path: root/drivers/of
2008-08-20powerpc/ibmebus: Restore "name" sysfs attribute on ibmebus devicesJoachim Fenkes
Recent of_platform changes made of_bus_type_init() overwrite the bus type's .dev_attrs list, meaning that the "name" attribute that ibmebus devices previously had is no longer present. This is a user-visible regression which breaks the userspace eHCA support, since the eHCA userspace driver relies on the name attribute to check for valid adapters. This fixes it by providing the "name" attribute in the generic OF device code instead. Tested on POWER. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-25spi: Add OF binding support for SPI bussesGrant Likely
This patch adds support for populating an SPI bus based on data in the OF device tree. This is useful for powerpc platforms which use the device tree instead of discrete code for describing platform layout. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-25of: adapt of_find_i2c_driver() to be usable by SPI alsoGrant Likely
SPI has a similar problem as I2C in that it needs to determine an appropriate modalias value for each device node. This patch adapts the of_i2c of_find_i2c_driver() function to be usable by of_spi also. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits) powerpc: Wireup new syscalls Move update_mmu_cache() declaration from tlbflush.h to pgtable.h powerpc/pseries: Remove kmalloc call in handling writes to lparcfg powerpc/pseries: Update arch vector to indicate support for CMO ibmvfc: Add support for collaborative memory overcommit ibmvscsi: driver enablement for CMO ibmveth: enable driver for CMO ibmveth: Automatically enable larger rx buffer pools for larger mtu powerpc/pseries: Verify CMO memory entitlement updates with virtual I/O powerpc/pseries: vio bus support for CMO powerpc/pseries: iommu enablement for CMO powerpc/pseries: Add CMO paging statistics powerpc/pseries: Add collaborative memory manager powerpc/pseries: Utilities to set firmware page state powerpc/pseries: Enable CMO feature during platform setup powerpc/pseries: Split retrieval of processor entitlement data into a helper routine powerpc/pseries: Add memory entitlement capabilities to /proc/ppc64/lparcfg powerpc/pseries: Split processor entitlement retrieval and gathering to helper routines powerpc/pseries: Remove extraneous error reporting for hcall failures in lparcfg powerpc: Fix compile error with binutils 2.15 ... Fixed up conflict in arch/powerpc/platforms/52xx/Kconfig manually.
2008-07-25gpiolib: allow user-selectionMichael Buesch
This patch adds functionality to the gpio-lib subsystem to make it possible to enable the gpio-lib code even if the architecture code didn't request to get it built in. The archtitecture code does still need to implement the gpiolib accessor functions in its asm/gpio.h file. This patch adds the implementations for x86 and PPC. With these changes it is possible to run generic GPIO expansion cards on every architecture that implements the trivial wrapper functions. Support for more architectures can easily be added. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22powerpc/mpc5200: Fix wrong 'no interrupt' handling in of_i2cWolfram Sang
If an I2C device node does not specify an interrupt, the .irq member of the board_info struct was set to -1. This caused crashes on following irq_dispose_mappings. Leave it NO_IRQ as returned from irq_of_parse_and_map. (Suggesting -1 as 'i2c-no-irq' used to be a bug in linux/i2c.h.) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-12OpenFirmware: Include <linux/of_i2c.h> from of_i2c.c.Robert P. J. Day
drivers/of/of_i2c.c should include <linux/of_i2c.h> for the prototype for of_register_i2c_devices(). Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-06-09Merge branch 'merge'Paul Mackerras
Conflicts: arch/powerpc/sysdev/fsl_soc.c
2008-06-06rtc-ds1374: rename device to just "ds1374"Jean Delvare
Change the name of the device from "rtc-ds1374" to just "ds1374", to match what all other RTC drivers do. I seem to remember that this name was chosen to avoid possible confusion with an older ds1374 driver, but that driver was removed 3 months ago. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23[POWERPC] of/gpio: Use dynamic base allocationAnton Vorontsov
Since the "gpiolib: dynamic gpio number allocation" patch was recently merged into Linus' tree (commit 8d0aab2f16c4fa170f32e7a74a52cd0122bbafef), we can use dynamic GPIO base allocation now. This, in turn, removes number of gpios per chip constraint. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-16[POWERPC] Move of_device_get_modalias to drivers/ofStephen Rothwell
Commit 140b932f8cb6cced10b96860651a198b1b89cbb9 ("Create modalias file in sysfs for of_platform bus") needs this to avoid breaking the sparc builds. Just move the code and add whitespace around some binary operators. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-16Merge branch 'linux-2.6' into powerpc-nextPaul Mackerras
2008-05-15[POWERPC] Add null pointer check to of_find_propertyTimur Tabi
Update function of_find_property() to return NULL if the device_node passed to it is also NULL. Otherwise, passing NULL will cause a null pointer dereference. Without this, the legacy_serial driver will crash if there's no 'chosen' node in the device tree. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-14[POWERPC] Create modalias file in sysfs for of_platform busOlaf Hering
Create /sys/bus/of_platform/devices/*/modalias file to allow autoloading of modules. Modalias files are already present for many other bus types. This adds also a newline to the devspec files. Also create a devspec file for mac-io devices. They were created as a side effect. Use correct buffer size for mac-io modalias buffer. Tested on iBook1 and Efika. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-24[POWERPC] drivers/of/of_i2c.c: Add MODULE_LICENSEAdrian Bunk
After commit 585468e5d5962660867c269e26f0a4b89a599473 ([POWERPC] i2c: Fix build breakage introduced by OF helpers) drivers/of/of_i2c.c needs a MODULE_LICENSE. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-20[POWERPC] i2c: Fix build breakage introduced by OF helpersJochen Friedrich
Fix build breakage introduced in commit "[POWERPC] i2c: OF helpers for the i2c API". If i2c-core is compiled as a module, the helper needs to be compiled as a module, as well. Rename i2c.c to of_i2c.c to avoid name space conflict. [paulus@samba.org: Changed dependency from OF to PPC_OF to avoid sparc{32,64} allmodconfig breakage.] Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-17[POWERPC] i2c: OF helpers for the i2c APIJochen Friedrich
This implements various helpers to support OF bindings for the i2c API. Signed-off-by: Jochen Friedrich <jochen@scram.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-17[POWERPC] OF helpers for the GPIO APIAnton Vorontsov
This implements various helpers to support OF bindings for the GPIO LIB API. Previously this was PowerPC specific, but it seems this code isn't arch-dependent anyhow, so let's place it into of/. SPARC will not see this addition yet, real hardware seem to not use GPIOs at all. But this might change: http://www.leox.org/docs/faq_MLleon.html "16-bit I/O port" sounds promising. :-) Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-07[POWERPC] Add of_device_is_available functionJosh Boyer
IEEE 1275 defined a standard "status" property to indicate the operational status of a device. The property has four possible values: okay, disabled, fail, fail-xxx. The absence of this property means the operational status of the device is unknown or okay. This adds a function called of_device_is_available that checks the state of the status property of a device. If the property is absent or set to either "okay" or "ok", it returns 1. Otherwise it returns 0. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-06[POWERPC] Create and hook up of_platform_device_shutdownMichael Ellerman
Although of_platform_device's can have a shutdown routine, at the moment the bus code doesn't actually call it. So add the required glue to hook the shutdown routine. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-06[POWERPC] Add of_get_next_parent()Michael Ellerman
Iterating through a device node's parents is simple enough, but dealing with the refcounts properly is a little ugly, and replicating that logic is asking for someone to get it wrong or forget it all together, eg: while (dn != NULL) { /* loop body */ tmp = of_get_parent(dn); of_node_put(dn); dn = tmp; } So add of_get_next_parent(), inspired by of_get_next_child(). The contract is that it returns the parent and drops the reference on the current node, this makes the loop look like: while (dn != NULL) { /* loop body */ dn = of_get_next_parent(dn); } Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-17[POWERPC] Add of_find_matching_node() helper functionGrant Likely
Similar to of_find_compatible_node(), of_find_matching_node() and for_each_matching_node() allow you to iterate over the device tree looking for specific nodes, except that they take of_device_id tables instead of strings. This also moves of_match_node() from driver/of/device.c to driver/of/base.c to colocate it with the of_find_matching_node which depends on it. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[SPARC/64]: Consolidate of_register_driverStephen Rothwell
Also of_unregister_driver. These will be shortly also used by the PowerPC code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-20Create drivers/of/platform.cStephen Rothwell
and populate it with the common parts from PowerPC and Sparc[64]. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Begin consolidation of of_device.hStephen Rothwell
This just moves the common stuff from the arch of_device.h files to linux/of_device.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Begin to consolidate of_device.cStephen Rothwell
This moves all the common parts for the Sparc, Sparc64 and PowerPC of_device.c files into drivers/of/device.c. Apart from the simple move, Sparc gains of_match_node() and a call to of_node_put in of_release_dev(). PowerPC gains better recovery if device_create_file() fails in of_device_register(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Consolidate of_find_node_by routinesStephen Rothwell
This consolidates the routines of_find_node_by_path, of_find_node_by_name, of_find_node_by_type and of_find_compatible_device. Again, the comparison of strings are done differently by Sparc and PowerPC and also these add read_locks around the iterations. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Consolidate of_get_next_childStephen Rothwell
This adds a read_lock around the child/next accesses on Sparc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Consolidate of_get_parentStephen Rothwell
This requires creating dummy of_node_{get,put} routines for sparc and sparc64. It also adds a read_lock around the parent accesses. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Consolidate of_find_propertyStephen Rothwell
The only change here is that a readlock is taken while the property list is being traversed on Sparc where it was not taken previously. Also, Sparc uses strcasecmp to compare property names while PowerPC uses strcmp. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Consolidate of_device_is_compatibleStephen Rothwell
The only difference here is that Sparc uses strncmp to match compatibility names while PowerPC uses strncasecmp. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
2007-07-20Start split out of common open firmware codeStephen Rothwell
This creates drivers/of/base.c (depending on CONFIG_OF) and puts the first trivially common bits from the prom.c files into it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
