path: root/drivers/oprofile
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] oprofile: convert from semaphores to mutexesMarkus Armbruster
Signed-off-by: Markus Armbruster <armbru@redhat.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] for_each_possible_cpu: oprofile.KAMEZAWA Hiroyuki
This patch replaces for_each_cpu with for_each_possible_cpu. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Add oprofile_add_ext_sampleBrian Rogan
On ppc64 we look at a profiling register to work out the sample address and if it was in userspace or kernel. The backtrace interface oprofile_add_sample does not allow this. Create oprofile_add_ext_sample and make oprofile_add_sample use it too. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] oprofile: Use vmalloc_node() in alloc_cpu_buffers()Eric Dumazet
Make oprofile alloc_cpu_buffers() function NUMA aware, allocating each CPU local buffer in its memory node if possible. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Make RCU task_struct safe for oprofilePaul E. McKenney
Applying RCU to the task structure broke oprofile, because free_task_notify() can now be called from softirq. This means that the task_mortuary lock must be acquired with irq disabled in order to avoid intermittent self-deadlock. Since irq is now disabled, the critical section within process_task_mortuary() has been restructured to be O(1) in order to maximize scalability and minimize realtime latency degradation. Kudos to Wu Fengguang for finding this problem! CC: Wu Fengguang <wfg@mail.ustc.edu.cn> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] oprofile: report anonymous region samplesJohn Levon
The below patch passes samples from anonymous regions to userspace instead of just dropping them. This provides the support needed for reporting anonymous-region code samples (today: basic accumulated results; later: Java and other dynamically compiled code). As this changes the format, an upgrade to the just-released 0.9 release of the userspace tools is required. This patch is based upon an earlier one by Will Cohen <wcohen@redhat.com> Signed-off-by: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] smp_processor_id() cleanupIngo Molnar
This patch implements a number of smp_processor_id() cleanup ideas that Arjan van de Ven and I came up with. The previous __smp_processor_id/_smp_processor_id/smp_processor_id API spaghetti was hard to follow both on the implementational and on the usage side. Some of the complexity arose from picking wrong names, some of the complexity comes from the fact that not all architectures defined __smp_processor_id. In the new code, there are two externally visible symbols: - smp_processor_id(): debug variant. - raw_smp_processor_id(): nondebug variant. Replaces all existing uses of _smp_processor_id() and __smp_processor_id(). Defined by every SMP architecture in include/asm-*/smp.h. There is one new internal symbol, dependent on DEBUG_PREEMPT: - debug_smp_processor_id(): internal debug variant, mapped to smp_processor_id(). Also, i moved debug_smp_processor_id() from lib/kernel_lock.c into a new lib/smp_processor_id.c file. All related comments got updated and/or clarified. I have build/boot tested the following 8 .config combinations on x86: {SMP,UP} x {PREEMPT,!PREEMPT} x {DEBUG_PREEMPT,!DEBUG_PREEMPT} I have also build/boot tested x64 on UP/PREEMPT/DEBUG_PREEMPT. (Other architectures are untested, but should work just fine.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-26[PATCH] oprofile trivial user annotationsAl Viro
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
