commit 03270c6ac6207fc55bbf9d20d195029dca210c79 upstream.
Usually every parallel port will have a single pardev registered with
it. But ppdev driver is an exception. This userspace parallel port
driver allows to create multiple parrallel port devices for a single
parallel port. And as a result we were having a nice warning like:
"sysctl table check failed:
/dev/parport/parport0/devices/ppdev0/timeslice Sysctl already exists"
Use the same logic as used in parport_register_device() and register
the proc files only once for each parallel port.
Fixes: 6fa45a226897 ("parport: add device-model to parport subsystem")
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1414656
Bugzilla: https://bugs.archlinux.org/task/52322
Tested-by: James Feeney <james@nurealm.net>
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
The drivers which depends on parport may sometimes try to iniitialize
and register with parport bus even before parport has actually
registered with the device layer.
The simplest solution is to mark the init function as subsys_initcall()
and load the parport before the other drivers loads.
It is not an usual practise to assign some value to a variable in the if
test condition.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
checkpatch complains that space is prohibited between function name and
open parenthesis '('.
checkpatch was complaining about NULL comparisons.
If kmalloc() or kzalloc() fails we will get sufficient messages in the logs,
no need to print these extra messages.
checkpatch was complaining about braces for single statement block.
user visible strings should not be split as that affects the ability to
grep.
Code should be indented using tabs and not by space.
The multi-line comments were not according to the kernel coding style.
All symbols were exported at the end of the file but they are supposed
to be exported just after the function. And checkpatch was complaining
about it.
Trailing white space is not accepted in kernel coding style. Remove
them.
s/regsiter/register/
Signed-off-by: Geliang Tang <geliangtang@163.com>
This reverts commit 23c405912b88 ("parport: fix memory leak")
par_dev->state was already being removed in parport_unregister_device().
Reported-by: Ying Huang <ying.huang@intel.com>
After the reference count becomes 0 when put_device() is called, it will
execute the release callback where we are freeing all the allocated
memory associated with the device. So if we just continue on the error
path then we are again freeing devname and trying to dereference par_dev
which has already been free-ed in the release callback.
memory associated with the device. We missed freeing par_dev->state.
After registering the device if exclusive access fails for any reason
then we need to unregister the device to remove all references.
As of now we were starting the registration process and after the device
is registered we were checking if the device can be used by the
parport. Now lets check it first so that we do not need to go through
the registration process only to fail at the end.
The original exclusive access check at the end is still there so that we
do not get any surprises if two different process registers its device
with same parport and with exclusive access at the same time.
parport subsystem starts using the device-model. Drivers using the
device-model has to define devmodel as true and should register the
device with parport using parport_register_dev_model().
Tested-by: Jean Delvare <jdelvare@suse.de>
Tested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
IRQ_TYPE_SLOW is no longer used by the Atari platform interrupt code
since commit 734085651c9b80aa ("[PATCH] m68k: convert atari irq code")
in v2.6.18-rc1, so drop it.
Note that its value has been reused for a different purpose
(IRQ_TYPE_NONE) since commit 6a6de9ef5850d063 ("[PATCH] genirq: core")
in v2.6.18-rc1.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver update for 3.19-rc1
Lots of little things all over the place in different drivers, and a
new subsystem, "coresight" has been added. Full details are in the
shortlog"
* tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits)
parport: parport_pc, do not remove parent devices early
spmi: Remove shutdown/suspend/resume kernel-doc
carma-fpga-program: drop videobuf dependency
carma-fpga: drop videobuf dependency
carma-fpga-program.c: fix compile errors
i8k: Fix temperature bug handling in i8k_get_temp()
cxl: Name interrupts in /proc/interrupt
CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning
coresight-replicator: remove .owner field for driver
coresight: fixed comments in coresight.h
coresight: fix typo in comment in coresight-priv.h
coresight: bindings for coresight drivers
coresight: Adding ABI documentation
w1: support auto-load of w1_bq27000 module.
w1: avoid potential u16 overflow
cn: verify msg->len before making callback
mei: export fw status registers through sysfs
mei: read and print all six FW status registers
mei: txe: add cherrytrail device id
mei: kill cached host and me csr values
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
When the parport_pc module is removed from the system, all parport
devices are iterated in parport_pc_exit and removed by a call to
parport_pc_unregister_port. Note that some parport devices have its
'struct device' parent, known as port->dev. And when port->dev is a
platform device, it is destroyed in parport_pc_exit too.
Now, when parport_pc_unregister_port is called for a going port,
drv->detach(port) is called for every parport driver in the system.
ppdev can be one of them. ppdev's detach() tears down its per-port
sysfs directory, which established port->dev as a parent earlier.
But since parport_pc_exit kills port->dev parents before unregisters
ports proper, ppdev's sysfs directory has no living parent anymore.
This results in the following warning:
WARNING: CPU: 1 PID: 785 at fs/sysfs/group.c:219 sysfs_remove_group+0x9b/0xa0
sysfs group ffffffff81c69e20 not found for kobject 'parport1'
Modules linked in: parport_pc(E-) ppdev(E) [last unloaded: ppdev]
CPU: 1 PID: 785 Comm: rmmod Tainted: G W E 3.18.0-rc5-next-20141120+ #824
Call Trace:
[<ffffffff810aff76>] warn_slowpath_fmt+0x46/0x50
[<ffffffff8123d81b>] sysfs_remove_group+0x9b/0xa0
[<ffffffff814c27e7>] dpm_sysfs_remove+0x57/0x60
[<ffffffff814b6ac9>] device_del+0x49/0x240
[<ffffffff814b6ce2>] device_unregister+0x22/0x70
[<ffffffff814b6dac>] device_destroy+0x3c/0x50
[<ffffffffc012209a>] pp_detach+0x4a/0x60 [ppdev]
[<ffffffff814b32dd>] parport_remove_port+0x11d/0x150
[<ffffffffc0137328>] parport_pc_unregister_port+0x28/0xf0 [parport_pc]
[<ffffffffc0138c0e>] parport_pc_exit+0x76/0x468 [parport_pc]
[<ffffffff81128dbc>] SyS_delete_module+0x18c/0x230
It is also easily reproducible on qemu with two dummy ports '-parallel
/dev/null -parallel /dev/null'.
So switch the order of killing the two structures. But since port is
freed by parport_pc_unregister_port, we have to remember port->dev
in a local variable.
Perhaps nothing worse than the warning happens thanks to the device
refcounting. We *should* be on the safe side.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Martin Pluskal <mpluskal@suse.com>
WCH382 is a PCI-E card with 1 LPT and 2 DB9 COM ports detected as
Serial controller: Device 1c00:3250 (rev 10) (prog-if 05 [16850])
Signed-off-by: Sergej Pupykin <ml@sergej.pp.ru>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
false-positives
We definitely know that only x86 (32-bit) architecture is affected by the issue, so implement a stub instead of the actual check for other architectures.
We also know that motherboard LPT chipset is affected, so the port is either come from
parport_pc_init (when `io' module param is used) or
parport_pc_find_isa_ports (when default LPT ports are probbed: 0x378, 0x278, 0x3bc).
In both cases the port considered as 'legacy' and `dev' member of struct parport is NULL. See also comments for `struct parport' in parport.h
Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru>
Put the code to check present of the Intel bug from parport_EPP_supported
into new intel_bug_present function. The later also return ECR register
to the state it has before function call.
replace IS_ERR/PTR_ERR
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Linus Walleij <linus.walleij@linaro.org>
Do not split the PARPORT-related symbols with the new kconfig
symbol ARCH_MIGHT_HAVE_PC_PARPORT. The split was causing incorrect
display of these symbols -- they were not being displayed together
as they should be.
Fixes: d90c3eb31535 "Kconfig cleanup (PARPORT_PC dependencies)"
Cc: Mark Salter <msalter@redhat.com>
Cc: stable@vger.kernel.org # for 3.13, 3.14, 3.15
This typedef is unnecessary and should just be removed.
This Multi-IO card has one serial 16550-like and one parallel port connector.
Here's the lspci output, after this commit is applied:
03:07.0 Serial controller: Device 4348:5053 (rev 10) (prog-if 02 [16550])
Subsystem: Device 4348:5053
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 21
Region 0: I/O ports at cf00 [size=8]
Region 1: I/O ports at ce00 [size=8]
Kernel driver in use: parport_serial
Kernel modules: 8250_pci, parport_serial
This commit adds an entry with the device ID to the blacklist declared in
8250_pci to prevent the driver from taking ownership. Also, and as was done
for the 2S/1P variant, add a quirk to skip autodetection and set the correct
type to 16550A clone.
Proper entries are added to parport_serial, to support the device parallel
and serial ports.
Cc: Gianluca Anzolin <gianluca@sottospazio.it>
Cc: Alan Cox <alan@linux.intel.com>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
The interruptible_sleep_on function is can still lead to the
deadlock mentioned in the comment above the caller, and we want
to remove it soon, so replace it now with the race-free
wait_event_interruptible.
Cc: Andrew Morton <akpm@osdl.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the big tty/serial driver pull request for 3.14-rc1
There are a number of n_tty fixes and cleanups, and some serial driver
bugfixes, and we got rid of one obsolete driver, making this series
remove more lines than added, always a nice surprise.
All of these have been in linux-next with no reports of issues"
* tag 'tty-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (60 commits)
tty/serial: at91: disable uart timer at start of shutdown
serial: 8250: enable UART_BUG_NOMSR for Tegra
tty/serial: at91: reset rx_ring when port is shutdown
tty/serial: at91: fix race condition in atmel_serial_remove
tty/serial: at91: Handle shutdown more safely
serial: sirf: correct condition for fetching dma buffer into tty
serial: sirf: provide pm entries of uart_ops
serial: sirf: use PM macro initialize PM functions
serial: clps711x: Enable driver compilation with COMPILE_TEST
serial: clps711x: Add support for N_IRDA line discipline
tty: synclink: avoid sleep_on race
tty/amiserial: avoid interruptible_sleep_on
tty: delete non-required instances of include <linux/init.h>
tty: an overflow of multiplication in drivers/tty/cyclades.c
serial: Remove old SC26XX driver
serial: add support for 200 v3 series Titan card
serial: 8250: Fix initialisation of Quatech cards with the AMCC PCI chip
tty: Removing the deprecated function tty_vhangup_locked()
TTY/n_gsm: Removing the wrong tty_unlock/lock() in gsm_dlci_release()
tty/serial: at91: document clock properties
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver patches for 3.14-rc1.
Lots of little things, and a new "big" driver, genwqe. Full details
are in the shortlog"
* tag 'char-misc-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits)
mei: limit the number of consecutive resets
mei: revamp mei reset state machine
drivers/char: don't use module_init in non-modular ttyprintk.c
VMCI: fix error handling path when registering guest driver
extcon: gpio: Add power resume support
Documentation: HOWTO: Updates on subsystem trees, patchwork, -next (vs. -mm) in ko_KR
Documentation: HOWTO: update for 2.6.x -> 3.x versioning in ko_KR
Documentation: HOWTO: update stable address in ko_KR
Documentation: HOWTO: update LXR web link in ko_KR
char: nwbutton: open-code interruptible_sleep_on
mei: fix syntax in comments and debug output
mei: nfc: mei_nfc_free has to be called under lock
mei: use hbm idle state to prevent spurious resets
mei: do not run reset flow from the interrupt thread
misc: genwqe: fix return value check in genwqe_device_create()
GenWQE: Fix warnings for sparc
GenWQE: Fix compile problems for Alpha
Documentation/misc-devices/mei/mei-amt-version.c: remove unneeded call of mei_deinit()
GenWQE: Rework return code for flash-update ioctl
sgi-xp: open-code interruptible_sleep_on_timeout
In commit 85747f ("PATCH] parport: add NetMOS 9805 support") Max added
the PCI ID for NetMOS 9805 based on a Debian bug report from 2k4 which
was at the v2.4.26 time frame. The patch made into 2.6.14.
Shortly before that patch akpm merged commit 296d3c783b ("[PATCH] Support
NetMOS based PCI cards providing serial and parallel ports") which made
into v2.6.9-rc1.
Now we have two different entries for the same PCI id.
I have here the NetMos 9805 which claims to support SPP/EPP/ECP mode.
This patch takes Max's entry for titan_1284p1 (base != -1 specifies the
ioport for ECP mode) and replaces akpm's entry for netmos_9805 which
specified -1 (=none). Both share the same PCI-ID (my card has subsystem
0x1000 / 0x0020 so it should match PCI_ANY).
While here I also drop the entry for titan_1284p2 which is the same as
netmos_9815.
Cc: Maximilian Attems <maks@stro.at>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: stable <stable@vger.kernel.org>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Since commit 7106b4e3 ("8250: Oxford Semiconductor Devices") the debug
print of the device id does no longer match the real device if it is
located in the "enum" behind oxsemi_pcie_pport. The reason is that the
code assumes that each id contains one entry in the PCI table.
The fix is to lookup the currently used id from the id-> parameter.
Cc: Lee Howard <lee.howard@mainpine.com>
ZTWO_VADDR() converts from physical to virtual I/O addresses, so it should
return "void __iomem *" instead of "unsigned long".
This allows to drop several casts, but requires adding a few casts to
accomodate legacy driver frameworks that store "unsigned long" I/O
addresses.
Pull Kconfig cleanups from Mark Salter:
"Remove some unused config options from C6X and clean up PC_PARPORT
dependencies. The latter was discussed here:
https://lkml.org/lkml/2013/10/8/12"
* tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
c6x: remove unused COMMON_CLKDEV Kconfig parameter
x86: select ARCH_MIGHT_HAVE_PC_PARPORT
unicore32: select ARCH_MIGHT_HAVE_PC_PARPORT
sparc: select ARCH_MIGHT_HAVE_PC_PARPORT
sh: select ARCH_MIGHT_HAVE_PC_PARPORT
powerpc: select ARCH_MIGHT_HAVE_PC_PARPORT
parisc: select ARCH_MIGHT_HAVE_PC_PARPORT
mips: select ARCH_MIGHT_HAVE_PC_PARPORT
microblaze: select ARCH_MIGHT_HAVE_PC_PARPORT
m68k: select ARCH_MIGHT_HAVE_PC_PARPORT
ia64: select ARCH_MIGHT_HAVE_PC_PARPORT
arm: select ARCH_MIGHT_HAVE_PC_PARPORT
alpha: select ARCH_MIGHT_HAVE_PC_PARPORT
c6x: remove unused parameter in Kconfig
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
Pull DMA mask updates from Russell King:
"This series cleans up the handling of DMA masks in a lot of drivers,
fixing some bugs as we go.
Some of the more serious errors include:
- drivers which only set their coherent DMA mask if the attempt to
set the streaming mask fails.
- drivers which test for a NULL dma mask pointer, and then set the
dma mask pointer to a location in their module .data section -
which will cause problems if the module is reloaded.
To counter these, I have introduced two helper functions:
- dma_set_mask_and_coherent() takes care of setting both the
streaming and coherent masks at the same time, with the correct
error handling as specified by the API.
- dma_coerce_mask_and_coherent() which resolves the problem of
drivers forcefully setting DMA masks. This is more a marker for
future work to further clean these locations up - the code which
creates the devices really should be initialising these, but to fix
that in one go along with this change could potentially be very
disruptive.
The last thing this series does is prise away some of Linux's addition
to "DMA addresses are physical addresses and RAM always starts at
zero". We have ARM LPAE systems where all system memory is above 4GB
physical, hence having DMA masks interpreted by (eg) the block layers
as describing physical addresses in the range 0..DMAMASK fails on
these platforms. Santosh Shilimkar addresses this in this series; the
patches were copied to the appropriate people multiple times but were
ignored.
Fixing this also gets rid of some ARM weirdness in the setup of the
max*pfn variables, and brings ARM into line with every other Linux
architecture as far as those go"
* 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits)
ARM: 7805/1: mm: change max*pfn to include the physical offset of memory
ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function
ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit()
ARM: DMA-API: better handing of DMA masks for coherent allocations
ARM: 7857/1: dma: imx-sdma: setup dma mask
DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks
DMA-API: dcdbas: update DMA mask handing
DMA-API: dma: edma.c: no need to explicitly initialize DMA masks
DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks
DMA-API: crypto: remove last references to 'static struct device *dev'
DMA-API: crypto: fix ixp4xx crypto platform device support
DMA-API: others: use dma_set_coherent_mask()
DMA-API: staging: use dma_set_coherent_mask()
DMA-API: usb: use new dma_coerce_mask_and_coherent()
DMA-API: usb: use dma_set_coherent_mask()
DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent()
DMA-API: net: octeon: use dma_coerce_mask_and_coherent()
DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent()
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull h8300 platform removal from Guenter Roeck:
"The patch series has been in -next for more than one relase cycle. I
did get a number of Acks, and no objections.
H8/300 has been dead for several years, the kernel for it has not
compiled for ages, and recent versions of gcc for it are broken.
Remove support for it"
* tag 'h8300-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
CREDITS: Add Yoshinori Sato for h8300
fs/minix: Drop dependency on H8300
Drop remaining references to H8/300 architecture
Drop MAINTAINERS entry for H8/300
watchdog: Drop references to H8300 architecture
net/ethernet: Drop H8/300 Ethernet driver
net/ethernet: smsc9194: Drop conditional code for H8/300
ide: Drop H8/300 driver
Drop support for Renesas H8/300 (h8300) architecture
The code sequence:
dev->coherent_dma_mask = DMA_BIT_MASK(24);
dev->dma_mask = &dev->coherent_dma_mask;
bypasses the architectures check on the DMA mask. It can be replaced
with dma_coerce_mask_and_coherent(), avoiding the direct initialization
of this mask.
Remove messy dependencies from PARPORT_PC by having it depend on one
Kconfig symbol (ARCH_MIGHT_HAVE_PC_PARPORT) and having architectures
which need it, select ARCH_MIGHT_HAVE_PC_PARPORT in arch/*/Kconfig.
New architectures are unlikely to need PARPORT_PC, so this avoids
having an ever growing list of architectures to exclude. Those
architectures which do select ARCH_MIGHT_HAVE_PC_PARPORT in this
patch are the ones which have an asm/parport.h (or use the generic
version).
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: Ingo Molnar <mingo@redhat.com>
CC: Richard Henderson <rth@twiddle.net>
CC: linux-alpha@vger.kernel.org
CC: Vineet Gupta <vgupta@synopsys.com>
CC: Russell King <linux@arm.linux.org.uk>
CC: linux-arm-kernel@lists.infradead.org
CC: Tony Luck <tony.luck@intel.com>
CC: Fenghua Yu <fenghua.yu@intel.com>
CC: linux-ia64@vger.kernel.org
CC: Geert Uytterhoeven <geert@linux-m68k.org>
CC: linux-m68k@lists.linux-m68k.org
CC: Michal Simek <monstr@monstr.eu>
CC: microblaze-uclinux@itee.uq.edu.au
CC: Ralf Baechle <ralf@linux-mips.org>
CC: linux-mips@linux-mips.org
CC: "James E.J. Bottomley" <jejb@parisc-linux.org>
CC: Helge Deller <deller@gmx.de>
CC: linux-parisc@vger.kernel.org
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Paul Mackerras <paulus@samba.org>
CC: linuxppc-dev@lists.ozlabs.org
CC: Paul Mundt <lethal@linux-sh.org>
CC: linux-sh@vger.kernel.org
CC: "David S. Miller" <davem@davemloft.net>
CC: sparclinux@vger.kernel.org
CC: Guan Xuetao <gxt@mprc.pku.edu.cn>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: x86@kernel.org
h8300 does not support PARPORT_PC.
The related error (with allmodconfig for h8300):
CC [M] drivers/parport/parport_pc.o
drivers/parport/parport_pc.c:67:25: fatal error: asm/parport.h: No such file or directory
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Replaced calls to kmalloc and memset with kzalloc.
Patch found using coccinelle.
Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com>
