path: root/drivers/parisc
2018-10-17parisc: Add alternative coding infrastructureHelge Deller
This patch adds the necessary code to patch a running kernel at runtime to improve performance. The current implementation offers a few optimizations variants: - When running a SMP kernel on a single UP processor, unwanted assembler statements like locking functions are overwritten with NOPs. When multiple instructions shall be skipped, one branch instruction is used instead of multiple nop instructions. - In the UP case, some pdtlb and pitlb instructions are patched to become pdtlb,l and pitlb,l which only flushes the CPU-local tlb entries instead of broadcasting the flush to other CPUs in the system and thus may improve performance. - fic and fdc instructions are skipped if no I- or D-caches are installed. This should speed up qemu emulation and cacheless systems. - If no cache coherence is needed for IO operations, the relevant fdc and sync instructions in the sba and ccio drivers are replaced by nops. - On systems which share I- and D-TLBs and thus don't have a seperate instruction TLB, the pitlb instruction is replaced by a nop. Live-patching is done early in the boot process, just after having run the system inventory. No drivers are running and thus no external interrupts should arrive. So the hope is that no TLB exceptions will occur during the patching. If this turns out to be wrong we will probably need to do the patching in real-mode. Signed-off-by: Helge Deller <deller@gmx.de>
2018-10-17parisc: Ratelimit dino stuck interrupt warningsHelge Deller
While playing with qemu with an emulated RT8139cp NIC, I faced lots of the following warnings: Dino 0x00810000: stuck interrupt 2 This patch ratelimits this warning and reports back that the IRQ was handled. Signed-off-by: Helge Deller <deller@gmx.de>
2018-10-17parisc: dino: Utilize DINO_MASK_IRQ() macroHelge Deller
2018-10-17parisc: remove the dead ccio-rm-dma driverChristoph Hellwig
This driver has never been wired up due to the life of the Linux git tree, and has severely bitrotted. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Helge Deller <deller@gmx.de>
2018-06-04Merge tag 'dma-mapping-4.18' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull dma-mapping updates from Christoph Hellwig: - replace the force_dma flag with a dma_configure bus method. (Nipun Gupta, although one patch is іncorrectly attributed to me due to a git rebase bug) - use GFP_DMA32 more agressively in dma-direct. (Takashi Iwai) - remove PCI_DMA_BUS_IS_PHYS and rely on the dma-mapping API to do the right thing for bounce buffering. - move dma-debug initialization to common code, and apply a few cleanups to the dma-debug code. - cleanup the Kconfig mess around swiotlb selection - swiotlb comment fixup (Yisheng Xie) - a trivial swiotlb fix. (Dan Carpenter) - support swiotlb on RISC-V. (based on a patch from Palmer Dabbelt) - add a new generic dma-noncoherent dma_map_ops implementation and use it for arc, c6x and nds32. - improve scatterlist validity checking in dma-debug. (Robin Murphy) - add a struct device quirk to limit the dma-mask to 32-bit due to bridge/system issues, and switch x86 to use it instead of a local hack for VIA bridges. - handle devices without a dma_mask more gracefully in the dma-direct code. * tag 'dma-mapping-4.18' of git://git.infradead.org/users/hch/dma-mapping: (48 commits) dma-direct: don't crash on device without dma_mask nds32: use generic dma_noncoherent_ops nds32: implement the unmap_sg DMA operation nds32: consolidate DMA cache maintainance routines x86/pci-dma: switch the VIA 32-bit DMA quirk to use the struct device flag x86/pci-dma: remove the explicit nodac and allowdac option x86/pci-dma: remove the experimental forcesac boot option Documentation/x86: remove a stray reference to pci-nommu.c core, dma-direct: add a flag 32-bit dma limits dma-mapping: remove unused gfp_t parameter to arch_dma_alloc_attrs dma-debug: check scatterlist segments c6x: use generic dma_noncoherent_ops arc: use generic dma_noncoherent_ops arc: fix arc_dma_{map,unmap}_page arc: fix arc_dma_sync_sg_for_{cpu,device} arc: simplify arc_dma_sync_single_for_{cpu,device} dma-mapping: provide a generic dma-noncoherent implementation dma-mapping: simplify Kconfig dependencies riscv: add swiotlb support riscv: only enable ZONE_DMA32 for 64-bit ...
2018-06-04Merge branch 'hch.procfs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull procfs updates from Al Viro: "Christoph's proc_create_... cleanups series" * 'hch.procfs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (44 commits) xfs, proc: hide unused xfs procfs helpers isdn/gigaset: add back gigaset_procinfo assignment proc: update SIZEOF_PDE_INLINE_NAME for the new pde fields tty: replace ->proc_fops with ->proc_show ide: replace ->proc_fops with ->proc_show ide: remove ide_driver_proc_write isdn: replace ->proc_fops with ->proc_show atm: switch to proc_create_seq_private atm: simplify procfs code bluetooth: switch to proc_create_seq_data netfilter/x_tables: switch to proc_create_seq_private netfilter/xt_hashlimit: switch to proc_create_{seq,single}_data neigh: switch to proc_create_seq_data hostap: switch to proc_create_{seq,single}_data bonding: switch to proc_create_seq_data rtc/proc: switch to proc_create_single_data drbd: switch to proc_create_single resource: switch to proc_create_seq_data staging/rtl8192u: simplify procfs code jfs: simplify procfs code ...
2018-05-18parisc: Move ccio_cujo20_fixup() into init sectionHelge Deller
ccio_cujo20_fixup() is called by dino_probe() only, which is in init section already. Signed-off-by: Helge Deller <deller@gmx.de>
2018-05-16proc: introduce proc_create_single{,_data}Christoph Hellwig
Variants of proc_create{,_data} that directly take a seq_file show callback and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-09iommu-helper: mark iommu_is_span_boundary as inlineChristoph Hellwig
This avoids selecting IOMMU_HELPER just for this function. And we only use it once or twice in normal builds so this often even is a size reduction. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-07PCI: remove PCI_DMA_BUS_IS_PHYSChristoph Hellwig
This was used by the ide, scsi and networking code in the past to determine if they should bounce payloads. Now that the dma mapping always have to support dma to all physical memory (thanks to swiotlb for non-iommu systems) there is no need to this crude hack any more. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Palmer Dabbelt <palmer@sifive.com> (for riscv) Reviewed-by: Jens Axboe <axboe@kernel.dk>
2018-05-02parisc: Fix section mismatchesHelge Deller
Fix three section mismatches: 1) Section mismatch in reference from the function ioread8() to the function .init.text:pcibios_init_bridge() 2) Section mismatch in reference from the function free_initmem() to the function .init.text:map_pages() 3) Section mismatch in reference from the function ccio_ioc_init() to the function .init.text:count_parisc_driver() Signed-off-by: Helge Deller <deller@gmx.de>
2018-03-27parisc/pci: Switch LBA PCI bus from Hard Fail to Soft Fail modeHelge Deller
Carlo Pisani noticed that his C3600 workstation behaved unstable during heavy I/O on the PCI bus with a VIA VT6421 IDE/SATA PCI card. To avoid such instability, this patch switches the LBA PCI bus from Hard Fail mode into Soft Fail mode. In this mode the bus will return -1UL for timed out MMIO transactions, which is exactly how the x86 (and most other architectures) PCI busses behave. This patch is based on a proposal by Grant Grundler and Kyle McMartin 10 years ago: https://www.spinics.net/lists/linux-parisc/msg01027.html Cc: Carlo Pisani <carlojpisani@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Reviewed-by: Grant Grundler <grantgrundler@gmail.com> Signed-off-by: Helge Deller <deller@gmx.de>
2018-03-27parisc: Directly call machine_power_off() in power button driverHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Tested-by: Matt Turner <mattst88@gmail.com>
2018-03-27parisc/led: Fix sparse warningsHelge Deller
Annotate user buffer and use NULL to avoid sparse warnings. Signed-off-by: Helge Deller <deller@gmx.de>
2018-01-02parisc: Show unhashed EISA EEPROM addressHelge Deller
Fixes: ad67b74d2469d9b8 ("printk: hash addresses printed with %p") Signed-off-by: Helge Deller <deller@gmx.de>
2018-01-02parisc: Show unhashed HPA of Dino chipHelge Deller
2017-12-17parisc: Hide Diva-built-in serial aux and graphics cardHelge Deller
Diva GSP card has built-in serial AUX port and ATI graphic card which simply don't work and which both don't have external connectors. User Guides even mention that those devices shouldn't be used. So, prevent that Linux drivers try to enable those devices. Signed-off-by: Helge Deller <deller@gmx.de> Cc: <stable@vger.kernel.org> # v3.0+
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24parisc: Fix up devices below a PCI-PCI MegaRAID controller bridgeHelge Deller
A MegaRAID PCI card in my rp5470 acts as PCI-PCI bridge. Resource allocation for PCI devices behind such a bridge is quite incomplete, so that syslog reports those warnings: LBA 0:10: PCI host bridge to bus 0000:50 pci_bus 0000:50: root bus resource [io 0x80000-0x8ffff] (bus address [0x0000-0xffff]) pci_bus 0000:50: root bus resource [mem 0xffffffff94000000-0xffffffff95ffffff] (bus address [0x94000000-0x95ffffff]) pci_bus 0000:50: root bus resource [bus 50-57] pci 0000:50:00.0: [8086:0964] type 01 class 0x060400 pci 0000:50:00.1: [8086:1960] type 00 class 0x0e0001 pci 0000:50:00.1: reg 0x10: [mem 0x00000000-0x003fffff pref] pci 0000:50:00.1: reg 0x30: [mem 0x00000000-0x00007fff pref] pci 0000:50:00.0: Changing bridge control from 0x00000000 to 0x00000023 pci_bus 0000:51: busn_res: can not insert [bus 51-ff] under [bus 50-57] (conflicts with (null) [bus 50-57]) pci 0000:50:00.0: PCI bridge to [bus 51-ff] pci 0000:50:00.0: bridge window [io 0x80000-0x80fff] pci 0000:50:00.0: bridge window [mem 0x00000000-0x000fffff] pci 0000:50:00.0: bridge window [mem 0x00000000-0x000fffff pref] pci 0000:50:00.0: can't claim BAR 14 [mem 0x00000000-0x000fffff]: no compatible bridge window pci 0000:50:00.0: can't claim BAR 15 [mem 0x00000000-0x000fffff pref]: no compatible bridge window pci 0000:50:00.0: can't claim BAR 16 [??? 0x00000000 flags 0x0]: no compatible bridge window pci_bus 0000:51: busn_res: [bus 51-ff] end is updated to 51 pci 0000:50:00.0: BAR 16: [??? 0x00000000 flags 0x20000000] has bogus alignment pci 0000:50:00.1: BAR 0: assigned [mem 0xffffffff94000000-0xffffffff943fffff pref] pci 0000:50:00.0: BAR 14: assigned [mem 0xffffffff94400000-0xffffffff944fffff] pci 0000:50:00.0: BAR 15: assigned [mem 0xffffffff94500000-0xffffffff945fffff pref] pci 0000:50:00.1: BAR 6: assigned [mem 0xffffffff94600000-0xffffffff94607fff pref] pci 0000:50:00.0: PCI bridge to [bus 51] pci 0000:50:00.0: bridge window [io 0x80000-0x80fff] pci 0000:50:00.0: bridge window [mem 0xffffffff94400000-0xffffffff944fffff] pci 0000:50:00.0: bridge window [mem 0xffffffff94500000-0xffffffff945fffff pref] The patch below tries to improve the resource allocation. Output is now: LBA 0:10: PCI host bridge to bus 0000:50 pci_bus 0000:50: root bus resource [io 0x80000-0x8ffff] (bus address [0x0000-0xffff]) pci_bus 0000:50: root bus resource [mem 0xffffffff94000000-0xffffffff95ffffff] (bus address [0x94000000-0x95ffffff]) pci_bus 0000:50: root bus resource [bus 50-57] pci 0000:50:00.0: Changing bridge control from 0x00000000 to 0x00000023 pci 0000:50:00.0: PCI bridge to [bus 51-ff] pci 0000:50:00.1: BAR 0: assigned [mem 0xffffffff94000000-0xffffffff943fffff pref] pci 0000:50:00.1: BAR 6: assigned [mem 0xffffffff94400000-0xffffffff94407fff pref] pci 0000:50:00.0: PCI bridge to [bus 51] pci 0000:50:00.0: bridge window [io 0x80000-0x80fff] Signed-off-by: Helge Deller <deller@gmx.de>
2017-08-22parisc: Fix section mismatches in parisc core driversHelge Deller
2017-08-16parisc: pci memory bar assignment fails with 64bit kernels on dino/cujoThomas Bogendoerfer
For 64bit kernels the lmmio_space_offset of the host bridge window isn't set correctly on systems with dino/cujo PCI host bridges. This leads to not assigned memory bars and failing drivers, which need to use these bars. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: <stable@vger.kernel.org> Acked-by: Helge Deller <deller@gmx.de> Signed-off-by: Helge Deller <deller@gmx.de>
2017-07-31parisc: pdc_stable: Fix locking when creating sysfs linksJames Bottomley
There's no need to take the write lock when creating sysfs links. This patch fixes the following BUG: BUG: sleeping function called from invalid context at mm/slab.h:416 in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: swapper/0 CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.13.0-rc2-00110-g0b5477d9dabd #111 Backtrace: [<0000000040217ac8>] show_stack+0x20/0x38 [<00000000406fbbb0>] dump_stack+0xb0/0x128 [<0000000040274090>] ___might_sleep+0x180/0x1b8 [<0000000040274144>] __might_sleep+0x7c/0xe8 [<0000000040373874>] kmem_cache_alloc+0x14c/0x1e0 [<0000000040419514>] __kernfs_new_node+0x84/0x1b8 [<000000004041b09c>] kernfs_new_node+0x3c/0x78 [<000000004041e040>] kernfs_create_link+0x40/0xd8 [<000000004041f320>] sysfs_do_create_link_sd.isra.0+0xb0/0x130 [<000000004041f3d4>] sysfs_create_link+0x34/0x58 [<000000004011b4a4>] pdc_stable_init+0x2c4/0x458 [<0000000040200250>] do_one_initcall+0x70/0x1d8 [<0000000040101644>] kernel_init_freeable+0x27c/0x390 [<000000004020be44>] kernel_init+0x24/0x1c0 Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Helge Deller <deller@gmx.de>
2017-07-23parisc: pdc_stable: constify attribute_group structures.Arvind Yadav
attribute_groups are not supposed to change at runtime. All functions working with attribute_groups provided by <linux/sysfs.h> work with const attribute_group. So mark the non-const structs as const. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Helge Deller <deller@gmx.de>
2017-07-05parisc: ->mapping_errorChristoph Hellwig
DMA_ERROR_CODE already went away in linux-next, but parisc unfortunately added a new instance of it without any review as far as I can tell. Move the two iommu drivers to report errors through ->mapping_error. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Helge Deller <deller@gmx.de>
2017-07-03parisc: DMA API: return error instead of BUG_ON for dma ops on non dma devsThomas Bogendoerfer
Enabling parport pc driver on a B2600 (and probably other 64bit PARISC systems) produced following BUG: CPU: 0 PID: 1 Comm: swapper Not tainted 4.12.0-rc5-30198-g1132d5e #156 task: 000000009e050000 task.stack: 000000009e04c000 YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI PSW: 00001000000001101111111100001111 Not tainted r00-03 000000ff0806ff0f 000000009e04c990 0000000040871b78 000000009e04cac0 r04-07 0000000040c14de0 ffffffffffffffff 000000009e07f098 000000009d82d200 r08-11 000000009d82d210 0000000000000378 0000000000000000 0000000040c345e0 r12-15 0000000000000005 0000000040c345e0 0000000000000000 0000000040c9d5e0 r16-19 0000000040c345e0 00000000f00001c4 00000000f00001bc 0000000000000061 r20-23 000000009e04ce28 0000000000000010 0000000000000010 0000000040b89e40 r24-27 0000000000000003 0000000000ffffff 000000009d82d210 0000000040c14de0 r28-31 0000000000000000 000000009e04ca90 000000009e04cb40 0000000000000000 sr00-03 0000000000000000 0000000000000000 0000000000000000 0000000000000000 sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000 IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000404aece0 00000000404aece4 IIR: 03ffe01f ISR: 0000000010340000 IOR: 000001781304cac8 CPU: 0 CR30: 000000009e04c000 CR31: 00000000e2976de2 ORIG_R28: 0000000000000200 IAOQ[0]: sba_dma_supported+0x80/0xd0 IAOQ[1]: sba_dma_supported+0x84/0xd0 RP(r2): parport_pc_probe_port+0x178/0x1200 Cause is a call to dma_coerce_mask_and_coherenet in parport_pc_probe_port, which PARISC DMA API doesn't handle very nicely. This commit gives back DMA_ERROR_CODE for DMA API calls, if device isn't capable of DMA transaction. Cc: <stable@vger.kernel.org> # v3.13+ Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Helge Deller <deller@gmx.de>
2017-03-03Merge branch 'parisc-4.11-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fixes and cleanups from Helge Deller: "Nothing really important in this patchset: fix resource leaks in error paths, coding style cleanups and code removal" * 'parisc-4.11-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Remove flush_user_dcache_range and flush_user_icache_range parisc: fix a printk parisc: ccio-dma: Handle return NULL error from ioremap_nocache parisc: Define access_ok() as macro parisc: eisa: Fix resource leaks in error paths parisc: eisa: Remove coding style errors
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/signal.h> We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/signal.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-25parisc: ccio-dma: Handle return NULL error from ioremap_nocacheArvind Yadav
Fix error paths and return -ENOMEM instead of '1'. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Helge Deller <deller@gmx.de>
2017-02-25parisc: eisa: Fix resource leaks in error pathsArvind Yadav
2017-02-25parisc: eisa: Remove coding style errorsArvind Yadav
This patch removes coding style errors in the eisa driver. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Helge Deller <deller@gmx.de>
2017-01-24treewide: Constify most dma_map_ops structuresBart Van Assche
Most dma_map_ops structures are never modified. Constify these structures such that these can be write-protected. This patch has been generated as follows: git grep -l 'struct dma_map_ops' | xargs -d\\n sed -i \ -e 's/struct dma_map_ops/const struct dma_map_ops/g' \ -e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \ -e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \ -e 's/const const struct dma_map_ops /const struct dma_map_ops /g'; sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops intel_dma_ops'); sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \ $(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc); sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \ -e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \ -e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \ drivers/pci/host/*.c sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Juergen Gross <jgross@suse.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Russell King <linux@armlinux.org.uk> Cc: x86@kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-16Merge tag 'pci-v4.6-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for v4.6: Enumeration: - Disable IO/MEM decoding for devices with non-compliant BARs (Bjorn Helgaas) - Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs (Bjorn Helgaas Resource management: - Mark shadow copy of VGA ROM as IORESOURCE_PCI_FIXED (Bjorn Helgaas) - Don't assign or reassign immutable resources (Bjorn Helgaas) - Don't enable/disable ROM BAR if we're using a RAM shadow copy (Bjorn Helgaas) - Set ROM shadow location in arch code, not in PCI core (Bjorn Helgaas) - Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs (Bjorn Helgaas) - ia64: Use ioremap() instead of open-coded equivalent (Bjorn Helgaas) - ia64: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas) - MIPS: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas) - Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY (Bjorn Helgaas) - Don't leak memory if sysfs_create_bin_file() fails (Bjorn Helgaas) - rcar: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi) - designware: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi) Virtualization: - Wait for up to 1000ms after FLR reset (Alex Williamson) - Support SR-IOV on any function type (Kelly Zytaruk) - Add ACS quirk for all Cavium devices (Manish Jaggi) AER: - Rename pci_ops_aer to aer_inj_pci_ops (Bjorn Helgaas) - Restore pci_ops pointer while calling original pci_ops (David Daney) - Fix aer_inject error codes (Jean Delvare) - Use dev_warn() in aer_inject (Jean Delvare) - Log actual error causes in aer_inject (Jean Delvare) - Log aer_inject error injections (Jean Delvare) VPD: - Prevent VPD access for buggy devices (Babu Moger) - Move pci_read_vpd() and pci_write_vpd() close to other VPD code (Bjorn Helgaas) - Move pci_vpd_release() from header file to pci/access.c (Bjorn Helgaas) - Remove struct pci_vpd_ops.release function pointer (Bjorn Helgaas) - Rename VPD symbols to remove unnecessary "pci22" (Bjorn Helgaas) - Fold struct pci_vpd_pci22 into struct pci_vpd (Bjorn Helgaas) - Sleep rather than busy-wait for VPD access completion (Bjorn Helgaas) - Update VPD definitions (Hannes Reinecke) - Allow access to VPD attributes with size 0 (Hannes Reinecke) - Determine actual VPD size on first access (Hannes Reinecke) Generic host bridge driver: - Move structure definitions to separate header file (David Daney) - Add pci_host_common_probe(), based on gen_pci_probe() (David Daney) - Expose pci_host_common_probe() for use by other drivers (David Daney) Altera host bridge driver: - Fix altera_pcie_link_is_up() (Ley Foon Tan) Cavium ThunderX host bridge driver: - Add PCIe host driver for ThunderX processors (David Daney) - Add driver for ThunderX-pass{1,2} on-chip devices (David Daney) Freescale i.MX6 host bridge driver: - Add DT bindings to configure PHY Tx driver settings (Justin Waters) - Move imx6_pcie_reset_phy() near other PHY handling functions (Lucas Stach) - Move PHY reset into imx6_pcie_establish_link() (Lucas Stach) - Remove broken Gen2 workaround (Lucas Stach) - Move link up check into imx6_pcie_wait_for_link() (Lucas Stach) Freescale Layerscape host bridge driver: - Add "fsl,ls2085a-pcie" compatible ID (Yang Shi) Intel VMD host bridge driver: - Attach VMD resources to parent domain's resource tree (Jon Derrick) - Set bus resource start to 0 (Keith Busch) Microsoft Hyper-V host bridge driver: - Add fwnode_handle to x86 pci_sysdata (Jake Oshins) - Look up IRQ domain by fwnode_handle (Jake Oshins) - Add paravirtual PCI front-end for Microsoft Hyper-V VMs (Jake Oshins) NVIDIA Tegra host bridge driver: - Add pci_ops.{add,remove}_bus() callbacks (Thierry Reding) - Implement ->{add,remove}_bus() callbacks (Thierry Reding) - Remove unused struct tegra_pcie.num_ports field (Thierry Reding) - Track bus -> CPU mapping (Thierry Reding) - Remove misleading PHYS_OFFSET (Thierry Reding) Renesas R-Car host bridge driver: - Depend on ARCH_RENESAS, not ARCH_SHMOBILE (Simon Horman) Synopsys DesignWare host bridge driver: - ARC: Add PCI support (Joao Pinto) - Add generic dw_pcie_wait_for_link() (Joao Pinto) - Add default link up check if sub-driver doesn't override (Joao Pinto) - Add driver for prototyping kits based on ARC SDP (Joao Pinto) TI Keystone host bridge driver: - Defer probing if devm_phy_get() returns -EPROBE_DEFER (Shawn Lin) Xilinx AXI host bridge driver: - Use of_pci_get_host_bridge_resources() to parse DT (Bharat Kumar Gogada) - Remove dependency on ARM-specific struct hw_pci (Bharat Kumar Gogada) - Don't call pci_fixup_irqs() on Microblaze (Bharat Kumar Gogada) - Update Zynq binding with Microblaze node (Bharat Kumar Gogada) - microblaze: Support generic Xilinx AXI PCIe Host Bridge IP driver (Bharat Kumar Gogada) Xilinx NWL host bridge driver: - Add support for Xilinx NWL PCIe Host Controller (Bharat Kumar Gogada) Miscellaneous: - Check device_attach() return value always (Bjorn Helgaas) - Move pci_set_flags() from asm-generic/pci-bridge.h to linux/pci.h (Bjorn Helgaas) - Remove includes of empty asm-generic/pci-bridge.h (Bjorn Helgaas) - ARM64: Remove generated include of asm-generic/pci-bridge.h (Bjorn Helgaas) - Remove empty asm-generic/pci-bridge.h (Bjorn Helgaas) - Remove includes of asm/pci-bridge.h (Bjorn Helgaas) - Consolidate PCI DMA constants and interfaces in linux/pci-dma-compat.h (Bjorn Helgaas) - unicore32: Remove unused HAVE_ARCH_PCI_SET_DMA_MASK definition (Bjorn Helgaas) - Cleanup pci/pcie/Kconfig whitespace (Andreas Ziegler) - Include pci/hotplug Kconfig directly from pci/Kconfig (Bjorn Helgaas) - Include pci/pcie/Kconfig directly from pci/Kconfig (Bogicevic Sasa) - frv: Remove stray pci_{alloc,free}_consistent() declaration (Christoph Hellwig) - Move pci_dma_* helpers to common code (Christoph Hellwig) - Add PCI_CLASS_SERIAL_USB_DEVICE definition (Heikki Krogerus) - Add QEMU top-level IDs for (sub)vendor & device (Robin H. Johnson) - Fix broken URL for Dell biosdevname (Naga Venkata Sai Indubhaskar Jupudi)" * tag 'pci-v4.6-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits) PCI: Add PCI_CLASS_SERIAL_USB_DEVICE definition PCI: designware: Add driver for prototyping kits based on ARC SDP PCI: designware: Add default link up check if sub-driver doesn't override PCI: designware: Add generic dw_pcie_wait_for_link() PCI: Cleanup pci/pcie/Kconfig whitespace PCI: Simplify pci_create_attr() control flow PCI: Don't leak memory if sysfs_create_bin_file() fails PCI: Simplify sysfs ROM cleanup PCI: Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY MIPS: Loongson 3: Keep CPU physical (not virtual) addresses in shadow ROM resource MIPS: Loongson 3: Use temporary struct resource * to avoid repetition ia64/PCI: Keep CPU physical (not virtual) addresses in shadow ROM resource ia64/PCI: Use ioremap() instead of open-coded equivalent ia64/PCI: Use temporary struct resource * to avoid repetition PCI: Clean up pci_map_rom() whitespace PCI: Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs PCI: thunder: Add driver for ThunderX-pass{1,2} on-chip devices PCI: thunder: Add PCIe host driver for ThunderX processors PCI: generic: Expose pci_host_common_probe() for use by other drivers PCI: generic: Add pci_host_common_probe(), based on gen_pci_probe() ...
2016-03-08PCI: Include pci/hotplug Kconfig directly from pci/KconfigBjorn Helgaas
Include pci/hotplug/Kconfig directly from pci/Kconfig, so arches don't have to source both pci/Kconfig and pci/hotplug/Kconfig. Note that this effectively adds pci/hotplug/Kconfig to the following arches, because they already sourced drivers/pci/Kconfig but they previously did not source drivers/pci/hotplug/Kconfig: alpha arm avr32 frv m68k microblaze mn10300 sparc unicore32 Inspired-by-patch-from: Bogicevic Sasa <brutallesale@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-01-30drivers: Initialize resource entry to zeroToshi Kani
I/O resource descriptor, 'desc' in struct resource, needs to be initialized to zero by default. Some drivers call kmalloc() to allocate a resource entry, but do not initialize it to zero by memset(). Change these drivers to call kzalloc(), instead. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Alexandre Bounine <alexandre.bounine@idt.com> Acked-by: Helge Deller <deller@gmx.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: linux-acpi@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-mm <linux-mm@kvack.org> Cc: linux-parisc@vger.kernel.org Cc: linux-renesas-soc@vger.kernel.org Cc: linux-sh@vger.kernel.org Link: http://lkml.kernel.org/r/1453841853-11383-10-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-20parisc: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Helge Deller <deller@gmx.de> Acked-by: Helge Deller <deller@gmx.de> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12parisc: Initialize PCI bridge cache line and default latencyHelge Deller
PCI controllers and pci-pci bridges may have not been fully initialized regarding cache line and defaul latency. This partly reverts commit 5f0e9b4 ("parisc: Remove unused pcibios_init_bus()") Signed-off-by: Helge Deller <deller@gmx.de>
2015-12-12parisc iommu: fix panic due to trying to allocate too large regionMikulas Patocka
When using the Promise TX2+ SATA controller on PA-RISC, the system often crashes with kernel panic, for example just writing data with the dd utility will make it crash. Kernel panic - not syncing: drivers/parisc/sba_iommu.c: I/O MMU @ 000000000000a000 is out of mapping resources CPU: 0 PID: 18442 Comm: mkspadfs Not tainted 4.4.0-rc2 #2 Backtrace: [<000000004021497c>] show_stack+0x14/0x20 [<0000000040410bf0>] dump_stack+0x88/0x100 [<000000004023978c>] panic+0x124/0x360 [<0000000040452c18>] sba_alloc_range+0x698/0x6a0 [<0000000040453150>] sba_map_sg+0x260/0x5b8 [<000000000c18dbb4>] ata_qc_issue+0x264/0x4a8 [libata] [<000000000c19535c>] ata_scsi_translate+0xe4/0x220 [libata] [<000000000c19a93c>] ata_scsi_queuecmd+0xbc/0x320 [libata] [<0000000040499bbc>] scsi_dispatch_cmd+0xfc/0x130 [<000000004049da34>] scsi_request_fn+0x6e4/0x970 [<00000000403e95a8>] __blk_run_queue+0x40/0x60 [<00000000403e9d8c>] blk_run_queue+0x3c/0x68 [<000000004049a534>] scsi_run_queue+0x2a4/0x360 [<000000004049be68>] scsi_end_request+0x1a8/0x238 [<000000004049de84>] scsi_io_completion+0xfc/0x688 [<0000000040493c74>] scsi_finish_command+0x17c/0x1d0 The cause of the crash is not exhaustion of the IOMMU space, there is plenty of free pages. The function sba_alloc_range is called with size 0x11000, thus the pages_needed variable is 0x11. The function sba_search_bitmap is called with bits_wanted 0x11 and boundary size is 0x10 (because dma_get_seg_boundary(dev) returns 0xffff). The function sba_search_bitmap attempts to allocate 17 pages that must not cross 16-page boundary - it can't satisfy this requirement (iommu_is_span_boundary always returns true) and fails even if there are many free entries in the IOMMU space. How did it happen that we try to allocate 17 pages that don't cross 16-page boundary? The cause is in the function iommu_coalesce_chunks. This function tries to coalesce adjacent entries in the scatterlist. The function does several checks if it may coalesce one entry with the next, one of those checks is this: if (startsg->length + dma_len > max_seg_size) break; When it finishes coalescing adjacent entries, it allocates the mapping: sg_dma_len(contig_sg) = dma_len; dma_len = ALIGN(dma_len + dma_offset, IOVP_SIZE); sg_dma_address(contig_sg) = PIDE_FLAG | (iommu_alloc_range(ioc, dev, dma_len) << IOVP_SHIFT) | dma_offset; It is possible that (startsg->length + dma_len > max_seg_size) is false (we are just near the 0x10000 max_seg_size boundary), so the funcion decides to coalesce this entry with the next entry. When the coalescing succeeds, the function performs dma_len = ALIGN(dma_len + dma_offset, IOVP_SIZE); And now, because of non-zero dma_offset, dma_len is greater than 0x10000. iommu_alloc_range (a pointer to sba_alloc_range) is called and it attempts to allocate 17 pages for a device that must not cross 16-page boundary. To fix the bug, we must make sure that dma_len after addition of dma_offset and alignment doesn't cross the segment boundary. I.e. change if (startsg->length + dma_len > max_seg_size) break; to if (ALIGN(dma_len + dma_offset + startsg->length, IOVP_SIZE) > max_seg_size) break; This patch makes this change (it precalculates max_seg_boundary at the beginning of the function iommu_coalesce_chunks). I also added a check that the mapping length doesn't exceed dma_get_seg_boundary(dev) (it is not needed for Promise TX2+ SATA, but it may be needed for other devices that have dma_get_seg_boundary lower than dma_get_max_seg_size). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Helge Deller <deller@gmx.de>
2015-11-10pci: remove pci_dma_supportedChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-22parisc: reduce syslog debug outputHelge Deller
2015-09-15PCI: Revert "PCI: Call pci_read_bridge_bases() from core instead of arch code"Bjorn Helgaas
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead of arch code"). Reading PCI bridge windows is not arch-specific in itself, but there is PCI core code that doesn't work correctly if we read them too early. For example, Hannes found this case on an ARM Freescale i.mx6 board: pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff] pci 0000:00:00.0: PCI bridge to [bus 01-ff] pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window) pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000] pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000] pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100] The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs 0x204100 of space, and mem windows are megabyte-aligned. Bus sizing can increase a bridge window size, but never *decrease* it (see d65245c3297a ("PCI: don't shrink bridge resources")). Prior to dff22d2054b5, ARM didn't read bridge windows at all, so the "original size" was zero, and we assigned a 3MB window. After dff22d2054b5, we read the bridge windows before sizing the bus. The firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since we never decrease the size, we kept 16MB even though we only needed 3MB. But 16MB doesn't fit in the host bridge aperture, so we failed to assign space for the window and the downstream devices. I think this is a defect in the PCI core: we shouldn't rely on the firmware to assign sensible windows. Ray reported a similar problem, also on ARM, with Broadcom iProc. Issues like this are too hard to fix right now, so revert dff22d2054b5. Reported-by: Hannes <oe5hpm@gmail.com> Reported-by: Ray Jui <rjui@broadcom.com> Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2015-09-10parisc: use seq_hex_dump() to dump buffersAndy Shevchenko
Instead of custom approach let's use recently introduced seq_hex_dump() helper. In one case it changes the output from 1111111122222222333333334444444455555555666666667777777788888888 to 11111111 22222222 33333333 44444444 55555555 66666666 77777777 88888888 though it seems it prints same data (by meaning) in both cases. I decide to choose to use the space divided one. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Joe Perches <joe@perches.com> Cc: Tadeusz Struk <tadeusz.struk@intel.com> Cc: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08PCI,parisc: Enable 64-bit bus addresses on PA-RISCHelge Deller
Commit 3a9ad0b ("PCI: Add pci_bus_addr_t") unconditionally introduced usage of 64-bit PCI bus addresses on all 64-bit platforms which broke PA-RISC. It turned out that due to enabling the 64-bit addresses, the PCI logic decided to use the GMMIO instead of the LMMIO region. This commit simply disables registering the GMMIO and thus we fall back to use the LMMIO region as before. Reverts commit 45ea2a5fed6dacb9bb0558d8b21eacc1c45d5bb4 ("PCI: Don't use 64-bit bus addresses on PA-RISC") To: linux-parisc@vger.kernel.org Cc: linux-pci@vger.kernel.org Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Meelis Roos <mroos@linux.ee> Cc: stable@vger.kernel.org # v3.19+ Signed-off-by: Helge Deller <deller@gmx.de>
2015-09-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This updated pull request does not contain the last few GIC related patches which were reported to cause a regression. There is a fix available, but I let it breed for a couple of days first. The irq departement provides: - new infrastructure to support non PCI based MSI interrupts - a couple of new irq chip drivers - the usual pile of fixlets and updates to irq chip drivers - preparatory changes for removal of the irq argument from interrupt flow handlers - preparatory changes to remove IRQF_VALID" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2 irqchip: Add documentation for the bcm2836 interrupt controller irqchip/bcm2835: Add support for being used as a second level controller irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ PCI: xilinx: Fix typo in function name irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance irqchip/gic: Only allow the primary GIC to set the CPU map PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove unicore32/irq: Prepare puv3_gpio_handler for irq argument removal tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal m68k/irq: Prepare irq handlers for irq argument removal C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal blackfin: Prepare irq handlers for irq argument removal arc/irq: Prepare idu_cascade_isr for irq argument removal sparc/irq: Use access helper irq_data_get_affinity_mask() sparc/irq: Use helper irq_data_get_irq_handler_data() parisc/irq: Use access helper irq_data_get_affinity_mask() mn10300/irq: Use access helper irq_data_get_affinity_mask() irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal ...
2015-07-31parisc/irq: Use access helper irq_data_get_affinity_mask()Jiang Liu
Use access helper irq_data_get_affinity_mask() to hide implementation details of struct irq_desc. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Link: http://lkml.kernel.org/r/1433145945-789-24-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-23PCI: Call pci_read_bridge_bases() from core instead of arch codeLorenzo Pieralisi
When we scan a PCI bus, we read PCI-PCI bridge window registers with pci_read_bridge_bases() so we can validate the resource hierarchy. Most architectures call pci_read_bridge_bases() from pcibios_fixup_bus(), but PCI-PCI bridges are not arch-specific, so this doesn't need to be in arch-specific code. Call pci_read_bridge_bases() directly from the PCI core instead of from arch code. For alpha and mips, we now call pci_read_bridge_bases() always; previously we only called it if PCI_PROBE_ONLY was set. [bhelgaas: changelog] Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Ralf Baechle <ralf@linux-mips.org> CC: James E.J. Bottomley <jejb@parisc-linux.org> CC: Michael Ellerman <mpe@ellerman.id.au> CC: Bjorn Helgaas <bhelgaas@google.com> CC: Richard Henderson <rth@twiddle.net> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: David Howells <dhowells@redhat.com> CC: Russell King <linux@arm.linux.org.uk> CC: Tony Luck <tony.luck@intel.com> CC: David S. Miller <davem@davemloft.net> CC: Ingo Molnar <mingo@redhat.com> CC: Guenter Roeck <linux@roeck-us.net> CC: Michal Simek <monstr@monstr.eu> CC: Chris Zankel <chris@zankel.net>
2015-04-24parisc: %pf is only for function pointersScott Wood
Use %ps for actual addresses, otherwise you'll get bad output on arches like parisc64 where %pf expects a function descriptor. This wasn't normally seen on parisc64 because the code is not built unless DEBUG_SUPERIO_INIT is manually defined. Patch modified by Helge Deller to utilize KERN_DEBUG. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: linux-parisc@vger.kernel.org cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Helge Deller <deller@gmx.de>
2015-04-21parisc: Eliminate sg_virt_addr() and private scatterlist.hMatthew Wilcox
The only reason to keep parisc's private asm/scatterlist.h was that it had the macro sg_virt_addr(). Convert all callers to use something else (sometimes just sg->offset was enough, others should use sg_virt()), and we can just use the asm-generic scatterlist.h instead. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Dave Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2015-04-15parisc: remove use of seq_printf return valueJoe Perches
The seq_printf return value, because it's frequently misused, will eventually be converted to void. See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to seq_has_overflowed() and make public") Signed-off-by: Joe Perches <joe@perches.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
