path: root/drivers/parisc
2006-03-24BUG_ON() Conversion in drivers/parisc/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-08[PARISC] Convert sba_iommu.c to use seq_fileKyle McMartin
Use seq_file interface for proc output in sba_iommu. Also clean up the bus root assignment, and give the proc files a more logical name. Tested on my J6000. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-02-08[PARISC] Convert ccio-dma.c to use seq_fileKyle McMartin
Gut ccio-dma.c of the ugly proc append and snprintf cruft and just use seq_printf instead. Tested on a K-class. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Clean up printk in superio.cKyle McMartin
Clean up some of the messages printed by the superio driver by defining a prefix instead of duplicating it in every message. Also some small coding style cleanups. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Add chassis_power_off routineKyle McMartin
Define a chassis_power_off routine that machines which have a way to turn off the power supply can hook into. Formerly they were using pm_power_off, which is now being used by generic code. Make lasi.c use chassis_power_off instead of pm_power_off. Note, all machines need to call machine_power_off so that the switch can power off the machine, though halt -p may not necessarily be able to work properly on the machine. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] pdc_stable version 0.22Thibaut VARENE
pdc_stable v0.22, changes since v0.10: o renamed root subsystem from 'pdc' to 'stable' o split 'info' into several files, one per PDC field o implemented 'autoboot' and 'autosearch' write calls to toggle these flags o grant read permission to all users on "safe" files o more code cleanup (removed duplicate code) o avoid bad stable storage clobbering by write locking critical sections o print consistent data as well o SMP cleanups Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PARISC] Fix Dino reporting on J2240Matthew Wilcox
Fix Dino reporting on J2240. This particular machine thought it had a Cujo. Also add J2240 Dino chip to the hp_hardware_list. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] pdc_stable: More robust sysfs error checkingThibaut VARENE
pdc_stable 0.10: As mentioned on LKML, pdc_stable wasn't checky enough on the return values of some calls. This patch makes it more robust to errors when registering objects in sysfs. Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Truncate overlapping PAT PDC reported rangesGrant Grundler
Deal with overlapping LBA MMIO resources, rp3440 PDC BUG: PDC reports lmmio range for the last rope that overlaps with the CPU HPA. Console output was: ... Found devices: 1. Storm Peak Fast at 0xfffffffffe798000 [152] { 0, 0x0, 0x889, 0x00004 } 2. Storm Peak Fast at 0xfffffffffe799000 [153] { 0, 0x0, 0x889, 0x00004 } ... FAILED: lba_fixup_bus() request for lmmio_space [fffffffff0000000/fffffffffecffffe] Output is now: LBA: Truncating lmmio_space [fffffffff0000000/fffffffffecffffe] to [fffffffff0000000,fffffffffe797fff] My only concern with this patch is how C8000 (PAT PDC) will report elmmio ranges when a gfx card is installed. I'll have to test this another day. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Introduce DINO_LOCAL_IRQS and use it for gsc_find_local_irqHelge Deller
Fix dino by using DINO_LOCAL_IRQS as the limit for gsc_find_local_irq() instead of the irq itself. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __user annotation to eisa_eeprom.cAlexey Dobriyan
Annotate eisa_eeprom_read() with __user. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Fix Cirrus 6832 Cardbus on RDI Tadpole PARISC LaptopHelge Deller
Fix irq-off-by-one for Cirrus 6832 Cardbus on RDI Tadpole PARISC Laptop. We just DECLARE_PCI_FIXUP_ENABLE as it is unlikely that this will be found in any other parisc system. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __read_mostly section for pariscHelge Deller
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few branches as unlikely() and cleanup a bit of code. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10spelling: s/trough/through/Adrian Bunk
Additionally, one comment was reformulated by Joe Perches <joe@perches.com>. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-17[PARISC] Make superio.c initialize before any driver needs itKyle McMartin
Convert superio_init to use PCI_FIXUP_FINAL as ohci_pci being called before superio_probe really makes a mess. superio_init will then fail to register irq 20 (the "SuperIO" irq) and BUG() because ohci_pci has stolen it before superio_fixup_irq can be moved USB to irq 1. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Add IRQ affinitiesJames Bottomley
This really only adds them for the machines I can check SMP on, which is CPU interrupts and IOSAPIC (so not any of the GSC based machines). With this patch, irqbalanced can be used to maintain irq balancing. Unfortunately, irqbalanced is a bit x86 centric, so it doesn't do an incredibly good job, but it does work. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-28Auto-update from upstreamKyle McMartin
2005-10-28[PATCH] gfp_t: dma-mapping (parisc)Al Viro
2005-10-21[PARISC] Avoid use of floating point in the kernelRandolph Chung
don't use *printf %f in the kernel, mm'kay? Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Initialize serial spinlocks in superio.cKyle McMartin
git commit 976ecd12b8144d066a23fe97c6fbfc1ac8470af7 changed our locking characteristics, and put the onus of spin_lock_init on superio.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Minor iosapic.c cleanupGrant Grundler
minor cleanup: qualify constant with "UL" Acked-by: "Hmamouche, Youssef" <youssef@ece.utexas.edu> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Use work queue in LED/LCD driver instead of tasklet.Grant Grundler
2.6.12-rc1-pa6 use work queue in LED/LCD driver instead of tasklet. Main advantage is it allows use of msleep() in the led_LCD_driver to "atomically" perform two MMIO writes (CMD, then DATA). Lead to nice cleanup of the main led_work_func() and led_LCD_driver(). Kudos to David for being persistent. From: David Pye <dmp@davidmpye.dyndns.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Update dino from parisc treeMatthew Wilcox
Fix card-mode Dino crashes on 725 (and probably other Snake) systems. Dino was coming up in fatal mode after a warm reboot. Resetting Dino brings it out of fatal mode, so do that if the status register indicates we're in fatal mode. Since this was never observed on any later systems, I presume firmware does this for us on those. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Add debug statements in the cfg_read and cfg_write functions Fix debug statements from the IRQ overhaul last winter Rename dino_driver_callback() to dino_probe() Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Update ccio-dma from parisc treeGrant Grundler
revert use of %%sr0 in fdc asm. Thanks to Joel Soete for pointing out this oversight. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.14-rc2-pa3 fdc/lci should be %r0 instead 0 for index (PA 1.1 compliance) From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Explain why we need insert_resource() instead of request_resource(). Fundementally, this is more convoluted for ccio driver because of o legacy (HP-PB) transperant bridges. o support for MMIO behind card-mode Dino (PCI) o support for above bridges without ccio in the box SBA driver doesn't have to worry about those issues. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Use insert_resource instead of request_resource now that the subdevices will already have their resources claimed Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> re-enable use of "inline" for perf critical functions. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.12-rc4-pa5 fix sign extension of MMIO range Fixes the problem of claiming a range that is disabled on 64-bit kernel: ccio_init_resource() claimed CCIO bus address space (ffffffff00000000, ffffffffffffffff) also removes use of __FILE__. Tested on both 32 and 64-bit systems by Joel. From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.12-rc1-pa7 incorrect BUG_ON in ccio ccio-dma.c line 1317 was preventing K-class with 4GB RAM from booting. Any ccio machine with >=2GB of RAM would have (incorrectly) triggered this. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Convert to ioremap and __raw_read/write Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Update sba_iommu from parisc treeGrant Grundler
revert use of %%sr0 in fdc asm. Thanks to Joel Soete for pointing out this oversight. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.14-rc2-pa3 move "sync" outside the main loop that fills IO Pdir. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> remove explicit use of sr0 in fdc ops. Thanks to Joel Soete for reminding me were I added those... Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.14-rc2-pa2 - make SBA more anal about invalidating pdir entries Previous code cleared the valid flag a pdir entry but it did NOT guarantee this change was visible to the PDIR before writing the PCOM register. Ie the SBA could pick up a stale entry if the write happened to hit the SBA before the cacheline was flushed from the cache. Long term, I think I want to make this a compile time flag. Developement tree should enable anal pdir checking by default and Debian can disable it with either a CONFIG option or one-line patch. fdc/sync options can only negatively affect performance though I haven't measure how much yet. If someone can run netperf TCP_RR across gige and compare -pa1 and -pa2, that would be sufficient. Cleaned up the use of "fdc" to make sure it's using "kernel" space id (specify sr0 but maps to sr4-7). It seems a bit fragile to assume "sr1" gets loaded with KERNEL_SPACE which is how the code works today. Tested on 32 and 64-bit SMP kernels on j6k. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> remove PDC_NARROW from SBA and document history of PDC_NARROW a bit. It will still show up in an older kernel's .config file. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> if/ifdef cleanups from Joel Soete. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> 2.6.12-rc4-pa2 fix 32-bit support for Astro platforms o Since my last SBA code change, SBA could allocate more than 1GB of IOVA space on Astro boxes with more than 1GB of RAM when running 32-bit kernel. This is bad since IOMMU can only talk to the first 1GB at most. Kudos to jejb for quickly spotting that bug. o jejb also noted SBA should *always* reject DMA masks > 32-bits since DMA-mapping.txt indicates caller should try again with 32-bits. o off-by-one error when comparing the mask to IOVA space size. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Change the driver names so /sys/bus/parisc/drivers/ looks betterMatthew Wilcox
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver names. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device tree to use struct device klistsMatthew Wilcox
Fix parse_tree_node. much more needs to be done to fix this file. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Make drivers.c compile based on a patch from Pat Mochel. From: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Fix drivers.c to create new device tree nodes when no match is found. Signed-off-by: Richard Hirst <rhirst@parisc-linux.org> Do a proper depth-first search returning parents before children, using the new klist infrastructure. Signed-off-by: Richard Hirst <rhirst@parisc-linux.org> Fixed parisc_device traversal so that pdc_stable works again Fixed check_dev so it doesn't dereference a parisc_device until it has verified the bus type Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Convert pa_dev->hpa from an unsigned long to a struct resource. Use insert_resource() instead of request_mem_region(). Request resources at bus walk time instead of driver probe time. Don't release the resources as we don't have any hotplug parisc_device support yet. Add parisc_pathname() to conveniently get the textual representation of the hwpath used in sysfs. Inline the remnants of claim_device() into its caller. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> I noticed that some of the STI regions weren't showing up in iomem. Reading the STI spec indicated that all STI devices occupy at least 32MB. So check for STI HPAs and give them 32MB instead of 4kB. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-10[PATCH] merge some from Rusty's trivial patchesAdrian Bunk
This patch contains the most trivial from Rusty's trivial patches: - spelling fixes - remove duplicate includes Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] more SPIN_LOCK_UNLOCKED -> DEFINE_SPINLOCK conversionsIngo Molnar
This converts the final 20 DEFINE_SPINLOCK holdouts. (another 580 places are already using DEFINE_SPINLOCK). Build tested on x86. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
