commit fe514739d8538783749d3ce72f78e5a999ea5668 upstream.
Commit a1f3e4d6a0c3 "libnvdimm, region: update nd_region_available_dpa()
for multi-pmem support" reworked blk dpa (DIMM Physical Address)
accounting to comprehend multiple pmem namespace allocations aliasing
with a given blk-dpa range.
The following call trace is a result of failing to account for allocated
blk capacity.
WARNING: CPU: 1 PID: 2433 at tools/testing/nvdimm/../../../drivers/nvdimm/names
4 size_store+0x6f3/0x930 [libnvdimm]
nd_region region5: allocation underrun: 0x0 of 0x1000000 bytes
Call Trace:
dump_stack+0x86/0xc3
__warn+0xcb/0xf0
warn_slowpath_fmt+0x5f/0x80
dev_attr_store+0x18/0x30
If a given blk-dpa allocation does not alias with any pmem ranges then
the full allocation should be accounted as busy space, not the size of
the current pmem contribution to the region.
The thinkos that led to this confusion was not realizing that the struct
resource management is already guaranteeing no collisions between pmem
allocations and blk allocations on the same dimm. Also, we do not try to
support blk allocations in aliased pmem holes.
This patch also fixes a case where the available blk goes negative.
Fixes: a1f3e4d6a0c3 ("libnvdimm, region: update nd_region_available_dpa() for multi-pmem support").
Reported-by: Dariusz Dokupil <dariusz.dokupil@intel.com>
Reported-by: Dave Jiang <dave.jiang@intel.com>
Reported-by: Vishal Verma <vishal.l.verma@intel.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
Tested-by: Vishal Verma <vishal.l.verma@intel.com>
Now that we have nd_region_available_dpa() able to handle the presence
of multiple PMEM allocations in aliased PMEM regions, reuse that same
infrastructure to track allocations from free space. In particular
handle allocating from an aliased PMEM region in the case where there
are dis-contiguous holes. The allocation for BLK and PMEM are
documented in the space_valid() helper:
BLK-space is valid as long as it does not precede a PMEM
allocation in a given region. PMEM-space must be contiguous
and adjacent to an existing existing allocation (if one
exists).
The free dpa (dimm-physical-address) space calculation reports how much
free space is available with consideration for aliased BLK + PMEM
regions. Recall that BLK capacity is allocated from high addresses and
PMEM is allocated from low addresses in their respective regions.
nd_region_available_dpa() accounts for the fact that the largest
encroachment (lowest starting address) into PMEM capacity by a BLK
allocation limits the available capacity to that point, regardless if
there is BLK allocation hole at a higher address. Similarly, for the
multi-pmem case we need to track the largest encroachment (highest
ending address) of a PMEM allocation in BLK capacity regardless of
whether there is an allocation hole that a BLK allocation could fill at
a lower address.
'ndctl list --buses --dimms' does not list any NVDIMM-Ns since
they are considered as idle. ndctl checks if any driver is
attached to nmem device. nvdimm_probe() always fails in
nvdimm_init_nsarea() since NVDIMM-Ns do not implement optinal
ND_CMD_GET_CONFIG_DATA command.
Change nvdimm_probe() to accept the case that the CONFIG_DATA
command is not implemented for NVDIMM-Ns. The driver attaches
without ndd, which keeps it no-op to the device.
Reported-by: Brian Boylston <brian.boylston@hpe.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: Johannes Thumshirn <jthumshirn@suse.de>
Per "ACPI 6.1 Section 9.20.3" NVDIMM devices, children of the ACPI0012
NVDIMM Root device, can receive health event notifications.
Given that these devices are precluded from registering a notification
handler via acpi_driver.acpi_device_ops (due to no _HID), we use
acpi_install_notify_handler() directly. The registered handler,
acpi_nvdimm_notify(), triggers a poll(2) event on the nmemX/nfit/flags
sysfs attribute when a health event notification is received.
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Tested-by: Toshi Kani <toshi.kani@hpe.com>
Reviewed-by: Vishal Verma <vishal.l.verma@intel.com>
Acked-by: Rafael J. Wysocki <rafael@kernel.org>
Reviewed-by: Toshi Kani <toshi.kani@hpe.com>
In preparation for triggering flushes of a DIMM's writes-posted-queue
(WPQ) via the pmem driver move mapping of flush hint addresses to the
region driver. Since this uses devm_nvdimm_memremap() the flush
addresses will remain mapped while any region to which the dimm belongs
is active.
We need to communicate more information to the nvdimm core to facilitate
this mapping, namely each dimm object now carries an array of flush hint
address resources.
ida instances allocate some internal memory for ->free_bitmap in
addition to the base 'struct ida'. Use ida_destroy() to release that
memory at module_exit().
Reported-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Clarify the distinction between "commands", the ioctls userspace calls
to request the kernel take some action on a given dimm device, and
"_DSMs", the actual function numbers used in the firmware interface to
the DIMM. _DSMs are ACPI specific whereas commands are Linux kernel
generic.
This is in preparation for breaking the 1:1 implicit relationship
between the kernel ioctl number space and the firmware specific function
numbers.
Cc: Jerry Hoemann <jerry.hoemann@hpe.com>
The return value from an 'ndctl_fn' reports the command execution
status, i.e. was the command properly formatted and was it successfully
submitted to the bus provider. The new 'cmd_rc' parameter allows the bus
provider to communicate command specific results, translated into
common error codes.
Convert the ARS commands to this scheme to:
1/ Consolidate status reporting
2/ Prepare for for expanding ars unit test cases
3/ Make the implementation more generic
Cc: Vishal Verma <vishal.l.verma@intel.com>
Signed-off-by: yalin wang <yalin.wang2010@gmail.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
The libnvdimm implementation handles allocating dimm address space (DPA)
between PMEM and BLK mode interfaces. After DPA has been allocated from
a BLK-region to a BLK-namespace the nd_blk driver attaches to handle I/O
as a struct bio based block device. Unlike PMEM, BLK is required to
handle platform specific details like mmio register formats and memory
controller interleave. For this reason the libnvdimm generic nd_blk
driver calls back into the bus provider to carry out the I/O.
This initial implementation handles the BLK interface defined by the
ACPI 6 NFIT [1] and the NVDIMM DSM Interface Example [2] composed from
DCR (dimm control region), BDW (block data window), IDT (interleave
descriptor) NFIT structures and the hardware register format.
[1]: http://www.uefi.org/sites/default/files/resources/ACPI_6.0.pdf
[2]: http://pmem.io/documents/NVDIMM_DSM_Interface_Example.pdf
Cc: Boaz Harrosh <boaz@plexistor.com>
Cc: Jens Axboe <axboe@fb.com>
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
After 'uuid', 'size', 'sector_size', and optionally 'alt_name' have been
set to valid values the labels on the dimm can be updated. The
difference with the pmem case is that blk namespaces are limited to one
dimm and can cover discontiguous ranges in dpa space.
Also, after allocating label slots, it is useful for userspace to know
how many slots are left. Export this information in sysfs.
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Neil Brown <neilb@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
After 'uuid', 'size', and optionally 'alt_name' have been set to valid
values the labels on the dimms can be updated.
Write procedure is:
1/ Allocate and write new labels in the "next" index
2/ Free the old labels in the working copy
3/ Write the bitmap and the label space on the dimm
4/ Write the index to make the update valid
Label ranges directly mirror the dpa resource values for the given
label_id of the namespace.
A blk label set describes a namespace comprised of one or more
discontiguous dpa ranges on a single dimm. They may alias with one or
more pmem interleave sets that include the given dimm.
This is the runtime/volatile configuration infrastructure for sysfs
manipulation of 'alt_name', 'uuid', 'size', and 'sector_size'. A later
patch will make these settings persistent by writing back the label(s).
Unlike pmem namespaces, multiple blk namespaces can be created per
region. Once a blk namespace has been created a new seed device
(unconfigured child of a parent blk region) is instantiated. As long as
a region has 'available_size' != 0 new child namespaces may be created.
A complete label set is a PMEM-label per-dimm per-interleave-set where
all the UUIDs match and the interleave set cookie matches the hosting
interleave set.
Present sysfs attributes for manipulation of a PMEM-namespace's
'alt_name', 'uuid', and 'size' attributes. A later patch will make
these settings persistent by writing back the label.
Note that PMEM allocations grow forwards from the start of an interleave
set (lowest dimm-physical-address (DPA)). BLK-namespaces that alias
with a PMEM interleave set will grow allocations backward from the
highest DPA.
This on media label format [1] consists of two index blocks followed by
an array of labels. None of these structures are ever updated in place.
A sequence number tracks the current active index and the next one to
write, while labels are written to free slots.
| nsindex0 |
| nsindex1 |
| label0 |
| label1 |
....nslot...
| labelN |
After reading valid labels, store the dpa ranges they claim into
per-dimm resource trees.
[1]: http://pmem.io/documents/NVDIMM_Namespace_Spec.pdf
On platforms that have firmware support for reading/writing per-dimm
label space, a portion of the dimm may be accessible via an interleave
set PMEM mapping in addition to the dimm's BLK (block-data-window
aperture(s)) interface. A label, stored in a "configuration data
region" on the dimm, disambiguates which dimm addresses are accessed
through which exclusive interface.
Add infrastructure that allows the kernel to block modifications to a
label in the set while any member dimm is active. Note that this is
meant only for enforcing "no modifications of active labels" via the
coarse ioctl command. Adding/deleting namespaces from an active
interleave set is always possible via sysfs.
Another aspect of tracking interleave sets is tracking their integrity
when DIMMs in a set are physically re-ordered. For this purpose we
generate an "interleave-set cookie" that can be recorded in a label and
validated against the current configuration. It is the bus provider
implementation's responsibility to calculate the interleave set cookie
and attach it to a given region.
Cc: <linux-acpi@vger.kernel.org>
Cc: Robert Moore <robert.moore@intel.com>
* Implement the device-model infrastructure for loading modules and
attaching drivers to nvdimm devices. This is a simple association of a
nd-device-type number with a driver that has a bitmask of supported
device types. To facilitate userspace bind/unbind operations 'modalias'
and 'devtype', that also appear in the uevent, are added as generic
sysfs attributes for all nvdimm devices. The reason for the device-type
number is to support sub-types within a given parent devtype, be it a
vendor-specific sub-type or otherwise.
* The first consumer of this infrastructure is the driver
for dimm devices. It simply uses control messages to retrieve and
store the configuration-data image (label set) from each dimm.
Note: nd_device_register() arranges for asynchronous registration of
nvdimm bus devices by default.
Tested-by: Toshi Kani <toshi.kani@hp.com>
Most discovery/configuration of the nvdimm-subsystem is done via sysfs
attributes. However, some nvdimm_bus instances, particularly the
ACPI.NFIT bus, define a small set of messages that can be passed to the
platform. For convenience we derive the initial libnvdimm-ioctl command
formats directly from the NFIT DSM Interface Example formats.
ND_CMD_SMART: media health and diagnostics
ND_CMD_GET_CONFIG_SIZE: size of the label space
ND_CMD_GET_CONFIG_DATA: read label space
ND_CMD_SET_CONFIG_DATA: write label space
ND_CMD_VENDOR: vendor-specific command passthrough
ND_CMD_ARS_CAP: report address-range-scrubbing capabilities
ND_CMD_ARS_START: initiate scrubbing
ND_CMD_ARS_STATUS: report on scrubbing state
ND_CMD_SMART_THRESHOLD: configure alarm thresholds for smart events
If a platform later defines different commands than this set it is
straightforward to extend support to those formats.
Most of the commands target a specific dimm. However, the
address-range-scrubbing commands target the bus. The 'commands'
attribute in sysfs of an nvdimm_bus, or nvdimm, enumerate the supported
commands for that object.
Reported-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
Enable nvdimm devices to be registered on a nvdimm_bus. The kernel
assigned device id for nvdimm devicesis dynamic. If userspace needs a
more static identifier it should consult a provider-specific attribute.
In the case where NFIT is the provider, the 'nmemX/nfit/handle' or
'nmemX/nfit/serial' attributes may be used for this purpose.
