path: root/drivers/parport
2014-02-28parport: fix interruptible_sleep_on raceArnd Bergmann
The interruptible_sleep_on function is can still lead to the deadlock mentioned in the comment above the caller, and we want to remove it soon, so replace it now with the race-free wait_event_interruptible. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrew Morton <akpm@osdl.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-20Merge tag 'tty-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver pull request for 3.14-rc1 There are a number of n_tty fixes and cleanups, and some serial driver bugfixes, and we got rid of one obsolete driver, making this series remove more lines than added, always a nice surprise. All of these have been in linux-next with no reports of issues" * tag 'tty-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (60 commits) tty/serial: at91: disable uart timer at start of shutdown serial: 8250: enable UART_BUG_NOMSR for Tegra tty/serial: at91: reset rx_ring when port is shutdown tty/serial: at91: fix race condition in atmel_serial_remove tty/serial: at91: Handle shutdown more safely serial: sirf: correct condition for fetching dma buffer into tty serial: sirf: provide pm entries of uart_ops serial: sirf: use PM macro initialize PM functions serial: clps711x: Enable driver compilation with COMPILE_TEST serial: clps711x: Add support for N_IRDA line discipline tty: synclink: avoid sleep_on race tty/amiserial: avoid interruptible_sleep_on tty: delete non-required instances of include <linux/init.h> tty: an overflow of multiplication in drivers/tty/cyclades.c serial: Remove old SC26XX driver serial: add support for 200 v3 series Titan card serial: 8250: Fix initialisation of Quatech cards with the AMCC PCI chip tty: Removing the deprecated function tty_vhangup_locked() TTY/n_gsm: Removing the wrong tty_unlock/lock() in gsm_dlci_release() tty/serial: at91: document clock properties ...
2014-01-20Merge tag 'char-misc-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver patches for 3.14-rc1. Lots of little things, and a new "big" driver, genwqe. Full details are in the shortlog" * tag 'char-misc-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) mei: limit the number of consecutive resets mei: revamp mei reset state machine drivers/char: don't use module_init in non-modular ttyprintk.c VMCI: fix error handling path when registering guest driver extcon: gpio: Add power resume support Documentation: HOWTO: Updates on subsystem trees, patchwork, -next (vs. -mm) in ko_KR Documentation: HOWTO: update for 2.6.x -> 3.x versioning in ko_KR Documentation: HOWTO: update stable address in ko_KR Documentation: HOWTO: update LXR web link in ko_KR char: nwbutton: open-code interruptible_sleep_on mei: fix syntax in comments and debug output mei: nfc: mei_nfc_free has to be called under lock mei: use hbm idle state to prevent spurious resets mei: do not run reset flow from the interrupt thread misc: genwqe: fix return value check in genwqe_device_create() GenWQE: Fix warnings for sparc GenWQE: Fix compile problems for Alpha Documentation/misc-devices/mei/mei-amt-version.c: remove unneeded call of mei_deinit() GenWQE: Rework return code for flash-update ioctl sgi-xp: open-code interruptible_sleep_on_timeout ...
2013-12-10parport: parport_pc: remove double PCI ID for NetMosSebastian Andrzej Siewior
In commit 85747f ("PATCH] parport: add NetMOS 9805 support") Max added the PCI ID for NetMOS 9805 based on a Debian bug report from 2k4 which was at the v2.4.26 time frame. The patch made into 2.6.14. Shortly before that patch akpm merged commit 296d3c783b ("[PATCH] Support NetMOS based PCI cards providing serial and parallel ports") which made into v2.6.9-rc1. Now we have two different entries for the same PCI id. I have here the NetMos 9805 which claims to support SPP/EPP/ECP mode. This patch takes Max's entry for titan_1284p1 (base != -1 specifies the ioport for ECP mode) and replaces akpm's entry for netmos_9805 which specified -1 (=none). Both share the same PCI-ID (my card has subsystem 0x1000 / 0x0020 so it should match PCI_ANY). While here I also drop the entry for titan_1284p2 which is the same as netmos_9815. Cc: Maximilian Attems <maks@stro.at> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-10parport_pc: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-10parport: parport_pc: fix id print of a deviceSebastian Andrzej Siewior
Since commit 7106b4e3 ("8250: Oxford Semiconductor Devices") the debug print of the device id does no longer match the real device if it is located in the "enum" behind oxsemi_pcie_pport. The reason is that the code assumes that each id contains one entry in the PCI table. The fix is to lookup the currently used id from the id-> parameter. Cc: Lee Howard <lee.howard@mainpine.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08parport_serial: remove unnecessary pci_set_drvdata()Jingoo Han
2013-11-26zorro: ZTWO_VADDR() should return "void __iomem *"Geert Uytterhoeven
ZTWO_VADDR() converts from physical to virtual I/O addresses, so it should return "void __iomem *" instead of "unsigned long". This allows to drop several casts, but requires adding a few casts to accomodate legacy driver frameworks that store "unsigned long" I/O addresses. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-11-15Merge tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreamingLinus Torvalds
Pull Kconfig cleanups from Mark Salter: "Remove some unused config options from C6X and clean up PC_PARPORT dependencies. The latter was discussed here: https://lkml.org/lkml/2013/10/8/12" * tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: c6x: remove unused COMMON_CLKDEV Kconfig parameter Kconfig cleanup (PARPORT_PC dependencies) x86: select ARCH_MIGHT_HAVE_PC_PARPORT unicore32: select ARCH_MIGHT_HAVE_PC_PARPORT sparc: select ARCH_MIGHT_HAVE_PC_PARPORT sh: select ARCH_MIGHT_HAVE_PC_PARPORT powerpc: select ARCH_MIGHT_HAVE_PC_PARPORT parisc: select ARCH_MIGHT_HAVE_PC_PARPORT mips: select ARCH_MIGHT_HAVE_PC_PARPORT microblaze: select ARCH_MIGHT_HAVE_PC_PARPORT m68k: select ARCH_MIGHT_HAVE_PC_PARPORT ia64: select ARCH_MIGHT_HAVE_PC_PARPORT arm: select ARCH_MIGHT_HAVE_PC_PARPORT alpha: select ARCH_MIGHT_HAVE_PC_PARPORT c6x: remove unused parameter in Kconfig
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-12Merge tag 'h8300-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull h8300 platform removal from Guenter Roeck: "The patch series has been in -next for more than one relase cycle. I did get a number of Acks, and no objections. H8/300 has been dead for several years, the kernel for it has not compiled for ages, and recent versions of gcc for it are broken. Remove support for it" * tag 'h8300-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: CREDITS: Add Yoshinori Sato for h8300 fs/minix: Drop dependency on H8300 Drop remaining references to H8/300 architecture Drop MAINTAINERS entry for H8/300 watchdog: Drop references to H8300 architecture net/ethernet: Drop H8/300 Ethernet driver net/ethernet: smsc9194: Drop conditional code for H8/300 ide: Drop H8/300 driver Drop support for Renesas H8/300 (h8300) architecture
2013-10-31DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent()Russell King
The code sequence: dev->coherent_dma_mask = DMA_BIT_MASK(24); dev->dma_mask = &dev->coherent_dma_mask; bypasses the architectures check on the DMA mask. It can be replaced with dma_coerce_mask_and_coherent(), avoiding the direct initialization of this mask. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-23Kconfig cleanup (PARPORT_PC dependencies)Mark Salter
Remove messy dependencies from PARPORT_PC by having it depend on one Kconfig symbol (ARCH_MIGHT_HAVE_PC_PARPORT) and having architectures which need it, select ARCH_MIGHT_HAVE_PC_PARPORT in arch/*/Kconfig. New architectures are unlikely to need PARPORT_PC, so this avoids having an ever growing list of architectures to exclude. Those architectures which do select ARCH_MIGHT_HAVE_PC_PARPORT in this patch are the ones which have an asm/parport.h (or use the generic version). Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: Ingo Molnar <mingo@redhat.com> CC: Richard Henderson <rth@twiddle.net> CC: linux-alpha@vger.kernel.org CC: Vineet Gupta <vgupta@synopsys.com> CC: Russell King <linux@arm.linux.org.uk> CC: linux-arm-kernel@lists.infradead.org CC: Tony Luck <tony.luck@intel.com> CC: Fenghua Yu <fenghua.yu@intel.com> CC: linux-ia64@vger.kernel.org CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: linux-m68k@lists.linux-m68k.org CC: Michal Simek <monstr@monstr.eu> CC: microblaze-uclinux@itee.uq.edu.au CC: Ralf Baechle <ralf@linux-mips.org> CC: linux-mips@linux-mips.org CC: "James E.J. Bottomley" <jejb@parisc-linux.org> CC: Helge Deller <deller@gmx.de> CC: linux-parisc@vger.kernel.org CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Paul Mackerras <paulus@samba.org> CC: linuxppc-dev@lists.ozlabs.org CC: Paul Mundt <lethal@linux-sh.org> CC: linux-sh@vger.kernel.org CC: "David S. Miller" <davem@davemloft.net> CC: sparclinux@vger.kernel.org CC: Guan Xuetao <gxt@mprc.pku.edu.cn> CC: Thomas Gleixner <tglx@linutronix.de> CC: "H. Peter Anvin" <hpa@zytor.com> CC: x86@kernel.org
2013-08-30drivers: parport: Kconfig: exclude h8300 for PARPORT_PCChen Gang
h8300 does not support PARPORT_PC. The related error (with allmodconfig for h8300): CC [M] drivers/parport/parport_pc.o drivers/parport/parport_pc.c:67:25: fatal error: asm/parport.h: No such file or directory Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-27parport: amiga: remove unnecessary platform_set_drvdata()Jingoo Han
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03drivers/parport/share.c: use kzallocAlexandru Gheorghiu
Replaced calls to kmalloc and memset with kzalloc. Patch found using coccinelle. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-16parport: disable PC-style parallel port support on crisGeert Uytterhoeven
2013-06-01parisc: parport0: fix this legacy no-device port driver!Helge Deller
Fix the above kernel error from parport_announce_port() on 32bit GSC machines (e.g. B160L). The parport driver requires now a pointer to the device struct. Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parport_pc: disable PARPORT_PC_SUPERIO on parisc architectureHelge Deller
If enabled, CONFIG_PARPORT_PC_SUPERIO scans on PC-like hardware for various super-io chips by accessing i/o ports in a range which will crash any parisc hardware at once. In addition, parisc has it's own incompatible superio chip (CONFIG_SUPERIO), so if we disable PARPORT_PC_SUPERIO completely for parisc we can avoid that people by accident enable the parport_pc superio option too. Signed-off-by: Helge Deller <deller@gmx.de>
2013-03-25parport: use kmemdup instead of kmalloc + memcpySilviu-Mihai Popescu
This replaces calls to kmalloc followed by memcpy with a single call to kmemdup. This was found via make coccicheck. Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25parport: amiga: use module_platform_driver_probe()Fabio Porcedda
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Cc: Matt Porter <mporter@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15drivers/parport: use module_pcmcia_driver() in pcmcia driversH Hartley Sweeten
Use the new module_pcmcia_driver() macro to remove the boilerplate module init/exit code in the pcmcia drivers. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "The most prominent change in this patch set is the software dirty bit patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and the page_test_and_clear_dirty primitive which makes the common memory management code a bit less obscure. Heiko fixed most of the PCI related fallout, more often than not missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270 patches which adds an export to tty_io to be able to resize a tty. The rest is the usual bunch of cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/module: Add missing R_390_NONE relocation type drivers/gpio: add missing GENERIC_HARDIRQ dependency drivers/input: add couple of missing GENERIC_HARDIRQS dependencies s390/cleanup: rename SPP to LPP s390/mm: implement software dirty bits s390/mm: Fix crst upgrade of mmap with MAP_FIXED s390/linker skript: discard exit.data at runtime drivers/media: add missing GENERIC_HARDIRQS dependency s390/bpf,jit: add vlan tag support drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency iucv: fix kernel panic at reboot s390/Kconfig: sort list of arch selected config options phylib: remove !S390 dependeny from Kconfig uio: remove !S390 dependency from Kconfig dasd: fix sysfs cleanup in dasd_generic_remove s390/pci: fix hotplug module init s390/pci: cleanup clp page allocation s390/pci: cleanup clp inline assembly s390/perf: cpum_cf: fallback to software sampling events s390/mm: provide PAGE_SHARED define ...
2013-02-14parport: disable PC-style parallel port support for s390Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-30serial/8250: Add suport for later SUNIX (TIMEDIA) boards.Stephen Chivers
Add support for later SUNIX (TIMEDIA) Universal PCI Single and Multi-Port Communications Boards. These boards have PCI Vendor ID 1fd4 with device ID 1999 but otherwise appear to be the same as the TIMEDIA boards already supported by 8250_pci and parport_serial. Tested with: a. the two port serial board part number SER5037A, b. the two port serial and one port parallel board part number MIO5079A. Signed-off-by: Stephen Chivers <schivers@csc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: parport: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Matt Porter <mporter@ti.com> Cc: Kay Sievers <kay@vrfy.org> Cc: Gianluca Anzolin <gianluca@sottospazio.it> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15drivers/parport: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-09Merge tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa patchset from Chris Zankel: "The Xtensa tree has been broken for some time now, and this patchset brings it back to life. It has been part of the linux-next tree for some time. Most changes are inside the xtensa subdirectory; the other changes mostly add another rule to already existing #ifdefs to exclude Xtensa, where required. The only 'common' change is to add two more sections ('.xt.prop' and '.xt.lit') to the white list in modpost." * tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linux: (27 commits) xtensa: Setup CROSS_COMPILE at the top xtensa: drop CONFIG_EMBEDDED_RAMDISK xtensa: fix TIOCGSERIAL and TIOCSSERIAL definitions xtensa: provide dummy gcc intrinsics xtensa: add missing symbol exports parport: disable for xtensa arch xtensa: rename MISC SR definition to avoid name clashes hisax: disable build for big-endian xtensa xtensa: fix CODA build xtensa: fix parallel make xtensa: ISS: drop unused io.c xtensa: ISS: exit simulator in case of halt or poweroff xtensa: ISS: change keyboard polling rate xtensa: ISS: add platform_pcibios_init xtensa: ISS: add dummy serial.h for ISS platform xtensa: change default platform clock frequency to 10MHz xtensa: add ARCH_WANT_OPTIONAL_GPIOLIB to xtensa config xtensa: set NO_IOPORT to 'n' by default xtensa: adopt generic io routines xtensa: fix ioremap ...
2012-10-03parport: disable for xtensa archMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-09-05parport: fix possible memory leak in parport_gsc_probe_port()Wei Yongjun
ops has been allocated in this function and should be freed before leaving from the error handling cases. spatch with a semantic match is used to found this problem. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05parport_serial: Add support for the WCH353 2S/1P multi-IO cardGuainluca Anzolin
To allow parport_serial to handle the card the same PCI ids are blacklisted in 8250_pci.c using the existing software blacklist mechanism. The blacklist array is also renamed because it now covers this new use case. Since the two serial ports are auto-detected as XScale instead of 16550A clones, we also add a quirk to 8250_pci.c to skip autodetection and set the correct port type. Signed-off-by: Gianluca Anzolin <gianluca@sottospazio.it> [Fold in fixes for the uart_8250 change] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-08parport: use KERN_CONT in printk() continuation linesKay Sievers
On Tue, May 8, 2012 at 10:48 AM, Sasha Levin <levinsasha928@gmail.com> wrote: > Before: > [ 10.110626] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] > > After: > parport0: PC-style at 0x378 > , irq 7 > [ > PCSPP > ,TRISTATE > ] Reported-By: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Kay Sievers <kay@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20parport: remove unused dead code from lowlevel driversMatt Porter
This unused code has been untouched for over 7 years and must go. Signed-off-by: Matt Porter <mporter@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-12drivers/parport/parport_pc.c: fix warningsAndrew Morton
drivers/parport/parport_pc.c: In function '__check_irq': drivers/parport/parport_pc.c:3415: warning: return from incompatible pointer type drivers/parport/parport_pc.c: In function '__check_dma': drivers/parport/parport_pc.c:3417: warning: return from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-09Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (65 commits) tty: serial: imx: move del_timer_sync() to avoid potential deadlock imx: add polled io uart methods imx: Add save/restore functions for UART control regs serial/imx: let probing fail for the dt case without a valid alias serial/imx: propagate error from of_alias_get_id instead of using -ENODEV tty: serial: imx: Allow UART to be a source for wakeup serial: driver for m32 arch should not have DEC alpha errata serial/documentation: fix documented name of DCD cpp symbol atmel_serial: fix spinlock lockup in RS485 code tty: Fix memory leak in virtual console when enable unicode translation serial: use DIV_ROUND_CLOSEST instead of open coding it serial: add support for 400 and 800 v3 series Titan cards serial: bfin-uart: Remove ASYNC_CTS_FLOW flag for hardware automatic CTS. serial: bfin-uart: Enable hardware automatic CTS only when CTS pin is available. serial: make FSL errata depend on 8250_CONSOLE, not just 8250 serial: add irq handler for Freescale 16550 errata. serial: manually inline serial8250_handle_port serial: make 8250 timeout use the specified IRQ handler serial: export the key functions for an 8250 IRQ handler serial: clean up parameter passing for 8250 Rx IRQ handling ...
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-30parport: convert drivers/parport/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/parport/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben@simtec.co.uk> Cc: Derrick J. Brashear <shadow@dementia.org> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18parport_pc: release IO region properly if unsupported ITE887x card is foundJiri Kosina
sio_ite_8872_probe() bails out if it detects no-parallel (1S, 2S) or unknown card. It doesn't call release_region() on the previously allocated resource though. This causes (a) leak of the resource (b) kernel oops when parport module is removed and /proc/ioports is read. This is because the string that has been associated to the IO port region is a static char array inside the already removed module. Let's call release_region() properly before baling out. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Niels de Vos <ndevos@redhat.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Joe Krahn <krahn@niehs.nih.gov> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-25Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits) amba pl011: workaround for uart registers lockup n_gsm: fix the wrong FCS handling pch_uart: add missing comment about OKI ML7223 pch_uart: Add MSI support tty: fix "IRQ45: nobody cared" PTI feature to allow user to name and mark masterchannel request. 0 for o PTI Makefile bug. tty: serial: samsung.c remove legacy PM code. SERIAL: SC26xx: Fix link error. serial: mrst_max3110: initialize waitqueue earlier mrst_max3110: Change max missing message priority. tty: s5pv210: Add delay loop on fifo reset function for UART tty/serial: Fix XSCALE serial ports, e.g. ce4100 serial: bfin_5xx: fix off-by-one with resource size drivers/tty: use printk_ratelimited() instead of printk_ratelimit() tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs tty: n_gsm: Add raw-ip support tty: n_gsm: expose gsmtty device nodes at ldisc open time pch_phub: Fix register miss-setting issue serial: 8250, increase PASS_LIMIT ...
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-07parport/serial: add support for Timedia/SUNIX cards to parport_serialFrédéric Brière
Timedia/SUNIX PCI cards with both serial and parallel ports are currently supported by 8250_pci and parport_pc individually. Moving that support into parport_serial allows using both types of ports at the same time. This was successfully tested with a SUNIX 4079T. Signed-off-by: Frédéric Brière <fbriere@fbriere.net> Acked-by: Alan Cox <alan@linux.intel.com> Cc: linux-serial@vger.kernel.org Cc: linux-parport@lists.infradead.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07Basic support for Moschip 9900 family I/O chipsNicos Gollan
Add I/O based support for serial and parallel ports of the following chips: Vendor: Moschip (0x9710) Parts (device IDs) * 9900 (0x9900) * 9904 (0x9904 * 9901 (0x9912, also sold as 9912) * 9922 (0x9922) On all chips but the 9900, a single port is provided per PCI subdevice (subvendor-ID 0xA000, subdevice-IDs 0x1000 for serial, 0x2000 for parallel with proper class codes). In cascading configurations, the 9900 provides two devices per subdevice, with subvendor-ID 0xA000 and subdevice-IDs 0x30ps where p is the number of parallel ports and s the number of serial ports. Basic testing was only done on the serial part of a 9912 to the point where it can be used for a serial kernel console, and advanced features are completely untested. It is possible to reduce functionality of the chips by adding a configuration EEPROM, and the datasheet [1] is inconsistent w.r.t subdevices in the 4s+2s1p and 2s1p+4s configurations. The subdevice-ID 0x3012 should likely read 0x3011 with a serial port in function 3, which would be consistent with the BAR layouts. For now, the drivers ignore subdevices with ID 0x1000 and no class code. The parallel ports are integrated in parport_serial even for purely parallel parts to reduce the footprint of the patch. [1] http://www.moschip.com/data/products/MCS9900/MCS9900_Datasheet.pdf Signed-off-by: Nicos Gollan <gtdev@spearhead.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-25parport: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
