commit 33f9e02495d15a061f0c94ef46f5103a2d0c20f3 upstream.
Enabling parport pc driver on a B2600 (and probably other 64bit PARISC
systems) produced following BUG:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.12.0-rc5-30198-g1132d5e #156
task: 000000009e050000 task.stack: 000000009e04c000
YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
PSW: 00001000000001101111111100001111 Not tainted
r00-03 000000ff0806ff0f 000000009e04c990 0000000040871b78 000000009e04cac0
r04-07 0000000040c14de0 ffffffffffffffff 000000009e07f098 000000009d82d200
r08-11 000000009d82d210 0000000000000378 0000000000000000 0000000040c345e0
r12-15 0000000000000005 0000000040c345e0 0000000000000000 0000000040c9d5e0
r16-19 0000000040c345e0 00000000f00001c4 00000000f00001bc 0000000000000061
r20-23 000000009e04ce28 0000000000000010 0000000000000010 0000000040b89e40
r24-27 0000000000000003 0000000000ffffff 000000009d82d210 0000000040c14de0
r28-31 0000000000000000 000000009e04ca90 000000009e04cb40 0000000000000000
sr00-03 0000000000000000 0000000000000000 0000000000000000 0000000000000000
sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000
IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000404aece0 00000000404aece4
IIR: 03ffe01f ISR: 0000000010340000 IOR: 000001781304cac8
CPU: 0 CR30: 000000009e04c000 CR31: 00000000e2976de2
ORIG_R28: 0000000000000200
IAOQ[0]: sba_dma_supported+0x80/0xd0
IAOQ[1]: sba_dma_supported+0x84/0xd0
RP(r2): parport_pc_probe_port+0x178/0x1200
Cause is a call to dma_coerce_mask_and_coherenet in parport_pc_probe_port,
which PARISC DMA API doesn't handle very nicely. This commit gives back
DMA_ERROR_CODE for DMA API calls, if device isn't capable of DMA
transaction.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Signed-off-by: Helge Deller <deller@gmx.de>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Tested-by: Helge Deller <deller@gmx.de>
Acked-by: Helge Deller <deller@gmx.de>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Instead of custom approach let's use recently introduced seq_hex_dump()
helper.
In one case it changes the output from
1111111122222222333333334444444455555555666666667777777788888888
to
11111111 22222222 33333333 44444444 55555555 66666666 77777777 88888888
though it seems it prints same data (by meaning) in both cases. I decide
to choose to use the space divided one.
Cc: Joe Perches <joe@perches.com>
Cc: Tadeusz Struk <tadeusz.struk@intel.com>
Cc: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com>
Cc: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
The only reason to keep parisc's private asm/scatterlist.h was that it
had the macro sg_virt_addr(). Convert all callers to use something else
(sometimes just sg->offset was enough, others should use sg_virt()), and
we can just use the asm-generic scatterlist.h instead.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Dave Anglin <dave.anglin@bell.net>
The seq_printf return value, because it's frequently misused,
will eventually be converted to void.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
These guys were getting it implicitly via module.h before,
when module.h was everywhere.
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
Some of the calculations (i.e. those not intending to use high memory)
should likely even use (totalram_pages - totalhigh_pages).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Patrick McHardy <kaber@trash.net>
fix the following 'make includecheck' warning:
drivers/parisc/ccio-dma.c: linux/proc_fs.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Fix this build error when CONFIG_PROC_FS is not set:
drivers/parisc/ccio-dma.c:1574: error: 'ccio_proc_info_fops' undeclared
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
ccio-dma.c:456: warning: overflow in implicit constant conversion
ccio-dma.c:459: warning: overflow in implicit constant conversion
ccio-dma.c:1032: warning: unused variable 'j'
ccio-dma.c:1031: warning: unused variable 'max'
ccio-dma.c:1031: warning: unused variable 'min'
ccio-dma.c:1031: warning: unused variable 'avg'
ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t'
dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t'
eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t'
eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
The block layer dropped the virtual merge feature
(b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY and
BIO_VMERGE_MAX_SIZE definitions are meaningless now.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Make the following needlessly global code static:
- asp.c: asp_init_chip()
- ccio-dma.c: ccio_io_pdir_entry()
- dino.c: struct dino_port_ops
- dino.c: struct dino_bios_ops
- hppb.c: struct hppb_card_head
- lasi.c: lasi_led_init()
- lasi.c: lasi_init_chip()
- lba_pci.c: struct lba_bios_ops
- sba_iommu.c: sba_io_pdir_entry()
- sba_iommu.c: sba_driver_callback()
- wax.c: wax_init_chip()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
Make it behave in the same manner as SBA_COLLECT_STATS, further
clean ups pending.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Matthew Wilcox <willy@debian.org>
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to
main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Kyle McMartin <kyle@parisc-linux.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
On 32bits boxes, boundary_size becomes zero due to a overflow and we
hit BUG_ON in iommu_is_span_boundary.
Make PARISC's two IOMMU implementations not allocate a memory area spanning
LLD's segment boundary.
This adds struct device argument to sba_alloc_range and ccio_alloc_range, a
preparation for modifications to fix the IOMMU segment boundary problem. This
change enables ccio_alloc_range to access to LLD's segment boundary limits.
This patch makes iommu respect segment size limits when merging sg
lists.
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_map_sg':
arch/parisc/kernel/pci-dma.c:487: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_unmap_sg':
arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_cpu':
arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page'
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_device':
arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page'
Hi Kyle,
this fixes section mismatches in ccio-dma.
Additionally, mark parisc_device_id table const.
Please apply, Helge
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Clean up ROUNDUP, Use ALIGN where ever appropriate.
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Fix various .c/.h typos in comments (no code changes).
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Addresses in F-space must be accessed uncached on most parisc machines.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Gut ccio-dma.c of the ugly proc append and snprintf cruft and
just use seq_printf instead. Tested on a K-class.
Helge,
o Convert a bunch of kmalloc/memset uses to kzalloc.
o pci.c: Add some __read_mostly annotations.
o pci.c: Move constant pci_post_reset_delay to asm/pci.h
o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG.
o Add some consts to perf.c/perf_images.h
Matthew,
o sticore.c: Add some consts to suppress compile warnings.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
revert use of %%sr0 in fdc asm.
Thanks to Joel Soete for pointing out this oversight.
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
2.6.14-rc2-pa3 fdc/lci should be %r0 instead 0 for index (PA 1.1 compliance)
Explain why we need insert_resource() instead of request_resource().
Fundementally, this is more convoluted for ccio driver because of
o legacy (HP-PB) transperant bridges.
o support for MMIO behind card-mode Dino (PCI)
o support for above bridges without ccio in the box
SBA driver doesn't have to worry about those issues.
Use insert_resource instead of request_resource now that the subdevices
will already have their resources claimed
re-enable use of "inline" for perf critical functions.
2.6.12-rc4-pa5 fix sign extension of MMIO range
Fixes the problem of claiming a range that is disabled on 64-bit kernel:
ccio_init_resource() claimed CCIO bus address space (ffffffff00000000,
ffffffffffffffff)
also removes use of __FILE__.
Tested on both 32 and 64-bit systems by Joel.
2.6.12-rc1-pa7 incorrect BUG_ON in ccio
ccio-dma.c line 1317 was preventing K-class with 4GB RAM from booting.
Any ccio machine with >=2GB of RAM would have (incorrectly) triggered this.
Convert to ioremap and __raw_read/write
Convert pa_dev->hpa from an unsigned long to a struct resource.
Fix up users of ->hpa to use ->hpa.start instead.
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver
names.
infrastructure for it.
Let it rip!
