 Cc: Vincent Cuissard <cuissard@marvell.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: trf7970a: Clean up coding style issuesMark Greer
Clean up coding style issues according to scripts/Lindent. Some scripts/Lindent changes were reverted when it appeared to make the code less readable or when it made the line run over 80 characters. Signed-off-by: Mark Greer <mgreer@animalcreek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2017-06-18NFC: trf7970a: Convert to descriptor based GPIO interfaceMark Greer
The trf7970a driver uses the deprecated integer-based GPIO consumer interface so convert it to use the new descriptor-based GPIO consumer interface. Signed-off-by: Mark Greer <mgreer@animalcreek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
