path: root/drivers/pci/hotplug
2008-04-29pciehp: fix error message about getting hotplug controlKenji Kaneshige
People are confused by the following error message that actually is not for indicating a error. Cannot get control of hotplug hardware for pci %s This patch changes this message to debug message. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2008-04-25pciehp: Fix command writeKenji Kaneshige
Current implementation of pciehp_write_cmd() always enables command completed interrupt. But pciehp_write_cmd() is also used for clearing command completed interrupt enable bit. In this case, we must not set the command completed interrupt enable bit. To fix this bug, this patch add the check to see if caller wants to change command complete interrupt enable bit. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25shpchp: fix slot nameKenji Kaneshige
Current shpchp uses the combination of bus number and slot number as a slot name. But it is not a good idea because bus number is not a physical identifier but a logical identifier. This is against the shpc specification. So remove the bus number from the physical identifier. However, there are some platforms with the problem that it provides the same slot number. For those platforms, this patch also introduces new module option 'shpchp_slot_with_bus'. If it is specified, shpchp uses the combination of bus number and slot number as a slot name. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25make pciehp_acpi_get_hp_hw_control_from_firmware()Adrian Bunk
this_patch_makes_the_needlessly_global_pciehp_acpi_get_hp_hw_control_from_firmware_static ;) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Clean up pcie_init()Kenji Kaneshige
Clean up pciehp_ini(). This patch is trying to - Remove redundant capablity checks that were already done in PCIe port bus driver. - Separate the code only for debugging and make debug information easier to read. - Make the entire code easier to read and understand what it is doing. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Mask hotplug interrupt at controller releaseKenji Kaneshige
We must disable hotplug interrupt at controller relase time, otherwise spurious interrupts might happen if any slot events occured (e.g. MRL change) after unloading pciehp driver. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Remove useless hotplug interrupt enablingKenji Kaneshige
Hotplug interrupt is enabled at initialization and nobody clears it. So we need to setup it in each command. This patch removes redundant codes about this. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Fix wrong slot capability checkKenji Kaneshige
Current pciehp saves only 8bits of Slot Capability registers in ctrl->ctrlcap. But it refers more than 8bit for checking EMI capability. It is clearly a bug and EMI would never work. To fix this problem, this patch saves full Slot Capability contens in ctrl->slot_cap. It also reduce the redundant reads of Slot Capability register. And this pach also cleans up the macros to check the slot capabilitys (e.g. MRL_SENS(), and so on). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Fix wrong slot control register accessKenji Kaneshige
Current pciehp implementaion clears hotplug events without waiting for command completion. Because of this, events might not be cleared properly. To prevent this problem, we must use pciehp_write_cmd() to write to Slot Control register. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Add missing memory barrierKenji Kaneshige
Fix the possible race condition between pcie_isr() and pciehp_write_cmd() because of the lack of memory barrier. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Fix interrupt event handligKenji Kaneshige
Current pciehp implementation disables and re-enables hotplug interrupts in its interrupt handler. This operation might be intend to guarantee that interrupts for the events newly occured during previous events are being handled will be successfully generated. But current implementaion has the following prolems. - Current interrupt service routin clears status changes without waiting command completion. Because of this, events might not be cleared properly. - Current interrupt service routine clears status changes caused by disabling or enabling hotplug interrupts itself. This will lose new events that occurs during previous interrupts are being handled. - Current implementation doesn't have any serialization mechanism between the code to wait for command completion and the interrupt handler that clears the command completion events caused by itself. There is clearly race conditions between them, and it may cause the problem that waiting for command completion doesn't work for example. To fix those problems, this patch stops disabling/re-enabling hotplug interrupts in interrupt service routine. Instead of this, this patch re-inspects Slot Status register after clearing what is presumed to be the last bending interrupt in order to guarantee that all interrupt events are serviced. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: fix slot nameKenji Kaneshige
Current pciehp uses the combination of bus number and slot number as a slot name. But it is not a good idea because bus number is not a physical identifier but a logical identifier. This is against the PCIE specification. So remove the bus number from the physical identifier. However, there are some platforms with the problem that it provides the same slot number. For those platforms, this patch also introduces new module option 'pciehp_slot_with_bus'. If it is specified, pciehp uses the combination of bus number and slot number as a slot name. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggeredTrent Piepho
The 'power' attribute of the fakephp driver originally only let one turn a slot off. If one tried to turn a slot on (echo 1 > .../power), it would return ENODEV, as fakephp did not support this function. An old (pre-git) patch changed this: 2004/11/11 16:33:31-08:00 jdittmer [PATCH] fakephp: add pci bus rescan ability http://article.gmane.org/gmane.linux.kernel/251183 Now writing "1" to the power attribute has the effect of triggering a bus rescan, but it still returns ENODEV, probably an oversight in the above patch. Using the BusyBox echo will not produce an error message, but will trigger *two* bus rescans (and return an exit code of 1): ~ # strace echo -n 1 > /sys/bus/pci/slots/0000:00:00.0/power ... write(1, "1", 1) = -1 ENODEV (No such device) write(1, "1", 1) = -1 ENODEV (No such device) exit(1) = ? Using cp gives a write error, even though the write did happen and a rescan was triggered: ~ # echo -n 1 > tmp ; cp tmp /sys/bus/pci/slots/0000:00:00.0/power cp: Write Error: No such device It seems much better to return success instead of failure. The actual status of the bus rescan is hard to return. It happens asynchronously in a work thread, so the sysfs store functions returns before any status is ready (the whole point of the work queue). And even if it didn't do this, the rescan doesn't have any clear status to return. Signed-off-by: Trent Piepho <tpiepho@freescale.com> CC: Jan Dittmer <jdittmer@ppp0.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno()Jesper Juhl
In drivers/pci/hotplug/ibmphp_core.c::ibmphp_init_devno() we allocate space dynamically for a PCI irq routing table by calling pcibios_get_irq_routing_table(), but we never free the allocated space. This patch frees the allocated space at the function exit points. Spotted by the Coverity checker. Compile tested only. Please consider applying. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI Hotplug: the ibm driver is not dependant on PCI_LEGACYGreg Kroah-Hartman
This was marked incorrectly for some reason. Allow the ibmphp driver to be built even if PCI_LEGACY is not enabled. Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI Hotplug: make cpcihp driver use modern apisGreg Kroah-Hartman
This removes the depandancy of the cpcihp driver from the PCI_LEGACY config option by removing its usage of the pci_find_bus() function. Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Scott Murray <scottm@somanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-17pciehp: don't enable slot unless forcedMark Lord
This fixes a 2.6.25 regression reported by Alex Chiang. Invoke pciehp_enable_slot() at startup only when pciehp_force=1. Some HP equipment apparently cannot cope with it otherwise. This restores the (previously working) 2.6.24 behaviour here, while allowing machines that need a kick to use pciehp_force=1. This was the original design back in October 2007, but Kristen suggested we try without it first: Kristen Carlson Accardi wrote: >I think it would be ok to try allowing the slot to be enabled when not >using pciehp_force mode. We can wrap it later if it proves to break things This ended up breaking one of Alex's setups, so it's time to put the wrapper back in now. Signed-off-by: Mark Lord <mlord@pobox.com> Acked-by: Alex Chiang <achiang@hp.com> Acked-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10PCI Hotplug: Fix small mem leak in IBM Hot Plug Controller DriverJesper Juhl
In drivers/pci/hotplug/ibmphp_ebda.c::ebda_rsrc_controller(), storage is allocated with kzalloc() and assigned to 'tmp_slot'. Then lots of stuff, like ->flag, ->supported_speed etc is set in tmp_slot. A bit further down there's then this test : if (!bus_info_ptr1) { rc = -ENODEV; goto error; } At this point, tmp_slot has not been assigned to anything, so when erroring-out we want to free it, but nothing at the 'error:' label free's 'tmp_slot' - and we can't really free 'tmp_slot' at 'error:' since we may jump to that label later when 'tmp_slot' *has* been used and we do not want it freed. So, the only sane option left seems to be to kfree(tmp_slot) just before jumping to the 'error:' label in the one place where this is what actually makes sense. The following patch does just that and thus kills off a tiny potential memory leak. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04pci: hotplug: pciehp: fix error code path in hpc_power_off_slotKenji Kaneshige
Fix the error code path in hpc_power_off_slot(). The Bad DLLP Mask bit must be restored before return. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04PCI: fix section mismatch warning in pci_scan_child_busSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.text+0x47bdb1): Section mismatch in reference from the function pci_scan_child_bus() to the function .devinit.text:pcibios_fixup_bus() We had plenty of functions that could be annotated __devinit but due to the former restriction that exported symbols could not be annotated they were not so. So annotate these function and fix the references from the pci/hotplug/* code to silence the resuting warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21PCI: don't load acpi_php when acpi is disabledYinghai Lu
When acpi=off and pci=nomsi, don't load acpiphp. Fixes this: pci_hotplug: PCI Hot Plug PCI Core version: 0.5 acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 ACPI Exception (utmutex-0263): AE_BAD_PARAMETER, Thread FFFF81103CC54000 could not acquire Mutex [1] [20070126] [akpm@linux-foundation.org: export acpi_pci_disabled for acpiphp.ko] [akpm@linux-foundation.org: fix return statement] Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21PCI: hotplug: acpiphp_ibm: Remove get device informationGary Hade
drivers/pci/hotplug/acpiphp_ibm.c:ibm_find_acpi_device() is not large enough to accommodate data returned by the _CID method executed from acpi_get_object_info(). This patch eliminates the problem by letting ACPI code (instead of driver code) determine and obtain a correctly sized buffer. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: Fix fakephp deadlockIan Abbott
If the fakephp driver is used to emulate removal of a PCI device by writing text string "0" to the "power" sysfs attribute file, this causes its parent directory and its contents (including the "power" file) to be deleted before the write operation returns. Unfortunately, it ends up in a deadlock waiting for itself to complete. The deadlock is as follows: sysfs_write_file calls flush_write_buffer which calls sysfs_get_active_two before calling power_write_file in pci_hotplug_core.c via the sysfs store operation. The power_write_file function calls disable_slot in fakephp.c via the slot operation. The disable_slot function calls remove_slot which calls pci_hp_deregister (back in pci_hotplug_core.c) which calls fs_remove_slot which calls sysfs_remove_file to remove the "power" file. The sysfs_remove_file function calls sysfs_hash_and_remove which calls sysfs_addrm_finish which calls sysfs_deactivate. The sysfs_deactivate function sees that something has an active reference on the sysfs_dirent (from the previous call to sysfs_get_active_two back up the call stack somewhere) so waits for the active reference to go away, which is of course impossible. The problem has been present since 2.6.21. This patch breaks the deadlock by queuing work queue items on a single- threaded work queue to remove a slot from sysfs, and to rescan the PCI buses. There is also some protection against disabling a slot that is already being removed. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pciehp: block new requests from the device before power offKenji Kaneshige
Disable Bus Master, SERR# and INTx to ensure that no new Requests will be generated from the device before turning power off, in accordance with the specification. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pciehp: workaround against Bad DLLP during power offKenji Kaneshige
Set Bad DLLP Mask bit in Correctable Error Mask Register during turning power off the slot. This is the workaround against Bad DLLP error that sometimes happen during turning power off on the slot which conforms to PCI Express 1.0a spec. The cause of this error seems that PCI Express 1.0a spec doesn't have the following consideration that was added to PCI Express 1.1 spec. "If the port is associated with a hot-pluggable slot (Hot-Plug Capable bit in the Slot Capabilities register set to 1b), and Power Controller Control bit in Slot Control register is 1b(Off), then any transition to DL Inactive must not be considered an error." Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pciehp: wait for 1000ms before LED operation after power offKenji Kaneshige
After turning power off, we must wait for at least 1 second *before* LED operation. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: PCIeHP: Fix some whitespace damageRolf Eike Beer
PCIeHP: Fix some whitespace damage Signed-off-by: Rolf Eike Beer <eike-hotplug@sf-tec.de> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: pciehp: use generic function to find ext capabilityKenji Kaneshige
Remove duplicated code to find an extend capability in PCIEHP driver. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: pciehp: remove needless hp_slot calculationKenji Kaneshige
Remove needless hp_slot calculation. This has no functional changes. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: pciehp: remove needless members from struct controllerKenji Kaneshige
Remove needless members from struct controller. This has no functional changes. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: acpiphp: remove unneeded acpi_get_name function callMUNEDA Takahiro
acpi_get_name() is called before and after dbg(). The latter is useless and should be removed. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: acpiphp: fix trivial typosMUNEDA Takahiro
fix trivial typos. Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCIe: fix double initialization bugMark Lord
Earlier patches to split out the hardware init for PCIe hotplug resulted in some one-time initializations being redone on every resume cycle. Eg. irq/polling initialization. This patch splits the hardware init into two parts, and separates the one-time initializations from those so that they only ever get done once, as intended. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCIE: Make use of the previously split out pcie_init_enable_events() functionMark Lord
Make use of the previously split out pcie_init_enable_events() function to reinitialize the hotplug hardware on resume from suspend, but only when pciehp_force==1. Otherwise behaviour is unmodified. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: more fixes for PCIe Hotplug so that it works with ExpressCard slots on ↵Mark Lord
Dell notebooks (and others?) in conjunction with modparam of pciehp_force=1 Split out the hotplug hardware initialization code from pcie_init() into pcie_init_enable_events(), without changing any functionality. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCIE: fix PCIe Hotplug so that it works with ExpressCard slots on Dell ↵Mark Lord
notebooks (and others?) in conjunction with modparam of pciehp_force=1. Fix pciehp_probe() to deal with ExpressCard cards that were inserted prior to the driver being loaded. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: Add missing "space" in printk messagesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pci hotplug: fix rpaphp directory namingLinas Vepstas
Fix presentation of the slot number in the /sys/bus/pci/slots directory to match that used in the majority of other drivers. > Greg said: > How is anyone supposed to write sane managability tools in the > presence > of such anarchy? > > > ~ # cat /sys/bus/pci/slots/0000:00:02.2/phy_location > > U787A.001.DNZ00Z5-P1-C2 > > Right. This should look like: > > # cat /sys/bus/pci/slots/U787A.001.DNZ00Z5-P1-C2/address > 0000:00:02 This patch implements exactly what you describe. Boot tested. I assume you really mean it -- if so, then please review and ack the patch !? I have absolutely no clue if this breaks any existing IBM tools. I'm pretty sure it doesn't ... but attention Mike Strosaker! does it? Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: <strosake@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: hotplug: Link fakephp lastAlex Chiang
Currently, fakephp will claim all devices; we really only want it to claim those not in slots. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: hotplug: pci_hotplug_core whitespace fixAlex Chiang
Remove superfluous space. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: hotplug: acpiphp: Remove unused variable from acpiphpAlex Chiang
Remove unused variable from acpiphp. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: hotplug: remove ExperimentalKristen Carlson Accardi
Remove EXPERIMENTAL from PCI Hot Plug. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: hotplug: Switch to pci_get_bus_and_slotJoonwoo Park
Thank you so much for your check & advise. This time, I've tried on ibmphp_core.c, is it OK? Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24driver core: add way to get to bus ksetGreg Kroah-Hartman
This allows an easier way to get to the kset associated with a struct bus_type (you have three to choose from...) This will make it easier to move these fields to be dynamic in a future patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change drivers/pci/hotplug/pci_hotplug_core.c to use ↵Greg Kroah-Hartman
kobject_init_and_add Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: clean up rpadlpar horrid sysfs abuseGreg Kroah-Hartman
rpadlpar pci hotplug driver was doing some pretty bad stuff with the sysfs files. This cleans up the logic to be sane and gets rid of the gratuitous kset that is not needed for a simple directory like this. Note, this patch is not even build tested, let alone run-time tested. Someone with access to this hardware and can test would be greatly appreciated. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: John Rose <johnrose@austin.ibm.com> Cc: Badari Pulavarty <pbadari@gmail.com> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
