path: root/drivers/parisc/ccio-dma.c
2011-10-31parisc: Add export.h to files needing EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These guys were getting it implicitly via module.h before, when module.h was everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-22mm: replace various uses of num_physpages by totalram_pagesJan Beulich
Sizing of memory allocations shouldn't depend on the number of physical pages found in a system, as that generally includes (perhaps a huge amount of) non-RAM pages. The amount of what actually is usable as storage should instead be used as a basis here. Some of the calculations (i.e. those not intending to use high memory) should likely even use (totalram_pages - totalhigh_pages). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Airlie <airlied@linux.ie> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-02parisc: includecheck fix for ccio-dma.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: drivers/parisc/ccio-dma.c: linux/proc_fs.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Helge Deller <deller@gmx.de>
2009-07-03parisc: ccio-dma: fix build failure without procfsAlexander Beregalov
Fix this build error when CONFIG_PROC_FS is not set: drivers/parisc/ccio-dma.c:1574: error: 'ccio_proc_info_fops' undeclared Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: drivers: fix warningsAlexander Beregalov
ccio-dma.c:456: warning: overflow in implicit constant conversion ccio-dma.c:459: warning: overflow in implicit constant conversion ccio-dma.c:1032: warning: unused variable 'j' ccio-dma.c:1031: warning: unused variable 'max' ccio-dma.c:1031: warning: unused variable 'min' ccio-dma.c:1031: warning: unused variable 'avg' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitionsFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions are meaningless now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: drivers/parisc/: make code staticAdrian Bunk
Make the following needlessly global code static: - asp.c: asp_init_chip() - ccio-dma.c: ccio_io_pdir_entry() - dino.c: struct dino_port_ops - dino.c: struct dino_bios_ops - hppb.c: struct hppb_card_head - lasi.c: lasi_led_init() - lasi.c: lasi_init_chip() - lba_pci.c: struct lba_bios_ops - sba_iommu.c: sba_io_pdir_entry() - sba_iommu.c: sba_driver_callback() - sba_iommu.c: sba_driver_callback() - wax.c: wax_init_chip() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-10parisc: unify CCIO_COLLECT_STATS implementationKyle McMartin
Make it behave in the same manner as SBA_COLLECT_STATS, further clean ups pending.
2008-05-15drivers/parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-04-29parisc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-05parisc: fix IOMMU's device boundary overflow bug on 32bits archFUJITA Tomonori
On 32bits boxes, boundary_size becomes zero due to a overflow and we hit BUG_ON in iommu_is_span_boundary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04iommu: parisc: make the IOMMUs respect the segment boundary limitsFUJITA Tomonori
Make PARISC's two IOMMU implementations not allocate a memory area spanning LLD's segment boundary. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04iommu: parisc: pass struct device to iommu_alloc_rangeFUJITA Tomonori
This adds struct device argument to sba_alloc_range and ccio_alloc_range, a preparation for modifications to fix the IOMMU segment boundary problem. This change enables ccio_alloc_range to access to LLD's segment boundary limits. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: parisc: make iommu respect the segment size limitsFUJITA Tomonori
This patch makes iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/parisc/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-23parisc: fix sg_page() falloutFUJITA Tomonori
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_map_sg': arch/parisc/kernel/pci-dma.c:487: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_unmap_sg': arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_cpu': arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_device': arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-27[PARISC] fix section mismatch in ccio-dmaHelge Deller
Hi Kyle, this fixes section mismatches in ccio-dma. Additionally, mark parisc_device_id table const. Please apply, Helge Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-05-22[PARISC] ROUNDUP macro cleanup in drivers/pariscMilind Arun Choudhary
Clean up ROUNDUP, Use ALIGN where ever appropriate. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-02-08[PARISC] Convert ccio-dma.c to use seq_fileKyle McMartin
Gut ccio-dma.c of the ugly proc append and snprintf cruft and just use seq_printf instead. Tested on a K-class. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-28Auto-update from upstreamKyle McMartin
2005-10-28[PATCH] gfp_t: dma-mapping (parisc)Al Viro
2005-10-21[PARISC] Update ccio-dma from parisc treeGrant Grundler
revert use of %%sr0 in fdc asm. Thanks to Joel Soete for pointing out this oversight. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.14-rc2-pa3 fdc/lci should be %r0 instead 0 for index (PA 1.1 compliance) From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Explain why we need insert_resource() instead of request_resource(). Fundementally, this is more convoluted for ccio driver because of o legacy (HP-PB) transperant bridges. o support for MMIO behind card-mode Dino (PCI) o support for above bridges without ccio in the box SBA driver doesn't have to worry about those issues. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Use insert_resource instead of request_resource now that the subdevices will already have their resources claimed Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> re-enable use of "inline" for perf critical functions. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.12-rc4-pa5 fix sign extension of MMIO range Fixes the problem of claiming a range that is disabled on 64-bit kernel: ccio_init_resource() claimed CCIO bus address space (ffffffff00000000, ffffffffffffffff) also removes use of __FILE__. Tested on both 32 and 64-bit systems by Joel. From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.12-rc1-pa7 incorrect BUG_ON in ccio ccio-dma.c line 1317 was preventing K-class with 4GB RAM from booting. Any ccio machine with >=2GB of RAM would have (incorrectly) triggered this. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Convert to ioremap and __raw_read/write Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Change the driver names so /sys/bus/parisc/drivers/ looks betterMatthew Wilcox
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver names. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
