When the OF code was originally made common by Grant in commit
51975db0b733 ("of/flattree: merge early_init_dt_scan_memory() common
code") (Feb 2010), the common code inherited a hack to handle
PPC "longtrail" machines, which had a "memory@0" node with no
device_type.
That check was then made to only apply to PPC32 in b44aa25d20e2 ("of:
Handle memory@0 node on PPC32 only") (May 2014).
But according to Paul Mackerras the "longtrail" machines are long
dead, if they were ever seen in the wild at all. If someone does still
have one, we can handle this firmware wart in powerpc platform code.
So remove the hack once and for all.
Signed-off-by: Rob Herring <robh@kernel.org>
Commit 99492c39f39f ("earlycon: Fix __earlycon_table stride") tried to fix
__earlycon_table stride by forcing the earlycon_id struct alignment to 32
and asking the linker to 32-byte align the __earlycon_table symbol. This
fix was based on commit 07fca0e57fca92 ("tracing: Properly align linker
defined symbols") which tried a similar fix for the tracing subsystem.
However, this fix doesn't quite work because there is no guarantee that
gcc will place structures packed into an array format. In fact, gcc 4.9
chooses to 64-byte align these structs by inserting additional padding
between the entries because it has no clue that they are supposed to be in
an array. If we are unlucky, the linker will assign symbol
"__earlycon_table" to a 32-byte aligned address which does not correspond
to the 64-byte aligned contents of section "__earlycon_table".
To address this same problem, the fix to the tracing system was
subsequently re-implemented using a more robust table of pointers approach
by commits:
3d56e331b653 ("tracing: Replace syscall_meta_data struct array with pointer array")
654986462939 ("tracepoints: Fix section alignment using pointer array")
e4a9ea5ee7c8 ("tracing: Replace trace_event struct array with pointer array")
Let's use this same "array of pointers to structs" approach for
EARLYCON_TABLE.
Fixes: 99492c39f39f ("earlycon: Fix __earlycon_table stride")
Signed-off-by: Daniel Kurtz <djkurtz@chromium.org>
Suggested-by: Aaron Durbin <adurbin@chromium.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Tested-by: Guenter Roeck <groeck@chromium.org>
Reviewed-by: Guenter Roeck <groeck@chromium.org>
Cc: stable <stable@vger.kernel.org>
memblock_virt_alloc() works for both memblock and bootmem, so use it and
make early_init_dt_alloc_memory_arch a static function. The arches using
bootmem define early_init_dt_alloc_memory_arch as either:
__alloc_bootmem(size, align, __pa(MAX_DMA_ADDRESS))
or:
alloc_bootmem_align(size, align)
Both of these evaluate to the same thing as does memblock_virt_alloc for
bootmem. So we can disable the arch specific functions by making
early_init_dt_alloc_memory_arch static and they can be removed in
subsequent commits.
Cc: Frank Rowand <frowand.list@gmail.com>
Convert remaining DT files to use SPDX-License-Identifier tags.
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Reviewed-by: Frank Rowand <frank.rowand@sony.com>
This wasn't documented.
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Reviewed-by: Frank Rowand <frowand.list@gmail.com>
For static DT usecases, we don't need the disabled nodes and can skip
unflattening. This saves a significant amount of RAM in memory constrained
cases. In one example on STM32F469, the RAM usage goes from 118K to 26K.
There are a few cases in the kernel that modify the status property
dynamically. These all are changes from enabled to disabled, depend on
OF_DYNAMIC or are not FDT based (PDT based).
Tested-by: Nicolas Pitre <nico@linaro.org>
Add an equivalent function to of_device_is_available for flattened DT, and
convert the one existing open coded occurrence.
With dependencies on a statically allocated full path name converted to
use %pOF format specifier, we can store just the basename of node, and
the unflattening of the FDT can be simplified.
This commit will affect the remaining users of full_name. After
analyzing these users, the remaining cases should only change some print
messages. The main users of full_name are providing a name for struct
resource. The resource names shouldn't be important other than providing
/proc/iomem names.
We no longer distinguish between pre and post 0x10 dtb formats as either
a full path or basename will work. However, less than 0x10 formats have
been broken since the conversion to use libfdt (and no one has cared).
The conversion of the unflattening code to be non-recursive also broke
pre 0x10 formats as the populate_node function would return 0 in that
case.
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- vsprintf format specifier %pOF for device_node's. This will enable us
to stop storing the full node names. Conversion of users will happen
next cycle.
- Update documentation to point to DT specification instead of ePAPR.
- Split out graph and property functions to a separate file.
- New of-graph functions for ALSA
- Add vendor prefixes for RISC-V, Linksys, iWave Systems, Roofull,
Itead, and BananaPi.
- Improve dtx_diff utility filename printing.
* tag 'devicetree-for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (32 commits)
of: document /sys/firmware/fdt
dt-bindings: Add RISC-V vendor prefix
vsprintf: Add %p extension "%pOF" for device tree
of: find_node_by_full_name rewrite to compare each level
of: use kbasename instead of open coding
dt-bindings: thermal: add file extension to brcm,ns-thermal
of: update ePAPR references to point to Devicetree Specification
scripts/dtc: dtx_diff - Show real file names in diff header
of: detect invalid phandle in overlay
of: be consistent in form of file mode
of: make __of_attach_node() static
of: address.c header comment typo
of: fdt.c header comment typo
of: make of_fdt_is_compatible() static
dt-bindings: display-timing.txt convert non-ascii characters to ascii
Documentation: remove overlay-notes reference to non-existent file
dt-bindings: usb: exynos-usb: Add missing required VDD properties
dt-bindings: Add vendor prefix for Linksys
MAINTAINERS: add device tree ABI documentation file
of: Add vendor prefix for iWave Systems Technologies Pvt. Ltd
Fix typo in header comment for early_init_dt_scan_memory()
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
The callers of of_fdt_is_compatible() are all in fdt.c so
make it static.
Pull DeviceTree fixes from Rob Herring:
- fix missing allocation failure handling in fdt code
- fix dtc compile error on 32-bit hosts
- revert bad sparse changes causing GCC7 warnings
* tag 'devicetree-fixes-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: fdt: add missing allocation-failure check
dtc: check.c fix compile error
Partially Revert "of: fix sparse warnings in fdt, irq, reserved mem, and resolver code"
The memory allocator passed to __unflatten_device_tree() (e.g. a wrapped
kzalloc) can fail so add the missing sanity check to avoid dereferencing
a NULL pointer.
Fixes: fe14042358fa ("of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree")
Cc: stable <stable@vger.kernel.org> # 2.6.38
Signed-off-by: Johan Hovold <johan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull more powerpc updates from Michael Ellerman:
"The change to the Linux page table geometry was delayed for more
testing with 16G pages, and there's the new CPU features stuff which
just needed one more polish before going in. Plus a few changes from
Scott which came in a bit late. And then various fixes, mostly minor.
Summary highlights:
- rework the Linux page table geometry to lower memory usage on
64-bit Book3S (IBM chips) using the Hash MMU.
- support for a new device tree binding for discovering CPU features
on future firmwares.
- Freescale updates from Scott:
"Includes a fix for a powerpc/next mm regression on 64e, a fix for
a kernel hang on 64e when using a debugger inside a relocated
kernel, a qman fix, and misc qe improvements."
Thanks to: Christophe Leroy, Gavin Shan, Horia Geantă, LiuHailong,
Nicholas Piggin, Roy Pledge, Scott Wood, Valentin Longchamp"
* tag 'powerpc-4.12-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/64s: Support new device tree binding for discovering CPU features
powerpc: Don't print cpu_spec->cpu_name if it's NULL
of/fdt: introduce of_scan_flat_dt_subnodes and of_get_flat_dt_phandle
powerpc/64s: Fix unnecessary machine check handler relocation branch
powerpc/mm/book3s/64: Rework page table geometry for lower memory usage
powerpc: Fix distclean with Makefile.postlink
powerpc/64e: Don't place the stack beyond TASK_SIZE
powerpc/powernv: Block PCI config access on BCM5718 during EEH recovery
powerpc/8xx: Adding support of IRQ in MPC8xx GPIO
soc/fsl/qbman: Disable IRQs for deferred QBMan work
soc/fsl/qe: add EXPORT_SYMBOL for the 2 qe_tdm functions
soc/fsl/qe: only apply QE_General4 workaround on affected SoCs
soc/fsl/qe: round brg_freq to 1kHz granularity
soc/fsl/qe: get rid of immrbar_virt_to_phys()
net: ethernet: ucc_geth: fix MEM_PART_MURAM mode
powerpc/64e: Fix hang when debugging programs with relocated kernel
Introduce primitives for FDT parsing. These will be used for powerpc
cpufeatures node scanning, which has quite complex structure but should
be processed early.
Cc: devicetree@vger.kernel.org
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
sparse generates the following warnings in drivers/of/:
../drivers/of/fdt.c:63:36: warning: cast to restricted __be32
../drivers/of/fdt.c:68:33: warning: cast to restricted __be32
../drivers/of/irq.c:105:88: warning: incorrect type in initializer (different base types)
../drivers/of/irq.c:105:88: expected restricted __be32
../drivers/of/irq.c:105:88: got int
../drivers/of/irq.c:526:35: warning: incorrect type in assignment (different modifiers)
../drivers/of/irq.c:526:35: expected int ( *const [usertype] irq_init_cb )( ... )
../drivers/of/irq.c:526:35: got void const *const data
../drivers/of/of_reserved_mem.c:200:50: warning: incorrect type in initializer (different modifiers)
../drivers/of/of_reserved_mem.c:200:50: expected int ( *[usertype] initfn )( ... )
../drivers/of/of_reserved_mem.c:200:50: got void const *const data
../drivers/of/resolver.c:95:42: warning: incorrect type in assignment (different base types)
../drivers/of/resolver.c:95:42: expected unsigned int [unsigned] [usertype] <noident>
../drivers/of/resolver.c:95:42: got restricted __be32 [usertype] <noident>
All these are harmless type mismatches fixed by adjusting the types.
Existing overlay unit tests examine individual pieces of the overlay
code. The new tests target the entire process of applying an overlay.
"Pretty standard stuff with dtc upstream sync being the biggest piece.
- Sync dtc to upstream commit 0931cea3ba20. This picks up overlay
support in dtc.
- Set dma_ops for reserved memory users.
- Make references to IOMMU consistent in DT bindings.
- Cleanup references to pm_power_off in bindings.
- Move some display bindings that snuck into the old bindings/video/
path.
- Fix some wrong documentation paths caused from binding
restructuring.
- Vendor prefixes for Faraday and Fujitsu.
- Fix an of_node ref counting leak in of_find_node_opts_by_path
- Introduce new graph helper of_graph_get_remote_node() which will be
used by DRM drivers in 4.12"
* tag 'devicetree-for-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (27 commits)
DT: add Faraday Tec. as vendor
of: introduce of_graph_get_remote_node
of: Add missing space at end of pr_fmt().
of: make of_device_make_bus_id() static
of: fix of_node leak caused in of_find_node_opts_by_path
dt-bindings: net: remove reference to fixed link support
dt-bindings: power: reset: qnap-poweroff: Drop reference to pm_power_off
dt-bindings: power: reset: gpio-poweroff: Drop reference to pm_power_off
dt-bindings: mfd: as3722: Drop reference to pm_power_off
dt-bindings: display: move ANX7814 and SiI8620 bridge bindings
of/unittest: Swap arguments of of_unittest_apply_overlay()
Documentation: usb: fix wrong documentation paths
serial: fsl-imx-uart.txt: Remove generic property
devicetree: Add Fujitsu Ltd. vendor prefix
Documentation: display: fix wrong documentation paths
of: remove redundant memset in overlay
bus:qcom : Fix typo in qcom,ebi2.txt
dt-bindings: qman: Remove pool channel node
Documentation: panel-dpi: fix path to display-timing.txt
devicetree: bindings: clk: mvebu: fix description for sata1 on Armada XP
Make pr_fmt() in fdt.c consistent with all other files in drivers/of/
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
An empty __dtb_start to __dtb_end section might result in
initial_boot_params being null for arch/mips/ralink. This showed that the
boot process hangs indefinitely in of_scan_flat_dt().
Signed-off-by: Tobias Wolf <dev-NTEO@vplace.de>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/14605/
When movable nodes are enabled, any node containing only hotpluggable
memory is made movable at boot time.
On x86, hotpluggable memory is discovered by parsing the ACPI SRAT,
making corresponding calls to memblock_mark_hotplug().
If we introduce a dt property to describe memory as hotpluggable,
configs supporting early fdt may then also do this marking and use
movable nodes.
Link: http://lkml.kernel.org/r/1479160961-25840-5-git-send-email-arbab@linux.vnet.ibm.com
Signed-off-by: Reza Arbab <arbab@linux.vnet.ibm.com>
Tested-by: Balbir Singh <bsingharora@gmail.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Alistair Popple <apopple@au1.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Bharata B Rao <bharata@linux.vnet.ibm.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Stewart Smith <stewart@linux.vnet.ibm.com>
We have multiple "earlycon" early_param handlers - merge the DT one into
the main earlycon one. It's a cleanup that also will be useful
to defer setting up DT console until ACPI/DT decision is made.
Rename the exported function to avoid clashing with the function from
arch/microblaze/kernel/prom.c
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Tested-by: Christopher Covington <cov@codeaurora.org>
@mynodes is set to NULL when __unflatten_device_tree() is called
to unflatten device sub-tree in PCI hot add scenario on PowerPC
PowerNV platform. Marking @mynodes detached unconditionally causes
kernel crash as below backtrace shows:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc000000000b26f64
cpu 0x0: Vector: 300 (Data Access) at [c000003fcc7cf740]
pc: c000000000b26f64: __unflatten_device_tree+0xf4/0x190
lr: c000000000b26f40: __unflatten_device_tree+0xd0/0x190
sp: c000003fcc7cf9c0
msr: 900000000280b033
dar: 0
dsisr: 40000000
current = 0xc000003fcc281680
paca = 0xc00000000ff00000 softe: 0 irq_happened: 0x01
pid = 2724, comm = sh
Linux version 4.7.0-gavin-07754-g92a6836 (gwshan@gwshan) (gcc version \
4.9.3 (Buildroot 2016.02-rc2-00093-g5ea3bce) ) #539 SMP Mon Aug 1 \
12:40:29 AEST 2016
enter ? for help
[c000003fcc7cfa50] c000000000b27060 of_fdt_unflatten_tree+0x60/0x90
[c000003fcc7cfaa0] c0000000004c6288 pnv_php_set_slot_power_state+0x118/0x440
[c000003fcc7cfb80] c0000000004c6a10 pnv_php_enable+0xc0/0x170
[c000003fcc7cfbd0] c0000000004c4d80 power_write_file+0xa0/0x190
[c000003fcc7cfc50] c0000000004be93c pci_slot_attr_store+0x3c/0x60
[c000003fcc7cfc70] c0000000002d3fd4 sysfs_kf_write+0x94/0xc0
[c000003fcc7cfcb0] c0000000002d2c30 kernfs_fop_write+0x180/0x260
[c000003fcc7cfd00] c000000000230fe0 __vfs_write+0x40/0x190
[c000003fcc7cfd90] c000000000232278 vfs_write+0xc8/0x240
[c000003fcc7cfde0] c000000000233d90 SyS_write+0x60/0x110
[c000003fcc7cfe30] c000000000009524 system_call+0x38/0x108
This avoids the kernel crash by marking @mynodes detached only when
@mynodes is dereferencing valid device node in __unflatten_device_tree().
Fixes: 1d1bde550ea3 ("of: fdt: mark unflattened tree as detached")
Reported-by: Meng Li <shlimeng@cn.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of/irq: Mark initialised interrupt controllers as populated
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
The tree returned from of_fdt_unflatten_tree cannot be attached to the
live tree because it is not marked as detached so mark it as such. The
dt resolver checks the flag and refuses to process the tree otherwise.
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
Clean-up all the DT printk functions to use common pr_fmt prefix.
Some print statements such as kmalloc errors were redundant, so just
drop those.
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Sometimes it needs to check if there is a subnode of given node in FDT
by given name. Introduce this helper to get the subnode if it exists.
CC: Rob Herring <robh@kernel.org>
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Tested-by: Julien Grall <julien.grall@arm.com>
The function is unflattening device sub-tree blob if @dad passed to
the function is valid. Currently, this functionality is used by PPC
PowerNV PCI hotplug driver only. There are possibly multiple nodes
in the first level of depth, fdt_next_node() bails immediately when
@depth becomes negative before the second device node can be probed
successfully. It leads to the device nodes except the first one won't
be unflattened successfully.
This fixes the issue by setting the initial depth (@inital_depth) to
1 when this function is called to unflatten device sub-tree blob. No
logic changes when this function is used to unflatten non-sub-tree
blob.
Cc: Rhyland Klein <rklein@nvidia.com>
Fixes: 78c44d910 ("drivers/of: Fix depth when unflattening devicetree")
Tested-by: Rhyland Klein <rklein@nvidia.com>
Tested-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Function populate_node() is used to unflatten FDT blob to device
tree. It supports maximal 64 level of device nodes. There is one
array @fpsizes[64] tracking the full name length of last unflattened
device node in the corresponding level (index of element in the
array - 1). Build warning is seen with CONFIG_FRAME_WARN=1024 like
below on ARM64 as Geert reported. The issue can be reproduced on
PPC64 as well.
$ make drivers/of/fdt.o
drivers/of/fdt.c:443:1: warning: the frame size of 1136 bytes is \
larger than 1024 bytes [-Wframe-larger-than=]
This changes the data type of @fpsizes[i] from "unsigned long" to
"unsigned int" to avoid the build warning. The return value type
of populate_node() and its @fpsize argument is adjusted accordingly.
With this applied, 256 bytes saved from the stack frame on ARM64 and
PPC64 platforms and the above warning isn't seen.
Fixes: 50800082f176 ("drivers/of: Avoid recursively calling unflatten_dt_node()")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
When the implementation for unflatten_dt_node() changed from being
recursive to being non-recursive, it had a side effect of increasing the
depth passed to fdt_next_node() by 1. This is fine most of the time, but
it seems that when the end of the dtb is being parsed, it will cause the
FDT_END condition in fdt_next_node() to return a different value
(returning nextoffset instead of -FDT_ERR_NOTFOUND). This ends up passing
an FDT_ERR_TRUNCATED error back to the unflatten_dt_node() which then
sees that and complains "Error -8 processing FDT" causing boot to fail.
This patch simply avoids incrementing depth and uses modified accesses
for local array indices so that the depth is the same as it was before
the change as far as fdt_next_node() is concerned.
This problem was discovered trying to boot Tegra210-Smaug platforms.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
[robh: squashed in KASAN fix from Rhyland]
This returns the allocate memory chunk, storing the unflattened device
tree, from of_fdt_unflatten_tree() so that memory chunk can be released
on demand in PowerNV PCI hotplug driver.
This adds one more argument to of_fdt_unflatten_tree() to specify
the parent node of the FDT blob that is going to be unflattened.
In the result, the function can be used to unflatten FDT blob that
represents device sub-tree in PowerNV PCI hotplug driver.
Cc: Jyri Sarha <jsarha@ti.com>
Acked-by: Jyri Sarha <jsarha@ti.com>
This renames unflatten_dt_node() to unflatten_dt_nodes() as it
populates multiple device nodes from FDT blob. No logical changes
introduced.
In current implementation, unflatten_dt_node() is called recursively
to unflatten device nodes in FDT blob. It's stress to limited stack
capacity, especially to adopt the function to unflatten device sub-tree
that possibly has multiple root nodes. In that case, we runs out of
stack and the system can't boot up successfully.
In order to reuse the function to unflatten device sub-tree, this avoids
calling the function recursively, meaning the device nodes are unflattened
in one call on unflatten_dt_node(): two arrays are introduced to track the
parent path size and the device node of current level of depth, which will
be used by the device node on next level of depth to be unflattened. All
device nodes in more than 64 level of depth are dropped and hopefully,
the system can boot up successfully with the partial device-tree.
Also, the parameter "poffset" and "fpsize" are unused and dropped and the
parameter "dryrun" is figured out from "mem == NULL". Besides, the return
value of the function is changed to indicate the size of memory consumed by
the unflatten device tree or error code.
The function unflatten_dt_node() is called recursively to unflatten
device nodes and properties in the FDT blob. It looks complicated
and hard to be understood.
This splits the function into 3 functions: populate_properties(),
populate_node() and unflatten_dt_node(). populate_properties(),
which is called by populate_node(), creates properties for the
indicated device node. The later one creates the device nodes
from FDT blob. populate_node() gets the offset in FDT blob for
next device nodes and then calls populate_node(). No logical
changes introduced.
On arm CONFIG_CMDLINE_EXTEND does not append build-in
cmdline in kernel to U-boot parameters. Fix it here.
Theoretically this patch should repair kdump work where
it adds elfcorehdr= and memmap additional parameters
to second kernel.
Signed-off-by: Max Uvarov <muvarov@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
"Here are the main arm64 updates for 4.6. There are some relatively
intrusive changes to support KASLR, the reworking of the kernel
virtual memory layout and initial page table creation.
Summary:
- Initial page table creation reworked to avoid breaking large block
mappings (huge pages) into smaller ones. The ARM architecture
requires break-before-make in such cases to avoid TLB conflicts but
that's not always possible on live page tables
- Kernel virtual memory layout: the kernel image is no longer linked
to the bottom of the linear mapping (PAGE_OFFSET) but at the bottom
of the vmalloc space, allowing the kernel to be loaded (nearly)
anywhere in physical RAM
- Kernel ASLR: position independent kernel Image and modules being
randomly mapped in the vmalloc space with the randomness is
provided by UEFI (efi_get_random_bytes() patches merged via the
arm64 tree, acked by Matt Fleming)
- Implement relative exception tables for arm64, required by KASLR
(initial code for ARCH_HAS_RELATIVE_EXTABLE added to lib/extable.c
but actual x86 conversion to deferred to 4.7 because of the merge
dependencies)
- Support for the User Access Override feature of ARMv8.2: this
allows uaccess functions (get_user etc.) to be implemented using
LDTR/STTR instructions. Such instructions, when run by the kernel,
perform unprivileged accesses adding an extra level of protection.
The set_fs() macro is used to "upgrade" such instruction to
privileged accesses via the UAO bit
- Half-precision floating point support (part of ARMv8.2)
- Optimisations for CPUs with or without a hardware prefetcher (using
run-time code patching)
- copy_page performance improvement to deal with 128 bytes at a time
- Sanity checks on the CPU capabilities (via CPUID) to prevent
incompatible secondary CPUs from being brought up (e.g. weird
big.LITTLE configurations)
- valid_user_regs() reworked for better sanity check of the
sigcontext information (restored pstate information)
- ACPI parking protocol implementation
- CONFIG_DEBUG_RODATA enabled by default
- VDSO code marked as read-only
- DEBUG_PAGEALLOC support
- ARCH_HAS_UBSAN_SANITIZE_ALL enabled
- Erratum workaround Cavium ThunderX SoC
- set_pte_at() fix for PROT_NONE mappings
- Code clean-ups"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (99 commits)
arm64: kasan: Fix zero shadow mapping overriding kernel image shadow
arm64: kasan: Use actual memory node when populating the kernel image shadow
arm64: Update PTE_RDONLY in set_pte_at() for PROT_NONE permission
arm64: Fix misspellings in comments.
arm64: efi: add missing frame pointer assignment
arm64: make mrs_s prefixing implicit in read_cpuid
arm64: enable CONFIG_DEBUG_RODATA by default
arm64: Rework valid_user_regs
arm64: mm: check at build time that PAGE_OFFSET divides the VA space evenly
arm64: KVM: Move kvm_call_hyp back to its original localtion
arm64: mm: treat memstart_addr as a signed quantity
arm64: mm: list kernel sections in order
arm64: lse: deal with clobbered IP registers after branch via PLT
arm64: mm: dump: Use VA_START directly instead of private LOWEST_ADDR
arm64: kconfig: add submenu for 8.2 architectural features
arm64: kernel: acpi: fix ioremap in ACPI parking protocol cpu_postboot
arm64: Add support for Half precision floating point
arm64: Remove fixmap include fragility
arm64: Add workaround for Cavium erratum 27456
arm64: mm: Mark .rodata as RO
Since architectures may not yet have their linear mapping up and running
when the initrd address is discovered from the DT, factor out the
assignment of initrd_start and initrd_end, so that an architecture can
override it and use the translation it needs.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
By default, early_init_dt_add_memory_arch() ignores memory below
the base of the kernel image since it won't be addressable via the
linear mapping. However, this is not appropriate anymore once we
decouple the kernel text mapping from the linear mapping, so archs
may want to drop the low limit entirely. So allow the minimum to be
overridden by setting MIN_MEMBLOCK_ADDR.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Earlycon may fail to initialize for a variety of reasons, most of
which log the default early param message. If the stdout-path node is
not found, log the path which was not found (and suppress the
default early param message).
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Cleanup the early DT/earlycon separation; remove the 'addr' parameter
from of_setup_earlycon() and get the uart phys addr directly with a
new wrapper function, of_flat_dt_translate_addr(). Limit
fdt_translate_address() to file scope.
Read the optional "reg-offset", "reg-shift", "reg-io-width" and endianness
properties and initialize the respective struct uart_port field if found.
NB: These bindings are common to several drivers and the values merely
indicate the default value; the registering earlycon setup() method can
simply override the values if required.
Pass-through any options string in the 'stdout-path' property to the
earlycon "driver" setup.
Use the console name embedded in the OF earlycon table by the
OF_EARLYCON_DECLARE() macro to initialize the struct console 'name'
and 'index' fields.
Use a single common table of struct earlycon_id for both command line
and devicetree. Re-define OF_EARLYCON_DECLARE() macro to instance a
unique earlycon declaration (the declaration is only guaranteed to be
unique within a compilation unit; separate compilation units must still
use unique earlycon names).
The semantics of OF_EARLYCON_DECLARE() is different; it declares an
earlycon which can matched either on the command line or by devicetree.
EARLYCON_DECLARE() is semantically unchanged; it declares an earlycon
which is matched by command line only. Remove redundant instances of
EARLYCON_DECLARE().
This enables all earlycons to properly initialize struct console
with the appropriate name and index, which improves diagnostics and
enables direct earlycon-to-console handoff.
__unflatten_device_tree() calls unflatten_dt_node(), which declares
a static variable. It is therefore not reentrant.
One of the callers of __unflatten_device_tree(), unflatten_device_tree(),
is only called once during early initialization and does not need to be
protected. The other caller, of_fdt_unflatten_tree(), can be called at
any time, possibly multiple times in parallel. This can happen, for
example, if multiple devicetree overlays have to be loaded and installed.
Without this protection, errors such as the following may be seen.
kernel: End of tree marker overwritten: e6a3a458
kernel: find_target_node:
Failed to find target-indirect node at /fragment@0
kernel: __of_overlay_create: of_build_overlay_info() failed for tree@/
Add a mutex to of_fdt_unflatten_tree() to make the call reentrant.
Cc: stable@vger.kernel.org # v4.1+
Signed-off-by: Dmitry V. Krivenok <krivenok.dmitry@gmail.com>
no need to initialise static variable with 0, hence correcting it.
Signed-off-by: Saurabh Sengar <saurabh.truth@gmail.com>
fdt_translate_address() returns OF_BAD_ADDR on error. It is defined as
a u64 value, so the variable "addr" should be defined as u64 as well.
Fixes: fb11ffe74c79 ("of/fdt: add FDT serial scanning for earlycon")
Many boards use an alias in the stdout-path specification along
with console options after a colon (e.g. serial0:115200n8). When
using earlycon, this specification currently does not work. While
fdt_path_offset supports alias resolution, it does not remove the
console options by itself. Use the fdt_path_offset_namelen variant
and provide the length of the alias to enable aliases with console
options in the stdout-path.
Signed-off-by: Stefan Agner <stefan@agner.ch>
