path: root/drivers/of/of_spi.c
2010-07-30of/spi: call of_register_spi_devices() from spi core codeAnatolij Gustschin
Move of_register_spi_devices() call from drivers to spi_register_master(). Also change the function to use the struct device_node pointer from master spi device instead of passing it as function argument. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-28of/irq: Move irq_of_parse_and_map() to common codeGrant Likely
Merge common code between PowerPC and Microblaze. SPARC implements irq_of_parse_and_map(), but the implementation is different, so it does not use this code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jeremy Kerr <jeremy.kerr@canonical.com>
2010-05-18of: eliminate of_device->node and dev_archdata->{of,prom}_nodeGrant Likely
This patch eliminates the node pointer from struct of_device and the of_node (or prom_node) pointer from struct dev_archdata since the node pointer is now part of struct device proper when CONFIG_OF is set, and all users of the old pointer locations have already been converted over to use device->of_node. Also remove dev_archdata_{get,set}_node() as it is no longer used by anything. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28driver-core: Add device node pointer to struct deviceGrant Likely
Currently, platforms using CONFIG_OF add a 'struct device_node *of_node' to dev->archdata. However, with CONFIG_OF becoming generic for all architectures, it makes sense for commonality to move it out of archdata and into struct device proper. This patch adds a struct device_node *of_node member to struct device and updates all locations which currently write the device_node pointer into archdata to also update dev->of_node. Subsequent patches will modify callers to use the archdata location and ultimately remove the archdata member entirely. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> CC: Michal Simek <monstr@monstr.eu> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: "David S. Miller" <davem@davemloft.net> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Jeremy Kerr <jeremy.kerr@canonical.com> CC: microblaze-uclinux@itee.uq.edu.au CC: linux-kernel@vger.kernel.org CC: linuxppc-dev@ozlabs.org CC: sparclinux@vger.kernel.org
2010-02-09of: assume big-endian properties, adding conversions where necessaryJeremy Kerr
Properties in the device tree are specified as big-endian. At present, the only platforms to support device trees are also big-endian, so we've been acessing the properties as raw values. We'd like to add device tree support to little-endian platforms too, so add endian conversion to the sites where we access property values in the common of code. Compiled on powerpc (ppc44x_defconfig & ppc64_defconfig) and arm (fdt support only for now). Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-10-20of/spi: Support specifying chip select as active high via device treeWolfgang Ocker
The patch allows to specify that an SPI device needs an active high chip select. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-25spi: Add OF binding support for SPI bussesGrant Likely
This patch adds support for populating an SPI bus based on data in the OF device tree. This is useful for powerpc platforms which use the device tree instead of discrete code for describing platform layout. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
