Currently, pciehp driver enables command completed interrupt as follows.
(1) Don't enable at initialization.
(2) Enable command completed interrupt whenever pciehp issues a
command, if the command doesn't attempt to disable the interrupt.
(3) Disable command completed interrupt at driver unloading.
Once we enable command completed interrupt, we don't need to re-enable
it for every command. So we can simplify above steps as follows:
(1) Enable command completed interrupt at initialization.
(2) No special sequence for command completed interrupt.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Current pciehp driver's intialization sequence is as follows:
(1) initialize controller data structure
(2) install interrupt handler
(3) enable software notification
(4) initialize controller specific slot data structure
(5) initialize generic slot data structure and register it to pci hotplug core
The interrupt handler of pciehp assumes that controller specific slot
data structure is already initialized. However, it is installed at (2)
before initializing controller specific slot data structure at
(4). Because of this, pciehp driver cannot handle the following cases
properly.
- If devices that shares IRQ with pciehp raise interrupts between (2) and (4).
- If hotplug events (e.g. MRL open) happen between (3) and (4).
We already have a workaround for this problem ("pciehp: fix NULL
dereference in interrupt handler: dbd79aed1aea2bece0bf43cc2ff3b2f9baf48a08).
But we still need fundamental fix.
This patch fix the problem by changing the initilization sequence as follows:
(2) initialize controller specific slot data structure
(3) install interrupt handler
(4) enable software notification
Acked-by: Alex Chiang <achiang@hp.com>
The pcie_poll_cmd() and pcie_wait_cmd() are too large to be
inlined.
Change command polling frequency to 100Hz from 10Hz in order to reduce
the delay in the common case of a command completing quickly.
Cleanup pcie_poll_cmd(): check the slot status once before entering our
completion test loop and convert the loop to a simpler while() block.
Fix the typo in hpc_release_ctlr().
Cleanup to remove a redundant NULL write to SLOTSTATUS.
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Fixup a typo in dbg_ctrl(); it was fetching SLOTSTATUS twice.
Fix the following problems of shpchp driver about getting hotplug
control from firmware.
- The shpchp driver must not control the hotplug controller if it
fails to get control from the firmware. But current shpchp
controls the hotplug controller regardless the result, because it
doesn't check the return value of get_hp_hw_control_from_firmware().
- Current shpchp driver doesn't support _OSC.
The pciehp driver already have the code for evaluating _OSC and OSHP
and shpchp and pciehp can share it. So this patch move that code from
pciehp to acpi_pcihp.c.
Since we need to wait for command completion for muximum 1sec, waiting
command should not be interrupted by a signal.
Current pciehp evaluates _OSC/OSHP method after some controller
initialization is done. So if evaluating _OSC/OSHP is failed, we need
to cleanup already initialized data structures or hardware. This
clearly is not robust way. With this patch, _OSC/OSHP evaluation is
done first.
According to the PCI Express specification, we must wait for at least
1 second after turning power off before taking any action that relies
on power having been removed from the slot/adapter. For this, current
pciehp wait for 1 second after issuing the power off command in
hpc_power_off_slot() function. But waiting for 1 second in
hpc_power_off_slot() can make pciehp probing slow-down because pciehp
probe code calls hpc_power_off_slot() if the slot is not occupied just
in case. We don't need to wait for 1 second at the pciehp probe time
because there is no action on that empty slot. So move 1 second wait
from hpc_power_off_slot() to the caller of hpc_power_off_slot().
Fix improper long wait for command completion in pciehp probing.
As described in PCI Express specification, software notification is
not generated if the command that occurs as a result of a write to the
Slot Control register that disables software notification of command
completed events. Since pciehp driver doesn't take it into account,
such command is issued in pciehp probing, and it causes improper long
wait for command completion.
This patch changes the pciehp driver to take such command into
account.
Fix the "pciehp probing slow" problem reported from Jan C. Nordholz in
http://bugzilla.kernel.org/show_bug.cgi?id=10751.
The command completed bit in Slot Status register applies only to
commands issued to control the attention indicator, power indicator,
power controller, or electromechanical interlock. However, writes to
other parts of the Slot Control register would end up writing to the
control fields. Hence, any write to Slot Control register is
considered as a command. However, if the controller doesn't support
any of attention indicator, power indicator, power controller and
electromechanical interlock, command completed bit would not set in
writing to Slot Control register. In this case, we should not wait for
command completed bit set, otherwise all commands would be considered
not completed in timeout seconds (1 sec.).
The cause of the problem is pciehp driver didn't take this situation
into account. This patch changes pciehp to take it into account. This
patch also add the check for "No Command Completed Support" bit in
Slot Capability register. If it is set, we should not wait for command
completed bit set as well.
This problem seems to be revealed by the commit
c27fb883dffe11aa4cb35ecea1fa1832ba45d4da that fixed the bug that
pciehp did not wait for command completed properly (pciehp just
ignored the command completion event).
Fix the following NULL dereference problem reported from Pierre Ossman
and Ingo Molnar.
pciehp: HPC vendor_id 8086 device_id 27d0 ss_vid 0 ss_did 0
pciehp: pciehp_find_slot: slot (device=0x0) not found
BUG: unable to handle kernel NULL pointer dereference at 0000000000000070
IP: [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
PGD 0
Oops: 0000 [1]
CPU 0
Modules linked in:
Pid: 1, comm: swapper Tainted: G W 2.6.26-rc3-sched-devel.git-00001-g2b99b26-dirty #170
RIP: 0010:[<ffffffff80494a8b>] [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
RSP: 0000:ffff81003f83fbb0 EFLAGS: 00010046
RAX: 0000000000000039 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000046
RBP: ffff81003f83fbd0 R08: 0000000000000001 R09: ffffffff80245103
R10: 0000000000000020 R11: 0000000000000000 R12: ffff81003ea53a30
R13: 0000000000000000 R14: 0000000000000011 R15: ffffffff80495926
FS: 0000000000000000(0000) GS:ffffffff80be7400(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000070 CR3: 0000000000201000 CR4: 00000000000006a0
Process swapper (pid: 1, threadinfo ffff81003f83e000, task ffff81003f840000)
Stack: 0000000000000008 ffff81003f83fbf6 ffff81003ea53a30 0000000000000008
ffff81003f83fc10 ffffffff80495ab4 0000000000000011 0000000000000002
0000000000000202 0000000000000202 00000000fffffff4 ffff81003ea53a30
Call Trace:
[<ffffffff80495ab4>] pcie_isr+0x18e/0x1bc
[<ffffffff80260831>] request_irq+0x106/0x12f
[<ffffffff80495fb6>] pcie_init+0x15e/0x6cc
[<ffffffff804933a3>] pciehp_probe+0x64/0x541
[<ffffffff8048f4e7>] pcie_port_probe_service+0x4c/0x76
[<ffffffff8054af70>] driver_probe_device+0xd4/0x1f0
[<ffffffff8054b108>] __driver_attach+0x7c/0x7e
[<ffffffff8054b08c>] ? __driver_attach+0x0/0x7e
[<ffffffff8054a4b6>] bus_for_each_dev+0x53/0x7d
[<ffffffff8054ad3c>] driver_attach+0x1c/0x1e
[<ffffffff8054a9c2>] bus_add_driver+0xdd/0x25b
[<ffffffff80c09d3d>] ? pcied_init+0x0/0x8b
[<ffffffff8054b288>] driver_register+0x5f/0x13e
[<ffffffff8048f441>] pcie_port_service_register+0x47/0x49
[<ffffffff80c09d52>] pcied_init+0x15/0x8b
[<ffffffff80bf3938>] kernel_init+0x75/0x243
[<ffffffff808639d2>] ? _spin_unlock_irq+0x2b/0x3a
[<ffffffff80228d1f>] ? finish_task_switch+0x57/0x9a
[<ffffffff8020c258>] child_rip+0xa/0x12
[<ffffffff8020bcec>] ? restore_args+0x0/0x30
[<ffffffff80bf38c3>] ? kernel_init+0x0/0x243
[<ffffffff8020c24e>] ? child_rip+0x0/0x12
Code: 83 80 00 00 00 48 39 f0 75 e1 0f b6 c9 48 c7 c2 00 0e 8d 80 48 c7 c6 8a 60 a6 80 48 c7 c7 10 db a8 80 31 c0 e8 3f 8d d9 ff 31 db <48> 8b 43 70 48 8d 75 ef 48 89 df ff 50 30 80 7d ef 00 74 37 48
RIP [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
RSP <ffff81003f83fbb0>
Kernel panic - not syncing: Fatal exception
The situation under which it occurs is hw and timing related: it appears
to happen on a system that has PCI hotplug hardware but with no active
hotplug cards, and another interrupt in the same (shared) IRQ line
arrives too early, before the hotplug-slot entry has been set up - as
triggered by CONFIG_DEBUG_SHIRQ=y:
This patch contains the following two fixes.
(1) Clear all events bits in Slot Status register to prevent the pciehp
driver from detecting the spurious events that would have been occur
before pciehp loading.
(2) Add check whether slot initialization had been already done.
This is short term fix. We need more structural fixes to install
interrupt handler after slot initialization is done.
People are confused by the following error message that actually is
not for indicating a error.
Cannot get control of hotplug hardware for pci %s
This patch changes this message to debug message.
Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
Current implementation of pciehp_write_cmd() always enables command
completed interrupt. But pciehp_write_cmd() is also used for clearing
command completed interrupt enable bit. In this case, we must not set
the command completed interrupt enable bit. To fix this bug, this
patch add the check to see if caller wants to change command complete
this_patch_makes_the_needlessly_global_pciehp_acpi_get_hp_hw_control_from_firmware_static
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Clean up pciehp_ini(). This patch is trying to
- Remove redundant capablity checks that were already done in PCIe
port bus driver.
- Separate the code only for debugging and make debug information
easier to read.
- Make the entire code easier to read and understand what it is doing.
We must disable hotplug interrupt at controller relase time, otherwise
spurious interrupts might happen if any slot events occured (e.g. MRL
change) after unloading pciehp driver.
Hotplug interrupt is enabled at initialization and nobody clears it.
So we need to setup it in each command. This patch removes redundant
codes about this.
Current pciehp saves only 8bits of Slot Capability registers in
ctrl->ctrlcap. But it refers more than 8bit for checking EMI capability.
It is clearly a bug and EMI would never work. To fix this problem,
this patch saves full Slot Capability contens in ctrl->slot_cap. It also
reduce the redundant reads of Slot Capability register. And this pach
also cleans up the macros to check the slot capabilitys (e.g. MRL_SENS(),
and so on).
Current pciehp implementaion clears hotplug events without waiting for
command completion. Because of this, events might not be cleared properly.
To prevent this problem, we must use pciehp_write_cmd() to write to
Fix the possible race condition between pcie_isr() and pciehp_write_cmd()
because of the lack of memory barrier.
Current pciehp implementation disables and re-enables hotplug interrupts
in its interrupt handler. This operation might be intend to guarantee
that interrupts for the events newly occured during previous events are
being handled will be successfully generated. But current implementaion
has the following prolems.
- Current interrupt service routin clears status changes without
waiting command completion. Because of this, events might not be
cleared properly.
- Current interrupt service routine clears status changes caused by
disabling or enabling hotplug interrupts itself. This will lose new
events that occurs during previous interrupts are being handled.
- Current implementation doesn't have any serialization mechanism
between the code to wait for command completion and the interrupt
handler that clears the command completion events caused by itself.
There is clearly race conditions between them, and it may cause
the problem that waiting for command completion doesn't work for
example.
To fix those problems, this patch stops disabling/re-enabling hotplug
interrupts in interrupt service routine. Instead of this, this patch
re-inspects Slot Status register after clearing what is presumed to
be the last bending interrupt in order to guarantee that all interrupt
events are serviced.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Fix the error code path in hpc_power_off_slot().
The Bad DLLP Mask bit must be restored before return.
Set Bad DLLP Mask bit in Correctable Error Mask Register during
turning power off the slot.
This is the workaround against Bad DLLP error that sometimes happen
during turning power off on the slot which conforms to PCI Express
1.0a spec. The cause of this error seems that PCI Express 1.0a spec
doesn't have the following consideration that was added to PCI Express
1.1 spec.
"If the port is associated with a hot-pluggable slot (Hot-Plug
Capable bit in the Slot Capabilities register set to 1b), and
Power Controller Control bit in Slot Control register is 1b(Off),
then any transition to DL Inactive must not be considered an
error."
After turning power off, we must wait for at least 1 second *before*
LED operation.
Earlier patches to split out the hardware init for PCIe hotplug resulted in
some one-time initializations being redone on every resume cycle. Eg.
irq/polling initialization.
This patch splits the hardware init into two parts, and separates the
one-time initializations from those so that they only ever get done once,
as intended.
Signed-off-by: Mark Lord <mlord@pobox.com>
Dell notebooks (and others?) in conjunction with modparam of pciehp_force=1
Split out the hotplug hardware initialization code from pcie_init()
into pcie_init_enable_events(), without changing any functionality.
Cc: Theodore Ts'o <tytso@mit.edu>
Minor cleanups for pciehp_hpc.c. The 80 column rules, removing
unnecessary lines, and so on.
Remove trailing whitespaces from pciehp_hpc.c.
This patch removes DBG_ENTER_ROUTIN, DBG_LEAVE_ROUTINE and related
code, which seem no longer needed.
Native hotplug
According to the PCI firmware spec (3.0), the OS must claim control
over the PCI Express Capability bits in addition to the PCI Express
Native Hot Plug feature when executing _OSC.
The slot control register is modified as follows:
(1) Read the register value
(2) Change the value
(3) Write the value to the register
Those must be done atomically, otherwise writing to control register
would cause an unexpected result.
The event handler of PCIEHP driver is unnecessarily very complex. In
addition, current event handler can only a fixed number of events at
the same time, and some of events would be lost if several number of
events happened at the same time.
This patch simplify the event handler using 'work queue', and it also
fix the above-mentioned issue.
driver.
This patch fixes this problem that pciehp driver will sleep
unnecessarily long when waiting for command completion. With this
patch, modprobe pciehp driver becomes very faster as follows for
instance.
o Without this patch
# time /sbin/modprobe pciehp
real 0m4.976s
user 0m0.000s
sys 0m0.004s
o With this patch
real 0m0.640s
user 0m0.000s
sys 0m0.004s
This patch cleans up the code to wait for command completion.
This patch removes unused pcie_cap_base variable.
This patch cleans up register access functions. This has no functional
change.
The struct php_ctlr seems to be only for complicating codes. This
patch removes struct php_ctlr and related codes.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
This patch fixes the problem that "irq XX: nobody cared" kernel oops
is reported when pciehp is once rmmoded and insmoded again. The cause
of this problem is pciehp driver calls pci_disable_msi() at controller
release time, even though it must be done by PCI Express Port Bus
driver. This patch removes unnecessary pci_disable_msi() call from
pciehp driver.
This patch fixes the problem that system will panic if multiple power
on/off operations are issued to the same slot in parallel. This
problem can be easily reproduced by commands below.
# while true; do echo 1 > power; echo 0 > power; done &
The cause is lack of locking for enable/disable operations. This patch
fixes this problem.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Make pciehp build on powerpc
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
drivers
This is needed if we wish to change the size of the resource structures.
Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
