path: root/drivers/parisc/eisa.c
2011-03-29parisc: Convert irq namespaceThomas Gleixner
Convert to the new function names. Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: linux-parisc@vger.kernel.org
2011-02-10[PARISC] Convert to new irq_chip functionsThomas Gleixner
Convert all the parisc driver interrupt handlers (dino, eisa, gsc, iosapic and superio) as well as the cpu interrupts. Prepare show_interrupts for GENERIC_HARDIRQS_NO_DEPRECATED and finally selects that Kconfig option [jejb: compile and testing fixes] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-04parisc: convert the rest of the irq handlers to simple/percpuJames Bottomley
The generic conversion eliminates the spurious no_ack and no_end routines, converts all the cascaded handlers to handle_simple_irq() and makes iosapic use a modified handle_percpu_irq() to become the same as the CPU irq's. This isn't an essential change, but it eliminates the mask/unmask overhead of handle_level_irq(). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-10-14parisc: convert eisa interrupts to flow handlersKyle McMartin
Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: lay groundwork for killing __do_IRQKyle McMartin
Use proper accessors and handlers for generic irq cleanups. We just call back into __do_IRQ through desc->handler now, and remove the explicit calls. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2009-12-16parisc: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-06-15parisc: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-parisc@vger.kernel.org Cc: Helge Deller <deller@gmx.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-02parisc: drivers: fix warningsAlexander Beregalov
ccio-dma.c:456: warning: overflow in implicit constant conversion ccio-dma.c:459: warning: overflow in implicit constant conversion ccio-dma.c:1032: warning: unused variable 'j' ccio-dma.c:1031: warning: unused variable 'max' ccio-dma.c:1031: warning: unused variable 'min' ccio-dma.c:1031: warning: unused variable 'avg' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-27[PARISC] fix section mismatch in parisc eisa driverHelge Deller
Hi Kyle, this patch fixes the following section mismatch (EISA cards should be hotplug aware, but the EISA bus itself shouldn't): WARNING: drivers/built-in.o(.text.eisa_probe+0x220): Section mismatch: reference to .init.text:eisa_root_register (after 'eisa_probe') Please apply, Helge Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-06Build fixes for struct pt_regs removalMatthew Wilcox
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: PARISC: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __read_mostly section for pariscHelge Deller
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few branches as unlikely() and cleanup a bit of code. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Change the driver names so /sys/bus/parisc/drivers/ looks betterMatthew Wilcox
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver names. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
