path: root/drivers/parisc/eisa_enumerator.c
2010-03-06parisc: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: linux-parisc@vger.kernel.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02parisc: drivers: fix warningsAlexander Beregalov
ccio-dma.c:456: warning: overflow in implicit constant conversion ccio-dma.c:459: warning: overflow in implicit constant conversion ccio-dma.c:1032: warning: unused variable 'j' ccio-dma.c:1031: warning: unused variable 'max' ccio-dma.c:1031: warning: unused variable 'min' ccio-dma.c:1031: warning: unused variable 'avg' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
