path: root/drivers/oprofile/oprofile_stats.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-20oprofile: Adding switch counter to oprofile statistic variablesRobert Richter
This patch moves the multiplexing switch counter from x86 code to common oprofile statistic variables. Now the value will be available and usable for all architectures. The initialization and incrementation also moved to common code. Signed-off-by: Robert Richter <robert.richter@amd.com>
2008-10-16oprofile: fixing whitespaces in drivers/oprofile/*Robert Richter
2008-10-15oprofile: more whitespace fixesRobert Richter
