path: root/drivers/pci/intr_remapping.h
2011-06-21x86/ia64: intel-iommu: move to drivers/iommu/Ohad Ben-Cohen
This should ease finding similarities with different platforms, with the intention of solving problems once in a generic framework which everyone can use. Note: to move intel-iommu.c, the declaration of pci_find_upstream_pcie_bridge() has to move from drivers/pci/pci.h to include/linux/pci.h. This is handled in this patch, too. As suggested, also drop DMAR's EXPERIMENTAL tag while we're at it. Compile-tested on x86_64. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-08-27intr-remap: generic support for remapping HPET MSIsSuresh Siddha
Generic support for remapping HPET MSI's by parsing the HPET timer block device scope in the ACPI DRHD tables. This is needed for platforms supporting interrupt-remapping and MSI capable HPET timer block. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Jay Fenlason <fenlason@redhat.com> LKML-Reference: <20090804190729.477649000@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-23Intel-IOMMU, intr-remap: source-id checkingWeidong Han
To support domain-isolation usages, the platform hardware must be capable of uniquely identifying the requestor (source-id) for each interrupt message. Without source-id checking for interrupt remapping , a rouge guest/VM with assigned devices can launch interrupt attacks to bring down anothe guest/VM or the VMM itself. This patch adds source-id checking for interrupt remapping, and then really isolates interrupts for guests/VMs with assigned devices. Because PCI subsystem is not initialized yet when set up IOAPIC entries, use read_pci_config_byte to access PCI config space directly. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-15VT-d: Changes to support KVMKay, Allen M
This patch extends the VT-d driver to support KVM [Ben: fixed memory pinning] [avi: move dma_remapping.h as well] Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Amit Shah <amit.shah@qumranet.com> Acked-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-07-12x64, x2apic/intr-remap: Interrupt remapping infrastructureSuresh Siddha
Interrupt remapping (part of Intel Virtualization Tech for directed I/O) infrastructure. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: akpm@linux-foundation.org Cc: arjan@linux.intel.com Cc: andi@firstfloor.org Cc: ebiederm@xmission.com Cc: jbarnes@virtuousgeek.org Cc: steiner@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-12x64, x2apic/intr-remap: parse ioapic scope under vt-d structuresSuresh Siddha
Parse the vt-d device scope structures to find the mapping between IO-APICs and the interrupt remapping hardware units. This will be used later for enabling Interrupt-remapping for IOAPIC devices. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: akpm@linux-foundation.org Cc: arjan@linux.intel.com Cc: andi@firstfloor.org Cc: ebiederm@xmission.com Cc: jbarnes@virtuousgeek.org Cc: steiner@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
