path: root/drivers/pci/hotplug/Makefile
2008-02-01PCI: hotplug: Link fakephp lastAlex Chiang
Currently, fakephp will claim all devices; we really only want it to claim those not in slots. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-28ACPIPHP: use ACPI dock driverKristen Accardi
Modify the acpiphp driver to use the ACPI dock driver for dock notifications. Only load the acpiphp driver if we find we have pci dock devices. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-23[PATCH] PCI Hotplug: add common acpi functions to coreKristen Accardi
shpchprm_acpi.c and pciehprm_acpi.c are nearly identical. In addition, there are functions in both these files that are also in acpiphp_glue.c. This patch will remove duplicate functions from shpchp, pciehp, and acpiphp and move this functionality to pci_hotplug, as it is not hardware specific. Get rid of shpchprm* and pciehprm* files since they are no longer needed. shpchprm_nonacpi.c and pciehprm_nonacpi.c are identical, as well as shpchprm_legacy.c and can be replaced with a macro. This patch also changes acpiphp to use the common hpp code. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] acpiphp: add dock event handlingKristen Accardi
These patches add generic dock event handling to acpiphp. If there are pci devices that need to be inserted/removed after the dock event, the event notification will be handed down to the normal pci hotplug event handler in acpiphp so that new bridges/devices can be enumerated. Because some dock stations do not have pci bridges or pci devices that need to be inserted after a dock, acpiphp will remain loaded to handle dock events even if no hotpluggable pci slots are discovered. You probably need to have the pci=assign-busses kernel parameter enabled to use these patches, and you may not allow ibm_acpi to handle docking notifications and use this patch. This patch incorporates feedback provided by many. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Move VIO registrationJohn Rose
Currently, rpaphp registers Virtual I/O slots as hotplug slots. The only purpose of this registration is to ensure that the VIO subsystem is notified of new VIO buses during DLPAR adds. Similarly, rpaphp notifies the VIO subsystem when a VIO bus is DLPAR-removed. The rpaphp module has special case code to fake results for attributes like power, adapter status, etc. The VIO register/unregister functions could just as easily be made from the DLPAR module. This patch moves the VIO registration calls to the DLPAR module, and removes the VIO fluff from rpaphp altogether. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-24[ACPI] delete CONFIG_ACPI_BUSLen Brown
it is a synonym for CONFIG_ACPI Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-06[IA64] hotplug/ia64: SN Hotplug Driver - SN Hotplug Driver codePrarit Bhargava
This patch is the SGI hotplug driver and additional changes required for the driver. These modifications include changes to the SN io_init.c code for memory management, the inclusion of new SAL calls to enable and disable PCI slots, and a hotplug-style driver. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-27[PATCH] acpi hotplug: convert acpiphp to use generic resource codeRajesh Shah
This patch converts acpiphp to use the generic PCI resource assignment code. It's quite large, but most of it is deleting the acpiphp_pci and acpiphp_res files. It's tested on an hp Integrity rx8620 (which won't work without this patch). Testers with other hardware welcomed. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
