path: root/drivers/parport
2014-02-06parport: parport_pc: remove double PCI ID for NetMosSebastian Andrzej Siewior
commit d6a484520c5572a4170fa915109ccfc0c38f5008 upstream. In commit 85747f ("PATCH] parport: add NetMOS 9805 support") Max added the PCI ID for NetMOS 9805 based on a Debian bug report from 2k4 which was at the v2.4.26 time frame. The patch made into 2.6.14. Shortly before that patch akpm merged commit 296d3c783b ("[PATCH] Support NetMOS based PCI cards providing serial and parallel ports") which made into v2.6.9-rc1. Now we have two different entries for the same PCI id. I have here the NetMos 9805 which claims to support SPP/EPP/ECP mode. This patch takes Max's entry for titan_1284p1 (base != -1 specifies the ioport for ECP mode) and replaces akpm's entry for netmos_9805 which specified -1 (=none). Both share the same PCI-ID (my card has subsystem 0x1000 / 0x0020 so it should match PCI_ANY). While here I also drop the entry for titan_1284p2 which is the same as netmos_9815. Cc: Maximilian Attems <maks@stro.at> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-01parisc: parport0: fix this legacy no-device port driver!Helge Deller
Fix the above kernel error from parport_announce_port() on 32bit GSC machines (e.g. B160L). The parport driver requires now a pointer to the device struct. Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parport_pc: disable PARPORT_PC_SUPERIO on parisc architectureHelge Deller
If enabled, CONFIG_PARPORT_PC_SUPERIO scans on PC-like hardware for various super-io chips by accessing i/o ports in a range which will crash any parisc hardware at once. In addition, parisc has it's own incompatible superio chip (CONFIG_SUPERIO), so if we disable PARPORT_PC_SUPERIO completely for parisc we can avoid that people by accident enable the parport_pc superio option too. Signed-off-by: Helge Deller <deller@gmx.de>
2013-03-25parport: use kmemdup instead of kmalloc + memcpySilviu-Mihai Popescu
This replaces calls to kmalloc followed by memcpy with a single call to kmemdup. This was found via make coccicheck. Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25parport: amiga: use module_platform_driver_probe()Fabio Porcedda
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com> Cc: Matt Porter <mporter@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15drivers/parport: use module_pcmcia_driver() in pcmcia driversH Hartley Sweeten
Use the new module_pcmcia_driver() macro to remove the boilerplate module init/exit code in the pcmcia drivers. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "The most prominent change in this patch set is the software dirty bit patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and the page_test_and_clear_dirty primitive which makes the common memory management code a bit less obscure. Heiko fixed most of the PCI related fallout, more often than not missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270 patches which adds an export to tty_io to be able to resize a tty. The rest is the usual bunch of cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/module: Add missing R_390_NONE relocation type drivers/gpio: add missing GENERIC_HARDIRQ dependency drivers/input: add couple of missing GENERIC_HARDIRQS dependencies s390/cleanup: rename SPP to LPP s390/mm: implement software dirty bits s390/mm: Fix crst upgrade of mmap with MAP_FIXED s390/linker skript: discard exit.data at runtime drivers/media: add missing GENERIC_HARDIRQS dependency s390/bpf,jit: add vlan tag support drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency iucv: fix kernel panic at reboot s390/Kconfig: sort list of arch selected config options phylib: remove !S390 dependeny from Kconfig uio: remove !S390 dependency from Kconfig dasd: fix sysfs cleanup in dasd_generic_remove s390/pci: fix hotplug module init s390/pci: cleanup clp page allocation s390/pci: cleanup clp inline assembly s390/perf: cpum_cf: fallback to software sampling events s390/mm: provide PAGE_SHARED define ...
2013-02-14parport: disable PC-style parallel port support for s390Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-01-30serial/8250: Add suport for later SUNIX (TIMEDIA) boards.Stephen Chivers
Add support for later SUNIX (TIMEDIA) Universal PCI Single and Multi-Port Communications Boards. These boards have PCI Vendor ID 1fd4 with device ID 1999 but otherwise appear to be the same as the TIMEDIA boards already supported by 8250_pci and parport_serial. Tested with: a. the two port serial board part number SER5037A, b. the two port serial and one port parallel board part number MIO5079A. Signed-off-by: Stephen Chivers <schivers@csc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: parport: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Matt Porter <mporter@ti.com> Cc: Kay Sievers <kay@vrfy.org> Cc: Gianluca Anzolin <gianluca@sottospazio.it> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15drivers/parport: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-09Merge tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa patchset from Chris Zankel: "The Xtensa tree has been broken for some time now, and this patchset brings it back to life. It has been part of the linux-next tree for some time. Most changes are inside the xtensa subdirectory; the other changes mostly add another rule to already existing #ifdefs to exclude Xtensa, where required. The only 'common' change is to add two more sections ('.xt.prop' and '.xt.lit') to the white list in modpost." * tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linux: (27 commits) xtensa: Setup CROSS_COMPILE at the top xtensa: drop CONFIG_EMBEDDED_RAMDISK xtensa: fix TIOCGSERIAL and TIOCSSERIAL definitions xtensa: provide dummy gcc intrinsics xtensa: add missing symbol exports parport: disable for xtensa arch xtensa: rename MISC SR definition to avoid name clashes hisax: disable build for big-endian xtensa xtensa: fix CODA build xtensa: fix parallel make xtensa: ISS: drop unused io.c xtensa: ISS: exit simulator in case of halt or poweroff xtensa: ISS: change keyboard polling rate xtensa: ISS: add platform_pcibios_init xtensa: ISS: add dummy serial.h for ISS platform xtensa: change default platform clock frequency to 10MHz xtensa: add ARCH_WANT_OPTIONAL_GPIOLIB to xtensa config xtensa: set NO_IOPORT to 'n' by default xtensa: adopt generic io routines xtensa: fix ioremap ...
2012-10-03parport: disable for xtensa archMax Filippov
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-09-05parport: fix possible memory leak in parport_gsc_probe_port()Wei Yongjun
ops has been allocated in this function and should be freed before leaving from the error handling cases. spatch with a semantic match is used to found this problem. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05parport_serial: Add support for the WCH353 2S/1P multi-IO cardGuainluca Anzolin
To allow parport_serial to handle the card the same PCI ids are blacklisted in 8250_pci.c using the existing software blacklist mechanism. The blacklist array is also renamed because it now covers this new use case. Since the two serial ports are auto-detected as XScale instead of 16550A clones, we also add a quirk to 8250_pci.c to skip autodetection and set the correct port type. Signed-off-by: Gianluca Anzolin <gianluca@sottospazio.it> [Fold in fixes for the uart_8250 change] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-08parport: use KERN_CONT in printk() continuation linesKay Sievers
On Tue, May 8, 2012 at 10:48 AM, Sasha Levin <levinsasha928@gmail.com> wrote: > Before: > [ 10.110626] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] > > After: > parport0: PC-style at 0x378 > , irq 7 > [ > PCSPP > ,TRISTATE > ] Reported-By: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Kay Sievers <kay@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20parport: remove unused dead code from lowlevel driversMatt Porter
This unused code has been untouched for over 7 years and must go. Signed-off-by: Matt Porter <mporter@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-12drivers/parport/parport_pc.c: fix warningsAndrew Morton
drivers/parport/parport_pc.c: In function '__check_irq': drivers/parport/parport_pc.c:3415: warning: return from incompatible pointer type drivers/parport/parport_pc.c: In function '__check_dma': drivers/parport/parport_pc.c:3417: warning: return from incompatible pointer type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-09Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (65 commits) tty: serial: imx: move del_timer_sync() to avoid potential deadlock imx: add polled io uart methods imx: Add save/restore functions for UART control regs serial/imx: let probing fail for the dt case without a valid alias serial/imx: propagate error from of_alias_get_id instead of using -ENODEV tty: serial: imx: Allow UART to be a source for wakeup serial: driver for m32 arch should not have DEC alpha errata serial/documentation: fix documented name of DCD cpp symbol atmel_serial: fix spinlock lockup in RS485 code tty: Fix memory leak in virtual console when enable unicode translation serial: use DIV_ROUND_CLOSEST instead of open coding it serial: add support for 400 and 800 v3 series Titan cards serial: bfin-uart: Remove ASYNC_CTS_FLOW flag for hardware automatic CTS. serial: bfin-uart: Enable hardware automatic CTS only when CTS pin is available. serial: make FSL errata depend on 8250_CONSOLE, not just 8250 serial: add irq handler for Freescale 16550 errata. serial: manually inline serial8250_handle_port serial: make 8250 timeout use the specified IRQ handler serial: export the key functions for an 8250 IRQ handler serial: clean up parameter passing for 8250 Rx IRQ handling ...
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-30parport: convert drivers/parport/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/parport/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben@simtec.co.uk> Cc: Derrick J. Brashear <shadow@dementia.org> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18parport_pc: release IO region properly if unsupported ITE887x card is foundJiri Kosina
sio_ite_8872_probe() bails out if it detects no-parallel (1S, 2S) or unknown card. It doesn't call release_region() on the previously allocated resource though. This causes (a) leak of the resource (b) kernel oops when parport module is removed and /proc/ioports is read. This is because the string that has been associated to the IO port region is a static char array inside the already removed module. Let's call release_region() properly before baling out. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Niels de Vos <ndevos@redhat.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Joe Krahn <krahn@niehs.nih.gov> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-25Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits) amba pl011: workaround for uart registers lockup n_gsm: fix the wrong FCS handling pch_uart: add missing comment about OKI ML7223 pch_uart: Add MSI support tty: fix "IRQ45: nobody cared" PTI feature to allow user to name and mark masterchannel request. 0 for o PTI Makefile bug. tty: serial: samsung.c remove legacy PM code. SERIAL: SC26xx: Fix link error. serial: mrst_max3110: initialize waitqueue earlier mrst_max3110: Change max missing message priority. tty: s5pv210: Add delay loop on fifo reset function for UART tty/serial: Fix XSCALE serial ports, e.g. ce4100 serial: bfin_5xx: fix off-by-one with resource size drivers/tty: use printk_ratelimited() instead of printk_ratelimit() tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs tty: n_gsm: Add raw-ip support tty: n_gsm: expose gsmtty device nodes at ldisc open time pch_phub: Fix register miss-setting issue serial: 8250, increase PASS_LIMIT ...
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-07parport/serial: add support for Timedia/SUNIX cards to parport_serialFrédéric Brière
Timedia/SUNIX PCI cards with both serial and parallel ports are currently supported by 8250_pci and parport_pc individually. Moving that support into parport_serial allows using both types of ports at the same time. This was successfully tested with a SUNIX 4079T. Signed-off-by: Frédéric Brière <fbriere@fbriere.net> Acked-by: Alan Cox <alan@linux.intel.com> Cc: linux-serial@vger.kernel.org Cc: linux-parport@lists.infradead.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07Basic support for Moschip 9900 family I/O chipsNicos Gollan
Add I/O based support for serial and parallel ports of the following chips: Vendor: Moschip (0x9710) Parts (device IDs) * 9900 (0x9900) * 9904 (0x9904 * 9901 (0x9912, also sold as 9912) * 9922 (0x9922) On all chips but the 9900, a single port is provided per PCI subdevice (subvendor-ID 0xA000, subdevice-IDs 0x1000 for serial, 0x2000 for parallel with proper class codes). In cascading configurations, the 9900 provides two devices per subdevice, with subvendor-ID 0xA000 and subdevice-IDs 0x30ps where p is the number of parallel ports and s the number of serial ports. Basic testing was only done on the serial part of a 9912 to the point where it can be used for a serial kernel console, and advanced features are completely untested. It is possible to reduce functionality of the chips by adding a configuration EEPROM, and the datasheet [1] is inconsistent w.r.t subdevices in the 4s+2s1p and 2s1p+4s configurations. The subdevice-ID 0x3012 should likely read 0x3011 with a serial port in function 3, which would be consistent with the BAR layouts. For now, the drivers ignore subdevices with ID 0x1000 and no class code. The parallel ports are integrated in parport_serial even for purely parallel parts to reduce the footprint of the patch. [1] http://www.moschip.com/data/products/MCS9900/MCS9900_Datasheet.pdf Signed-off-by: Nicos Gollan <gtdev@spearhead.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-25parport: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-06parport: Use request_muxed_region for IT87 probe and lockAlan Cox
This is needed as part of making the various IT87 drivers actually co-exist politely with each other, and with other superio devices that may be muxed on 0x2E/0x2F. It can be applied before or after the other patches by Nat Gurumoorthy without problem. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-04-19parport_pc.c: correctly release the requested region for the IT887xNiels de Vos
Replace release_resource() by release_region() and also fix the inconsistency in the size of the requested/released region. The size of the resource should be 32, not 0x8 like it was corrected in commit e7c310c36e5fdf1b83a459e5db167bfbd86137db already. CC: linux-serial@vger.kernel.org Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Niels de Vos <ndevos@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-28dt/sparc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/sparc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-26parport: make lockdep happy with waitlist_lockAlexander Gordeev
parport_unregister_device() should never be used when interrupts are enabled in hardware and irq handler is registered so there is no need to disable interrupts when using waitlist_lock. But there is no way to explain this subtle semantics to lockdep analyzer. So disable interrupts here too to simplify things. The price is negligible. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (22 commits) pcmcia: synclink_cs: fix information leak to userland pcmcia: don't call flush_scheduled_work() spuriously serial_cs: drop spurious flush_scheduled_work() call pcmcia/yenta: guide users in case of problems with O2-bridges pcmcia: fix unused function compile warning pcmcia: vrc4173_cardu: Fix error path for pci_release_regions and pci_disable_device pcmcia: add a few debug statements pcmcia: remove obsolete and wrong comments pcmcia: avoid messages on module (un)loading pcmcia: move driver name to struct pcmcia_driver pcmcia: remove the "Finally, report what we've done" message pcmcia: use autoconfiguration feature for ioports and iomem pcmcia: introduce autoconfiguration feature pcmcia: Documentation update pcmcia: convert pcmcia_request_configuration to pcmcia_enable_device pcmcia: move config_{base,index,regs} to struct pcmcia_device pcmcia: simplify IntType pcmcia: simplify Status, ExtStatus register access pcmcia: remove Pin, Copy configuration register access pcmcia: move Vpp setup to struct pcmcia_device ...
2010-10-12parport: Semaphore cleanupThomas Gleixner
Get rid of init_MUTEX[_LOCKED]() and use sema_init() instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Christoph Hellwig <hch@infradead.org> LKML-Reference: <20100907125055.743613774@linutronix.de>
2010-09-29pcmcia: remove obsolete and wrong commentsDominik Brodowski
What's worse than no comment? A wrong comment. Several PCMCIA device drivers contained the same comments, which were based on how the PCMCIA subsystem worked in the old days of 2.4., and which were originally part of a "dummy_cs" driver. These comments no longer matched at all what is happening now, and therefore should be removed. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move config_{base,index,regs} to struct pcmcia_deviceDominik Brodowski
Several drivers prefer to explicitly set config_{base,index,regs}, formerly known as ConfigBase, ConfigIndex and Present. Instead of passing these values inside config_req_t, store it in struct pcmcia_device. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-24parport_pc: show the detection of a 2 serial port ITE8874 chipNiels de Vos
The printk message for the 2 serial port version is obscured with a debug macro, unlike all other versions of the card. It should be changed to make the output equal for all detected models. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=578616#c1 CC: Joe Krahn <krahn@niehs.nih.gov> Signed-off-by: Niels de Vos <ndevos@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
