path: root/drivers/of/of_reserved_mem.c
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-07-18of: use pr_fmt prefix for all console printingRob Herring
Clean-up all the DT printk functions to use common pr_fmt prefix. Some print statements such as kmalloc errors were redundant, so just drop those. Cc: Frank Rowand <frowand.list@gmail.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-07-08Merge tag 'v4.7-rc6' into patchworkMauro Carvalho Chehab
Linux 4.7-rc6 * tag 'v4.7-rc6': (1245 commits) Linux 4.7-rc6 ovl: warn instead of error if d_type is not supported MIPS: Fix possible corruption of cache mode by mprotect. locks: use file_inode() usb: dwc3: st: Use explicit reset_control_get_exclusive() API phy: phy-stih407-usb: Use explicit reset_control_get_exclusive() API phy: miphy28lp: Inform the reset framework that our reset line may be shared namespace: update event counter when umounting a deleted dentry 9p: use file_dentry() lockd: unregister notifier blocks if the service fails to come up completely ACPI,PCI,IRQ: correct operator precedence fuse: serialize dirops by default drm/i915: Fix missing unlock on error in i915_ppgtt_info() powerpc: Initialise pci_io_base as early as possible mfd: da9053: Fix compiler warning message for uninitialised variable mfd: max77620: Fix FPS switch statements phy: phy-stih407-usb: Inform the reset framework that our reset line may be shared usb: dwc3: st: Inform the reset framework that our reset line may be shared usb: host: ehci-st: Inform the reset framework that our reset line may be shared usb: host: ohci-st: Inform the reset framework that our reset line may be shared ...
2016-06-09[media] of: reserved_mem: restore old behavior when no region is definedMarek Szyprowski
Change return value back to -ENODEV when no region is defined for given device. This restores old behavior of this function, as some drivers rely on such error code. Fixes: 59ce4039727ef40 ("of: reserved_mem: add support for using more than one region for given device") Reported-by: Liviu Dudau <liviu.dudau@arm.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Rob Herring <robh@kernel.org> Reviewed-by: Sumit Semwal <sumit.semwal@linaro.org>
2016-06-03of: silence warnings due to max() usageStephen Rothwell
pageblock_order can be (at least) an unsigned int or an unsigned long depending on the kernel config and architecture, so use max_t(unsigned long ...) when comparing it. fixes these warnings: In file included from include/linux/list.h:8:0, from include/linux/kobject.h:20, from include/linux/of.h:21, from drivers/of/of_reserved_mem.c:17: drivers/of/of_reserved_mem.c: In function ‘__reserved_mem_alloc_size’: include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); \ ^ include/linux/kernel.h:747:9: note: in definition of macro ‘max’ typeof(y) _max2 = (y); \ ^ drivers/of/of_reserved_mem.c:131:48: note: in expansion of macro ‘max’ align = max(align, (phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_ord ^ include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); \ ^ include/linux/kernel.h:747:21: note: in definition of macro ‘max’ typeof(y) _max2 = (y); \ ^ drivers/of/of_reserved_mem.c:131:48: note: in expansion of macro ‘max’ align = max(align, (phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_ord ^ Fixes: 1cc8e3458b51 ("drivers: of: of_reserved_mem: fixup the alignment with CMA setup") Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03drivers: of: of_reserved_mem: fixup the CMA alignment not to affect dma-coherentJaewon
There was an alignment mismatch issue for CMA and it was fixed by commit 1cc8e3458b51 ("drivers: of: of_reserved_mem: fixup the alignment with CMA setup"). However the way of the commit considers not only dma-contiguous(CMA) but also dma-coherent which has no that requirement. This patch checks more to distinguish dma-contiguous(CMA) from dma-coherent. Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com> Acked-by: Jason Liu <r64343@freescale.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> [robh: remove erroneous opening bracket] Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03of: reserved_mem: add support for using more than one region for given deviceMarek Szyprowski
This patch allows device drivers to initialize more than one reserved memory region assigned to given device. When driver needs to use more than one reserved memory region, it should allocate child devices and initialize regions by index for each of its child devices. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
2016-03-03of: alloc anywhere from memblock if range not specifiedVinayak Menon
early_init_dt_alloc_reserved_memory_arch passes end as 0 to __memblock_alloc_base, when limits are not specified. But __memblock_alloc_base takes end value of 0 as MEMBLOCK_ALLOC_ACCESSIBLE and limits the end to memblock.current_limit. This results in regions never being placed in HIGHMEM area, for e.g. CMA. Let __memblock_alloc_base allocate from anywhere in memory if limits are not specified. Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org> Cc: stable@vger.kernel.org Signed-off-by: Rob Herring <robh@kernel.org>
2015-11-30of: Fix comparison of reserved memory regionsMichael Ellerman
In order to check for overlapping reserved memory regions, we first need to sort the array of memory regions. This is implemented using sort(), and a custom comparison function __rmem_cmp(). Unfortunatley __rmem_cmp() doesn't work in all cases. Because the two base values are phys_addr_t, they may be u64 on some platforms, in which case subtracting one from the other and then (implicitly) casting to int does not give us the -ve/0/+ve value we need. This leads to incorrect reports about overlaps, eg: ibm,slw-image@1ffe600000 (0x0000001ffe600000--0x0000001ffe700000) overlaps with ibm,firmware-allocs-memory@1000000000 (0x0000001000000000--0x0000001000dc0200) Fix it by just doing the standard double if and return 0 logic. Fixes: ae1add247bf8 ("of: Check for overlap in reserved memory regions") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Rob Herring <robh@kernel.org>
2015-11-10drivers: of: of_reserved_mem: fixup the alignment with CMA setupJason Liu
There is an alignment mismatch issue between the of_reserved_mem and the CMA setup requirement. The of_reserved_mem will try to get the alignment value from the DTS and pass it to __memblock_alloc_base to do the memory block base allocation, but the alignment value specified in the DTS may not satisfy the CAM setup requirement since CMA setup required the alignment as the following in the code: align = PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order); The sanity check in the function of rmem_cma_setup will fail if the alignment does not setup correctly and thus CMA will fail to setup. This patch is to fixup the alignment to meet the CMA setup required. Mailing-list-thread: https://lkml.org/lkml/2015/11/9/138 Signed-off-by: Jason Liu <r64343@freescale.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Rob Herring <robh@kernel.org>
2015-11-10of: Print rather than WARN'ing when overlap check failsMichael Ellerman
__rmem_check_for_overlap() is called very early in boot, and on some powerpc systems it's not safe to call WARN that early in boot. If the overlap check fails the system will oops instead of printing a warning. Furthermore because it's so early in boot the console is not up and the user doesn't see the oops, they just get a dead system. Fix it by printing an error instead of calling WARN. Fixes: ae1add247bf8 ("of: Check for overlap in reserved memory regions") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Rob Herring <robh@kernel.org>
2015-09-17of: Check for overlap in reserved memory regionsMitchel Humpherys
Any overlap in the reserved memory regions (those specified in the reserved-memory DT node) is a bug. These bugs might go undetected as long as the contested region isn't used simultaneously by multiple software agents, which makes such bugs hard to debug. Fix this by printing a scary warning during boot if overlap is detected. Signed-off-by: Mitchel Humpherys <mitchelh@codeaurora.org> Signed-off-by: Rob Herring <robh@kernel.org>
2015-01-13drivers: of: Export of_reserved_mem_device_{init,release}George G. Davis
Export of_reserved_mem_device_{init,release} so that modules can initialize and release their assigned per-device cma_area. Signed-off-by: George G. Davis <george_davis@mentor.com> [robh: s/EXPORT_SYMBOL/EXPORT_SYMBOL_GPL/] Signed-off-by: Rob Herring <robh@kernel.org>
2014-10-29drivers: of: add return value to of_reserved_mem_device_init()Marek Szyprowski
Driver calling of_reserved_mem_device_init() might be interested if the initialization has been successful or not, so add support for returning error code. This fixes a build warining caused by commit 7bfa5ab6fa1b ("drivers: dma-coherent: add initialization from device tree"), which has been merged without this change and without fixing function return value. Fixes: 7bfa5ab6fa1b1 ("drivers: dma-coherent: add initialization from device tree") Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Josh Cartwright <joshc@codeaurora.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-01drivers: of: add automated assignment of reserved regions to client devicesMarek Szyprowski
This patch adds code for automated assignment of reserved memory regions to struct device. reserved_mem->ops->device_init()/device_cleanup() callbacks are called to perform reserved memory driver specific initialization and cleanup Based on previous code provided by Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-05-20of: align RESERVEDMEM_OF_DECLARE function callbacks to other callbacksRob Herring
All the parameters for RESERVEDMEM_OF_DECLARE function callbacks are members of struct reserved_mem, so just pass the struct ptr to callback functions so the function callback is more in line with other OF match table callbacks. Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Rob Herring <robh@kernel.org>
2014-04-30of/fdt: update of_get_flat_dt_prop in prep for libfdtRob Herring
Make of_get_flat_dt_prop arguments compatible with libfdt fdt_getprop call in preparation to convert FDT code to use libfdt. Make the return value const and the property length ptr type an int. Signed-off-by: Rob Herring <robh@kernel.org> Tested-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Grant Likely <grant.likely@linaro.org> Tested-by: Stephen Chivers <schivers@csc.com>
2014-03-11drivers: of: add support for custom reserved memory driversMarek Szyprowski
Add support for custom reserved memory drivers. Call their init() function for each reserved region and prepare for using operations provided by them with by the reserved_mem->ops array. Based on previous code provided by Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2014-03-11drivers: of: add initialization code for dynamic reserved memoryMarek Szyprowski
This patch adds support for dynamically allocated reserved memory regions declared in device tree. Such regions are defined by 'size', 'alignment' and 'alloc-ranges' properties. Based on previous code provided by Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-15Revert "drivers: of: add initialization code for dma reserved memory"Marek Szyprowski
This reverts commit 9d8eab7af79cb4ce2de5de39f82c455b1f796963. There is still no consensus on the bindings for the reserved memory and various drawbacks of the proposed solution has been shown, so the best now is to revert it completely and start again from scratch later. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-09-10drivers: of: fix build break if asm/dma-contiguous.h is missingMarek Szyprowski
It is not needed to include asm/dma-contiguous.h header to compile reserved memory initialization code, so remove it to avoid build break on architectures without CMA support. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Guenter Roeck <linux@roeck-us.net>
2013-08-27drivers: of: add initialization code for dma reserved memoryMarek Szyprowski
This patch adds device tree support for contiguous and reserved memory regions defined in device tree. Large memory blocks can be reliably reserved only during early boot. This must happen before the whole memory management subsystem is initialized, because we need to ensure that the given contiguous blocks are not yet allocated by kernel. Also it must happen before kernel mappings for the whole low memory are created, to ensure that there will be no mappings (for reserved blocks) or mapping with special properties can be created (for CMA blocks). This all happens before device tree structures are unflattened, so we need to get reserved memory layout directly from fdt. Later, those reserved memory regions are assigned to devices on each device structure initialization. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Tomasz Figa <t.figa@samsung.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Rob Herring <rob.herring@calxeda.com>
