[ Upstream commit a5bea04fcc0b3c0aec71ee1fd58fd4ff7ee36177 ]
Commit dabf6b36b83a ("of: Add OF_DMA_DEFAULT_COHERENT & select it on
powerpc") added a check to of_dma_is_coherent which returns early
if OF_DMA_DEFAULT_COHERENT is enabled. This results in the of_node_put()
being skipped causing a memory leak. Moved the of_node_get() below this
check so we now we only get the node if OF_DMA_DEFAULT_COHERENT is not
enabled.
Fixes: dabf6b36b83a ("of: Add OF_DMA_DEFAULT_COHERENT & select it on powerpc")
Signed-off-by: Evan Nimmo <evan.nimmo@alliedtelesis.co.nz>
Link: https://lore.kernel.org/r/20201110022825.30895-1-evan.nimmo@alliedtelesis.co.nz
Signed-off-by: Rob Herring <robh@kernel.org>
[ Upstream commit ca05f33316559a04867295dd49f85aeedbfd6bfd ]
The reserved-memory overlap detection code fails to detect overlaps if
either of the regions starts at address 0x0. The code explicitly checks
for and ignores such regions, apparently in order to ignore dynamically
allocated regions which have an address of 0x0 at this point. These
dynamically allocated regions also have a size of 0x0 at this point, so
fix this by removing the check and sorting the dynamically allocated
regions ahead of any static regions at address 0x0.
For example, there are two overlaps in this case but they are not
currently reported:
foo@0 {
reg = <0x0 0x2000>;
bar@0 {
reg = <0x0 0x1000>;
baz@1000 {
reg = <0x1000 0x1000>;
quux {
size = <0x1000>;
but they are after this patch:
OF: reserved mem: OVERLAP DETECTED!
bar@0 (0x00000000--0x00001000) overlaps with foo@0 (0x00000000--0x00002000)
foo@0 (0x00000000--0x00002000) overlaps with baz@1000 (0x00001000--0x00002000)
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Link: https://lore.kernel.org/r/ded6fd6b47b58741aabdcc6967f73eca6a3f311e.1603273666.git-series.vincent.whitchurch@axis.com
commit 48c1699d5335bc045b50989a06b1c526b17a25ff upstream.
Make sure to drop the of_node reference also on failure to parse the
speed property in of_phy_register_fixed_link().
Fixes: 3be2a49e5c08 ("of: provide a binding for fixed link PHYs")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 216830d2413cc61be3f76bc02ffd905e47d2439e ]
kmemleak reports several memory leaks from devicetree unittest.
This is the fix for problem 2 of 5.
of_unittest_platform_populate() left an elevated reference count for
grandchild nodes (which are platform devices). Fix the platform
device reference counts so that the memory will be freed.
Fixes: fb2caa50fbac ("of/selftest: add testcase for nodes with same name and address")
Reported-by: Erhard F. <erhard_f@mailbox.org>
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
[ Upstream commit bd82bbf38cbe27f2c65660da801900d71bcc5cc8 ]
The ref counting is broken for OF_DYNAMIC when sysfs is disabled because
the kobject initialization is skipped. Only the properties
add/remove/update should be skipped for !SYSFS config.
Tested-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit dabf6b36b83a18d57e3d4b9d50544ed040d86255 upstream.
There's an OF helper called of_dma_is_coherent(), which checks if a
device has a "dma-coherent" property to see if the device is coherent
for DMA.
But on some platforms devices are coherent by default, and on some
platforms it's not possible to update existing device trees to add the
"dma-coherent" property.
So add a Kconfig symbol to allow arch code to tell
of_dma_is_coherent() that devices are coherent by default, regardless
of the presence of the property.
Select that symbol on powerpc when NOT_COHERENT_CACHE is not set, ie.
when the system has a coherent cache.
Fixes: 92ea637edea3 ("of: introduce of_dma_is_coherent() helper")
Cc: stable@vger.kernel.org # v3.16+
Reported-by: Christian Zigotzky <chzigotzky@xenosoft.de>
Tested-by: Christian Zigotzky <chzigotzky@xenosoft.de>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit f6707fd6241e483f6fea2caae82d876e422bb11a ]
Cache nodes under the cpu node(s) is PowerMac specific according to the
comment above, so make the code enforce that.
[ Upstream commit e13de8fe0d6a51341671bbe384826d527afe8d44 ]
In unittest_data_add, a copy buffer is created via kmemdup. This buffer
is leaked if of_fdt_unflatten_tree fails. The release for the
unittest_data buffer is added.
Fixes: b951f9dc7f25 ("Enabling OF selftest to run without machine's devicetree")
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
[ Upstream commit 36156f9241cb0f9e37d998052873ca7501ad4b36 ]
Add of_get_compatible_child() helper that can be used to lookup
compatible child nodes.
Several drivers currently use of_find_compatible_node() to lookup child
nodes while failing to notice that the of_find_ functions search the
entire tree depth-first (from a given start node) and therefore can
match unrelated nodes. The fact that these functions also drop a
reference to the node they start searching from (e.g. the parent node)
is typically also overlooked, something which can lead to use-after-free
bugs.
commit 8894891446c9380709451b99ab45c5c53adfd2fc upstream.
On systems with OF_IMAP_OLDWORLD_MAC set in of_irq_workarounds, the
devicetree interrupt parsing code is different, causing unit tests of
devicetree interrupt nodes to fail. Due to a bug in unittest code, which
tries to dereference an uninitialized pointer, this results in a crash.
OF: /testcase-data/phandle-tests/consumer-a: arguments longer than property
Unable to handle kernel paging request for data at address 0x00bc616e
Faulting instruction address: 0xc08e9468
Oops: Kernel access of bad area, sig: 11 [#1]
BE PREEMPT PowerMac
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.72-rc1-yocto-standard+ #1
task: cf8e0000 task.stack: cf8da000
NIP: c08e9468 LR: c08ea5bc CTR: c08ea5ac
REGS: cf8dbb50 TRAP: 0300 Not tainted (4.14.72-rc1-yocto-standard+)
MSR: 00001032 <ME,IR,DR,RI> CR: 82004044 XER: 00000000
DAR: 00bc616e DSISR: 40000000
GPR00: c08ea5bc cf8dbc00 cf8e0000 c13ca517 c13ca517 c13ca8a0 00000066 00000002
GPR08: 00000063 00bc614e c0b05865 000affff 82004048 00000000 c00047f0 00000000
GPR16: c0a80000 c0a9cc34 c13ca517 c0ad1134 05ffffff 000affff c0b05860 c0abeef8
GPR24: cecec278 cecec278 c0a8c4d0 c0a885e0 c13ca8a0 05ffffff c13ca8a0 c13ca517
NIP [c08e9468] device_node_gen_full_name+0x30/0x15c
LR [c08ea5bc] device_node_string+0x190/0x3c8
Call Trace:
[cf8dbc00] [c007f670] trace_hardirqs_on_caller+0x118/0x1fc (unreliable)
[cf8dbc40] [c08ea5bc] device_node_string+0x190/0x3c8
[cf8dbcb0] [c08eb794] pointer+0x25c/0x4d0
[cf8dbd00] [c08ebcbc] vsnprintf+0x2b4/0x5ec
[cf8dbd60] [c08ec00c] vscnprintf+0x18/0x48
[cf8dbd70] [c008e268] vprintk_store+0x4c/0x22c
[cf8dbda0] [c008ecac] vprintk_emit+0x94/0x130
[cf8dbdd0] [c008ff54] printk+0x5c/0x6c
[cf8dbe10] [c0b8ddd4] of_unittest+0x2220/0x26f8
[cf8dbea0] [c0004434] do_one_initcall+0x4c/0x184
[cf8dbf00] [c0b4534c] kernel_init_freeable+0x13c/0x1d8
[cf8dbf30] [c0004814] kernel_init+0x24/0x118
[cf8dbf40] [c0013398] ret_from_kernel_thread+0x5c/0x64
The problem was observed when running a qemu test for the g3beige machine
with devicetree unittests enabled.
Disable interrupt node tests on affected systems to avoid both false
unittest failures and the crash.
With this patch in place, unittest on the affected system passes with
the following message.
dt-test ### end of unittest - 144 passed, 0 failed
Fixes: 53a42093d96ef ("of: Add device tree selftests")
Reviewed-by: Frank Rowand <frank.rowand@sony.com>
commit 3b9cf7905fe3ab35ab437b5072c883e609d3498d upstream.
For strings, account for trailing \0 in property length field:
This is consistent with how dtc builds string properties.
Function __of_prop_dup() would misbehave on such properties as it duplicates
properties based on the property length field creating new string values
without trailing \0s.
Signed-off-by: Stefan M Schaeckeler <sschaeck@cisco.com>
Tested-by: Frank Rowand <frank.rowand@sony.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit bcf54d5385abaea9c8026aae6f4eeb348671a52d ]
If the length of the modalias is greater than the buffer size, then the
modalias is truncated. However the untruncated length is returned which
will cause an error. Fix this to return the truncated length. If an error
in the case was desired, then then we should just return -ENOMEM.
The reality is no device will ever have 4KB of compatible strings to hit
this case.
Cc: Frank Rowand <frowand.list@gmail.com>
commit 7a3b7cd332db08546f3cdd984f11773e0d1999e7 upstream.
The ULPI bus can be built as a module, and it will soon be
calling these functions when it supports probing devices from DT.
Export them so they can be used by the ULPI module.
Acked-by: Rob Herring <robh@kernel.org>
Cc: <devicetree@vger.kernel.org>
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit 3ec754410cb3e931a6c4920b1a150f21a94a2bf4 upstream.
An empty __dtb_start to __dtb_end section might result in
initial_boot_params being null for arch/mips/ralink. This showed that the
boot process hangs indefinitely in of_scan_flat_dt().
Signed-off-by: Tobias Wolf <dev-NTEO@vplace.de>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/14605/
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit eb3100365791b06242b8bb5c3c2854ba41dabfbc upstream.
sparse gives the following warning for 'pci_space':
../drivers/of/address.c:266:26: warning: incorrect type in assignment (different base types)
../drivers/of/address.c:266:26: expected unsigned int [unsigned] [usertype] pci_space
../drivers/of/address.c:266:26: got restricted __be32 const [usertype] <noident>
It appears that pci_space is only ever accessed on powerpc, so the endian
swap is often not needed.
commit aaaab56dba9af4fe75461e0ee13231c1a6ea174d upstream.
pageblock_order can be (at least) an unsigned int or an unsigned long
depending on the kernel config and architecture, so use max_t(unsigned
long ...) when comparing it.
fixes these warnings:
In file included from include/linux/list.h:8:0,
from include/linux/kobject.h:20,
from include/linux/of.h:21,
from drivers/of/of_reserved_mem.c:17:
drivers/of/of_reserved_mem.c: In function ‘__reserved_mem_alloc_size’:
include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast
(void) (&_max1 == &_max2); \
include/linux/kernel.h:747:9: note: in definition of macro ‘max’
typeof(y) _max2 = (y); \
drivers/of/of_reserved_mem.c:131:48: note: in expansion of macro ‘max’
align = max(align, (phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_ord
include/linux/kernel.h:747:21: note: in definition of macro ‘max’
Fixes: 1cc8e3458b51 ("drivers: of: of_reserved_mem: fixup the alignment with CMA setup")
commit 34276bb062b8449b3b0a208c9b848a1a27920075 upstream.
The called of_graph_get_next_endpoint() already decrements the refcount
of the prev node, so it is wrong to do it again in the calling function.
Use the for_each_endpoint_of_node() helper to interate through the
endpoint OF nodes, which already does the right thing and simplifies
the code a bit.
Fixes: 8ccd0d0ca041
(of: add helper for getting endpoint node of specific identifiers)
Reported-by: David Jander <david@protonic.nl>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
commit d9fc880723321dbf16b2981e3f3e916b73942210 upstream.
Fix a memory leak resulting from memory allocation in safe_name().
This patch fixes all call sites of safe_name().
Mathieu Malaterre reported the memory leak on boot:
On my PowerMac device-tree would generate a duplicate name:
[ 0.023043] device-tree: Duplicate name in PowerPC,G4@0, renamed to "l2-cache#1"
in this case a newly allocated name is generated by `safe_name`. However
in this case it is never deallocated.
The bug was found using kmemleak reported as:
unreferenced object 0xdf532e60 (size 32):
comm "swapper", pid 1, jiffies 4294892300 (age 1993.532s)
hex dump (first 32 bytes):
6c 32 2d 63 61 63 68 65 23 31 00 dd e4 dd 1e c2 l2-cache#1......
ec d4 ba ce 04 ec cc de 8e 85 e9 ca c4 ec cc 9e ................
backtrace:
[<c02d3350>] kvasprintf+0x64/0xc8
[<c02d3400>] kasprintf+0x4c/0x5c
[<c0453814>] safe_name.isra.1+0x80/0xc4
[<c04545d8>] __of_attach_node_sysfs+0x6c/0x11c
[<c075f21c>] of_core_init+0x8c/0xf8
[<c0729594>] kernel_init_freeable+0xd4/0x208
[<c00047e8>] kernel_init+0x24/0x11c
[<c00158ec>] ret_from_kernel_thread+0x5c/0x64
Link: https://bugzilla.kernel.org/show_bug.cgi?id=120331
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Reported-by: mathieu.malaterre@gmail.com
Tested-by: Mathieu Malaterre <mathieu.malaterre@gmail.com>
commit 3993546646baf1dab5f5c4f7d9bb58f2046fd1c1 upstream.
The kernel-doc for the of_irq_get[_byname]() is clearly inadequate in
describing the return values -- of_irq_get_byname() is documented better
than of_irq_get() but it still doesn't mention that 0 is returned iff
irq_create_of_mapping() fails (it doesn't return an error code in this
case). Document all possible return value variants, making the writing
of the word "IRQ" consistent, while at it...
Fixes: 9ec36cafe43b ("of/irq: do irq resolution in platform_get_irq")
Fixes: ad69674e73a1 ("of/irq: do irq resolution in platform_get_irq_byname()")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
commit e53b50c0cbe392c946807abf7d07615a3c588642 upstream.
early_init_dt_alloc_reserved_memory_arch passes end as 0 to
__memblock_alloc_base, when limits are not specified. But
__memblock_alloc_base takes end value of 0 as MEMBLOCK_ALLOC_ACCESSIBLE
and limits the end to memblock.current_limit. This results in regions
never being placed in HIGHMEM area, for e.g. CMA.
Let __memblock_alloc_base allocate from anywhere in memory if limits are
not specified.
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org>
commit 5d589d81acf974d23af98044aac56c6339d659f8 upstream.
The existing msi-map code is fine for shifting the entire RID space
upwards, but attempting finer-grained remapping reveals a bug. It turns
out that we are mistakenly treating the msi-base part as an offset, not
as a new base to remap onto, so things get squiffy when rid-base is
nonzero. Fix this, and at the same time add a sanity check against
having msi-map-mask clash with a nonzero rid-base, as that's another
thing one can easily get wrong.
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Stuart Yoder <stuart.yoder@nxp.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: David Daney <david.daney@cavium.com>
of_irq_find_parent was made static since it had no users outside of
of_irq.c. Export it again since we are going to use it again.
Signed-off-by: Carlo Caione <carlo@endlessm.com>
[robh: move of_irq_find_parent to correct ifdef section]
__unflatten_device_tree() calls unflatten_dt_node(), which declares
a static variable. It is therefore not reentrant.
One of the callers of __unflatten_device_tree(), unflatten_device_tree(),
is only called once during early initialization and does not need to be
protected. The other caller, of_fdt_unflatten_tree(), can be called at
any time, possibly multiple times in parallel. This can happen, for
example, if multiple devicetree overlays have to be loaded and installed.
Without this protection, errors such as the following may be seen.
kernel: End of tree marker overwritten: e6a3a458
kernel: find_target_node:
Failed to find target-indirect node at /fragment@0
kernel: __of_overlay_create: of_build_overlay_info() failed for tree@/
Add a mutex to of_fdt_unflatten_tree() to make the call reentrant.
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Cc: stable@vger.kernel.org # v4.1+
Remove the "not" before "cannot".
I am fixing the comment block style while I am here.
Signed-off-by: Dmitry V. Krivenok <krivenok.dmitry@gmail.com>
In order to check for overlapping reserved memory regions, we first need
to sort the array of memory regions. This is implemented using sort(),
and a custom comparison function __rmem_cmp().
Unfortunatley __rmem_cmp() doesn't work in all cases. Because the two
base values are phys_addr_t, they may be u64 on some platforms, in which
case subtracting one from the other and then (implicitly) casting to int
does not give us the -ve/0/+ve value we need.
This leads to incorrect reports about overlaps, eg:
ibm,slw-image@1ffe600000 (0x0000001ffe600000--0x0000001ffe700000) overlaps with
ibm,firmware-allocs-memory@1000000000 (0x0000001000000000--0x0000001000dc0200)
Fix it by just doing the standard double if and return 0 logic.
Fixes: ae1add247bf8 ("of: Check for overlap in reserved memory regions")
Pull more power management and ACPI updates from Rafael Wysocki:
"The only new feature in this batch is support for the ACPI _CCA device
configuration object, which it a pre-requisite for future ACPI PCI
support on ARM64, but should not affect the other architectures.
The rest is fixes and cleanups, mostly in cpufreq (including
intel_pstate), the Operating Performace Points (OPP) framework and
tools (cpupower and turbostat).
Specifics:
- Support for the ACPI _CCA configuration object intended to tell the
OS whether or not a bus master device supports hardware managed
cache coherency and a new set of functions to allow drivers to
check the cache coherency support for devices in a platform
firmware interface agnostic way (Suravee Suthikulpanit, Jeremy
Linton).
- ACPI backlight quirks for ESPRIMO Mobile M9410 and Dell XPS L421X
(Aaron Lu, Hans de Goede).
- Fixes for the arm_big_little and s5pv210-cpufreq cpufreq drivers
(Jon Medhurst, Nicolas Pitre).
- kfree()-related fixup for the recently introduced CPPC cpufreq
frontend (Markus Elfring).
- intel_pstate fix reducing kernel log noise on systems where
P-states are managed by hardware (Prarit Bhargava).
- intel_pstate maintainers information update (Srinivas Pandruvada).
- cpufreq core optimization related to the handling of delayed work
items used by governors (Viresh Kumar).
- Locking fixes and cleanups of the Operating Performance Points
(OPP) framework (Viresh Kumar).
- Generic power domains framework cleanups (Lina Iyer).
- cpupower tool updates (Jacob Tanenbaum, Sriram Raghunathan, Thomas
Renninger).
- turbostat tool updates (Len Brown)"
* tag 'pm+acpi-4.4-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
PCI: ACPI: Add support for PCI device DMA coherency
PCI: OF: Move of_pci_dma_configure() to pci_dma_configure()
of/pci: Fix pci_get_host_bridge_device leak
device property: ACPI: Remove unused DMA APIs
device property: ACPI: Make use of the new DMA Attribute APIs
device property: Adding DMA Attribute APIs for Generic Devices
ACPI: Adding DMA Attribute APIs for ACPI Device
device property: Introducing enum dev_dma_attr
ACPI: Honor ACPI _CCA attribute setting
cpufreq: CPPC: Delete an unnecessary check before the function call kfree()
PM / OPP: Add opp_rcu_lockdep_assert() to _find_device_opp()
PM / OPP: Hold dev_opp_list_lock for writers
PM / OPP: Protect updates to list_dev with mutex
PM / OPP: Propagate error properly from dev_pm_opp_set_sharing_cpus()
cpufreq: s5pv210-cpufreq: fix wrong do_div() usage
MAINTAINERS: update for intel P-state driver
Creating a common structure initialization pattern for struct option
cpupower: Enable disabled Cstates if they are below max latency
cpupower: Remove debug message when using cpupower idle-set -D switch
cpupower: cpupower monitor reports uninitialized values for offline cpus
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- Add empty of_translate_address needed for HiSilicon network driver.
- Fix alignment requirements for CMA regions in DT.
- Fix booting on PPC systems which can't do WARN() early.
- Rename ak4554 binding doc from .c to .txt.
* tag 'devicetree-fixes-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: Provide static inline function for of_translate_address if needed
of: Print rather than WARN'ing when overlap check fails
dt-bindings: ak4554: extension should be .txt
There is an alignment mismatch issue between the of_reserved_mem and
the CMA setup requirement. The of_reserved_mem will try to get the
alignment value from the DTS and pass it to __memblock_alloc_base to
do the memory block base allocation, but the alignment value specified
in the DTS may not satisfy the CAM setup requirement since CMA setup
required the alignment as the following in the code:
align = PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order);
The sanity check in the function of rmem_cma_setup will fail if the
alignment does not setup correctly and thus CMA will fail to setup.
This patch is to fixup the alignment to meet the CMA setup required.
Mailing-list-thread: https://lkml.org/lkml/2015/11/9/138
Signed-off-by: Jason Liu <r64343@freescale.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
__rmem_check_for_overlap() is called very early in boot, and on some
powerpc systems it's not safe to call WARN that early in boot.
If the overlap check fails the system will oops instead of printing a
warning. Furthermore because it's so early in boot the console is not up
and the user doesn't see the oops, they just get a dead system.
Fix it by printing an error instead of calling WARN.
* acpi-pci:
drivers/crypto/ccp/ccp-platform.c
This patch move of_pci_dma_configure() to a more generic
pci_dma_configure(), which can be extended by non-OF code (e.g. ACPI).
This has no functional change.
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Acked-by: Rob Herring <robh+dt@kernel.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
In case of error, the current code return w/o calling
pci_put_host_bridge_device. This patch fixes this.
Pull DeviceTree updates from Rob Herring:
"A fairly large (by DT standards) pull request this time with the
majority being some overdue moving DT binding docs around to
consolidate similar bindings.
- DT binding doc consolidation moving similar bindings to common
locations. The majority of these are display related which were
scattered in video/, fb/, drm/, gpu/, and panel/ directories.
- Add new config option, CONFIG_OF_ALL_DTBS, to enable building all
dtbs in the tree for most arches with dts files (except powerpc for
now).
- OF_IRQ=n fixes for user enabled CONFIG_OF.
- of_node_put ref counting fixes from Julia Lawall.
- Common DT binding for wakeup-source and deprecation of all similar
bindings.
- DT binding for PXA LCD controller.
- Allow ignoring failed PCI resource translations in order to ignore
64-bit addresses on non-LPAE 32-bit kernels.
- Support setting the NUMA node from DT instead of only from parent
device.
- Couple of earlycon DT parsing fixes for address and options"
* tag 'devicetree-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (45 commits)
MAINTAINERS: update DT binding doc locations
devicetree: add Sigma Designs vendor prefix
of: simplify arch_find_n_match_cpu_physical_id() function
Documentation: arm: Fixed typo in socfpga fpga mgr example
Documentation: devicetree: fix reference to legacy wakeup properties
Documentation: devicetree: standardize/consolidate on "wakeup-source" property
drivers: of: removing assignment of 0 to static variable
xtensa: enable building of all dtbs
mips: enable building of all dtbs
metag: enable building of all dtbs
metag: use common make variables for dtb builds
h8300: enable building of all dtbs
arm64: enable building of all dtbs
arm: enable building of all dtbs
arc: enable building of all dtbs
arc: use common make variables for dtb builds
of: add config option to enable building of all dtbs
of/fdt: fix error checking for earlycon address
of/overlay: add missing of_node_put
of/platform: add missing of_node_put
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Resource management:
- Add support for Enhanced Allocation devices (Sean O. Stalley)
- Add Enhanced Allocation register entries (Sean O. Stalley)
- Handle IORESOURCE_PCI_FIXED when sizing resources (David Daney)
- Handle IORESOURCE_PCI_FIXED when assigning resources (David Daney)
- Handle Enhanced Allocation capability for SR-IOV devices (David Daney)
- Clear IORESOURCE_UNSET when reverting to firmware-assigned address (Bjorn Helgaas)
- Make Enhanced Allocation bitmasks more obvious (Bjorn Helgaas)
- Expand Enhanced Allocation BAR output (Bjorn Helgaas)
- Add of_pci_check_probe_only to parse "linux,pci-probe-only" (Marc Zyngier)
- Fix lookup of linux,pci-probe-only property (Marc Zyngier)
- Add sparc mem64 resource parsing for root bus (Yinghai Lu)
PCI device hotplug:
- pciehp: Queue power work requests in dedicated function (Guenter Roeck)
Driver binding:
- Add builtin_pci_driver() to avoid registration boilerplate (Paul Gortmaker)
Virtualization:
- Set SR-IOV NumVFs to zero after enumeration (Alexander Duyck)
- Remove redundant validation of SR-IOV offset/stride registers (Alexander Duyck)
- Remove VFs in reverse order if virtfn_add() fails (Alexander Duyck)
- Reorder pcibios_sriov_disable() (Alexander Duyck)
- Wait 1 second between disabling VFs and clearing NumVFs (Alexander Duyck)
- Fix sriov_enable() error path for pcibios_enable_sriov() failures (Alexander Duyck)
- Enable SR-IOV ARI Capable Hierarchy before reading TotalVFs (Ben Shelton)
- Don't try to restore VF BARs (Wei Yang)
MSI:
- Don't alloc pcibios-irq when MSI is enabled (Joerg Roedel)
- Add msi_controller setup_irqs() method for special multivector setup (Lucas Stach)
- Export all remapped MSIs to sysfs attributes (Romain Bezut)
- Disable MSI on SiS 761 (Ondrej Zary)
AER:
- Clear error status registers during enumeration and restore (Taku Izumi)
Generic host bridge driver:
- Allow multiple hosts with different map_bus() methods (David Daney)
- Pass starting bus number to pci_scan_root_bus() (David Daney)
- Fix address window calculation for non-zero starting bus (David Daney)
Altera host bridge driver:
- Add msi.h to ARM Kbuild (Ley Foon Tan)
- Add Altera PCIe host controller driver (Ley Foon Tan)
- Add Altera PCIe MSI driver (Ley Foon Tan)
APM X-Gene host bridge driver:
- Remove msi_controller assignment (Duc Dang)
Broadcom iProc host bridge driver:
- Fix header comment "Corporation" misspelling (Florian Fainelli)
- Fix code comment to match code (Ray Jui)
- Remove unused struct iproc_pcie.irqs[] (Ray Jui)
- Call pci_fixup_irqs() for ARM64 as well as ARM (Ray Jui)
- Fix PCIe reset logic (Ray Jui)
- Improve link detection logic (Ray Jui)
- Update PCIe device tree bindings (Ray Jui)
- Add outbound mapping support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Return real error code from imx6_add_pcie_port() (Fabio Estevam)
- Add PCIE_PHY_RX_ASIC_OUT_VALID definition (Fabio Estevam)
Freescale Layerscape host bridge driver:
- Remove ls_pcie_establish_link() (Minghuan Lian)
- Ignore PCIe controllers in Endpoint mode (Minghuan Lian)
- Factor out SCFG related function (Minghuan Lian)
- Update ls_add_pcie_port() (Minghuan Lian)
- Remove unused fields from struct ls_pcie (Minghuan Lian)
- Add support for LS1043a and LS2080a (Minghuan Lian)
- Add ls_pcie_msi_host_init() (Minghuan Lian)
HiSilicon host bridge driver:
- Add HiSilicon SoC Hip05 PCIe driver (Zhou Wang)
Marvell MVEBU host bridge driver:
- Return zero for reserved or unimplemented config space (Russell King)
- Use exact config access size; don't read/modify/write (Russell King)
- Use of_get_available_child_count() (Russell King)
- Use for_each_available_child_of_node() to walk child nodes (Russell King)
- Report full node name when reporting a DT error (Russell King)
- Use port->name rather than "PCIe%d.%d" (Russell King)
- Move port parsing and resource claiming to separate function (Russell King)
- Fix memory leaks and refcount leaks (Russell King)
- Split port parsing and resource claiming from port setup (Russell King)
- Use gpio_set_value_cansleep() (Russell King)
- Use devm_kcalloc() to allocate an array (Russell King)
- Use gpio_desc to carry around gpio (Russell King)
- Improve clock/reset handling (Russell King)
- Add PCI Express root complex capability block (Russell King)
- Remove code restricting accesses to slot 0 (Russell King)
NVIDIA Tegra host bridge driver:
- Wrap static pgprot_t initializer with __pgprot() (Ard Biesheuvel)
Renesas R-Car host bridge driver:
- Build pci-rcar-gen2.c only on ARM (Geert Uytterhoeven)
- Build pcie-rcar.c only on ARM (Geert Uytterhoeven)
- Make PCI aware of the I/O resources (Phil Edworthy)
- Remove dependency on ARM-specific struct hw_pci (Phil Edworthy)
- Set root bus nr to that provided in DT (Phil Edworthy)
- Fix I/O offset for multiple host bridges (Phil Edworthy)
ST Microelectronics SPEAr13xx host bridge driver:
- Fix dw_pcie_cfg_read/write() usage (Gabriele Paoloni)
Synopsys DesignWare host bridge driver:
- Make "clocks" and "clock-names" optional DT properties (Bhupesh Sharma)
- Use exact access size in dw_pcie_cfg_read() (Gabriele Paoloni)
- Simplify dw_pcie_cfg_read/write() interfaces (Gabriele Paoloni)
- Require config accesses to be naturally aligned (Gabriele Paoloni)
- Make "num-lanes" an optional DT property (Gabriele Paoloni)
- Move calculation of bus addresses to DRA7xx (Gabriele Paoloni)
- Replace ARM pci_sys_data->align_resource with global function pointer (Gabriele Paoloni)
- Factor out MSI msg setup (Lucas Stach)
- Implement multivector MSI IRQ setup (Lucas Stach)
- Make get_msi_addr() return phys_addr_t, not u32 (Lucas Stach)
- Set up high part of MSI target address (Lucas Stach)
- Fix PORT_LOGIC_LINK_WIDTH_MASK (Zhou Wang)
- Revert "PCI: designware: Program ATU with untranslated address" (Zhou Wang)
- Use of_pci_get_host_bridge_resources() to parse DT (Zhou Wang)
- Make driver arch-agnostic (Zhou Wang)
Miscellaneous:
- Make x86 pci_subsys_init() static (Alexander Kuleshov)
- Turn off Request Attributes to avoid Chelsio T5 Completion erratum (Hariprasad Shenai)"
* tag 'pci-v4.4-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: altera: Add Altera PCIe MSI driver
PCI: hisi: Add HiSilicon SoC Hip05 PCIe driver
PCI: layerscape: Add ls_pcie_msi_host_init()
PCI: layerscape: Add support for LS1043a and LS2080a
PCI: layerscape: Remove unused fields from struct ls_pcie
PCI: layerscape: Update ls_add_pcie_port()
PCI: layerscape: Factor out SCFG related function
PCI: layerscape: Ignore PCIe controllers in Endpoint mode
PCI: layerscape: Remove ls_pcie_establish_link()
PCI: designware: Make "clocks" and "clock-names" optional DT properties
PCI: designware: Make driver arch-agnostic
ARM/PCI: Replace pci_sys_data->align_resource with global function pointer
PCI: designware: Use of_pci_get_host_bridge_resources() to parse DT
PCI: designware: Move calculation of bus addresses to DRA7xx
PCI: designware: Make "num-lanes" an optional DT property
PCI: designware: Require config accesses to be naturally aligned
PCI: designware: Simplify dw_pcie_cfg_read/write() interfaces
PCI: designware: Use exact access size in dw_pcie_cfg_read()
PCI: spear: Fix dw_pcie_cfg_read/write() usage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here's the "big" driver core updates for 4.4-rc1. Primarily a bunch
of debugfs updates, with a smattering of minor driver core fixes and
updates as well.
All have been in linux-next for a long time"
* tag 'driver-core-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
debugfs: Add debugfs_create_ulong()
of: to support binding numa node to specified device in devicetree
debugfs: Add read-only/write-only bool file ops
debugfs: Add read-only/write-only size_t file ops
debugfs: Add read-only/write-only x64 file ops
debugfs: Consolidate file mode checks in debugfs_create_*()
Revert "mm: Check if section present during memory block (un)registering"
driver-core: platform: Provide helpers for multi-driver modules
devres: fix a for loop bounds check
CMA: fix CONFIG_CMA_SIZE_MBYTES overflow in 64bit
base/platform: assert that dev_pm_domain callbacks are called unconditionally
sysfs: correctly handle short reads on PREALLOC attrs.
base: soc: siplify ida usage
kobject: move EXPORT_SYMBOL() macros next to corresponding definitions
kobject: explain what kobject's sd field is
debugfs: document that debugfs_remove*() accepts NULL and error values
debugfs: Pass bool pointer to debugfs_create_bool()
ACPI / EC: Fix broken 64bit big-endian users of 'global_lock'
This commit does not change the function behavior.
no need to initialise static variable with 0, hence correcting it.
Signed-off-by: Saurabh Sengar <saurabh.truth@gmail.com>
Enable building all dtb files when CONFIG_OF_ALL_DTBS is enabled. The dtbs
are not really dependent on a platform being enabled or any other kernel
config, so for testing coverage it is convenient to build all of the dtbs.
In order to only build dtbs, this option can be used by creating an
allno.config file containing:
CONFIG_COMPILE_TEST=y
CONFIG_OF=y
CONFIG_OF_ALL_DTBS=y
And then running:
make KCONFIG_ALLCONFIG=1 allnoconfig
make dtbs
While building the dtbs themselves don't need a cross compiler, the
scripts dependency does need one. This can be hacked around by
commenting out "subdir-y += mod" in scripts/Makefile.
fdt_translate_address() returns OF_BAD_ADDR on error. It is defined as
a u64 value, so the variable "addr" should be defined as u64 as well.
Fixes: fb11ffe74c79 ("of/fdt: add FDT serial scanning for earlycon")
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
// <smpl>
expression root,e;
local idexpression child;
for_each_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
return child;
+ of_node_put(child);
? return ...;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
// <smpl>
local idexpression n;
expression root,e;
for_each_child_of_node(root,n) {
of_node_put(n);
e = n
+ of_node_put(n);
? break;
... when != n
// </smpl>
for_each_matching_node performs an of_node_get on each iteration, so
// <smpl>
expression e;
identifier l;
for_each_matching_node(n,...) {
of_node_put(n);
e = n
+ of_node_put(n);
? goto l;
l: ... when != n
// </smpl>
Besides the issue found by the semantic patch, this code also stores the
device_node value in a list, which requires an of_node_get, and then cleans
up the list on exit from the function, which requires an of_node_put.
// <smpl>
expression root,e;
when != e = child
return child;
? return ...;
// </smpl>
Combine the puts into code at the end of the function, for conciseness.
For now, in function device_add, the new device will be forced to
inherit the numa node of its parent. But this will override the device's
numa node which configured in devicetree.
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
While msi-parent is used to point to the MSI controller that
works for all the devices behind a root complex, it doesn't
allow configurations where each individual device can be routed
to a separate MSI controller.
The msi-map property provides this flexibility (and much more),
so let's add a utility function that parses it, and return the
corresponding MSI domain.
The msi-map property is also used to identify the MSI controller
as a form of grown-up msi-parent property.
Looking it up is complicated enough, and since of_msi_map_rid
already implements this, let's turn it into an internal utility
function. We'll put that to good use later on.
Now that we have a function that implements the complexity of the
"msi-parent" property parsing, switch to that.
