path: root/drivers/pci/hotplug/pciehp_hpc.c
2007-07-11PCI: hotplug: pciehp: Fix possible race condition in writing slotKenji Kaneshige
The slot control register is modified as follows: (1) Read the register value (2) Change the value (3) Write the value to the register Those must be done atomically, otherwise writing to control register would cause an unexpected result. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02pciehp: Event handling reworkKenji Kaneshige
The event handler of PCIEHP driver is unnecessarily very complex. In addition, current event handler can only a fixed number of events at the same time, and some of events would be lost if several number of events happened at the same time. This patch simplify the event handler using 'work queue', and it also fix the above-mentioned issue. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07PCIEHP: Add Electro Mechanical Interlock (EMI) support to the PCIE hotplug ↵Kristen Carlson Accardi
driver. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: fix wait command completionKenji Kaneshige
This patch fixes this problem that pciehp driver will sleep unnecessarily long when waiting for command completion. With this patch, modprobe pciehp driver becomes very faster as follows for instance. o Without this patch # time /sbin/modprobe pciehp real 0m4.976s user 0m0.000s sys 0m0.004s o With this patch # time /sbin/modprobe pciehp real 0m0.640s user 0m0.000s sys 0m0.004s Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: cleanup wait command completionKenji Kaneshige
This patch cleans up the code to wait for command completion. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: remove unused pcie_cap_baseKenji Kaneshige
This patch removes unused pcie_cap_base variable. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: cleanup register accessKenji Kaneshige
This patch cleans up register access functions. This has no functional change. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: remove unnecessary php_ctlrKenji Kaneshige
The struct php_ctlr seems to be only for complicating codes. This patch removes struct php_ctlr and related codes. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01pciehp: remove unnecessary pci_disable_msiKenji Kaneshige
This patch fixes the problem that "irq XX: nobody cared" kernel oops is reported when pciehp is once rmmoded and insmoded again. The cause of this problem is pciehp driver calls pci_disable_msi() at controller release time, even though it must be done by PCI Express Port Bus driver. This patch removes unnecessary pci_disable_msi() call from pciehp driver. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18pciehp - add missing lockingKenji Kaneshige
This patch fixes the problem that system will panic if multiple power on/off operations are issued to the same slot in parallel. This problem can be easily reproduced by commands below. # while true; do echo 1 > power; echo 0 > power; done & # while true; do echo 1 > power; echo 0 > power; done & The cause is lack of locking for enable/disable operations. This patch fixes this problem. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-11pciehp: make pciehp build for powerpcKristen Carlson Accardi
Make pciehp build on powerpc Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-02[PATCH] irq-flags: pci: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in pci core and hotplug ↵Greg Kroah-Hartman
drivers This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-19[PATCH] PCI Hotplug: Fix recovery path from errors during pcie_init()Jan Beulich
Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-19[PATCH] pciehp: dont call pci_enable_devKristen Accardi
Don't call pci_enable_device from pciehp because the pcie port service driver already does this. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-19[PATCH] PCI Hotplug: don't use acpi_os_freeKristen Accardi
acpi_os_free should not be used by drivers outside of acpi/*/*.c. Replace with kfree(). Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] acpiphp: fix acpi_path_nameMUNEDA Takahiro
I encountered the problem that the insmod of the acpiphp fails because of the mis-freeing of the memory. I tested this patch on my tiger4 box. Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI Hotplug: add common acpi functions to coreKristen Accardi
shpchprm_acpi.c and pciehprm_acpi.c are nearly identical. In addition, there are functions in both these files that are also in acpiphp_glue.c. This patch will remove duplicate functions from shpchp, pciehp, and acpiphp and move this functionality to pci_hotplug, as it is not hardware specific. Get rid of shpchprm* and pciehprm* files since they are no longer needed. shpchprm_nonacpi.c and pciehprm_nonacpi.c are identical, as well as shpchprm_legacy.c and can be replaced with a macro. This patch also changes acpiphp to use the common hpp code. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI hotplug: convert semaphores to mutexIngo Molnar
semaphore to mutex conversion. the conversion was generated via scripts, and the result was validated automatically via a script as well. build tested with allyesconfig. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] pciehp: handle sticky power-fault statusThomas Schaefer
This patch disables power fault, MRL sensor and presence detection interrupts when a PCIe slot is powered-off and enables those interrupts when it is powered-on again. This is necessary to prevent the associated events from causing an endless cycle of interrupts due to the power-fault bit, which stays set till power is restored to the slot. Signed-off-by: Thomas Schaefer <thomas.schaefer@kontron.com> Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-08[PATCH] fix more missing includesTim Schmielau
Include fixes for 2.6.14-git11. Should allow to remove sched.h from module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more to come since I haven't yet checked the other archs. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] PCI Express Hotplug: clear sticky power-fault bitRajesh Shah
Per the PCI Express spec, the power-fault-detected bit in the slot status register can be set anytime hardware detects a power fault, regardless of whether the slot has a device populated in it or not. This bit is sticky and must be explicitly cleared. This patch is needed to allow hot-add after such a power fault has been detected. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] pciehp_hpc build fixAndrew Morton
drivers/pci/hotplug/pciehp_hpc.c:221: parse error before "pcie_isr" drivers/pci/hotplug/pciehp_hpc.c:221: warning: type defaults to `int' in declaration of `pcie_isr' drivers/pci/hotplug/pciehp_hpc.c:221: warning: data definition has no type or storage class drivers/pci/hotplug/pciehp_hpc.c: In function `hpc_release_ctlr': drivers/pci/hotplug/pciehp_hpc.c:715: implicit declaration of function `free_irq' drivers/pci/hotplug/pciehp_hpc.c: At top level: drivers/pci/hotplug/pciehp_hpc.c:839: parse error before "pcie_isr" drivers/pci/hotplug/pciehp_hpc.c:840: warning: return type defaults to `int' drivers/pci/hotplug/pciehp_hpc.c: In function `pcie_isr': drivers/pci/hotplug/pciehp_hpc.c:850: `IRQ_NONE' undeclared (first use in this function) drivers/pci/hotplug/pciehp_hpc.c:850: (Each undeclared identifier is reported only once drivers/pci/hotplug/pciehp_hpc.c:850: for each function it appears in.) drivers/pci/hotplug/pciehp_hpc.c:979: `IRQ_HANDLED' undeclared (first use in this function) drivers/pci/hotplug/pciehp_hpc.c: In function `pcie_init': drivers/pci/hotplug/pciehp_hpc.c:1362: implicit declaration of function `request_irq' Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] PCI: fix namespace clashesRajesh Shah
2005-11-10[PATCH] pciehp: fix handling of power faults during hotplugrajesh.shah@intel.com
The current pciehp implementation reports a power-fail error even if the condition has cleared by the time the corresponding interrupt handling code gets a chance to run. This patch fixes this problem. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: clean-up how we request control of hotplug hardwarerajesh.shah@intel.com
This patch further tweaks how we request control of hotplug controller hardware from BIOS. We first search the ACPI namespace corresponding to a specific hotplug controller looking for an _OSC or OSHP method. On failure, we successively move to the ACPI parent object, till we hit the highest level host bridge in the hierarchy. This allows for different types of BIOS's which place the _OSC/OSHP methods at various places in the acpi namespace, while still not encroaching on the namespace of some other root level host bridge. This patch also introduces a new load time option (pciehp_force) that allows us to bypass all _OSC/OSHP checking. Not supporting these methods seems to be be the most common ACPI firmware problem we've run into. This will still _not_ allow the pciehp driver to work correctly if the BIOS really doesn't support pciehp (i.e. if it doesn't generate a hotplug interrupt). Use this option with caution. Some BIOS's may deliberately not build any _OSC/OSHP methods to make sure it retains control the hotplug hardware. Using the pciehp_force parameter for such systems can lead to two separate entities trying to control the same hardware. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: reduce debug message verbosityrajesh.shah@intel.com
Reduce the number of debug messages generated if pciehp debug is enabled. I tried to restrict this to removing debug messages that are either early-driver-debug type messages, or print information that can be inferred through other debug prints. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: miscellaneous cleanupsrajesh.shah@intel.com
Remove un-necessary header includes, remove dead code, remove some hardcoded constants... Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: reduce dependence on ACPIrajesh.shah@intel.com
Reduce the PCI Express hotplug driver's dependence on ACPI. We don't walk the acpi namespace anymore to build a list of bridges and devices. We go to ACPI only to run the _OSC or _OSHP methods to transition control of hotplug hardware from system BIOS to the hotplug driver, and to run the _HPP method to get hotplug device parameters like cache line size, latency timer and SERR/PERR enable from BIOS. Note that one of the side effects of this patch is that pciehp does not automatically enable the hot-added device or its DMA bus mastering capability now. It expects the device driver to do that. This may break some drivers and we will have to fix them as they are reported. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-16[PATCH] PCI Hotplug: new contact infoKristen Accardi
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] PCI Hotplug: get pciehp to work on the downstream port of a switchDely Sy
Here is the updated patch to get pciehp driver to work for downstream port of a switch and handle the difference in the offset value of PCI Express capability list item of different ports. Signed-off-by: Dely Sy <dely.l.sy@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
