path: root/drivers/pci/pci-label.c
2011-07-26pci-label.c: size_t misspelled as mode_tAl Viro
no, really, strlen() and snprintf() do not return mode_t values... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-16PCI: label: remove #include of ACPI header to avoid warningsShyam_Iyer@Dell.com
I found that including acpi/apci_drivers.h is not necessary and introduces these warnings: In file included from drivers/pci/pci-label.c:32: include/acpi/acpi_drivers.h:103: warning: ‘struct acpi_device’ declared inside parameter list include/acpi/acpi_drivers.h:103: warning: its scope is only this definition or declaration, which is probably not what you want include/acpi/acpi_drivers.h:107: warning: ‘struct acpi_pci_root’ declared inside parameter list Signed-off-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-03-16PCI: label: Fix compilation error when CONFIG_ACPI is unsetNarendra_K@Dell.com
This patch fixes compilation error descibed below introduced by the commit 6058989bad05b82e78baacce69ec14f27a11b5fd drivers/pci/pci-label.c: In function ‘pci_create_firmware_label_files’: drivers/pci/pci-label.c:366:2: error: implicit declaration of function ‘device_has_dsm’ Signed-off-by: Narendra K <narendra_k@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-03-04PCI: Export ACPI _DSM provided firmware instance number and string name to sysfsNarendra_K@Dell.com
This patch exports ACPI _DSM (Device Specific Method) provided firmware instance number and string name of PCI devices as defined by 'PCI Firmware Specification Revision 3.1' section 4.6.7.( DSM for Naming a PCI or PCI Express Device Under Operating Systems) to sysfs. New files created are: /sys/bus/pci/devices/.../label which contains the firmware name for the device in question, and /sys/bus/pci/devices/.../acpi_index which contains the firmware device type instance for the given device. cat /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/acpi_index 1 cat /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/label Embedded Broadcom 5709C NIC 1 cat /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/acpi_index 2 cat /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/label Embedded Broadcom 5709C NIC 2 The ACPI _DSM provided firmware 'instance number' and 'string name' will be given priority if the firmware also provides 'SMBIOS type 41 device type instance and string'. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com> Signed-off-by: Narendra K <narendra_k@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-08-04PCI: update for owner removal from struct device_attributeStephen Rothwell
Fixes the build. Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-07-30PCI: export SMBIOS provided firmware instance and label to sysfsNarendra K
This patch exports SMBIOS provided firmware instance and label of onboard PCI devices to sysfs. New files are: /sys/bus/pci/devices/.../label which contains the firmware name for the device in question, and /sys/bus/pci/devices/.../index which contains the firmware device type instance for the given device. Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com> Signed-off-by: Narendra K <narendra_k@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
