path: root/drivers/of
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-01of/platform: Register of_platform_drivers with an "of:" prefixGrant Likely
Currently there are some drivers in tree which register both a platform_driver and an of_platform_driver with the same name. This is a temporary situation until all the relevant of_platform_drivers are converted to be normal platform_drivers. Until then, this patch gives all the of_platform_drivers an "of:" prefix to protect against bogus matches and namespace conflicts.
2010-07-30of/spi: call of_register_spi_devices() from spi core codeAnatolij Gustschin
Move of_register_spi_devices() call from drivers to spi_register_master(). Also change the function to use the struct device_node pointer from master spi device instead of passing it as function argument. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-30of/device: Make of_device_make_bus_id() usable by other code.Grant Likely
The AMBA bus should also use of_device_make_bus_id() when populating device out of device tree data. This patch makes the function non-static, and adds a suitable prototype in of_device.h Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of/irq: Fix endian issues in parsing interrupt specifiersGrant Likely
This patch fixes some instances where interrupt specifiers are dereferenced directly instead of doing a be32_to_cpu() conversion first. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: Fix phandle endian issuesGrant Likely
The flat tree code wasn't fixing the endianness on phandle values when unflattening the tree, and the code in drivers/of wasn't always doing a be32_to_cpu before trying to dereference the phandle values. This patch fixes them. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of/flattree: fix of_flat_dt_is_compatible() to match the full compatible stringStuart Yoder
With the current string comparison, a device tree compatible of "foo-bar" would match as compatible with a driver looking for "foo". This patch fixes the function to use the of_compat_cmp() macro so that it does the right thing on all platforms (If sparc ever uses this code, it will still want the strncasecmp() behaviour). Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: remove of_default_bus_idsJonas Bonn
This list used was by only two platforms with all other platforms defining an own list of valid bus id's to pass to of_platform_bus_probe. This patch: i) copies the default list to the two platforms that depended on it (powerpc) ii) remove the usage of of_default_bus_ids in of_platform_bus_probe iii) removes the definition of the list from all architectures that defined it Passing a NULL 'matches' parameter to of_platform_bus_probe is still valid; the function returns no error in that case as the NULL value is equivalent to an empty list. Signed-off-by: Jonas Bonn <jonas@southpole.se> [grant.likely@secretlab.ca: added __initdata annotations, warn on and return error on missing match table, and fix whitespace errors] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: make of_find_device_by_node genericJonas Bonn
There's no need for this function to be architecture specific and all four architectures defining it had the same definition. The function has been moved to drivers/of/platform.c. Signed-off-by: Jonas Bonn <jonas@southpole.se> [grant.likely@secretlab.ca: moved to drivers/of/platform.c, simplified code, and added kerneldoc comment] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of/device: Replace of_device with platform_device in includes and core codeGrant Likely
of_device is currently just an #define alias to platform_device until it gets removed entirely. This patch removes references to it from the include directories and the core drivers/of code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of/device: Protect against binding of_platform_drivers to non-OF devicesGrant Likely
There is an unlikely chance of this situation is occurring, but it is easy to protect against. If a matching entry cannot be found in the of_match_table, then don't bind the driver. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-24of: Merge of_platform_bus_type with platform_bus_typeGrant Likely
of_platform_bus was being used in the same manner as the platform_bus. The only difference being that of_platform_bus devices are generated from data in the device tree, and platform_bus devices are usually statically allocated in platform code. Having them separate causes the problem of device drivers having to be registered twice if it was possible for the same device to appear on either bus. This patch removes of_platform_bus_type and registers all of_platform bus devices and drivers on the platform bus instead. A previous patch made the of_device structure an alias for the platform_device structure, and a shim is used to adapt of_platform_drivers to the platform bus. After all of of_platform_bus drivers are converted to be normal platform drivers, the shim code can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-18of/device: Fix build errors for non-ppc and non-microblazeGrant Likely
Only powerpc and microblaze supply (struct device *)->archdata.dma_mask. This patch stops referencing it on other architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-18of/flattree: Fix crash when device tree absentGrant Likely
This patch fixes the condition where device tree support is compiled in, but no device tree was proved by firmware. It makes of_platform_bus_probe() explicitly check for a NULL device tree pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-14of/flattree: Use common ALIGN() macro instead of arch specific _ALIGNGrant Likely
There's no reason to use the powerpc-specific _ALIGN macro in the fdt code. Replace it with ALIGN() from kernel.h Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-By: Jeremy Kerr <jeremy.kerr@canonical.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-14drivers/of: fix build error when CONFIG_PPC_DCR is setGrant Likely
Commit 94c0931983ee9d1cd96c32d52ac64c17464f0bbd (of: Merge of_device_alloc() and of_device_make_bus_id()) moved code that does calls a dcr routine without including the correct header which causes the following build error on some powerpc configurations: drivers/of/platform.c: In function 'of_device_make_bus_id': drivers/of/platform.c:437: error: implicit declaration of function 'of_translate_dcr_address' This patch adds the appropriate header to drivers/of/platform.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05proc: unify PROC_DEVICETREE configAndres Salomon
Microblaze and PPC both use PROC_DEVICETREE, and OLPC will as well.. put the Kconfig option into fs/ rather than in arch/*/Kconfig. Signed-off-by: Andres Salomon <dilinger@queued.net> [grant.likely@secretlab.ca: changed depends to PROC_FS && !SPARC] [grant.likely@secretlab.ca: moved to drivers/of/Kconfig] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of: Put all CONFIG_OF dependencies into a Kconfig menu blockGrant Likely
All of the options in drivers/of/Kconfig depend on CONFIG_OF. Putting all of them inside a menu block simplifies the dependency statements. It also creates a logical group for adding user selectable OF options. This patch also changes (PPC_OF || MICROBLAZE) statements to (!SPARC) so that those options are available to other architectures (and in fact the !SPARC conditions should probably be re-evalutated since the code is more generic now) This patch also moves the definition of CONFIG_DTC from arch/* to drivers/of/Kconfig Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of: define CONFIG_OF globally so architectures can select itStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of: Fix missing includeGrant Likely
Fix a build failure on ARM Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of: refactor of_modalias_node() and remove explicit match table.Grant Likely
This patch tightens up the behaviour of of_modalias_node() to be more predicatable and to eliminate the explicit of_modalias_tablep[] that is currently used to override the first entry in the compatible list of a device. The override table was needed originally because spi and i2c drivers had no way to do of-style matching. Now that all devices can have an of_node pointer, and all drivers can have an of_match_table, the explicit override table is no longer needed because each driver can specify its own OF-style match data. The mpc8349emitx-mcu driver is modified to explicitly specify the correct device to bind against. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of/i2c: Generalize OF supportGrant Likely
This patch cleans up the i2c OF support code to make it selectable by all architectures and allow for automatic registration of i2c devices. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of/device: Add OF style matching helper functionGrant Likely
Add of_driver_match_device() helper function. This function can be used by bus types to determine if a driver works with a device when using OF style matching. If CONFIG_OF is unselected, then it is a nop. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Michal Simek <monstr@monstr.eu> CC: Grant Likely <grant.likely@secretlab.ca> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: linux-kernel@vger.kernel.org CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: fix of_gpio includesGrant Likely
drivers/of/gpio.c is missing includes for of_irq and struct device which cause build failures on ARM. This patch adds the correct include files and removes the unneeded kernel.h include Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-05of/gpio: add default of_xlate function if device has a node pointerAnton Vorontsov
Implement generic OF gpio hooks and thus make device-enabled GPIO chips (i.e. the ones that have gpio_chip->dev specified) automatically attach to the OpenFirmware subsystem. Which means that now we can handle I2C and SPI GPIO chips almost* transparently. * "Almost" because some chips still require platform data, and for these chips OF-glue is still needed, though with this change the glue will be much smaller. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Bill Gatliff <bgat@billgatliff.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Andrew Morton <akpm@linux-foundation.org> CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: stop using device_node data pointer to find gpio_chipGrant Likely
Currently the kernel uses the struct device_node.data pointer to resolve a struct gpio_chip pointer from a device tree node. However, the .data member doesn't provide any type checking and there aren't any rules enforced on what it should be used for. There's no guarantee that the data stored in it actually points to an gpio_chip pointer. Instead of relying on the .data pointer, this patch modifies the code to add a lookup function which scans through the registered gpio_chips and returns the gpio_chip that has a pointer to the specified device_node. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Andrew Morton <akpm@linux-foundation.org> CC: Anton Vorontsov <avorontsov@ru.mvista.com> CC: Grant Likely <grant.likely@secretlab.ca> CC: David Brownell <dbrownell@users.sourceforge.net> CC: Bill Gatliff <bgat@billgatliff.com> CC: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Jean Delvare <khali@linux-fr.org> CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: Kill of_gpio_chip and add members directly to gpio_chipAnton Vorontsov
The OF gpio infrastructure is great for describing GPIO connections within the device tree. However, using a GPIO binding still requires changes to the gpio controller just to add an of_gpio structure. In most cases, the gpio controller doesn't actually need any special support and the simple OF gpio mapping function is more than sufficient. Additional, the current scheme of using of_gpio_chip requires a convoluted scheme to maintain 1:1 mappings between of_gpio_chip and gpio_chip instances. If the struct of_gpio_chip data members were moved into struct gpio_chip, then it would simplify the processing of OF gpio bindings, and it would make it trivial to use device tree OF connections on existing gpiolib controller drivers. This patch eliminates the of_gpio_chip structure and moves the relevant fields into struct gpio_chip (conditional on CONFIG_OF_GPIO). This move simplifies the existing code and prepares for adding automatic device tree support to existing drivers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Bill Gatliff <bgat@billgatliff.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org>
2010-07-05of/device: populate platform_device (of_device) resource table on allocationGrant Likely
When allocating a platform_device to represent an OF node, also allocate space for the resource table and populate it with IRQ and reg property information. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type so that existing platform_driver code can retrieve base addresses and IRQs data. Background: a previous commit removed struct of_device and made it a #define alias for platform_device. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Grant Likely <grant.likely@secretlab.ca> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of: Merge of_device_alloc() and of_device_make_bus_id()Grant Likely
This patch merges the common routines of_device_alloc() and of_device_make_bus_id() from powerpc and microblaze. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Grant Likely <grant.likely@secretlab.ca> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/device: Merge of_platform_bus_probe()Grant Likely
Merge common code between PowerPC and microblaze. This patch merges the code that scans the tree and registers devices. The functions merged are of_platform_bus_probe(), of_platform_bus_create(), and of_platform_device_create(). This patch also move the of_default_bus_ids[] table out of a Microblaze header file and makes it non-static. The device ids table isn't merged because powerpc and microblaze use different default data. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Grant Likely <grant.likely@secretlab.ca> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org
2010-07-05of: Modify of_device_get_modalias to be passed struct deviceGrant Likely
Now that the of_node pointer is part of struct device, of_device_get_modalias could be used on any struct device that has the device node pointer set. This patch changes of_device_get_modalias to accept a struct device instead of a struct of_device. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Wolfram Sang <w.sang@pengutronix.de> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org
2010-07-05of/device: merge of_device_ueventGrant Likely
Merge common code between powerpc and microblaze Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Wolfram Sang <w.sang@pengutronix.de> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org
2010-07-05of: Use full node name in resource structuresGrant Likely
Resource names appear in human readable output, so when extracting IRQ and address resources from a device tree node, use the full node name to give proper context in places like /proc/iomem. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: microblaze-uclinux@itee.uq.edu.au CC: linuxppc-dev@ozlabs.org
2010-07-05of/address: restrict 'no-ranges' kludge to powerpcGrant Likely
Certain Apple machines don't use the ranges property correctly, but the workaround should not be applied on other architectures. This patch disables the workaround for non-powerpc architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-05of/address: little-endian fixesGrant Likely
Fix some endian issues in the OF address translation code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Michal Simek <monstr@monstr.eu> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-05of/address: Merge all of the bus translation codeGrant Likely
Microblaze and PowerPC share a large chunk of code for translating OF device tree data into usable addresses. Differences between the two consist of cosmetic differences, and the addition of dma-ranges support code to powerpc but not microblaze. This patch moves the powerpc version into common code and applies many of the cosmetic (non-functional) changes from the microblaze version. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Michal Simek <monstr@monstr.eu> CC: Wolfram Sang <w.sang@pengutronix.de> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-05of/address: merge of_address_to_resource()Grant Likely
Merge common code between PowerPC and Microblaze. This patch also moves the prototype of pci_address_to_pio() out of pci-bridge.h and into prom.h because the only user of pci_address_to_pio() is of_address_to_resource(). Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Michal Simek <monstr@monstr.eu> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-05of/address: merge of_iomap()Grant Likely
Merge common code between Microblaze and PowerPC. This patch creates new of_address.h and address.c files to containing address translation and mapping routines. First routine to be moved it of_iomap() Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Michal Simek <monstr@monstr.eu> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-05of/irq: little endian fixesRob Herring
Fix some endian issues in the irq mapping OF code. Signed-off-by: Rob Herring <r.herring@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Wolfram Sang <w.sang@pengutronix.de> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-05of/irq: merge irq mapping codeGrant Likely
Merge common irq mapping code between PowerPC and Microblaze. This patch merges of_irq_find_parent(), of_irq_map_raw() and of_irq_map_one(). The functions are dependent on one another, so all three are merged in a single patch. Other than cosmetic difference (ie. DBG() vs. pr_debug()), the implementations are identical. of_irq_to_resource() is also merged, but in this case the implementations are different. This patch drops the microblaze version and uses the powerpc implementation unchanged. The microblaze version essentially open-coded irq_of_parse_and_map() which it does not need to do. Therefore the powerpc version is safe to adopt. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Michal Simek <monstr@monstr.eu> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Stephen Rothwell <sfr@canb.auug.org.au>
2010-06-28of/irq: Move irq_of_parse_and_map() to common codeGrant Likely
Merge common code between PowerPC and Microblaze. SPARC implements irq_of_parse_and_map(), but the implementation is different, so it does not use this code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jeremy Kerr <jeremy.kerr@canonical.com>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: change of_match_device to work with struct deviceGrant Likely
The of_node pointer is now stored directly in struct device, so of_match_device() should work with any device, not just struct of_device. This patch changes the interface to of_match_device() to accept a struct device instead of struct of_device. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-22drivercore: Add of_match_table to the common device driversGrant Likely
OF-style matching can be available to any device, on any type of bus. This patch allows any driver to provide an OF match table when CONFIG_OF is enabled so that drivers can be bound against devices described in the device tree. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18of: eliminate of_device->node and dev_archdata->{of,prom}_nodeGrant Likely
This patch eliminates the node pointer from struct of_device and the of_node (or prom_node) pointer from struct dev_archdata since the node pointer is now part of struct device proper when CONFIG_OF is set, and all users of the old pointer locations have already been converted over to use device->of_node. Also remove dev_archdata_{get,set}_node() as it is no longer used by anything. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28i2c/of: Allow device node to be passed via i2c_board_infoGrant Likely
The struct device_node *of_node pointer is moving out of dev->archdata and into the struct device proper. of_i2c.c needs to set the of_node pointer before the device is registered. Since the i2c subsystem doesn't allow 2 stage allocation and registration of i2c devices, the of_node pointer needs to be passed via the i2c_board_info structure so that it is set prior to registration. This patch adds of_node to struct i2c_board_info (conditional on CONFIG_OF), sets of_node in i2c_new_device(), and modifies of_i2c.c to use the new parameter. The calling of dev_archdata_set_node() from of_i2c will be removed in a subsequent patch when of_node is removed from archdata and all users are converted over. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28driver-core: Add device node pointer to struct deviceGrant Likely
Currently, platforms using CONFIG_OF add a 'struct device_node *of_node' to dev->archdata. However, with CONFIG_OF becoming generic for all architectures, it makes sense for commonality to move it out of archdata and into struct device proper. This patch adds a struct device_node *of_node member to struct device and updates all locations which currently write the device_node pointer into archdata to also update dev->of_node. Subsequent patches will modify callers to use the archdata location and ultimately remove the archdata member entirely. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> CC: Michal Simek <monstr@monstr.eu> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: "David S. Miller" <davem@davemloft.net> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Jeremy Kerr <jeremy.kerr@canonical.com> CC: microblaze-uclinux@itee.uq.edu.au CC: linux-kernel@vger.kernel.org CC: linuxppc-dev@ozlabs.org CC: sparclinux@vger.kernel.org
2010-04-28of/flattree: Make unflatten_device_tree() safe to call from any archGrant Likely
This patch makes unflatten_device_tree() safe to call from any arch setup code with the following changes: - Make sure initial_boot_params actually points to a device tree blob before unflattening - Make sure the initial_boot_params->magic field is correct - If CONFIG_OF_FLATTREE is not set, then make unflatten_device_tree() an empty static inline function. This patch also adds some additional debug output to the top of unflatten_device_tree(). Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
