commit 4098116039911e8870d84c975e2ec22dab65a909 upstream.
For 64bit kernels the lmmio_space_offset of the host bridge window
isn't set correctly on systems with dino/cujo PCI host bridges.
This leads to not assigned memory bars and failing drivers, which
need to use these bars.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Acked-by: Helge Deller <deller@gmx.de>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 33f9e02495d15a061f0c94ef46f5103a2d0c20f3 upstream.
Enabling parport pc driver on a B2600 (and probably other 64bit PARISC
systems) produced following BUG:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.12.0-rc5-30198-g1132d5e #156
task: 000000009e050000 task.stack: 000000009e04c000
YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
PSW: 00001000000001101111111100001111 Not tainted
r00-03 000000ff0806ff0f 000000009e04c990 0000000040871b78 000000009e04cac0
r04-07 0000000040c14de0 ffffffffffffffff 000000009e07f098 000000009d82d200
r08-11 000000009d82d210 0000000000000378 0000000000000000 0000000040c345e0
r12-15 0000000000000005 0000000040c345e0 0000000000000000 0000000040c9d5e0
r16-19 0000000040c345e0 00000000f00001c4 00000000f00001bc 0000000000000061
r20-23 000000009e04ce28 0000000000000010 0000000000000010 0000000040b89e40
r24-27 0000000000000003 0000000000ffffff 000000009d82d210 0000000040c14de0
r28-31 0000000000000000 000000009e04ca90 000000009e04cb40 0000000000000000
sr00-03 0000000000000000 0000000000000000 0000000000000000 0000000000000000
sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000
IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000404aece0 00000000404aece4
IIR: 03ffe01f ISR: 0000000010340000 IOR: 000001781304cac8
CPU: 0 CR30: 000000009e04c000 CR31: 00000000e2976de2
ORIG_R28: 0000000000000200
IAOQ[0]: sba_dma_supported+0x80/0xd0
IAOQ[1]: sba_dma_supported+0x84/0xd0
RP(r2): parport_pc_probe_port+0x178/0x1200
Cause is a call to dma_coerce_mask_and_coherenet in parport_pc_probe_port,
which PARISC DMA API doesn't handle very nicely. This commit gives back
DMA_ERROR_CODE for DMA API calls, if device isn't capable of DMA
transaction.
PCI controllers and pci-pci bridges may have not been fully initialized
regarding cache line and defaul latency.
This partly reverts
commit 5f0e9b4 ("parisc: Remove unused pcibios_init_bus()")
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead
of arch code").
Reading PCI bridge windows is not arch-specific in itself, but there is PCI
core code that doesn't work correctly if we read them too early. For
example, Hannes found this case on an ARM Freescale i.mx6 board:
pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff]
pci 0000:00:00.0: PCI bridge to [bus 01-ff]
pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window)
pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000]
pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000]
pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100]
The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs
0x204100 of space, and mem windows are megabyte-aligned.
Bus sizing can increase a bridge window size, but never *decrease* it (see
d65245c3297a ("PCI: don't shrink bridge resources")). Prior to
dff22d2054b5, ARM didn't read bridge windows at all, so the "original size"
was zero, and we assigned a 3MB window.
After dff22d2054b5, we read the bridge windows before sizing the bus. The
firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since
we never decrease the size, we kept 16MB even though we only needed 3MB.
But 16MB doesn't fit in the host bridge aperture, so we failed to assign
space for the window and the downstream devices.
I think this is a defect in the PCI core: we shouldn't rely on the firmware
to assign sensible windows.
Ray reported a similar problem, also on ARM, with Broadcom iProc.
Issues like this are too hard to fix right now, so revert dff22d2054b5.
Reported-by: Hannes <oe5hpm@gmail.com>
Reported-by: Ray Jui <rjui@broadcom.com>
Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com
Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
When we scan a PCI bus, we read PCI-PCI bridge window registers with
pci_read_bridge_bases() so we can validate the resource hierarchy. Most
architectures call pci_read_bridge_bases() from pcibios_fixup_bus(), but
PCI-PCI bridges are not arch-specific, so this doesn't need to be in
arch-specific code.
Call pci_read_bridge_bases() directly from the PCI core instead of from
arch code.
For alpha and mips, we now call pci_read_bridge_bases() always; previously
we only called it if PCI_PROBE_ONLY was set.
[bhelgaas: changelog]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
CC: Ralf Baechle <ralf@linux-mips.org>
CC: James E.J. Bottomley <jejb@parisc-linux.org>
CC: Michael Ellerman <mpe@ellerman.id.au>
CC: Bjorn Helgaas <bhelgaas@google.com>
CC: Richard Henderson <rth@twiddle.net>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: David Howells <dhowells@redhat.com>
CC: Russell King <linux@arm.linux.org.uk>
CC: Tony Luck <tony.luck@intel.com>
CC: David S. Miller <davem@davemloft.net>
CC: Ingo Molnar <mingo@redhat.com>
CC: Guenter Roeck <linux@roeck-us.net>
CC: Michal Simek <monstr@monstr.eu>
CC: Chris Zankel <chris@zankel.net>
Signed-off-by: Hans Wennborg <hans@hanshq.net>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Replace list_for_each() + pci_dev_b() with the simpler
list_for_each_entry().
CC: linux-parisc@vger.kernel.org
Add the host bridge bus number aperture to the resource list.
Like the MMIO and I/O port apertures, this is used when assigning
resources to hot-added devices or in the case of conflicts.
[bhelgaas: changelog, set flags directly, at LBA bus_num init]
CC: Kyle McMartin <kyle@mcmartin.ca>
CC: Helge Deller <deller@gmx.de>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Replace the struct pci_bus secondary/subordinate members with the
struct resource busn_res. Later we'll build a resource tree of these
bus numbers.
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
resources
Supply root bus resources to pci_create_root_bus() so they're correct
immediately. This fixes the problem of "early" and "header" quirks seeing
incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
No functional change here; just converting from pci_scan_bus_parented()
to pci_create_bus() to make a future patch simpler.
Convert all the parisc driver interrupt handlers (dino, eisa, gsc,
iosapic and superio) as well as the cpu interrupts. Prepare
show_interrupts for GENERIC_HARDIRQS_NO_DEPRECATED and finally selects
that Kconfig option
[jejb: compile and testing fixes]
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The generic conversion eliminates the spurious no_ack and no_end
routines, converts all the cascaded handlers to handle_simple_irq() and
makes iosapic use a modified handle_percpu_irq() to become the same as
the CPU irq's. This isn't an essential change, but it eliminates the
mask/unmask overhead of handle_level_irq().
Tested-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Use proper accessors and handlers for generic irq cleanups. We just
call back into __do_IRQ through desc->handler now, and remove the
explicit calls.
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have
been kept around for migration reasons. After more than two years it's
time to remove them finally.
This patch cleans up one of the remaining users. When all such patches
hit mainline we can remove the defines and typedefs finally.
Impact: cleanup
Convert the last remaining users to struct irq_chip and remove the
define.
Alex Chiang asked me why PARISC was calling pci_bus_add_devices()
and pci_bus_assign_resources() in the opposite order from everyone else.
No reason and I couldn't see any data dependency.
Patch below applies cleanly to 2.6.30-rc2.
Later, I suspected the code worked only because no drivers would be
loaded/ready until much later in the system initialization sequence.
Tested "LBA" code on J6000 (32-bit) and A500 (64-bit SMP) with 2.6.30-rc2.
Not tested with any Dino controllers.
Not tested with PCI-PCI Bridge (TBD).
Reported-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
ccio-dma.c:456: warning: overflow in implicit constant conversion
ccio-dma.c:459: warning: overflow in implicit constant conversion
ccio-dma.c:1032: warning: unused variable 'j'
ccio-dma.c:1031: warning: unused variable 'max'
ccio-dma.c:1031: warning: unused variable 'min'
ccio-dma.c:1031: warning: unused variable 'avg'
ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t'
dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t'
eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t'
eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t'
eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t'
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> posted a patch series
to linux-pci to fix a wrong assumption about pci_bus->self==NULL for
all PCI host bus controllers. While PARISC platforms to not behave
this way, I prefer to have the code consistent across architectures.
The following patch replaces pci_bus->self with pci_bus->parent when
used as a test to check for "root bus controller".
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: export length of os_hpmc vector
parisc: fix kernel crash (protection id trap) when compiling ruby1.9
parisc: Use DEFINE_SPINLOCK
parisc: add uevent helper for parisc bus
parisc: fix ipv6 checksum
parisc: quiet palo not-found message from "which"
parisc: Replace NR_CPUS in parisc code
parisc: trivial fixes
parisc: fix braino in commit adding __space_to_prot
parisc: factor out sid to protid conversion
parisc: use leX_to_cpu in place of __fswabX
parisc: fix GFP_KERNEL use while atomic in unwinder
parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions
parisc: set_time() catch errors
parisc: use the new byteorder headers
parisc: drivers/parisc/: make code static
parisc: lib/: make code static
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code.
Acked-by: Kyle McMartin <kyle@infradead.org>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Make the following needlessly global code static:
- asp.c: asp_init_chip()
- ccio-dma.c: ccio_io_pdir_entry()
- dino.c: struct dino_port_ops
- dino.c: struct dino_bios_ops
- hppb.c: struct hppb_card_head
- lasi.c: lasi_led_init()
- lasi.c: lasi_init_chip()
- lba_pci.c: struct lba_bios_ops
- sba_iommu.c: sba_io_pdir_entry()
- sba_iommu.c: sba_driver_callback()
- wax.c: wax_init_chip()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Grant Grundler <grundler@parisc-linux.org>
irq_desc[]
add CONFIG_HAVE_SPARSE_IRQ to for use condensed array.
Get rid of irq_desc[] array assumptions.
Preallocate 32 irq_desc, and irq_desc() will try to get more.
( No change in functionality is expected anywhere, except the odd build
failure where we missed a code site or where a crossing commit itroduces
new irq_desc[] usage. )
v2: according to Eric, change get_irq_desc() to irq_desc()
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
Remove the parisc usage of the global_list, as it's not needed anymore.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
Addresses in F-space must be accessed uncached on most parisc machines.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Helge,
o Convert a bunch of kmalloc/memset uses to kzalloc.
o pci.c: Add some __read_mostly annotations.
o pci.c: Move constant pci_post_reset_delay to asm/pci.h
o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG.
o Add some consts to perf.c/perf_images.h
Matthew,
o sticore.c: Add some consts to suppress compile warnings.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Fix Dino reporting on J2240. This particular machine thought it
had a Cujo. Also add J2240 Dino chip to the hp_hardware_list.
Fix dino by using DINO_LOCAL_IRQS as the limit for gsc_find_local_irq()
instead of the irq itself.
Fix irq-off-by-one for Cirrus 6832 Cardbus on RDI Tadpole PARISC Laptop.
We just DECLARE_PCI_FIXUP_ENABLE as it is unlikely that this will be
found in any other parisc system.
Fix card-mode Dino crashes on 725 (and probably other Snake) systems.
Dino was coming up in fatal mode after a warm reboot. Resetting Dino
brings it out of fatal mode, so do that if the status register indicates
we're in fatal mode. Since this was never observed on any later systems,
I presume firmware does this for us on those.
Add debug statements in the cfg_read and cfg_write functions
Fix debug statements from the IRQ overhaul last winter
Rename dino_driver_callback() to dino_probe()
Convert pa_dev->hpa from an unsigned long to a struct resource.
Fix up users of ->hpa to use ->hpa.start instead.
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver
names.
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and
devices attached to it that have not been configured by firmware. In this
case, we need to configure the devices before starting them. This patch
separates device start from device scan so that we can introduce the
configuration step in the middle.
I kept the existing semantics for pci_scan_bus() since there are a huge number
of callers to that function.
Also, I have no way of testing the changes I made to the parisc files, so this
needs review by those folks. Sorry for the massive cross-post, this touches
files in many different places.
Signed-off-by: Rajesh Shah <rajesh.shah@intel.com>
infrastructure for it.
Let it rip!
