This patch adds macros of_property_for_each_u32() and
of_property_for_each_string(), which iterate over an array of values
within a device-tree property. Usage is for example:
struct property *prop;
const __be32 *p;
u32 u;
of_property_for_each_u32(np, "propname", prop, p, u)
printk("U32 value: %x\n", u);
const char *s;
of_property_for_each_string(np, "propname", prop, s)
printk("String value: %s\n", s);
Based on work by Rob Herring <robherring2@gmail.com>
Change-Id: I8409ee84d2a94398a36bf1cc3f8b8e6821f40842
Cc: Grant Likely <grant.likely@secretlab.ca>
Acked-by: Rob Herring <rob.herring@calxeda.com>
(cherry picked from commit c541adc637066407d4cda9db14dcb0e618966a4c)
Reviewed-on: http://git-master/r/120038
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
GVS: Gerrit_Virtual_Submit
of_gpio_simple_xlate() has an off-by-one bug where it checks to see if
args[0] is > ngpio instead of >=. args[0] must always be less than
ngpio because it is a zero-based enumeration.
Signed-off-by: Roland Stigge <stigge@antcom.de>
[grant.likely: beef up commit text]
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Since 9e6c643b (phy/fixed: use an unique MDIO bus name) the name of the fixed
PHY bus is "fixed-0". Teach of_phy_connect_fixed_link() the new name.
Tested on a P1020RDB PowerPC system.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Acked-by: Florian Fainelli <florian@openwrt.org>
drivers/of/fdt.c included 'asm/setup.h' twice, remove the duplicate.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
git://git.secretlab.ca/git/linux-2.6
2nd set of device tree changes and SPI bug fixes for v3.3
* tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of/irq: Add interrupts-names property to name an irq resource
of/address: Add reg-names property to name an iomem resource
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6:
spi/tegra: depend instead of select TEGRA_SYSTEM_DMA
In the file drivers/of/fdt.c, it uses the COMMAND_LINE_SIZE which is stated
in asm/setup.h, so asm/setup.h should be included in drivers/of/fdt.c.
Signed-off-by: Yu Yue <yuyue@mprc.pku.edu.cn>
Signed-off-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn>
Cc: Grant Likerly <grant.likely@secretlab.ca>
Cc: devicetree-discuss@lists.ozlabs.org
devicetree/next changes queued for v3.3 merge window
* tag 'devicetree-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6:
ARM: prom.h: Fix build error by removing unneeded header file
irq: check domain hwirq range for DT translate
dt: add empty of_get_node/of_put_node functions
of/pdt: fix section mismatch warning
i2c-designware: add OF binding support
dt/i2c: Enumerate some of the known trivial i2c devices
dt: reform for_each_property to for_each_property_of_node
ARM/of: allow *machine_desc.dt_compat to be const
of/base: Take NULL string into account for property with multiple strings
OF/device-tree: Add some entries to vendor-prefixes.txt
Fix up trivial add-add conflicts in include/linux/of.h
Changes queued in gpio/next for the start of the 3.3 merge window
* tag 'gpio-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6:
gpio: Add decode of WM8994 GPIO configuration
gpio: Convert GPIO drivers to module_platform_driver
gpio: Fix typo in comment in Samsung driver
gpio: Explicitly index samsung_gpio_cfgs
gpio: Add Linus Walleij as gpio co-maintainer
of: Add device tree selftests
of: create of_phandle_args to simplify return of phandle parsing data
gpio/powerpc: Eliminate duplication of of_get_named_gpio_flags()
gpio/microblaze: Eliminate duplication of of_get_named_gpio_flags()
gpiolib: output basic details and consolidate gpio device drivers
pch_gpio: Change company name OKI SEMICONDUCTOR to LAPIS Semiconductor
pch_gpio: Support new device LAPIS Semiconductor ML7831 IOH
spi/pl022: make the chip deselect handling thread safe
spi/pl022: add support for pm_runtime autosuspend
spi/pl022: disable the PL022 block when unused
spi/pl022: move device disable to workqueue thread
spi/pl022: skip default configuration before suspending
spi/pl022: fix build warnings
spi/pl022: only enable RX interrupts when TX is complete
Fix the following build error:
CC [M] fs/udf/balloc.o
In file included from /home/fabio/next/linux-next/arch/arm/include/asm/prom.h:16,
from include/linux/of.h:140,
from include/asm-generic/gpio.h:7,
from arch/arm/plat-mxc/include/mach/irqs.h:14,
from /home/fabio/next/linux-next/arch/arm/include/asm/irq.h:4,
from /home/fabio/next/linux-next/arch/arm/include/asm/hardirq.h:6,
from include/linux/hardirq.h:7,
from include/linux/highmem.h:8,
from include/linux/pagemap.h:10,
from include/linux/buffer_head.h:13,
from fs/udf/udfdecl.h:11,
from fs/udf/balloc.c:22:
/home/fabio/next/linux-next/arch/arm/include/asm/setup.h:146: error: redefinition of 'struct tag'
[grant.likely: fix build failure on drivers/of/fdt.c]
Add a interrupts-names property to allow the possibility to provide a name
to any interrupts entries. If the name is available, use it to name the
resource, otherwise keep the device full name.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Rob Herring <rob.herring@calxeda.com>
[grant.likely: use "interrupt-names" and tidy documentation]
Add a reg-names property to allow for reg regions to be reference by name
instead of by index. Some devices have multiple register regions which
are more naturally referenced by name.
If the name is available, use it to name the resource when creating a devices.
Otherwise keep the device name.
[Generalized documentation to be for any -names property]
Fix the following section mismatch warning - seen when building sparc32:
WARNING: vmlinux.o(.text+0x1ff9c0): Section mismatch in reference from the function kernel_tree_alloc() to the function .init.text:prom_early_alloc()
The function kernel_tree_alloc() references
the function __init prom_early_alloc().
This is often because kernel_tree_alloc lacks a __init
annotation or the annotation of prom_early_alloc is wrong.
prom_early_alloc() is annotated __init, and users of
kernel_tree_alloc() is also annotated __init.
So simply match the annoation of these to fix the warning.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Make this macro easier to use(do not need to pass properties, a node is
enough), also change to a more sensible name as for_each_child_of_node.
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
This allows dt_compat to point to a constant list of compatible strings.
The current implementation just ignore any NULL string inserted in a
multiple strings property.
In some cases we can have a property with a fix number of strings but
not necessarily used, like for example in a list of valid pinmux modes.
prop = "uart_rx", "uart_tx", "", "", "safe_mode";
Do no skip NULL string and take them into account in
of_property_read_string_index and of_property_count_strings.
Reported-by: Tony Lindgren <tony@atomide.com>
There is no requirement to override name entries in auxdata. Fix the
entry matching to use .compatible instead of .name to find the end of the
list.
Add some runtime test cases for the library of device tree parsing functions.
v2: - Add testcase for phandle with 0 args
- Don't run testcases if testcase data isn't present in device tree
of_parse_phandle_with_args() needs to return quite a bit of data. Rather
than making each datum a separate **out_ argument, this patch creates
struct of_phandle_args to contain all the returned data and reworks the
user of the function. This patch also enables of_parse_phandle_with_args()
to return the device node pointer for the phandle node.
This patch also ends up being fairly major surgery to
of_parse_handle_with_args(). The existing structure didn't work well
when extending to use of_phandle_args, and I discovered bugs during testing.
I also took the opportunity to rename the function to be like the
existing of_parse_phandle().
v2: - moved declaration of of_phandle_args to fix compile on non-DT builds
- fixed incorrect index in example usage
- fixed incorrect return code handling for empty entries
Reviewed-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds a kernel message, containing GPIO range and device
name on successful device registration, and removes duplicate messages from the following drivers:
* gpio-adp5588
* gpio-bt8xx
* gpio-cs5535
* gpio-janz-ttl
* gpio-nomadik
* gpio-pcf857x
* gpio-xilinx
* drivers/of/gpio.c
Signed-off-by: Hartmut Knaack <knaack.h@gmx.de>
[grant.likely@secretlab.ca: squashed 2 patches together]
PPC32/64 defines NO_IRQ to zero, so no problems expected.
ARM defines NO_IRQ to -1, but OF code relies on IRQ domains support,
which returns correct ('0') value in 'no irq' case. So everything
should be fine.
Other arches might break if some of their OF drivers rely on NO_IRQ
being not 0. If so, the drivers must be fixed, finally.
[ Rob Herring points out that microblaze should be fixed, and has posted
a patch for testing for that. - Linus ]
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
With the revert of "of/irq: of_irq_find_parent: check for parent equal to
child" (dc9372808412edb), we need another way to handle parent node equal
to the child node. This can simply be handled in of_irq_init by checking
for this condition.
Tested-by: Pawel Moll <pawel.moll@arm.com>
This reverts commit dc9372808412edbc653a675a526c2ee6c0c14a91.
As requested by Ben Herrenschmidt:
"This breaks some powerpc platforms at least. The practice of having
a node provide an explicit "interrupt-parent" property pointing to
itself is an old trick that we've used in the past to allow a
device-node to have interrupts routed to different controllers.
In that case, the node also contains an interrupt-map, so the node is
its own parent, the interrupt resolution hits the map, which then can
route each individual interrupt to a different parent."
Grant says:
"Ah, nuts, yes that is broken then. Yes, please revert the commit and
Rob & I will come up with a better solution.
Rob, I think it can be done by explicitly checking for np ==
desc->interrupt_parent in of_irq_init() instead of relying on
of_irq_find_parent() returning NULL."
Requested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: linuxppc-dev <linuxppc-dev@lists.ozlabs.org>
Cc: Tanmay Inamdar <tinamdar@apm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (106 commits)
powerpc/p3060qds: Add support for P3060QDS board
powerpc/83xx: Add shutdown request support to MCU handling on MPC8349 MITX
powerpc/85xx: Make kexec to interate over online cpus
powerpc/fsl_booke: Fix comment in head_fsl_booke.S
powerpc/85xx: issue 15 EOI after core reset for FSL CoreNet devices
powerpc/8xxx: Fix interrupt handling in MPC8xxx GPIO driver
powerpc/85xx: Add 'fsl,pq3-gpio' compatiable for GPIO driver
powerpc/86xx: Correct Gianfar support for GE boards
powerpc/cpm: Clear muram before it is in use.
drivers/virt: add ioctl for 32-bit compat on 64-bit to fsl-hv-manager
powerpc/fsl_msi: add support for "msi-address-64" property
powerpc/85xx: Setup secondary cores PIR with hard SMP id
powerpc/fsl-booke: Fix settlbcam for 64-bit
powerpc/85xx: Adding DCSR node to dtsi device trees
powerpc/85xx: clean up FPGA device tree nodes for Freecsale QorIQ boards
powerpc/85xx: fix PHYS_64BIT selection for P1022DS
powerpc/fsl-booke: Fix setup_initial_memory_limit to not blindly map
powerpc: respect mem= setting for early memory limit setup
powerpc: Update corenet64_smp_defconfig
powerpc: Update mpc85xx/corenet 32-bit defconfigs
Fix up trivial conflicts in:
- arch/powerpc/configs/40x/hcu4_defconfig
removed stale file, edited elsewhere
- arch/powerpc/include/asm/udbg.h, arch/powerpc/kernel/udbg.c:
added opal and gelic drivers vs added ePAPR driver
- drivers/tty/serial/8250.c
moved UPIO_TSI to powerpc vs removed UPIO_DWAPB support
* Correct description of of_platform_bus_create to match implementation
* Remove a level of indentation in of_dev_lookup
* 'next/dt' of git://git.linaro.org/people/arnd/arm-soc:
ARM: gic: use module.h instead of export.h
ARM: gic: fix irq_alloc_descs handling for sparse irq
ARM: gic: add OF based initialization
ARM: gic: add irq_domain support
irq: support domains with non-zero hwirq base
of/irq: introduce of_irq_init
ARM: at91: add at91sam9g20 and Calao USB A9G20 DT support
ARM: at91: dt: at91sam9g45 family and board device tree files
arm/mx5: add device tree support for imx51 babbage
arm/mx5: add device tree support for imx53 boards
ARM: msm: Add devicetree support for msm8660-surf
msm_serial: Add devicetree support
msm_serial: Use relative resources for iomem
Fix up conflicts in arch/arm/mach-at91/{at91sam9260.c,at91sam9g45.c}
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
For files that were getting these macros via the implicit presence
of module.h being everywhere.
With contributions from Stephen Rothwell <sfr@canb.auug.org.au>.
This file really needs the full module.h header file present, but
was just getting it implicitly before. Fix it up in advance so we
avoid build failures once the cleanup commit is present.
It was getting it implicitly before, since module.h was pulled
in via device.h -- but that is something we are going to make
go away soon.
arch/arm/include/asm/localtimer.h
arch/arm/mach-msm/board-msm8x60.c
of_irq_init will scan the devicetree for matching interrupt controller
nodes. Then it calls an initialization function for each found controller
in the proper order with parent nodes initialized before child nodes.
Based on initial pseudo code from Grant Likely.
Changes in v4:
- Drop unnecessary empty list check
- Be more verbose on errors
- Simplify "if (!desc) WARN_ON(1)" to "if (WARN_ON(!desc))"
Changes in v3:
- add missing kfree's found by Jamie
- Implement Grant's comments to simplify the init loop
- fix function comments
Changes in v2:
- Complete re-write of list searching code from Grant Likely
Reviewed-by: Jamie Iles <jamie@jamieiles.com>
Tested-by: Thomas Abraham <thomas.abraham@linaro.org>
The "phy_device_register()" call 5 lines down already calls
phy_scan_fixups(), there's no need to do it a second time.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
devicetree/next
An interrupt controller may often implicitly inherit itself from a parent
node when in fact the controller is the interrupt root controller. Guard
against the case of child == parent and return NULL in this case.
This can also be fixed by adding an explicit "interrupt-parent;" to a root
interrupt controller node.
Based on code from Grant Likely.
Add a helper similar to of_property_read_u32() that handles 64-bit
integers.
v2/v3: constify device node and property name parameters.
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Add of_property_read_string_index and of_property_count_strings
to retrieve one string inside a property that will contains
severals strings.
Signed-off-by: Kevin Hilman <khilman@ti.com>
The patch adds function of_alias_scan to populate a global lookup
table with the properties of 'aliases' node and function
of_alias_get_id for drivers to find alias id from the lookup table.
v3: Split out automatic addition of aliases on id lookup so that it can be
debated separately from the core functionality.
v2: - Add of_chosen/of_aliases populating and of_alias_scan() invocation
for OF_PROMTREE.
- Add locking
- rework parse loop
We used to overwrite with CONFIG_CMDLINE if we found a chosen
node but failed to get bootargs out of it or they were empty,
unless CONFIG_CMDLINE_FORCE is set.
Instead change that to overwrite if "data" is non empty after
the bootargs check. It allows arch code to have other mechanisms
to retrieve the command line prior to parsing the device-tree.
Note: CONFIG_CMDLINE_FORCE case should ideally be handled elsewhere
as it won't work as it-is if the device-tree has no /chosen node
CC: devicetree-discuss@lists-ozlabs.org
CC: Grant Likely <grant.likely@secretlab.ca>
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb.
of_alias_* still needs work to be generalized for 'promtree' dt
platforms, and to no implicitly create entries for available ids.
[grant.likely: add locking and rework parse loop]
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6:
MAINTAINERS: Add keyword match for of_match_table to device tree section
of: constify property name parameters for helper functions
input: xilinx_ps2: Add missing of_address.h header
of: address: use resource_size helper
The helper functions for reading u32 integers, u32 arrays and strings
should have the property name as a const pointer.
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio_msm: Move Qualcomm MSM v2 gpio driver into drivers
gpio_msm: Move Qualcomm v6 MSM driver into drivers
msm: gpio: Fold register defs into C file
msm: gpiomux: Move public API to public header
msm: gpio: Remove ifdefs on gpio chip registers
msm: gpio: Remove chip-specific register definitions
msm: Remove chip-ifdefs for GPIO io mappings
msm: gpio: Remove unsupported devices
gpio: ab8500: fix MODULE_ALIAS for ab8500
of/gpio: export of_gpio_simple_xlate
that should be the approved way of calculating
the size of resources. No functional changes.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Allow GPIO drivers to use of_gpio_simple_xlate. This is useful for the
generic GPIO driver for example where gpio_chip is embedded in
bgpio_chip and doesn't need of_mm_gpio_chip but has a simple 1:1 GPIO
mapping.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
The patch extends 'enum phy_interface_t' and of_get_phy_mode a little
bit with PHY_INTERFACE_MODE_NA and PHY_INTERFACE_MODE_SMII added,
and then converts ibm_newemac net driver to use of_get_phy_mode
getting phy mode from device tree.
It also resolves the namespace conflict on phy_read/write between
common mdiobus interface and ibm_newemac private one.
Acked-by: David Miller <davem@davemloft.net>
It adds the helper function of_get_phy_mode getting phy interface
from device tree.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
