path: root/drivers/pci/access.c
2011-05-10PCI: handle positive error codesGreg Thelen
Callers expect pci_user_{read,write}_config_*() to indicate errors by returning negative values. Prior to this change, the indicated routines could return positive error codes (e.g. PCIBIOS_BAD_REGISTER_NUMBER) which callers would mistakenly interpret as success. This change converts any non-zero return from the mentioned routines into unambiguous negative value return codes. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: check pci_vpd_pci22_wait() returnGreg Thelen
pci_vpd_pci22_write() calls pci_vpd_pci22_wait() after writing PCI_VPD_DATA and PCI_VPD_ADDR to wait for the VPD operation to complete. The result pci_vpd_pci22_wait() was not checked for error. This change checks for error. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-18PCI: output FW warning in pci_read/write_vpdPrarit Bhargava
pci_read/write_vpd() can fail due to a timeout. Usually the command times out because of firmware issues (incorrect vpd length, etc.) on the PCI card. Currently, the timeout occurs silently. Output a message to the user indicating that they should check with their vendor for new firmware. Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-11PCI: Convert pci_lock to raw_spinlockThomas Gleixner
pci_lock must be a real spinlock in preempt-rt. Convert it to raw_spinlock. No change for !RT kernels. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16PCI: Add pci_bus_set_opsHuang Ying
pci_bus_set_ops changes pci_ops associated with a pci_bus. This can be used by debug tools such as PCIE AER error injection to fake some PCI configuration registers. Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-22docbooks: add/fix PCI kernel-docRandy Dunlap
Add drivers/pci/*.c source files to DocBook/kernel-api.tmpl and update those pci/*.c source files that need kernel-doc fixes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-07PCI: Fix oops in pci_vpd_truncateAnton Vorontsov
pci_vpd_truncate() should check for dev->vpd->attr, otherwise this might happen: sky2 driver version 1.22 Unable to handle kernel paging request for data at address 0x0000000c Faulting instruction address: 0xc01836fc Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c01836fc] pci_vpd_truncate+0x38/0x40 LR [c029be18] sky2_probe+0x14c/0x518 Call Trace: [ef82bde0] [c029bda4] sky2_probe+0xd8/0x518 (unreliable) [ef82be20] [c018a11c] local_pci_probe+0x24/0x34 [ef82be30] [c018a14c] pci_call_probe+0x20/0x30 [ef82be50] [c018a330] __pci_device_probe+0x64/0x78 [ef82be60] [c018a44c] pci_device_probe+0x30/0x58 [ef82be80] [c01aa270] really_probe+0x78/0x1a0 [ef82bea0] [c01aa460] __driver_attach+0xa4/0xa8 [ef82bec0] [c01a96ac] bus_for_each_dev+0x60/0x9c [ef82bef0] [c01aa0b4] driver_attach+0x24/0x34 [ef82bf00] [c01a9e08] bus_add_driver+0x12c/0x1cc [ef82bf20] [c01aa87c] driver_register+0x6c/0x110 [ef82bf30] [c018a770] __pci_register_driver+0x4c/0x9c [ef82bf50] [c03782c8] sky2_init_module+0x30/0x40 [ef82bf60] [c0001dbc] do_one_initcall+0x34/0x1a0 [ef82bfd0] [c0362240] do_initcalls+0x38/0x58 This happens with CONFIG_SKY2=y, and "ip=on" kernel command line, so pci_vpd_truncate() is called before late_initcall(pci_sysfs_init), therefore ->attr isn't yet initialized. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07PCI: add interface to set visible size of VPDStephen Hemminger
The VPD on all devices may not be 32K. Unfortunately, there is no generic way to find the size, so this adds a simple API hook to reset it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: revise VPD access interfaceStephen Hemminger
Change PCI VPD API which was only used by sysfs to something usable in drivers. * move iteration over multiple words to the low level * use conventional types for arguments * add exportable wrapper Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: handle long delays in VPD accessStephen Hemminger
Accessing the VPD area can take a long time. The existing VPD access code fails consistently on my hardware. There are comments in the SysKonnect vendor driver that it can take up to 13ms per word. Change the access routines to: * use a mutex rather than spinning with IRQ's disabled and lock held * have a much longer timeout * call cond_resched while spinning Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-02PCI: Limit VPD read/write lengths for Broadcom 5706, 5708, 5709 rev.Benjamin Li
For Broadcom 5706, 5708, 5709 rev. A nics, any read beyond the VPD end tag will hang the device. This problem was initially observed when a vpd entry was created in sysfs ('/sys/bus/pci/devices/<id>/vpd'). A read to this sysfs entry will dump 32k of data. Reading a full 32k will cause an access beyond the VPD end tag causing the device to hang. Once the device is hung, the bnx2 driver will not be able to reset the device. We believe that it is legal to read beyond the end tag and therefore the solution is to limit the read/write length. A majority of this patch is from Matthew Wilcox who gave code for reworking the PCI vpd size information. A PCI quirk added for the Broadcom NIC's to limit the read/write's. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: Expose PCI VPD through sysfsBen Hutchings
Vital Product Data (VPD) may be exposed by PCI devices in several ways. It is generally unsafe to read this information through the existing interfaces to user-land because of stateful interfaces. This adds: - abstract operations for VPD access (struct pci_vpd_ops) - VPD state information in struct pci_dev (struct pci_vpd) - an implementation of the VPD access method specified in PCI 2.2 (in access.c) - a 'vpd' binary file in sysfs directories for PCI devices with VPD operations defined It adds a probe for PCI 2.2 VPD in pci_scan_device() and release of VPD state in pci_release_dev(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-04[PATCH] severing module.h->sched.hAl Viro
2006-12-01PCI: Block on access to temporarily unavailable pci deviceMatthew Wilcox
The existing implementation of pci_block_user_cfg_access() was recently criticised for providing out of date information and for returning errors on write, which applications won't be expecting. This reimplementation uses a global wait queue and a bit per device. I've open-coded prepare_to_wait() / finish_wait() as I could optimise it significantly by knowing that the pci_lock protected us at all points. It looked a bit funny to be doing a spin_unlock_irqsave(); schedule(), so I used spin_lock_irq() for the _user versions of pci_read_config and pci_write_config. Not carrying a flags pointer around made the code much less nasty. Attempts to block an already blocked device hit a BUG() and attempts to unblock an already unblocked device hit a WARN(). If we need to block access to a device from userspace, it's because it's unsafe for even another bit of the kernel to access the device. An attempt to block a device for a second time means we're about to access the device to perform some other operation, which could provoke undefined behaviour from the device. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Adam Belay <abelay@novell.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: drivers/pci/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - access.c should #include "pci.h" for getting the prototypes of it's global functions - hotplug/shpchp_pci.c: make the needlessly global function program_fw_provided_values() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] PCI: Block config access during BISTBrian King
Some PCI adapters (eg. ipr scsi adapters) have an exposure today in that they issue BIST to the adapter to reset the card. If, during the time it takes to complete BIST, userspace attempts to access PCI config space, the host bus bridge will master abort the access since the ipr adapter does not respond on the PCI bus for a brief period of time when running BIST. On PPC64 hardware, this master abort results in the host PCI bridge isolating that PCI device from the rest of the system, making the device unusable until Linux is rebooted. This patch is an attempt to close that exposure by introducing some blocking code in the PCI code. When blocked, writes will be humored and reads will return the cached value. Ben Herrenschmidt has also mentioned that he plans to use this in PPC power management. Signed-off-by: Brian King <brking@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/pci/access.c | 89 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pci/pci-sysfs.c | 20 +++++----- drivers/pci/pci.h | 7 +++ drivers/pci/proc.c | 28 +++++++-------- drivers/pci/syscall.c | 14 +++---- include/linux/pci.h | 7 +++ 6 files changed, 134 insertions(+), 31 deletions(-)
