commit 913050b91eb94f194392dd797b1ff3779f606ac0 upstream.
If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
commit 87121ca504fd1d963a66b3fb0c72054b0fd9a177 upstream.
Oprofile may crash in a KVM guest while unlaoding modules. This
happens if oprofile_arch_init() fails and oprofile switches to the hr
timer mode as a fallback. In this case oprofile_arch_exit() is called,
but it never was initialized properly which causes the crash. This
patch fixes this.
oprofile: using timer interrupt.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
PGD 41da3f067 PUD 41d80e067 PMD 0
Oops: 0002 [#1] PREEMPT SMP
CPU 5
Modules linked in: oprofile(-)
Pid: 2382, comm: modprobe Not tainted 3.1.0-rc7-00018-g709a39d #18 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff8123c226>] [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP: 0018:ffff88041de1de98 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffffffffa00060e0 RCX: dead000000200200
RDX: 0000000000000000 RSI: dead000000100100 RDI: ffffffff8178c620
RBP: ffff88041de1dea8 R08: 0000000000000001 R09: 0000000000000082
R10: 0000000000000000 R11: ffff88041de1dde8 R12: 0000000000000080
R13: fffffffffffffff5 R14: 0000000000000001 R15: 0000000000610210
FS: 00007f9ae5bef700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 000000041ca44000 CR4: 00000000000006e0
Process modprobe (pid: 2382, threadinfo ffff88041de1c000, task ffff88042db6d040)
Stack:
ffff88041de1deb8 ffffffffa0006770 ffff88041de1deb8 ffffffffa000251e
ffff88041de1dec8 ffffffffa00022c2 ffff88041de1ded8 ffffffffa0004993
ffff88041de1df78 ffffffff81073115 656c69666f72706f 0000000000610200
Call Trace:
[<ffffffffa000251e>] op_nmi_exit+0x15/0x17 [oprofile]
[<ffffffffa00022c2>] oprofile_arch_exit+0xe/0x10 [oprofile]
[<ffffffffa0004993>] oprofile_exit+0x13/0x15 [oprofile]
[<ffffffff81073115>] sys_delete_module+0x1c3/0x22f
[<ffffffff811bf09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8148070b>] system_call_fastpath+0x16/0x1b
Code: 20 c6 78 81 e8 c5 cc 23 00 48 8b 13 48 8b 43 08 48 be 00 01 10 00 00 00 ad de 48 b9 00 02 20 00 00 00 ad de 48 c7 c7 20 c6 78 81
89 42 08 48 89 10 48 89 33 48 89 4b 08 e8 a6 c0 23 00 5a 5b
RIP [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP <ffff88041de1de98>
---[ end trace 06d4e95b6aa3b437 ]---
This fixes the A->B/B->A locking dependency, see the warning below.
The function task_exit_notify() is called with (task_exit_notifier)
.rwsem set and then calls sync_buffer() which locks buffer_mutex. In
sync_start() the buffer_mutex was set to prevent notifier functions to
be started before sync_start() is finished. But when registering the
notifier, (task_exit_notifier).rwsem is locked too, but now in
different order than in sync_buffer(). In theory this causes a locking
dependency, what does not occur in practice since task_exit_notify()
is always called after the notifier is registered which means the lock
is already released.
However, after checking the notifier functions it turned out the
buffer_mutex in sync_start() is unnecessary. This is because
sync_buffer() may be called from the notifiers even if sync_start()
did not finish yet, the buffers are already allocated but empty. No
need to protect this with the mutex.
So we fix this theoretical locking dependency by removing buffer_mutex
in sync_start(). This is similar to the implementation before commit:
750d857 oprofile: fix crash when accessing freed task structs
which introduced the locking dependency.
Lockdep warning:
oprofiled/4447 is trying to acquire lock:
(buffer_mutex){+.+...}, at: [<ffffffffa0000e55>] sync_buffer+0x31/0x3ec [oprofile]
but task is already holding lock:
((task_exit_notifier).rwsem){++++..}, at: [<ffffffff81058026>] __blocking_notifier_call_chain+0x39/0x67
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 ((task_exit_notifier).rwsem){++++..}:
[<ffffffff8106557f>] lock_acquire+0xf8/0x11e
[<ffffffff81463a2b>] down_write+0x44/0x67
[<ffffffff810581c0>] blocking_notifier_chain_register+0x52/0x8b
[<ffffffff8105a6ac>] profile_event_register+0x2d/0x2f
[<ffffffffa00013c1>] sync_start+0x47/0xc6 [oprofile]
[<ffffffffa00001bb>] oprofile_setup+0x60/0xa5 [oprofile]
[<ffffffffa00014e3>] event_buffer_open+0x59/0x8c [oprofile]
[<ffffffff810cd3b9>] __dentry_open+0x1eb/0x308
[<ffffffff810cd59d>] nameidata_to_filp+0x60/0x67
[<ffffffff810daad6>] do_last+0x5be/0x6b2
[<ffffffff810dbc33>] path_openat+0xc7/0x360
[<ffffffff810dbfc5>] do_filp_open+0x3d/0x8c
[<ffffffff810ccfd2>] do_sys_open+0x110/0x1a9
[<ffffffff810cd09e>] sys_open+0x20/0x22
[<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b
-> #0 (buffer_mutex){+.+...}:
[<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711
[<ffffffff814634f0>] mutex_lock_nested+0x63/0x309
[<ffffffffa0001226>] task_exit_notify+0x16/0x1a [oprofile]
[<ffffffff81467b96>] notifier_call_chain+0x37/0x63
[<ffffffff8105803d>] __blocking_notifier_call_chain+0x50/0x67
[<ffffffff81058068>] blocking_notifier_call_chain+0x14/0x16
[<ffffffff8105a718>] profile_task_exit+0x1a/0x1c
[<ffffffff81039e8f>] do_exit+0x2a/0x6fc
[<ffffffff8103a5e4>] do_group_exit+0x83/0xae
[<ffffffff8103a626>] sys_exit_group+0x17/0x1b
1 lock held by oprofiled/4447:
#0: ((task_exit_notifier).rwsem){++++..}, at: [<ffffffff81058026>] __blocking_notifier_call_chain+0x39/0x67
stack backtrace:
Pid: 4447, comm: oprofiled Not tainted 2.6.39-00007-gcf4d8d4 #10
Call Trace:
[<ffffffff81063193>] print_circular_bug+0xae/0xbc
[<ffffffffa0000e55>] ? sync_buffer+0x31/0x3ec [oprofile]
[<ffffffff81062627>] ? mark_lock+0x42f/0x552
[<ffffffff81058026>] ? __blocking_notifier_call_chain+0x39/0x67
[<ffffffff81465031>] ? retint_swapgs+0xe/0x13
Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Carl Love <carll@us.ibm.com>
Cc: <stable@kernel.org> # .36+
After registering the task free notifier we possibly have tasks in our
dying_tasks list. Free them after unregistering the notifier in case
of an error.
The oprofile code is still including asm/mutex.h instead of
linux/mutex.h.
This patch is a rework of the hwsampler oprofile implementation that
has been applied recently. Now there are less non-architectural
changes. The only changes are:
* introduction of oprofile_add_ext_hw_sample(), and
* removal of section attributes of oprofile_timer_init/_exit().
To setup hwsampler for oprofile we need to modify start()/stop()
callbacks and additional hwsampler control files in oprofilefs. We do
not reinitialize the timer or hwsampler mode by restarting calling
init/exit() anymore, instead hwsampler_running is used to switch the
mode directly in oprofile_hwsampler_start/_stop(). For locking reasons
there is also hwsampler_file that reflects the value in oprofilefs.
The overall diffstat of the oprofile s390 hwsampler implemenation
shows the low impact to non-architectural code:
arch/Kconfig | 3 +
arch/s390/Kconfig | 1 +
arch/s390/oprofile/Makefile | 2 +-
arch/s390/oprofile/hwsampler.c | 1256 ++++++++++++++++++++++++++++++++++
arch/s390/oprofile/hwsampler.h | 113 +++
arch/s390/oprofile/hwsampler_files.c | 162 +++++
arch/s390/oprofile/init.c | 6 +-
drivers/oprofile/cpu_buffer.c | 24 +-
drivers/oprofile/timer_int.c | 4 +-
include/linux/oprofile.h | 7 +
10 files changed, 1567 insertions(+), 11 deletions(-)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
OProfile is enhanced to export all files for controlling System z's
hardware sampling, and to invoke hwsampler exported functions to
initialize and use System z's hardware sampling.
The patch invokes hwsampler_setup() during oprofile init and exports
following hwsampler files under oprofilefs if hwsampler's setup
succeeded:
A new directory for hardware sampling based files
/dev/oprofile/hwsampling/
The userland daemon must explicitly write to the following files
to disable (or enable) hardware based sampling
/dev/oprofile/hwsampling/hwsampler
to modify the actual sampling rate
/dev/oprofile/hwsampling/hw_interval
to modify the amount of sampling memory (measured in 4K pages)
/dev/oprofile/hwsampling/hw_sdbt_blocks
The following files are read only and show
the possible minimum sampling rate
/dev/oprofile/hwsampling/hw_min_interval
the possible maximum sampling rate
/dev/oprofile/hwsampling/hw_max_interval
The patch splits the oprofile_timer_[init/exit] function so that it
can be also called through user context (oprofilefs) to avoid kernel
oops.
Applied with following changes:
* whitespace changes in Makefile and timer_int.c
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Signed-off-by: Maran Pakkirisamy <maranp@linux.vnet.ibm.com>
Signed-off-by: Heinz Graalfs <graalfs@linux.vnet.ibm.com>
(oprofile_add_ext_hw_sample)
This patch introduces a new oprofile sample add function
(oprofile_add_ext_hw_sample) that can also take task_struct as an
argument, which is used by the hwsampler kernel module when copying
hardware samples to OProfile buffers.
* removed #include <linux/module.h>
* removed conditional compilation (CONFIG_HAVE_HWSAMPLER)
* modified order of functions
* fix missing function definition in header file
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
jump label: Add work around to i386 gcc asm goto bug
x86, ftrace: Use safe noops, drop trap test
jump_label: Fix unaligned traps on sparc.
jump label: Make arch_jump_label_text_poke_early() optional
jump label: Fix error with preempt disable holding mutex
oprofile: Remove deprecated use of flush_scheduled_work()
oprofile: Fix the hang while taking the cpu offline
jump label: Fix deadlock b/w jump_label_mutex vs. text_mutex
jump label: Fix module __init section race
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Check irq_remapped instead of remapping_enabled in destroy_irq()
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
flush_scheduled_work() is deprecated and scheduled to be removed.
sync_stop() currently cancels cpu_buffer works inside buffer_mutex and
flushes the system workqueue outside. Instead, split end_cpu_work()
into two parts - stopping further work enqueues and flushing works -
and do the former inside buffer_mutex and latter outside.
For stable kernels v2.6.35.y and v2.6.36.y.
Cc: stable@kernel.org
The kernel build with CONFIG_OPROFILE and CPU_HOTPLUG enabled.
The oprofile is initialised using system timer in absence of hardware
counters supports. Oprofile isn't started from userland.
In this setup while doing a CPU offline the kernel hangs in infinite
for loop inside lock_hrtimer_base() function
This happens because as part of oprofile_cpu_notify(, it tries to
stop an hrtimer which was never started. These per-cpu hrtimers
are started when the oprfile is started.
echo 1 > /dev/oprofile/enable
This problem also existwhen the cpu is booted with maxcpus parameter
set. When bringing the remaining cpus online the timers are started
even if oprofile is not yet enabled.
This patch fix this issue by adding a state variable so that
these hrtimer start/stop is only attempted when oprofile is
started
Reported-by: Jan Sebastien <s-jan@ti.com>
Tested-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Make !CONFIG_PM function stubs static inline and remove section
attribute.
Commit e9677b3ce (oprofile, ARM: Use oprofile_arch_exit() to
cleanup on failure) caused oprofile_perf_exit to be called
in the cleanup path of oprofile_perf_init. The __exit tag
for oprofile_perf_exit should therefore be dropped.
The same has to be done for exit_driverfs as well, as this
function is called from oprofile_perf_exit. Else, we get
the following two linker errors.
LD .tmp_vmlinux1
`oprofile_perf_exit' referenced in section `.init.text' of arch/arm/oprofile/built-in.o: defined in discarded section `.exit.text' of arch/arm/oprofile/built-in.o
make: *** [.tmp_vmlinux1] Error 1
LD .tmp_vmlinux1
`exit_driverfs' referenced in section `.text' of arch/arm/oprofile/built-in.o: defined in discarded section `.exit.text' of arch/arm/oprofile/built-in.o
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
oprofile_perf.c needs to include platform_device.h
Otherwise we get the following build break.
CC arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.o
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:192: warning: 'struct platform_device' declared inside parameter list
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:192: warning: its scope is only this definition or declaration, which is probably not what you want
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:201: warning: 'struct platform_device' declared inside parameter list
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:210: error: variable 'oprofile_driver' has initializer but incomplete type
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:211: error: unknown field 'driver' specified in initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:211: error: extra brace group at end of initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:211: error: (near initialization for 'oprofile_driver')
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:213: warning: excess elements in struct initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:213: warning: (near initialization for 'oprofile_driver')
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:214: error: unknown field 'resume' specified in initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:214: warning: excess elements in struct initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:214: warning: (near initialization for 'oprofile_driver')
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:215: error: unknown field 'suspend' specified in initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:215: warning: excess elements in struct initializer
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c:215: warning: (near initialization for 'oprofile_driver')
arch/arm/oprofile/../../../drivers/oprofile/oprofile_perf.c: In function 'init_driverfs':
Cc: Matt Fleming <matt@console-pimps.org>
arch/arm/oprofile/common.c
kernel/perf_event.c
Oprofile counters are setup when profiling is disabled. Thus, writing
to oprofilefs has no immediate effect. Changes are updated only after
oprofile is reenabled.
To keep userland and kernel states synchronized, we now allow
configuration of oprofile only if profiling is disabled. In this case
it checks if the profiler is running and then disables write access to
oprofilefs by returning -EBUSY. The change should be backward
compatible with current oprofile userland daemon.
Acked-by: Maynard Johnson <maynardj@us.ibm.com>
Cc: William Cohen <wcohen@redhat.com>
Cc: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
There is duplicate cleanup code in the init and exit functions. Now,
oprofile_arch_exit() is also used if oprofile_arch_init() fails.
Acked-by: Will Deacon <will.deacon@arm.com>
This patch simplifies op_create_counter(). Removing if/else if paths
and return code variable by direct returning from function.
This patch removes some unnecessary goto statements.
This patch fixes a resource leak on failure, where the
oprofilefs and some counters may not released properly.
Cc: <stable@kernel.org> # .35.x
LKML-Reference: <20100929145225.GJ13563@erda.amd.com>
Move the perf-events backend from arch/arm/oprofile into
drivers/oprofile so that the code can be shared between architectures.
This allows each architecture to maintain only a single copy of the PMU
accessor functions instead of one for both perf and OProfile. It also
becomes possible for other architectures to delete much of their
OProfile code in favour of the common code now available in
drivers/oprofile/oprofile_perf.c.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Tested-by: Will Deacon <will.deacon@arm.com>
Removing duplicate code by assigning the inodes private data pointer
in __oprofilefs_create_file(). Extending the function interface to
pass the pointer.
oprofile_init calls oprofile_arch_init to initialise the architecture-specific
backend code. If this backend code returns failure, oprofile_arch_exit is
called immediately, making it difficult to allocate and free resources
correctly.
This patch removes the oprofile_arch_exit call from oprofile_init,
meaning that all architectures must ensure that oprofile_arch_init
cleans up any mess it's made before returning an error. As far as
I can tell, this only affects the code for ARM.
Cc: Robert Richter <robert.richter@amd.com>
This patch fixes a crash during shutdown reported below. The crash is
caused by accessing already freed task structs. The fix changes the
order for registering and unregistering notifier callbacks.
All notifiers must be initialized before buffers start working. To
stop buffer synchronization we cancel all workqueues, unregister the
notifier callback and then flush all buffers. After all of this we
finally can free all tasks listed.
This should avoid accessing freed tasks.
On 22.07.10 01:14:40, Benjamin Herrenschmidt wrote:
> So the initial observation is a spinlock bad magic followed by a crash
> in the spinlock debug code:
> [ 1541.586531] BUG: spinlock bad magic on CPU#5, events/5/136
> [ 1541.597564] Unable to handle kernel paging request for data at address 0x6b6b6b6b6b6b6d03
> Backtrace looks like:
> spin_bug+0x74/0xd4
> ._raw_spin_lock+0x48/0x184
> ._spin_lock+0x10/0x24
> .get_task_mm+0x28/0x8c
> .sync_buffer+0x1b4/0x598
> .wq_sync_buffer+0xa0/0xdc
> .worker_thread+0x1d8/0x2a8
> .kthread+0xa8/0xb4
> .kernel_thread+0x54/0x70
> So we are accessing a freed task struct in the work queue when
> processing the samples.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
The event buffer cannot deal with seeks, so
we should forbid that outright.
Cc: oprofile-list@lists.sf.net
http://lkml.org/lkml/2010/4/27/285
Protect against dereferencing regs when it's NULL, and
force a magic number into pc to prevent too deep processing.
This approach permits the dropped samples to be tallied as
invalid Instruction Pointer events.
e.g. output from about 15mins at 10kHz sample rate:
Nr. samples received: 2565380
Nr. samples lost invalid pc: 4
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
oprofile used a double buffer scheme for its cpu event buffer
to avoid races on reading with the old locked ring buffer.
But that is obsolete now with the new ring buffer, so simply
use a single buffer. This greatly simplifies the code and avoids
a lot of sample drops on large runs, especially with call graph.
Based on suggestions from Steven Rostedt
For stable kernels from v2.6.32, but not earlier.
Cc: stable <stable@kernel.org>
include/linux/module.h
kernel/module.c
Semantic conflict:
include/trace/events/module.h
Merge reason: Resolve the conflict with upstream commit 5fbfb18 ("Fix up
possibly racy module refcounting")
Currently, when the ring buffer drops events, it does not record
the fact that it did so. It does inform the writer that the event
was dropped by returning a NULL event, but it does not put in any
place holder where the event was dropped.
This is not a trivial thing to add because the ring buffer mostly
runs in overwrite (flight recorder) mode. That is, when the ring
buffer is full, new data will overwrite old data.
In a produce/consumer mode, where new data is simply dropped when
the ring buffer is full, it is trivial to add the placeholder
for dropped events. When there's more room to write new data, then
a special event can be added to notify the reader about the dropped
events.
But in overwrite mode, any new write can overwrite events. A place
holder can not be inserted into the ring buffer since there never
may be room. A reader could also come in at anytime and miss the
placeholder.
Luckily, the way the ring buffer works, the read side can find out
if events were lost or not, and how many events. Everytime a write
takes place, if it overwrites the header page (the next read) it
updates a "overrun" variable that keeps track of the number of
lost events. When a reader swaps out a page from the ring buffer,
it can record this number, perfom the swap, and then check to
see if the number changed, and take the diff if it has, which would be
the number of events dropped. This can be stored by the reader
and returned to callers of the reader.
Since the reader page swap will fail if the writer moved the head
page since the time the reader page set up the swap, this gives room
to record the overruns without worrying about races. If the reader
sets up the pages, records the overrun, than performs the swap,
if the swap succeeds, then the overrun variable has not been
updated since the setup before the swap.
For binary readers of the ring buffer, a flag is set in the header
of each sub page (sub buffer) of the ring buffer. This flag is embedded
in the size field of the data on the sub buffer, in the 31st bit (the size
can be 32 or 64 bits depending on the architecture), but only 27
bits needs to be used for the actual size (less actually).
We could add a new field in the sub buffer header to also record the
number of events dropped since the last read, but this will change the
format of the binary ring buffer a bit too much. Perhaps this change can
be made if the information on the number of events dropped is considered
important enough.
Note, the notification of dropped events is only used by consuming reads
or peeking at the ring buffer. Iterating over the ring buffer does not
keep this information because the necessary data is only available when
a page swap is made, and the iterator does not swap out pages.
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Oprofile is currently broken on systems running with NOHZ enabled.
A maximum of 1 tick is accounted via the timer_hook if a cpu sleeps
for a longer period of time. This does bad things to the percentages
in the profiler output. To solve this problem convert oprofile to
use a restarting hrtimer instead of the timer_hook.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
This patch updates percpu related symbols in oprofile such that percpu
symbols are unique and don't clash with local symbols. This serves
two purposes of decreasing the possibility of global percpu symbol
collision and allowing dropping per_cpu__ prefix from percpu symbols.
* drivers/oprofile/cpu_buffer.c: s/cpu_buffer/op_cpu_buffer/
Partly based on Rusty Russell's "alloc_percpu: rename percpu vars
which cause name clashes" patch.
Acked-by: Robert Richter <robert.richter@amd.com>
A race shouldn't happen since all workqueues or handlers are canceled
or flushed before the event buffer is freed. A warning is triggered
now if the buffer is freed too early.
Also, this patch adds some comments about event buffer protection,
reworks some code and adds code to clear buffer_pos during alloc and
free of the event buffer.
Cc: Stephane Eranian <eranian@google.com>
Looking at the 2.6.31-rc9 code, it appears there is a race condition
in the event_buffer cleanup code path (shutdown). This could lead to
kernel panic as some CPUs may be operating on the event buffer AFTER
it has been freed. The attached patch solves the problem and makes
sure CPUs check if the buffer is not NULL before they access it as
some may have been spinning on the mutex while the buffer was being
freed.
The race may happen if the buffer is freed during pending reads. But
it is not clear why there are races in add_event_entry() since all
workqueues or handlers are canceled or flushed before the event buffer
is freed.
Signed-off-by: David Rientjes <rientjes@google.com>
Signed-off-by: Stephane Eranian <eranian@google.com>
Remove open-coded zalloc_cpumask_var() and zalloc_cpumask_var_node().
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
This patch moves the multiplexing switch counter from x86 code to
common oprofile statistic variables. Now the value will be available
and usable for all architectures. The initialization and
incrementation also moved to common code.
This patch moves multiplexing code to a single section of code. This
reduces the use of #ifdefs especially within functions.
oprofile_multiplexing_init() can be removed when moving the
initialization of oprofile_time_slice to oprofile_create_files().
