path: root/drivers/of
2011-05-25Merge branch 'devicetree/arm-next' of git://git.secretlab.ca/git/linux-2.6 ↵Russell King
into devel-stable
2011-05-11dt/flattree: explicitly pass command line pointer to early_init_dt_scan_chosenGrant Likely
This patch drops the reference to a global 'cmd_line' variable from early_init_dt_scan_chosen, and instead passes the pointer to the command line string via the *data argument. Each architecture does something slightly different with the initial command line, so it makes sense for the architecture to be able to specify the variable name. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-20of: Export of_irq_find_parent()Michael Ellerman
We have platform code that needs to find a node's interrupt parent, so export of_irq_find_parent() so we can use it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-23of/flattree: minor cleanupsAndres Salomon
- static-ize some functions - add some additional comments Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: eliminate OF_NO_DEEP_PROBE and test for NULL match tableGrant Likely
There are no users of OF_NO_DEEP_PROBE, and of_match_node() now gracefully handles being passed a NULL pointer, so the checks at the top of of_platform_bus_probe can be dropped. While at it, consolidate the root node pointer check to be easier to read and tidy up related comments. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: protect against NULL matches passed to of_match_node()Grant Likely
There are a few use cases where it is convenient to pass NULL to of_match_node() and have it fail gracefully. The patch adds a null check to the beginning so taht it does so. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: Refactor of_platform_bus_probe()Grant Likely
The current implementation uses three copies of of basically identical code. This patch consolidates them to make the code simpler. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-02of/promtree: allow DT device matching by fixing 'name' brokenness (v5)Andres Salomon
Commit e2f2a93b, "of/promtree: add package-to-path support to pdt" changed dp->name from using the 'name' property to using package-to-path. This fixed /proc/device-tree creation by eliminating conflicts between names (the 'name' property provides names like 'battery', whereas package-to-path provides names like '/foo/bar/battery@0', which we stripped to 'battery@0'). However, it also breaks of_device_id table matching. The fix that we _really_ wanted was to keep dp->name based upon the name property ('battery'), but based dp->full_name upon package-to-path ('battery@0'). This patch does just that. This changes all users (except SPARC) of promtree to use the full result from package-to-path for full_name, rather than stripping the directory out. In practice, the strings end up being exactly the same; this change saves time, code, and memory. SPARC continues to use the existing build_path_component() code. v2: combine two patches and revert of_pdt_node_name to original version v3: use dp->phandle instead of passing around node v4: warn/bail out for non-sparc archs if pkg2path is not set v5: split of_pdt_build_full_name into sparc & non-sparc versions v6: Pass NULL to pkg2path before buf gets assigned. Drop check for pkg2path hook on each and every node. v7: Don't BUG() when unable to get the full_path; create a known-unique name instead. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-01dt: eliminate of_platform_driver shim codeGrant Likely
Commit eca393016, "of: Merge of_platform_bus_type with platform_bus_type" added a shim to allow of_platform_drivers to get registers onto the platform bus so that there was time to migrate the existing drivers to the platform_bus_type. This patch removes the shim since there are no more users of the old interface. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-28dt/powerpc: move of_bus_type infrastructure to ibmebusGrant Likely
arch/powerpc/kernel/ibmebus.c is the only remaining user of the of_bus_type support code for initializing the bus and registering drivers. All others have either been switched to the vanilla platform bus or already have their own infrastructure. This patch moves the functionality that ibmebus is using out of drivers/of/{platform,device}.c and into ibmebus.c where it is actually used. Also renames the moved symbols from of_platform_* to ibmebus_bus_* to reflect the actual usage. This patch is part of moving all of the of_platform_bus_type users over to the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-23x86: dtb: Add support for PCI devices backed by dtb nodesSebastian Andrzej Siewior
x86_of_pci_init() does two things: - it provides a generic irq enable and disable function. enable queries the device tree for the interrupt information, calls ->xlate on the irq host and updates the pci->irq information for the device. - it walks through PCI bus(es) in the device tree and adds its children (device) nodes to appropriate pci_dev nodes in kernel. So the dtb node information is available at probe time of the PCI device. Adding a PCI bus based on the information in the device tree is currently not supported. Right now direct access via ioports is used. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Tested-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org LKML-Reference: <1298405266-1624-8-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-04of/pci: move of_irq_map_pci() into generic codeSebastian Andrzej Siewior
There is a tiny difference between PPC32 and PPC64. Microblaze uses the PPC32 variant. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> [grant.likely@secretlab.ca: Added comment to #endif, moved documentation block to function implementation, fixed for non ppc and microblaze compiles] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-15dt/flattree: Return virtual address from early_init_dt_alloc_memory_arch()Grant Likely
The physical address is never used by the device tree code when allocating memory for unflattening. Change the architecture's alloc hook to return the virutal address instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-10Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits) of/flattree: forward declare struct device_node in of_fdt.h ipmi: explicitly include of_address.h and of_irq.h sparc: explicitly cast negative phandle checks to s32 powerpc/405: Fix missing #{address,size}-cells in i2c node powerpc/5200: dts: refactor dts files powerpc/5200: dts: Change combatible strings on localbus powerpc/5200: dts: remove unused properties powerpc/5200: dts: rename nodes to prepare for refactoring dts files of/flattree: Update dtc to current mainline. of/device: Don't register disabled devices powerpc/dts: fix syntax bugs in bluestone.dts of: Fixes for OF probing on little endian systems of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF of/flattree: Add of_flat_dt_match() helper function of_serial: explicitly include of_irq.h of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree of/flattree: Reorder unflatten_dt_node of/flattree: Refactor unflatten_dt_node of/flattree: Add non-boottime device tree functions of/flattree: Add Kconfig for EARLY_FLATTREE ... Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
2011-01-03of/device: Don't register disabled devicesGrant Likely
Device nodes with the property status="disabled" are not usable and so don't register them when parsing the device tree for devices. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Hollis Blanchard <hollis_blanchard@mentor.com> Cc: Deepak Saxena <deepak_saxena@mentor.com> Cc: Scott Wood <scottwood@freescale.com>, Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-01of/flattree: Add of_flat_dt_match() helper functionGrant Likely
This patch adds of_flat_dt_match() which tests a node for compatibility with a list of values and converts the relevant powerpc platform code to use it. This approach simplifies the board support code a bit. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
2010-12-29of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_treeStephen Neuendorffer
unflatten_device_tree has two dependencies on things that happen during boot time. Firstly, it references the initial device tree directly. Secondly, it allocates memory using the early boot allocator. This patch factors out these dependencies and uses the new __unflatten_device_tree function to implement a driver-visible fdt_unflatten_tree function, which can be used to unflatten a blob after boot time. V2: - remove extra __va() call - make dt_alloc functions return void *. This doesn't fix the general strangeness in this code that constantly casts back and forth between unsigned long and __be32 * Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Reorder unflatten_dt_nodeStephen Neuendorffer
Move unflatten_dt_node to be grouped with non-__init functions. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Refactor unflatten_dt_nodeStephen Neuendorffer
unflatten_dt_node is a helper function that does most of the work to convert a device tree blob into tree of device nodes. This code now uses a passed-in blob instead of using the single boot-time blob, allowing it to be called in more contexts. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Add non-boottime device tree functionsStephen Neuendorffer
In preparation for providing run-time handling of device trees, factor out some of the basic functions so that they take an arbitrary blob, rather than relying on the single boot-time tree. V2: - functions have of_fdt_* names - removed find_flat_dt_string - blob argument is first Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Add Kconfig for EARLY_FLATTREEStephen Neuendorffer
The device tree code is now in two pieces: some which can be used generically on any platform which selects CONFIG_OF_FLATTREE, and some early which is used at boot time on only a few architectures. This patch segregates the early code so that only those architectures which care about it need compile it. This also means that some of the requirements in the early code (such as a cmd_line variable) that most architectures (e.g. X86) don't provide can be ignored. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> [grant.likely@secretlab.ca: remove extra blank line addition] [grant.likely@secretlab.ca: fixed incorrect #ifdef CONFIG_EARLY_FLATTREE check] [grant.likely@secretlab.ca: Made OF_EARLY_FLATTREE select instead of depend on OF_FLATTREE] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-24of/i2c: Fix request module by aliasDavid Daney
If we are registering an i2c device that has a device tree node like this real-world example: rtc@68 { compatible = "dallas,ds1337"; reg = <0x68>; }; of_i2c_register_devices() will try to load a module called ds1337.ko. There is no such module, so it will fail. If we look in modules.alias we will find entries like these: . . . alias i2c:ds1339 rtc_ds1307 alias i2c:ds1338 rtc_ds1307 alias i2c:ds1337 rtc_ds1307 alias i2c:ds1307 rtc_ds1307 alias i2c:ds1374 rtc_ds1374 . . . The module we want is really called rtc_ds1307.ko. If we request a module called "i2c:ds1337", the userspace module loader will do the right thing (unless it is busybox) and load rtc_ds1307.ko. So we add the I2C_MODULE_PREFIX to the request_module() string. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-24of/mdio: Fix some endianness problems.David Daney
In of_mdiobus_register(), the __be32 *addr variable is dereferenced. This will not work on little-endian targets. Also since it is unsigned, checking for less than zero is redundant. Fix these two issues. Signed-off-by: David Daney <ddaney@caviumnetworks.com> [grant.likely@secretlab.ca: removed goto] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-23of/address: use proper endianess in get_flagsSebastian Andrzej Siewior
This patch changes u32 to __be32 for all "ranges", "prop" and "addr" and such. Those variables are pointing to the device tree which contains integers in big endian format. Most functions are doing it right because of_read_number() is doing the right thing for them. of_bus_isa_get_flags(), of_bus_pci_get_flags() and of_bus_isa_map() were accessing the data directly and were doing it wrong. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-11-01of/net: Move of_get_mac_address() to a common source file.David Daney
There are two identical implementations of of_get_mac_address(), one each in arch/powerpc/kernel/prom_parse.c and arch/microblaze/kernel/prom_parse.c. Move this function to a new common file of_net.{c,h} and adjust all the callers to include the new header. Signed-off-by: David Daney <ddaney@caviumnetworks.com> [grant.likely@secretlab.ca: protect header with #ifdef] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21of/mips: Cleanup some include directives/files.David Daney
The __init directives should go on the definitions of things, not the declaration, also __init is meaningless for inline functions, so remove it from prom.h. This allows us to get rid of a useless #include, but most of the rest of them are useless too, so kill them as well. If of_i2c.c needs irq definitions, it should include linux/irq.h directly, not assume indirect inclusion via asm/prom.h. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21of/flattree: Eliminate need to provide early_init_dt_scan_chosen_archGrant Likely
This patch refactors the early init parsing of the chosen node so that architectures aren't forced to provide an empty implementation of early_init_dt_scan_chosen_arch. Instead, if an architecture wants to do something different, it can either use a wrapper function around early_init_dt_scan_chosen(), or it can replace it altogether. This patch was written in preparation to adding device tree support to both x86 ad MIPS. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: David Daney <ddaney@caviumnetworks.com>
2010-10-21of/device: Rework to use common platform_device_alloc() for allocating devicesGrant Likely
The current code allocates and manages platform_devices created from the device tree manually. It also uses an unsafe shortcut for allocating the platform_device and the resource table at the same time. (which I added in the last rework; sorry). This patch refactors the code to use platform_device_alloc() for allocating new devices. This reduces the amount of custom code implemented by of_platform, eliminates the unsafe alloc trick, and has the side benefit of letting the platform_bus code manage freeing the device data and resources when the device is freed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michal Simek <monstr@monstr.eu>
2010-10-12of: use __be32 types for big-endian device tree dataJeremy Kerr
Use the sparse annotations so we can keep track of endianness. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12of/irq: remove references to NO_IRQ in drivers/of/platform.cAndres Salomon
Instead of referencing NO_IRQ in platform.c, define some helper functions in irq.c to call instead from platform.c. Keep NO_IRQ usage local to irq.c, and define NO_IRQ if not defined in headers. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12of/promtree: add package-to-path support to pdtAndres Salomon
package-to-path is a PROM function which tells us the real (full) name of the node. This provides a hook for that in the prom ops struct, and makes use of it in the pdt code when attempting to determine a node's name. If the hook is available, try using it (falling back to looking at the "name" property if it fails). Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12of/promtree: add of_pdt namespace to pdt codeAndres Salomon
For symbols still lacking namespace qualifiers, add an of_pdt_ prefix. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12of/promtree: no longer call prom_ functions directly; use an ops structureAndres Salomon
Rather than assuming an architecture defines prom_getchild and friends, define an ops struct with hooks for the various prom functions that pdt.c needs. This ops struct is filled in by the arch-(and sometimes firmware-)specific code, and passed to of_pdt_build_devicetree. Update sparc code to define the ops struct as well. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-10of/promtree: make drivers/of/pdt.c no longer sparc-onlyAndres Salomon
Clean up pdt.c: - make build dependent upon config OF_PROMTREE - #ifdef out the sparc-specific stuff - create pdt-specific header Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-09sparc: break out some PROM device-tree building code out into drivers/ofAndres Salomon
Transitioning into making this useful for architectures other than sparc. This is a verbatim copy of all functions/variables that've been moved. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-01of/platform: Register of_platform_drivers with an "of:" prefixGrant Likely
Currently there are some drivers in tree which register both a platform_driver and an of_platform_driver with the same name. This is a temporary situation until all the relevant of_platform_drivers are converted to be normal platform_drivers. Until then, this patch gives all the of_platform_drivers an "of:" prefix to protect against bogus matches and namespace conflicts.
2010-07-30of/spi: call of_register_spi_devices() from spi core codeAnatolij Gustschin
Move of_register_spi_devices() call from drivers to spi_register_master(). Also change the function to use the struct device_node pointer from master spi device instead of passing it as function argument. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-30of/device: Make of_device_make_bus_id() usable by other code.Grant Likely
The AMBA bus should also use of_device_make_bus_id() when populating device out of device tree data. This patch makes the function non-static, and adds a suitable prototype in of_device.h Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of/irq: Fix endian issues in parsing interrupt specifiersGrant Likely
This patch fixes some instances where interrupt specifiers are dereferenced directly instead of doing a be32_to_cpu() conversion first. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: Fix phandle endian issuesGrant Likely
The flat tree code wasn't fixing the endianness on phandle values when unflattening the tree, and the code in drivers/of wasn't always doing a be32_to_cpu before trying to dereference the phandle values. This patch fixes them. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of/flattree: fix of_flat_dt_is_compatible() to match the full compatible stringStuart Yoder
With the current string comparison, a device tree compatible of "foo-bar" would match as compatible with a driver looking for "foo". This patch fixes the function to use the of_compat_cmp() macro so that it does the right thing on all platforms (If sparc ever uses this code, it will still want the strncasecmp() behaviour). Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: remove of_default_bus_idsJonas Bonn
This list used was by only two platforms with all other platforms defining an own list of valid bus id's to pass to of_platform_bus_probe. This patch: i) copies the default list to the two platforms that depended on it (powerpc) ii) remove the usage of of_default_bus_ids in of_platform_bus_probe iii) removes the definition of the list from all architectures that defined it Passing a NULL 'matches' parameter to of_platform_bus_probe is still valid; the function returns no error in that case as the NULL value is equivalent to an empty list. Signed-off-by: Jonas Bonn <jonas@southpole.se> [grant.likely@secretlab.ca: added __initdata annotations, warn on and return error on missing match table, and fix whitespace errors] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: make of_find_device_by_node genericJonas Bonn
There's no need for this function to be architecture specific and all four architectures defining it had the same definition. The function has been moved to drivers/of/platform.c. Signed-off-by: Jonas Bonn <jonas@southpole.se> [grant.likely@secretlab.ca: moved to drivers/of/platform.c, simplified code, and added kerneldoc comment] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of/device: Replace of_device with platform_device in includes and core codeGrant Likely
of_device is currently just an #define alias to platform_device until it gets removed entirely. This patch removes references to it from the include directories and the core drivers/of code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of/device: Protect against binding of_platform_drivers to non-OF devicesGrant Likely
There is an unlikely chance of this situation is occurring, but it is easy to protect against. If a matching entry cannot be found in the of_match_table, then don't bind the driver. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: Merge of_platform_bus_type with platform_bus_typeGrant Likely
of_platform_bus was being used in the same manner as the platform_bus. The only difference being that of_platform_bus devices are generated from data in the device tree, and platform_bus devices are usually statically allocated in platform code. Having them separate causes the problem of device drivers having to be registered twice if it was possible for the same device to appear on either bus. This patch removes of_platform_bus_type and registers all of_platform bus devices and drivers on the platform bus instead. A previous patch made the of_device structure an alias for the platform_device structure, and a shim is used to adapt of_platform_drivers to the platform bus. After all of of_platform_bus drivers are converted to be normal platform drivers, the shim code can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
