path: root/drivers/oprofile/event_buffer.h
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-25[PATCH] oprofile: convert from semaphores to mutexesMarkus Armbruster
Signed-off-by: Markus Armbruster <armbru@redhat.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] oprofile: report anonymous region samplesJohn Levon
The below patch passes samples from anonymous regions to userspace instead of just dropping them. This provides the support needed for reporting anonymous-region code samples (today: basic accumulated results; later: Java and other dynamically compiled code). As this changes the format, an upgrade to the just-released 0.9 release of the userspace tools is required. This patch is based upon an earlier one by Will Cohen <wcohen@redhat.com> Signed-off-by: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
