path: root/drivers/parport
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pcmcia: move event handlerDominik Brodowski
Move the "event handler" to struct pcmcia_driver -- the unified event handler will disappear really soon, but switching it to struct pcmcia_driver in the meantime allows for better "step-by-step" patches. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-01[PATCH] PCI: clean up dynamic pci id logicGreg Kroah-Hartman
The dynamic pci id logic has been bothering me for a while, and now that I started to look into how to move some of this to the driver core, I thought it was time to clean it all up. It ends up making the code smaller, and easier to follow, and fixes a few bugs at the same time (dynamic ids were not being matched everywhere, and so could be missed on some call paths for new devices, semaphore not needed to be grabbed when adding a new id and calling the driver core, etc.) I also renamed the function pci_match_device() to pci_match_id() as that's what it really does. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] pcmcia: id_table for parport_cs.cDominik Brodowski
Add pcmcia_device_id table. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] parport: NetMos nm9855 fixMartin Schitter
kernel 2.6.12-rc2 adopted some code by Bjorn Helgaas supporting NetMos combo controller cards. this implementation doesn't work for nm9855 based cards! there are two reasons: a) the module 'parport_pc' doesn't want to give the resonsibility for the netmos_9855 to 'parport_serial' and can not handle the serial lines -- trivial to fix... http://lists.infradead.org/pipermail/linux-parport/2005-February/000250.html http://lkml.org/lkml/2005/3/24/199 b) the support for the nm9855 in 'parport_serial' still doesn't work because of wrong assumptions about the relevant BARs port address layout for this chip: 0000:00:09.0 Communication controller: NetMos Technology PCI 9855 Multi-I/O Controller (rev 01) (= 9710:9855) Subsystem: LSI Logic / Symbios Logic 1P4S (= 1000:0014) Flags: medium devsel, IRQ 177 I/O ports at a800 [size=8] (= parport) I/O ports at a400 [size=8] I/O ports at a000 [size=8] (= serial) I/O ports at 9800 [size=8] (= serial) I/O ports at 9400 [size=8] (= serial) I/O ports at 9000 [size=16] (= serial) the following patch will fix the problem. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] ISA_DMA Kconfig fixes - part 2 (parport_pc)Al Viro
Part of parport_pc that uses ISA DMA helpers made conditional on CONFIG_ISA_DMA_API. As the result, driver got usable for boxen that do not have ISA DMA stuff and have normal PCI parport card stuck into them - these never use DMA anyway. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
