[ Upstream commit 95f566de0269a0c59fd6a737a147731302136429 ]
If one of the child devices is missing the of_mdiobus_register_phy()
call will return -ENODEV. When a missing device is encountered the
registration of the remaining PHYs is stopped and the MDIO bus will
fail to register. Propagate all errors except ENODEV to avoid it.
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
If an Ethernet PHY is initialized before the interrupt controller it is
connected to, a message like the following is printed:
irq: no irq domain found for /interrupt-controller@e61c0000 !
However, the actual error is ignored, leading to a non-functional (POLL)
PHY interrupt later:
Micrel KSZ8041RNLI ee700000.ethernet-ffffffff:01: attached PHY driver [Micrel KSZ8041RNLI] (mii_bus:phy_addr=ee700000.ethernet-ffffffff:01, irq=POLL)
Depending on whether the PHY driver will fall back to polling, Ethernet
may or may not work.
To fix this:
1. Switch of_mdiobus_register_phy() from irq_of_parse_and_map() to
of_irq_get().
Unlike the former, the latter returns -EPROBE_DEFER if the
interrupt controller is not yet available, so this condition can be
detected.
Other errors are handled the same as before, i.e. use the passed
mdio->irq[addr] as interrupt.
2. Propagate and handle errors from of_mdiobus_register_phy() and
of_mdiobus_register_device().
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
"There's a few orphans in the conversion to %pOF printf specifiers
included here that no one else picked up.
Summary:
- Convert more DT code to use of_property_read_* API.
- Improve DT overlay support when adding multiple overlays
- Convert printk's to %pOF format specifiers. Most went via subsystem
trees, but picked up the remaining orphans
- Correct unittests to use preferred "okay" for "status" property
value
- Add a KASLR seed property
- Vendor prefixes for Mellanox, Theobroma System, Adaptrum, Moxa
- Fix modalias buffer handling
- Clean-up of include paths for building dtbs
- Add bindings for amc6821, isl1208, tsl2x7x, srf02, and srf10
devices
- Add nvmem bindings for MediaTek MT7623 and MT7622 SoC
- Add compatible string for Allwinner H5 Mali-450 GPU
- Fix links to old OpenFirmware docs with new mirror on
devicetree.org
- Remove status property from binding doc examples"
* tag 'devicetree-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits)
devicetree: Adjust status "ok" -> "okay" under drivers/of/
dt-bindings: Remove "status" from examples
dt-bindings: pinctrl: sh-pfc: Use generic node name
dt-bindings: Add vendor Mellanox
dt-binding: net/phy: fix interrupts description
virt: Convert to using %pOF instead of full_name
macintosh: Convert to using %pOF instead of full_name
ide: pmac: Convert to using %pOF instead of full_name
microblaze: Convert to using %pOF instead of full_name
dt-bindings: usb: musb: Grammar s/the/to/, s/is/are/
of: Use PLATFORM_DEVID_NONE definition
of/device: Fix of_device_get_modalias() buffer handling
of/device: Prevent buffer overflow in of_device_modalias()
dt-bindings: add amc6821, isl1208 trivial bindings
dt-bindings: add vendor prefix for Theobroma Systems
of: search scripts/dtc/include-prefixes path for both CPP and DTC
of: remove arch/$(SRCARCH)/boot/dts from include search path for CPP
of: remove drivers/of/testcase-data from include search path for CPP
of: return of_get_cpu_node from of_cpu_device_node_get if CPUs are not registered
iio: srf08: add device tree binding for srf02 and srf10
Looks like gcc isn't always able to figure out that 3 *if* branches in
of_phy_register_fixed_link() calling fixed_phy_register() at their ends
are similar enough and thus can be merged. The "manual" merge saves 40
bytes of the object code (AArch64 gcc 4.8.5), and still saves 12 bytes
even if gcc was able to merge the branch tails (ARM gcc 4.8.5)...
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
The "fixed-link" prop support predated of_property_read_u32_array(), so
basically had to open-code it. Using the modern API saves 24 bytes of the
object code (ARM gcc 4.8.5); the only behavior change would be that the
prop length check is now less strict (however the strict pre-check done
in of_phy_is_fixed_link() is left intact anyway)...
Reviewed-by: Rob Herring <robh@kernel.org>
of_phy_register_fixed_link() declares the 'err' variable to hold the result
of of_property_read_string() but only uses it once after that, while that
function can be called directly from the *if* statement...
Remove that variable and move/regroup 'link_gpio' and 'len' variables in
order to sort the declarations in the reverse Xmas tree order -- to please
DaveM. ;-)
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
The of_mdio_parse_addr() helper function is useful to other code, but
the module dependency chain causes issues. To work around this, we can
move of_mdio_parse_addr() to be an inline function in the header file.
This gets rid of the dependencies and still allows for the reuse of
code.
Reported-by: Liviu Dudau <liviu@dudau.co.uk>
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
Fixes: 342fa1964439 ("mdio: mux: make child bus walking more permissive and errors more verbose")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Commit 4c5e7a2c0501 ("dt-bindings: mdio: Clarify binding document")
declared that a MDIO reset GPIO property should have only a single GPIO
reference/specifier, however the supporting code was left intact, still
burdening the kernel with now apparently useless loops -- get rid of them.
Some boards [1] leave the PHYs at an invalid state
during system power-up or reset thus causing unreliability
issues with the PHY which manifests as PHY not being detected
or link not functional. To fix this, these PHYs need to be RESET
via a GPIO connected to the PHY's RESET pin.
Some boards have a single GPIO controlling the PHY RESET pin of all
PHYs on the bus whereas some others have separate GPIOs controlling
individual PHY RESETs.
In both cases, the RESET de-assertion cannot be done in the PHY driver
as the PHY will not probe till its reset is de-asserted.
So do the RESET de-assertion in the MDIO bus driver.
[1] - am572x-idk, am571x-idk, a437x-idk
Signed-off-by: Roger Quadros <rogerq@ti.com>
Some Cavium dev boards have firmware which doesn't supply a proper
ethernet-phy-ieee802.3-c22" compatible property. Restore these boards
to working order by whitelisting this compatible value.
Signed-off-by: David Daney <david.daney@cavium.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Add helper to deregister fixed-link PHYs registered using
of_phy_register_fixed_link().
Convert the two drivers that care to deregister their fixed-link PHYs to
use the new helper, but note that most drivers currently fail to do so.
Signed-off-by: Johan Hovold <johan@kernel.org>
Make sure to drop the reference taken by bus_find_device() before
returning NULL from of_phy_find_device() when the found device is not a
PHY.
Fixes: 6ed742363b9c ("of: of_mdio: Ensure mdio device is a PHY")
Make sure to drop the of_node reference also on failure to parse the
speed property in of_phy_register_fixed_link().
Fixes: 3be2a49e5c08 ("of: provide a binding for fixed link PHYs")
Abstract a general interface "of_phy_get_and_connect"
for PHY connect. User will have no bother with getting
"phy-mode" and "phy-handle" any more.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Dongpo Li <lidongpo@hisilicon.com>
Reviewed-by: Jiancheng Xue <xuejiancheng@hisilicon.com>
Calling the fixed-phy functions when CONFIG_FIXED_PHY=m as a previous
change tried cannot work if the caller is in built-in code:
drivers/of/built-in.o: In function `of_phy_register_fixed_link':
of_reserved_mem.c:(.text+0x85e0): undefined reference to `fixed_phy_register'
Making of_mdio depend on 'FIXED_PHY || !FIXED_PHY' would solve this
dependency by enforcing that OF_MDIO itself becomes a loadable module
when FIXED_PHY=y, but that creates a different dependency as it
breaks any built-in ethernet driver that uses of_mdio.
Making FIXED_PHY a bool option also cannot work, since it depends on
PHYLIB, which again is tristate.
This version now uses 'select FIXED_PHY' to ensure that the fixed-phy
portion of of_mdio is not optional. The main downside of this is
a small increase in code size for cases that do not need fixed phy
support, but it should avoid all of the link-time problems.
Fixes: d1bd330a229f ("of_mdio: Enable fixed PHY support if driver is a module")
Acked-by: Randy Dunlap <rdunlap@infradead.org>
The fixed_phy driver doesn't have to be built-in, and it's
important that of_mdio supports it even if it's a module.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Add a check whether the 'struct device_node' pointer passed to
of_mdiobus_register() is an available (aka enabled) node in the Device
Tree.
Rationale for doing this are cases where an Ethernet MAC provides a MDIO
bus controller and node, and an additional Ethernet MAC might be
connecting its PHY/switches to that first MDIO bus controller, while
still embedding one internally which is therefore marked as "disabled".
Instead of sprinkling checks like these in callers of
of_mdiobus_register(), do this in a central location.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Now that get_phy_device() no longer returns NULL on error, we don't need
to check for it...
The results of of_mdiobus_register_{device|phy}() are never checked, so we
can make both these functions *void*...
PTR_ERR_OR_ZERO() is open coded in of_phy_register_fixed_link(), so just
call it directly...
Reviewed-by: Vladimir Zapolskiy <vz@mleia.com>
IS_ERR_OR_NULL() is open coded in of_mdiobus_register_phy(), so just call
it directly...
mdio_device_create() never returns NULL, thus checking for it in
of_mdiobus_register_device() is pointless...
Suggested-by: Vladimir Zapolskiy <vz@mleia.com>
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
The 'flags' parameter of the of_phy_connect() function wasn't described
in the kernel-doc comment...
of_mdiobus_register() declares the 'paddr' variable to hold the result of
the of_get_property() but only uses it once after that while the function
can be called directly from the *if* statement. Remove that variable and
switch to calling of_find_property() instead since we don't care about
the "reg" property's value anyway...
Commit ae461131960b ("of: of_mdio: Add a whitelist of PHY
compatibilities.") missed one compatible string used in in-tree DTBs:
in OCTEON, for selected boards, the kernel DTB pruning code will overwrite
the DTB compatible string with "marvell,88e1145", which is missing
from the whitelist. Add it.
The patch fixes broken networking on EdgeRouter Lite.
Fixes: ae461131960b ("of: of_mdio: Add a whitelist of PHY compatibilities.")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Some phy nodes list a compatible value indicating the PHY make/model.
This is never used to match the device to the driver. However it does
confuse the code to separate a PHY from a generic MDIO device like a
switch. Generic MDIO devices must have a compatible value, PHYs can
list clause 22 or 45, but nothing else.
Issue a warning if we find a compatible value known on the whitelist,
and say it is a PHY.
Fixes: a9049e0c513c ("mdio: Add support for mdio drivers.")
Reported-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Reported-by: Olof Johansson <olof@lixom.net>
Tested-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
of_phy_find_device() is used to find the phy device associated with a
device node. It is expected the node is for a PHY device, but in fact
it could of been probed as a generic MDIO device. Ensure the device is
a PHY before returning it.
It used to be that mdio->irq was a pointer but after e7f4dc3536a4
('mdio: Move allocation of interrupts into core') it's an array inside
the mdio struct so it can never be NULL.
Not all devices on an MDIO bus are PHYs. Meaning not all MDIO drivers
are PHY drivers. Add support for generic MDIO drivers.
Rather than have drivers directly manipulate the mii_bus structure,
provide and API for registering and unregistering devices on an MDIO
bus, and performing lookups.
We will soon support devices other than phys on the mdio bus. Look at
a child's compatibility string to determine if it is a phy, before
registering a phy device.
Not all devices attached to an MDIO bus are phys. So add an
mdio_device structure to represent the generic parts of an mdio
device, and place this structure into the phy_device.
Have mdio_alloc() create the array of interrupt numbers, and
initialize it to POLLING. This is what most MDIO drivers want, so
allowing code to be removed from the drivers.
bus_find_device() is defined as:
* This is similar to the bus_for_each_dev() function above, but it
* returns a reference to a device that is 'found' for later use, as
* determined by the @match callback.
and it does indeed return a reference-counted pointer to the device:
while ((dev = next_device(&i)))
if (match(dev, data) && get_device(dev))
break;
klist_iter_exit(&i);
return dev;
What that means is that when we're done with the struct device, we must
drop that reference. Neither of_phy_connect() nor of_phy_attach() did
this when phy_connect_direct() or phy_attach_direct() failed.
With our previous patch, phy_connect_direct() and phy_attach_direct()
take a new refcount on the phy device when successful, so we can drop
our local reference immediatley after these functions, whether or not
they succeeded.
Acked-by: Rob Herring <robh@kernel.org>
An SFP module may have a link up/down status pin which can be
connection to a GPIO line of the host. Add support for reading such an
GPIO in the fixed_phy driver.
Currently the PHY management type is selected by the MAC driver arbitrary.
The decision is based on the presence of the "fixed-link" node and on a
will of the driver's authors.
This caused a regression recently, when mvneta driver suddenly started
to use the in-band status for auto-negotiation on fixed links.
It appears the auto-negotiation may not work when expected by the MAC driver.
Sebastien Rannou explains:
<< Yes, I confirm that my HW does not generate an in-band status. AFAIK, it's
a PHY that aggregates 4xSGMIIs to 1xQSGMII ; the MAC side of the PHY (with
inband status) is connected to the switch through QSGMII, and in this context
we are on the media side of the PHY. >>
https://lkml.org/lkml/2015/7/10/206
This patch introduces the new string property 'managed' that allows
the user to set the management type explicitly.
The supported values are:
"auto" - default. Uses either MDIO or nothing, depending on the presence
of the fixed-link node
"in-band-status" - use in-band status
Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net>
CC: Rob Herring <robh+dt@kernel.org>
CC: Pawel Moll <pawel.moll@arm.com>
CC: Mark Rutland <mark.rutland@arm.com>
CC: Ian Campbell <ijc+devicetree@hellion.org.uk>
CC: Kumar Gala <galak@codeaurora.org>
CC: Florian Fainelli <f.fainelli@gmail.com>
CC: Grant Likely <grant.likely@linaro.org>
CC: devicetree@vger.kernel.org
CC: linux-kernel@vger.kernel.org
CC: netdev@vger.kernel.org
Some Ethernet PHY devices/switches may not properly release the MDIO bus
during turn-around time, and fail to drive it low, which can be seen by
some controllers as a read failure, while the data clocked in is still
correct.
Add a boolean property "broken-turn-around" which is parsed by the
generic MDIO bus probing code and will set the corresponding bit in the
MDIO bus phy_ignore_ta_mask bitmask for MDIO bus drivers to utilize that
information.
Export of_mdio_parse_addr() which allows parsing a given Ethernet PHY
node MDIO address, verify it is within the allowed range, and return
its value. This is going to be useful for the DSA code which needs to
deal with multiple layers of MDIO buses.
Adjust fixed_phy_register() to return struct phy_device *, so that
it becomes easy to use fixed PHYs without device tree support:
phydev = fixed_phy_register(PHY_POLL, &fixed_phy_status, NULL);
fixed_phy_set_link_update(phydev, fixed_phy_link_update);
phy_connect_direct(netdev, phydev, handler_fn, phy_interface);
This change is a prerequisite for modifying bcmgenet driver to work
without a device tree on Broadcom's MIPS-based 7xxx platforms.
Signed-off-by: Petri Gynther <pgynther@google.com>
Commit f9a8f83b04e0 ("net: phy: remove flags argument from phy_{attach,
connect, connect_direct}") removed the flags argument to the PHY library
calls to: phy_{attach,connect,connect_direct}.
Most Device Tree aware drivers call of_phy_connect() with the flag
argument set to 0, but some of them might want to set a different value
there in order for the PHY driver to key a specific behavior based on
the phy_device::phy_flags value.
Allow such drivers to set custom phy_flags as part of the
of_phy_connect() call since of_phy_connect() does start the PHY state
machine, it will call into the PHY driver config_init() callback which
is usually where a specific phy_flags value is important.
Fixes: f9a8f83b04e0 ("net: phy: remove flags argument from phy_{attach, connect, connect_direct}")
Commit 86f6cf4127 (net: of_mdio: add of_mdiobus_link_phydev()) introduced a
circular dependency between libphy and of_mdio.
depmod: ERROR: <modroot>/kernel/drivers/net/phy/libphy.ko in
dependency cycle!
depmod: ERROR: <modroot>/kernel/drivers/of/of_mdio.ko in dependency cycle!
The problem is that of_mdio.c references &mdio_bus_type and libphy now
references of_mdiobus_link_phydev.
Fix this by not exporting of_mdiobus_link_phydev() from of_mdio.ko.
Make it a static function in mdio_bus.c instead.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reported-by: Jeff Mahoney <jeffm@suse.com>
Fixes: 86f6cf4127 (net: of_mdio: add of_mdiobus_link_phydev())
Fixes commit 3be2a49e5c08 ("of: provide a binding for fixed link PHYs")
Fix the parsing of the new fixed link dts bindings for duplex,
pause, and asym_pause by using the correct device node pointer.
Signed-off-by: Richard Retanubun <rretanubun.work@gmail.com>
Make of_mdiobus_link_phydev externally available.
This fixes CONFIG_OF_MDIO=m.
Fixes: 86f6cf41272 ("net: of_mdio: add of_mdiobus_link_phydev()")
Use int rather than u32 to fix the following warning:
drivers/of/of_mdio.c:147 of_mdiobus_register() warn: unsigned 'addr' is
never less than zero.
Fixes: 8f8382888cba ("net: of_mdio: factor out code to parse a phy's 'reg' property")
of_get_property() can be called with NULL as 2nd argument if the caller
is not interested in the length of a property. Use that here so we can
get rid of a variable.
Add a function to walk the list of subnodes of a mdio bus and look for
a node that matches the phy's address with its 'reg' property. If found,
set the of_node pointer for the phy. This allows auto-probed pyh
devices to be augmented by information passed in via DT.
Factor out some logic into of_mdio_parse_addr() so it can be reused
later. While at it, use of_property_read_u32() rather than open-coding
the same logic again.
Commit de906af1 (net: phy: make of_set_phy_supported work with genphy driver)
removed the last user of variable 'max_speed' in function
of_mdiobus_register_phy(), leading to compile warning "unused variable
‘max_speed’ [-Wunused-variable]". Thus remove it.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
