Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
All arches do essentially the same thing now for
early_init_dt_setup_initrd_arch, so it can now be removed.
arch/arm/mm/init.c
arch/c6x/kernel/devicetree.c
arch/powerpc/kernel/prom.c
(cherry picked from commit 29eb45a9ab4839a1e9cef2bcf369b918c9c4fcad)
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: x86@kernel.org
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
Change-Id: I84b59cec16fa7e96fa8ff3de04aa959f7039a7a9
Create a weak version of early_init_dt_add_memory_arch which uses
memblock. This will unify all architectures except ones with custom
memory bank structs.
arch/openrisc/kernel/prom.c
(cherry picked from commit 068f6310b965d67d57f89ebf4c539e5933754366)
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: microblaze-uclinux@itee.uq.edu.au
Cc: linux@lists.openrisc.net
Cc: devicetree@vger.kernel.org
Change-Id: I8f3bd8d9d0816666cf90363e16f596b365db4632
Most architectures scan the all the same items early in the FDT and none
are really architecture specific. Create a common early_init_dt_scan to
unify the early scan of root, memory, and chosen nodes in the flattened
DT.
(cherry picked from commit 0288ffcbfdf9b8656e7320c24caa1e4c1d498287)
Change-Id: I56ce372cc740ab11a8828d11bf8e508069bdac88
Most architectures use the same implementation. Collapse the common ones
into a single weak function that can be overridden.
(cherry picked from commit a1727da599ad030ccaf4073473fd235c8ee28219)
Change-Id: I5cfcac67b98407f8e4c4dcb89829f2a8e0d1b88b
Signed-off-by: Grant Likely <grant.likely@linaro.org>
On some PAE architectures, the entire range of physical memory could reside
outside the 32-bit limit. These systems need the ability to specify the
initrd location using 64-bit numbers.
This patch globally modifies the early_init_dt_setup_initrd_arch() function to
use 64-bit numbers instead of the current unsigned long.
There has been quite a bit of debate about whether to use u64 or phys_addr_t.
It was concluded to stick to u64 to be consistent with rest of the device
tree code. As summarized by Geert, "The address to load the initrd is decided
by the bootloader/user and set at that point later in time. The dtb should not
be tied to the kernel you are booting"
More details on the discussion can be found here:
https://lkml.org/lkml/2013/6/20/690
https://lkml.org/lkml/2012/9/13/544
(cherry picked from commit 374d5c9964c10373ba39bbe934f4262eb87d7114)
Change-Id: Iab36378e1de4e6c2cb07a3b88aeb5ff4afbe535b
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
strlcat takes the size of the buffer, not the number of characters
to concatenate. If the size of the device tree command line p is
larger than the CONFIG_CMDLINE string data, then strcat(data, p, l)
will hit a BUG_ON because strlen(data) > l.
Replace the second strlcat with a strncpy plus a manual null
termination.
Also rearrange the code to reduce indent depth to make it more
readable, and replace data with a char *cmdline to avoid extra
casts.
Signed-off-by: Colin Cross <ccross@android.com>
The old logic assumes CMDLINE_FROM_BOOTLOADER vs. CMDLINE_FORCE and
ignores CMDLINE_EXTEND. Here's the old logic:
- CONFIG_CMDLINE_FORCE=true
CONFIG_CMDLINE
- dt bootargs=non-empty:
dt bootargs
- dt bootargs=empty, @data is non-empty string
@data is left unchanged
- dt bootargs=empty, @data is empty string
CONFIG_CMDLINE (or "" if that's not defined)
The new logic is now documented in of_fdt.h and is copied here for
reference:
CONFIG_CMDLINE
- CONFIG_CMDLINE_EXTEND=true, @data is non-empty string
@data + dt bootargs (even if dt bootargs are empty)
- CONFIG_CMDLINE_EXTEND=true, @data is empty string
CONFIG_CMDLINE + dt bootargs (even if dt bootargs are empty)
- CMDLINE_FROM_BOOTLOADER=true, dt bootargs=non-empty:
dt bootargs
- CMDLINE_FROM_BOOTLOADER=true, dt bootargs=empty, @data is non-empty string
- CMDLINE_FROM_BOOTLOADER=true, dt bootargs=empty, @data is empty string
Signed-off-by: Doug Anderson <dianders@chromium.org>
CC: devicetree-discuss@lists.ozlabs.org
CC: Grant Likely <grant.likely@secretlab.ca>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Rob Herring <rob.herring@calxeda.com>
Change-Id: I40ace250847f813358125dfcaa8998fd32cf7ea3
commit 14e2abb732e485ee57d9d5b2cb8884652238e5c1 upstream.
On IBM pseries systems the device_type device-tree property of a PCIe
bridge contains the string "pciex". The of_bus_pci_match() function was
looking only for "pci" on this property, so in such cases the bus
matching code was falling back to the default bus, causing problems on
functions that should be using "assigned-addresses" for region address
translation. This patch fixes the problem by also looking for "pciex" on
the PCI bus match function.
v2: added comment
Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit 13fcca8f25f4e9ce7f55da9cd353bb743236e212 upstream.
This reverts commit e38c0a1fbc5803cbacdaac0557c70ac8ca5152e7.
Nikita Yushchenko reports:
While trying to make freescale p2020ds and mpc8572ds boards working
with mainline kernel, I faced that commit e38c0a1f (Handle
Both these boards have uli1575 chip.
Corresponding part in device tree is something like
uli1575@0 {
reg = <0x0 0x0 0x0 0x0 0x0>;
#size-cells = <2>;
#address-cells = <3>;
ranges = <0x2000000 0x0 0x80000000
0x0 0x20000000
0x1000000 0x0 0x0
0x1000000 0x0 0x0
0x0 0x10000>;
isa@1e {
I.e. it has #address-cells = <3>
With commit e38c0a1f reverted, devices under uli1575 are registered
correctly, e.g. for rtc
OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 **
OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e
OF: translating address: 00000001 00000070
OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0
OF: walking ranges...
OF: ISA map, cp=0, s=1000, da=70
OF: parent translation for: 01000000 00000000 00000000
OF: with offset: 70
OF: one level translation: 00000000 00000000 00000070
OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0
OF: default map, cp=a0000000, s=20000000, da=70
OF: default map, cp=0, s=10000, da=70
OF: with offset: 70
OF: one level translation: 01000000 00000000 00000070
OF: PCI map, cp=0, s=10000, da=70
OF: with offset: 70
OF: parent bus is default (na=2, ns=2) on /
OF: parent translation for: 00000000 ffc10000
OF: with offset: 70
OF: one level translation: 00000000 ffc10070
OF: reached root node
With commit e38c0a1f in place, address translation fails:
OF: with offset: 70
OF: not found !
Thierry Reding confirmed this commit was not needed after all:
"We ended up merging a different address representation for Tegra PCIe
and I've confirmed that reverting this commit doesn't cause any obvious
regressions. I think all other drivers in drivers/pci/host ended up
copying what we did on Tegra, so I wouldn't expect any other breakage
either."
There doesn't appear to be a simple way to support both behaviours, so
reverting this as nothing should be depending on the new behaviour.
commit 0640332e073be9207f0784df43595c0c39716e42 upstream.
Any calls to dt_alloc() need to be zeroed. This is a temporary fix, but
the allocation function itself needs to zero memory before returning
it. This is a follow up to patch 9e4012752, "of: fdt: fix memory
initialization for expanded DT" which fixed one call site but missed
another.
Acked-by: Wladislav Wiebe <wladislav.kw@gmail.com>
commit 9e40127526e857fa3f29d51e83277204fbdfc6ba upstream.
Already existing property flags are filled wrong for properties created from
initial FDT. This could cause problems if this DYNAMIC device-tree functions
are used later, i.e. properties are attached/detached/replaced. Simply dumping
flags from the running system show, that some initial static (not allocated via
kzmalloc()) nodes are marked as dynamic.
I putted some debug extensions to property_proc_show(..) :
+ if (OF_IS_DYNAMIC(pp))
+ pr_err("DEBUG: xxx : OF_IS_DYNAMIC\n");
+ if (OF_IS_DETACHED(pp))
+ pr_err("DEBUG: xxx : OF_IS_DETACHED\n");
when you operate on the nodes (e.g.: ~$ cat /proc/device-tree/*some_node*) you
will see that those flags are filled wrong, basically in most cases it will dump
a DYNAMIC or DETACHED status, which is in not true.
(BTW. this OF_IS_DETACHED is a own define for debug purposes which which just
make a test_bit(OF_DETACHED, &x->_flags)
If nodes are dynamic kernel is allowed to kfree() them. But it will crash
attempting to do so on the nodes from FDT -- they are not allocated via
kzmalloc().
Signed-off-by: Wladislav Wiebe <wladislav.kw@gmail.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
commit 6dd18e4684f3d188277bbbc27545248487472108 upstream.
Commit:
of/address: Handle #address-cells > 2 specially
broke real time clock access on Bimini, js2x, and similar powerpc
machines using the "maple" platform. That code was indirectly relying
on the old (broken) behaviour of the translation for the hypertransport
to ISA bridge.
This fixes it by treating hypertransport as a PCI bus
Cc: Jonghwan Choi <jhbird.choi@gmail.com>
The OF code uses irqsafe locks everywhere except in a handful of functions
for no obvious reasons. Since the conversion from the old rwlocks, this
now triggers lockdep warnings when used at interrupt time. At least one
driver (ibmvscsi) seems to be doing that from softirq context.
This converts the few non-irqsafe locks into irqsafe ones, making them
consistent with the rest of the code.
Pull device tree fixes from Grant Likely:
"Device tree bug fixes and documentation updates for v3.10
Nothing earth shattering here. A build failure fix, and fix for
releasing nodes and some documenation updates."
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux:
Documentation/devicetree: make semantic of initrd-end more explicit
of/base: release the node correctly in of_parse_phandle_with_args()
of/documentation: move video device bindings to a common place
<linux/of_platform.h>: fix compilation warnings with DT disabled
of_mdiobus_register creates a phy_device even if get_phy_device failed
to create it previously. This causes indefinite polling on non-existent
PHYs. This fix makes of_mdio_register rely on get_phy_device to
properly create the device or fail otherwise.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Pull ARM SoC driver changes from Olof Johansson:
"This is a rather large set of patches for device drivers that for one
reason or another the subsystem maintainer preferred to get merged
through the arm-soc tree. There are both new drivers as well as
existing drivers that are getting converted from platform-specific
code into standalone drivers using the appropriate subsystem specific
interfaces.
In particular, we can now have pinctrl, clk, clksource and irqchip
drivers in one file per driver, without the need to call into platform
specific interface, or to get called from platform specific code, as
long as all information about the hardware is provided through a
device tree.
Most of the drivers we touch this time are for clocksource. Since now
most of them are part of drivers/clocksource, I expect that we won't
have to touch these again from arm-soc and can let the clocksource
maintainers take care of these in the future.
Another larger part of this series is specific to the exynos platform,
which is seeing some significant effort in upstreaming and
modernization of its device drivers this time around, which
unfortunately is also the cause for the churn and a lot of the merge
conflicts.
There is one new subsystem that gets merged as part of this series:
the reset controller interface, which is a very simple interface for
taking devices on the SoC out of reset or back into reset. Patches to
use this interface on i.MX follow later in this merge window, and we
are going to have other platforms (at least tegra and sirf) get
converted in 3.11. This will let us get rid of platform specific
callbacks in a number of platform independent device drivers."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits)
irqchip: s3c24xx: add missing __init annotations
ARM: dts: Disable the RTC by default on exynos5
clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3}
ARM: exynos: restore mach/regs-clock.h for exynos5
clocksource: exynos_mct: fix build error on non-DT
pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register()
irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure
reset: NULL deref on allocation failure
reset: Add reset controller API
dt: describe base reset signal binding
ARM: EXYNOS: Add arm-pmu DT binding for exynos421x
ARM: EXYNOS: Add arm-pmu DT binding for exynos5250
ARM: EXYNOS: Enable PMUs for exynos4
irqchip: exynos-combiner: Correct combined IRQs for exynos4
irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: tegra: fix enum tegra114_clk to match binding
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Supply a function (proc_remove()) to remove a proc entry (and any subtree
rooted there) by proc_dir_entry pointer rather than by name and (optionally)
root dir entry pointer. This allows us to eliminate all remaining pde->name
accesses outside of procfs.
Acked-by: Grant Likely <grant.likely@linaro.or>
cc: linux-acpi@vger.kernel.org
cc: openipmi-developer@lists.sourceforge.net
cc: devicetree-discuss@lists.ozlabs.org
cc: linux-pci@vger.kernel.org
cc: netdev@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
Currently modular V4L2 build with enabled OF is broken dur to the
of_get_next_parent() function being unavailable to modules. Export it to
fix the build.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Call of_node_put() only when the out_args is NULL on success,
or the node's reference count will not be correct because the caller
will call of_node_put() again.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
[grant.likely: tightened up the patch]
Using DT for mdiobus and ethernet-phy requires to know the PHY address, which
is hard to guess if you don't know it. This patch extends of_mdiobus_register
to scan mdiobus for PHYs if reg property of the corresponding node is not set.
This also allows to have phy nodes in SoC DT files where the reg property can
be overwritten in the board file later. To encourage people to finally set the
actual phy address, the mdiobus scan is noisier than required.
Several functions in of/base.c have the same code duplicated for
finding and validating a property and value.
struct property *prop = of_find_property(np, propname, NULL);
if (!prop)
return -EINVAL;
if (!prop->value)
return -ENODATA;
if (<some length> > prop->length)
return -EOVERFLOW;
This patch adds of_find_property_value_of_size() which performs the
equivalent of the above code and removes the instances where it was
duplicated in several functions.
Reported-by: Rob Herring <robherring2@gmail.com>
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
This patch adds an of_property_read_u32_index() function to allow
reading a single indexed u32 value from a property containing multiple
u32 values.
Acked-by: Rob Herring <robherring2@gmail.com>
Pull trivial tree from Jiri Kosina:
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
Pull networking update from David Miller:
1) Checkpoint/restarted TCP sockets now can properly propagate the TCP
timestamp offset. From Andrey Vagin.
2) VMWARE VM VSOCK layer, from Andy King.
3) Much improved support for virtual functions and SR-IOV in bnx2x,
from Ariel ELior.
4) All protocols on ipv4 and ipv6 are now network namespace aware, and
all the compatability checks for initial-namespace-only protocols is
removed. Thanks to Tom Parkin for helping deal with the last major
holdout, L2TP.
5) IPV6 support in netpoll and network namespace support in pktgen,
from Cong Wang.
6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration
Protocol (MVRP) support, from David Ward.
7) Compute packet lengths more accurately in the packet scheduler, from
Eric Dumazet.
8) Use per-task page fragment allocator in skb_append_datato_frags(),
also from Eric Dumazet.
9) Add support for connection tracking labels in netfilter, from
Florian Westphal.
10) Fix default multicast group joining on ipv6, and add anti-spoofing
checks to 6to4 and 6rd. From Hannes Frederic Sowa.
11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern
times, rearrange inet frag datastructures for better cacheline
locality, and move more operations outside of locking. From Jesper
Dangaard Brouer.
12) Instead of strict master <--> slave relationships, allow arbitrary
scenerios with "upper device lists". From Jiri Pirko.
13) Improve rate limiting accuracy in TBF and act_police, also from Jiri
Pirko.
14) Add a BPF filter netfilter match target, from Willem de Bruijn.
15) Orphan and delete a bunch of pre-historic networking drivers from
Paul Gortmaker.
16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although
this still needs some minor bug fixing before it's %100 correct in
all cases.
17) Handle unresolved IPSEC states like ARP, with a resolution packet
queue. From Steffen Klassert.
18) Remove TCP Appropriate Byte Count support (ABC), from Stephen
Hemminger. This was long overdue.
19) Support SO_REUSEPORT, from Tom Herbert.
20) Allow locking a socket BPF filter, so that it cannot change after a
process drops capabilities.
21) Add VLAN filtering to bridge, from Vlad Yasevich.
22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in
the ipv6 routes, from YOSHIFUJI Hideaki.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits)
ipv6: fix race condition regarding dst->expires and dst->from.
net: fix a wrong assignment in skb_split()
ip_gre: remove an extra dst_release()
ppp: set qdisc_tx_busylock to avoid LOCKDEP splat
atl1c: restore buffer state
net: fix a build failure when !CONFIG_PROC_FS
net: ipv4: fix waring -Wunused-variable
net: proc: fix build failed when procfs is not configured
Revert "xen: netback: remove redundant xenvif_put"
net: move procfs code to net/core/net-procfs.c
qmi_wwan, cdc-ether: add ADU960S
bonding: set sysfs device_type to 'bond'
bonding: fix bond_release_all inconsistencies
b44: use netdev_alloc_skb_ip_align()
net: fec: Do a sanity check on the gpio number
ip_gre: propogate target device GSO capability to the tunnel device
ip_gre: allow CSUM capable devices to handle packets
bonding: Fix initialize after use for 3ad machine state spinlock
bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate()
This reverts commit aac73f34542bc7ae4317928d2eabfeb21d247323. That
commit causes two kinds of breakage; it breaks registration of AMBA
devices when one of the parent nodes already contains overlapping
resource regions, and it breaks calls to request_region() by device
drivers in certain conditions where there are overlapping memory
regions. Both of these problems can probably be fixed, but it is better
to back out the commit and get a proper fix designed before trying again.
This patch creates of_count_phandle_with_args(), a new function for
counting the number of phandle+argument tuples in a given property. This
is better than the existing method of parsing each phandle individually
until parsing fails which is a horribly slow way to do the count.
Tested on ARM using the selftest code.
v3: - Rebased on top of selftest code cleanup patch
v2: - fix bug where of_parse_phandle_with_args() could behave like _count_.
- made of_gpio_named_count() into a static inline regardless of CONFIG_OF_GPIO
Tested-by: Andreas Larsson <andreas@gaisler.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Some of the exit paths were not correctly releasing the node. Fix it by
creating an 'err' label for collecting the error paths and releasing the
node.
Some of the selftests are open-coded. Others use the selftest() macro
defined in drivers/of/selftest.c. The macro makes for cleaner selftest
code, so refactor the of_parse_phandle_with_args() tests to use it.
The of_gpio_named_count() self test doesn't hit the out-of-range
condition even though it is coded. Fix the bug by increasing the for
loop range by one.
Reported-by: Andreas Larsson <andreas@gaisler.com>
of_get_next_available_child() acquires devtree_lock, then calls
of_device_is_available() which calls of_get_property() which calls
of_find_property() which tries to re-acquire devtree_lock, thus causing
deadlock.
To avoid this, create a new __of_device_is_available() which calls
__of_get_property() instead, which calls __of_find_property(), which
does not take the lock,. Update of_get_next_available_child() to call
the new __of_device_is_available() since it already owns the lock.
With the locking cleanup in place (from "OF: Fixup resursive
locking code paths"), we can now do the conversion from the
rw_lock to a raw spinlock as required for preempt-rt.
The previous cleanup and this conversion were originally
separate since they predated when mainline got raw spinlock (in
commit c2f21ce2e31286a "locking: Implement new raw_spinlock").
So, at that point in time, the cleanup was considered plausible
for mainline, but not this conversion. In any case, we've kept
them separate as it makes for easier review and better bisection.
[PG: taken from preempt-rt, update subject & add a commit log]
git://sources.calxeda.com/kernel/linux.git
This allows platform_device_add a chance to call insert_resource on all
of the resources from OF. At a minimum this fills in proc/iomem and
presumably makes resource tracking and conflict detection work better.
However, it has the side effect of moving all OF generated platform
devices from /sys/devices to /sys/devices/platform/. It /shouldn't/
break userspace because userspace is not supposed to depend on the full
path (because userspace always does what it is supposed to, right?).
This may cause breakage if either:
1) any two nodes in a given device tree have overlapping & staggered
regions (ie. 0x80..0xbf and 0xa0..0xdf; where one is not contained
within the other). In this case one of the devices will fail to
register and an exception will be needed in platform_device_add() to
complain but not fail.
2) any device calls request_mem_region() on a region larger than
specified in the device tree. In this case the device node may be
wrong, or the driver is overreaching. In either case I'd like to know
about any problems and fix them.
Please test. Despite the above, I'm still fairly confident that this
patch is in good shape. I'd like to put it into linux-next, but would
appreciate some bench testing from others before I do; particularly on
PowerPC machines.
v2: Remove powerpc special-case
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
In some situations, userspace may want to resolve a
device by function and logical number (ie, "serial0")
rather than by the base address or full device path. Being
able to resolve a device by alias frees userspace from the
burden of otherwise having to maintain a mapping between
device addresses and their logical assignments on each
platform when multiple instances of the same hardware block
are present in the system.
Although the uevent device attribute contains devicetree
compatible information and the full device path, the uevent
does not list the alises that may have been defined for the
device.
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
[grant.likely: Removed OF_ALIAS_N field; I don't think it's needed]
[grant.likely: Added #ifndef _LINUX_OF_PRIVATE_H wrapper]
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
There is no real reason to use a rwlock for devtree_lock. It even
could be a mutex, but unfortunately it's locked from cpu hotplug
paths which can't schedule :(
So it needs to become a raw lock on rt as well. The devtree_lock would
be the only user of a raw_rw_lock, so we are better off cleaning up the
recursive locking paths which allows us to convert devtree_lock to a
read_lock.
Here we do the standard thing of introducing __foo() as the "raw"
version of foo(), so that we can take better control of the locking.
The "raw" versions are not exported and are for internal use within
the file itself.
The of_find_matching_node_and_match() function incorrectly sets the matched
entry to 'matches' when the compatible value of a node matches one of the
possible values. This results in incorrectly selecting the the first entry in
the 'matches' list as the matched entry. Fix this by noting down the result of
the call to of_match_node() and setting that as the matched entry.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
The flags argument of the phy_{attach,connect,connect_direct} functions
is then used to assign a struct phy_device dev_flags with its value.
All callers but the tg3 driver pass the flag 0, which results in the
underlying PHY drivers in drivers/net/phy/ not being able to actually
use any of the flags they would set in dev_flags. This patch gets rid of
the flags argument, and passes phydev->dev_flags to the internal PHY
library call phy_attach_direct() such that drivers which actually modify
a phy device dev_flags get the value preserved for use by the underlying
phy driver.
Acked-by: Kosta Zertsekel <konszert@marvell.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
15c3597d (dt/platform: allow device name to be overridden) added a
lookup parameter to of_platform_populate() but did not update the
documentation. This patch adds the missing documentation entry.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Javi Merino <javi.merino@arm.com>
Signed-off-by: Andrew Murray <Andrew.Murray@arm.com>
Commit 50c8af4cf9, "of: introduce for_each_matching_node_and_match()"
renamed of_find_matching_node() to of_find_matching_node_and_match() and
created a new static inline of_find_matching_node() wrapper around the
new name. However, the change neglected to change the EXPORT_SYMBOL()
reference causing build errors for modules.
This patch fixes the EXPORT_SYMBOL() statement. Discovered on a PowerPC
Efika build with the mpc52xx_uart driver being built as a module.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlight is probably some base POWER8 support. There's more
to come such as transactional memory support but that will wait for
the next one.
Overall it's pretty quiet, or rather I've been pretty poor at picking
things up from patchwork and reviewing them this time around and Kumar
no better on the FSL side it seems..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits)
powerpc+of: Rename and fix OF reconfig notifier error inject module
powerpc: mpc5200: Add a3m071 board support
powerpc/512x: don't compile any platform DIU code if the DIU is not enabled
powerpc/mpc52xx: use module_platform_driver macro
powerpc+of: Export of_reconfig_notifier_[register,unregister]
powerpc/dma/raidengine: add raidengine device
powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct
powerpc/mpc85xx: Change spin table to cached memory
powerpc/fsl-pci: Add PCI controller ATMU PM support
powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI
drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS]
powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers
powerpc: Disable relocation on exceptions when kexecing
powerpc: Enable relocation on during exceptions at boot
powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function
powerpc: Add wrappers to enable/disable relocation on exceptions
powerpc: Add set_mode hcall
powerpc: Setup relocation on exceptions for bare metal systems
powerpc: Move initial mfspr LPCR out of __init_LPCR
powerpc: Add relocation on exception vector handlers
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Pull another devicetree update from Grant Likely:
"Here's a couple more devicetree changes that I missed in the first
pull by putting the tag in the wrong place.
Two minor devicetree fixups for v3.8. Addition of dummy inlines and
constification of node argument to of_parse_phandle_with_args()."
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of: *node argument to of_parse_phandle_with_args should be const
of/i2c: add dummy inline functions for when CONFIG_OF_I2C(_MODULE) isn't defined
Pull tiny sparc update from David Miller:
"Not much going on this release cycle in sparc land, just a Kconfig
tweak."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next:
of_i2c: sparc: Allow OF_I2C for sparc
The "struct device_node *" argument of of_parse_phandle_with_args() can
be const. Making this change makes it explicit that the function will
not modify a node.
[grant.likely: Resolved conflict with previous patch modifying of_parse_phandle()]
