Commit fab4c256a58b ("PCI/AER: Add a TLP header print helper") introduced
the helper function __print_tlp_header(), but contrary to the intention,
the behaviour did change: Since we're taking the address of the parameter
t, the first 4 or 8 bytes printed will be the value of the pointer t
itself, and the remaining 12 or 8 bytes will be who-knows-what (something
from the stack).
We want to show the values of the four members of the struct
aer_header_log_regs; that can be done without ugly and error-prone casts.
On little-endian this should produce the same output as originally
intended, and since no-one has complained about getting garbage output so
far, I think big-endian should be ok too.
Fixes: fab4c256a58b ("PCI/AER: Add a TLP header print helper")
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Borislav Petkov <bp@suse.de>
CC: stable@vger.kernel.org # v3.14+
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kconfig updates from Michal Marek:
"Yann E Morin was supposed to take over kconfig maintainership, but
this hasn't happened. So I'm sending a few kconfig patches that I
collected:
- Fix for missing va_end in kconfig
- merge_config.sh displays used if given too few arguments
- s/boolean/bool/ in Kconfig files for consistency, with the plan to
only support bool in the future"
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: use va_end to match corresponding va_start
merge_config.sh: Display usage if given too few arguments
kconfig: use bool instead of boolean for type definition attributes
The functions link_state_store() and clk_ctl_store() had just subtracted
ASCII '0' from input which could lead to undesired results. Instead, use
Linux string functions to safely parse input.
[bhelgaas: check kstrtouint() return value]
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
Support for keyword 'boolean' will be dropped later on.
No functional change.
Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com
Signed-off-by: Christoph Jaeger <cj@linux.com>
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so quite a few
depend on CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM in the PCI core code.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Kevin Hilman <khilman@linaro.org>
If the irqchip handling the PCIe PME interrupt is not able
to enable interrupt wakeup we should properly reflect this
in the PME suspend status.
This fixes a kernel warning on resume, where it would try
to disable the irq wakeup that failed to be activated while
suspending, for example:
WARNING: CPU: 0 PID: 609 at kernel/irq/manage.c:536 irq_set_irq_wake+0xc0/0xf8()
Unbalanced IRQ 384 wake disable
Fixes: 76cde7e49590 (PCI / PM: Make PCIe PME interrupts wake up from suspend-to-idle)
Reported-and-tested-by: Richard Zhu <richard.zhu@freescale.com>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Pull ACPI and power management updates from Rafael Wysocki:
"Features-wise, to me the most important this time is a rework of
wakeup interrupts handling in the core that makes them work
consistently across all of the available sleep states, including
suspend-to-idle. Many thanks to Thomas Gleixner for his help with
this work.
Second is an update of the generic PM domains code that has been in
need of some care for quite a while. Unused code is being removed, DT
support is being added and domains are now going to be attached to
devices in bus type code in analogy with the ACPI PM domain. The
majority of work here was done by Ulf Hansson who also has been the
most active developer this time.
Apart from this we have a traditional ACPICA update, this time to
upstream version 20140828 and a few ACPI wakeup interrupts handling
patches on top of the general rework mentioned above. There also are
several cpufreq commits including renaming the cpufreq-cpu0 driver to
cpufreq-dt, as this is what implements generic DT-based cpufreq
support, and a new DT-based idle states infrastructure for cpuidle.
In addition to that, the ACPI LPSS driver is updated, ACPI support for
Apple machines is improved, a few bugs are fixed and a few cleanups
are made all over.
Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree
maintained by Kevin Hilman that will be merged through the PM tree.
Numbers-wise, the generic PM domains update takes the lead this time
with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd
place goes to the wakeup interrupts handling rework (13 commits).
Specifics:
- Rework the handling of wakeup IRQs by the IRQ core such that all of
them will be switched over to "wakeup" mode in suspend_device_irqs()
and in that mode the first interrupt will abort system suspend in
progress or wake up the system if already in suspend-to-idle (or
equivalent) without executing any interrupt handlers. Among other
things that eliminates the wakeup-related motivation to use the
IRQF_NO_SUSPEND interrupt flag with interrupts which don't really
need it and should not use it (Thomas Gleixner and Rafael Wysocki)
- Switch over ACPI to handling wakeup interrupts with the help of the
new mechanism introduced by the above IRQ core rework (Rafael Wysocki)
- Rework the core generic PM domains code to eliminate code that's
not used, add DT support and add a generic mechanism by which
devices can be added to PM domains automatically during enumeration
(Ulf Hansson, Geert Uytterhoeven and Tomasz Figa).
- Add debugfs-based mechanics for debugging generic PM domains
(Maciej Matraszek).
- ACPICA update to upstream version 20140828. Included are updates
related to the SRAT and GTDT tables and the _PSx methods are in the
METHOD_NAME list now (Bob Moore and Hanjun Guo).
- Add _OSI("Darwin") support to the ACPI core (unfortunately, that
can't really be done in a straightforward way) to prevent
Thunderbolt from being turned off on Apple systems after boot (or
after resume from system suspend) and rework the ACPI Smart Battery
Subsystem (SBS) driver to work correctly with Apple platforms
(Matthew Garrett and Andreas Noever).
- ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code,
adding support for 133MHz I2C source clock on Intel Baytrail to it
and making it avoid using UART RTS override with Auto Flow Control
(Heikki Krogerus).
- ACPI backlight updates removing the video_set_use_native_backlight
quirk which is not necessary any more, making the code check the
list of output devices returned by the _DOD method to avoid
creating acpi_video interfaces that won't work and adding a quirk
for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak)
- New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin)
- Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes,
Sudip Mukherjee, Yijing Wang, and Zhang Rui)
- cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy,
Rasmus Villemoes)
- cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change
among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U
Murthy, Shilpasri G Bhat, Lucas Stach)
- cpuidle support for DT-based idle states infrastructure, new ARM64
cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus
Villemoes)
- ARM big.LITTLE cpuidle driver updates: support for DT-based
initialization and Exynos5800 compatible string (Lorenzo Pieralisi,
Kevin Hilman)
- Rework of the test_suspend kernel command line argument and a new
trace event for console resume (Srinivas Pandruvada, Todd E Brandt)
- Second attempt to optimize swsusp_free() (hibernation core) to make
it avoid going through all PFNs which may be way too slow on some
systems (Joerg Roedel)
- devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide).
- rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry
update in MAINTAINERS (Heiko Stübner, Kevin Hilman)
- PM core fix related to clock management (Geert Uytterhoeven)
- PM core's sysfs code cleanup (Johannes Berg)"
* tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits)
ACPI / fan: printk replacement
PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME
PM / Domains: Rename cpu_data to cpuidle_data
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
cpufreq: ppc-corenet: remove duplicate update of cpu_data
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPI / video: check _DOD list when creating backlight devices
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
PM / devfreq: exynos: Enable building exynos PPMU as module
PM / devfreq: Export helper functions for drivers
* pci/aer:
PCI/AER: Rename PCI_ERR_UNC_TRAIN to PCI_ERR_UNC_UND
PCI/AER: Add additional PCIe AER error strings
trace, RAS: Add additional PCIe AER error strings
trace, RAS: Replace bare numbers with #defines for PCIe AER error strings
* pci/virtualization:
PCI: Add ACS quirk for Intel 10G NICs
Add strings for all AER error bits defined in PCIe r3.0.
[bhelgaas: changelog, drop designated initializer change]
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
Since commit de7d5f729c72 ("PCI/PM: Disable runtime PM of PCIe ports") the
runtime PM support code for PCIe ports in portdrv_pci.c has never been
used, so drop it entirely.
If we are to support runtime PM of PCIe ports, it will have to be done in a
different way most likely anyway.
To make PCIe PME interrupts wake up the system from suspend to idle,
make the PME driver use enable_irq_wake() on the IRQ during system
suspend (if there are any wakeup devices below the given PCIe port)
without disabling PME interrupts. This way, an interrupt will still
trigger if a wakeup event happens and the system will be woken up (or
system suspend in progress will be aborted) by means of the new
mechanics introduced previously.
This change allows Wake-on-LAN to be used for wakeup from
suspend-to-idle on my MSI Wind tesbed netbook.
Pull RAS updates from Ingo Molnar:
"The main changes in this cycle are:
- RAS tracing/events infrastructure, by Gong Chen.
- Various generalizations of the APEI code to make it available to
non-x86 architectures, by Tomasz Nowicki"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/ras: Fix build warnings in <linux/aer.h>
acpi, apei, ghes: Factor out ioremap virtual memory for IRQ and NMI context.
acpi, apei, ghes: Make NMI error notification to be GHES architecture extension.
apei, mce: Factor out APEI architecture specific MCE calls.
RAS, extlog: Adjust init flow
trace, eMCA: Add a knob to adjust where to save event log
trace, RAS: Add eMCA trace event interface
RAS, debugfs: Add debugfs interface for RAS subsystem
CPER: Adjust code flow of some functions
x86, MCE: Robustify mcheck_init_device
trace, AER: Move trace into unified interface
trace, RAS: Add basic RAS trace event
x86, MCE: Kill CPU_POST_DEAD
For hot-added PCIe ports on x86 platforms, we always warned about an
invalid IRQ, e.g.,
pci 0000:00:00.0: device [8086:0e0b] has invalid IRQ; check vendor BIOS
This was because we check pci_dev->irq before actually allocating the IRQ
for the device, which happens in this path:
pcie_port_device_register
pci_enable_device
pci_enable_device_flags
do_pci_enable_device
pcibios_enable_device (on x86)
pcibios_enable_irq
This warning message isn't generated for PCIe ports present at boot time
because x86 arch code has called acpi_pci_irq_enable() in pci_acpi_init()
for each PCI device for safety.
[bhelgaas: changelog]
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
AER uses a separate trace interface by now. To make it
consistent, move it into unified RAS trace interface.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Merge quoted strings that are broken across lines into a single entity.
The compiler merges them anyway, but checkpatch complains about it, and
merging them makes it easier to grep for strings.
[bhelgaas: changelog, do the same for everything under drivers/pci]
Signed-off-by: Ryan Desfosses <ryan@desfo.org>
Fix various whitespace errors.
[bhelgaas: fix other similar problems]
into next
* pci/hotplug:
PCI: rphahp: Fix endianess issues
PCI: Allow hotplug service drivers to operate in polling mode
PCI: pciehp: Acknowledge spurious "cmd completed" event
PCI: pciehp: Use PCI_EXP_SLTCAP_PSN define
PCI: hotplug: Remove unnecessary "dev->bus" test
* pci/msi:
GenWQE: Use pci_enable_msi_exact() instead of pci_enable_msi_block()
PCI/MSI: Simplify populate_msi_sysfs()
PCI/portdrv: Use pci_enable_msix_exact() instead of pci_enable_msix()
PCI: Add Patsburg (X79) to Intel PCH root port ACS quirk
* pci/misc:
PCI: Fix use of uninitialized MPS value
PCI: Remove dead code
MAINTAINERS: Add arch/x86/kernel/quirks.c to PCI file patterns
PCI: Remove unnecessary __ref annotations
PCI: Fail new_id for vendor/device values already built into driver
PCI: Add new ID for Intel GPU "spurious interrupt" quirk
PCI: Update my email address
PCI: Fix incorrect vgaarb conditional in WARN_ON()
PCI: Use designated initialization in PCI_VDEVICE
PCI: Remove old serial device IDs
PCI: Remove unnecessary includes of <linux/init.h>
powerpc/PCI: Fix NULL dereference in sys_pciconfig_iobase() list traversal
Today the PCIe port bus driver disables the Hot-plug service if the port
device does not have the capability to generate interrupts. However, a
user must be able to use the "pciehp_poll_mode" parameter to use the pciehp
in polling method in such a case. Today it is not possible.
This patch allows a hotplug service driver to decide whether or not it
would like to continue in the absence of interrupts.
Signed-off-by: Rajat Jain <rajatxjain@gmail.com>
Signed-off-by: Rajat Jain <rajatjain@juniper.net>
Signed-off-by: Guenter Roeck <groeck@juniper.net>
As result of deprecation of MSI-X/MSI enablement functions
pci_enable_msix() and pci_enable_msi_block() all drivers using these two
interfaces need to be updated to use the new pci_enable_msi_range() or
pci_enable_msi_exact() and pci_enable_msix_range() or
pci_enable_msix_exact() interfaces.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
* pci/dead-code:
PCI: Make local functions static
PCI: Remove unused alloc_pci_dev()
PCI: Remove unused pci_renumber_slot()
PCI: Remove unused pcie_aspm_enabled()
PCI: Remove unused pci_vpd_truncate()
PCI: Remove unused ID-Based Ordering support
PCI: Remove unused Optimized Buffer Flush/Fill support
PCI: Remove unused Latency Tolerance Reporting support
PCI: Removed unused parts of Page Request Interface support
drivers/pci/pci.c
include/linux/pci.h
* pci/aer:
PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0
ACPICA: Add helper macros to extract bus/segment numbers from HEST table.
In the discussion for this set of patches [link below], Bjorn Helgaas
pointed out that the ACPI HEST AER error sources do not have the PCIe
segment number associated with the bus. I worked with the ACPI spec and
got this change to definition of the "Bus" field into the recently released
ACPI Spec 5.0a section 18.3.2.3-5:
Identifies the PCI Bus and Segment of the device. The Bus is encoded in
bits 0-7. For systems that expose multiple PCI segment groups, the
segment number is encoded in bits 8-23 and bits 24-31 must be zero. For
systems that do not expose multiple PCI segment groups, bits 8-31 must be
zero. If the GLOBAL flag is specified, this field is ignored.
This patch makes use of the new definition in the only place in the kernel
that uses the acpi_hest_aer_common's bus field.
This depends on 36f3615152c1 ("ACPICA: Add helper macros to extract
bus/segment numbers from HEST table.")
Link: http://lkml.kernel.org/r/1370542251-27387-1-git-send-email-betty.dall@hp.com
Signed-off-by: Betty Dall <betty.dall@hp.com>
My philosophy is unused code is dead code. And dead code is subject to bit
rot and is a likely source of bugs. Use it or lose it.
This reverts part of 3e1b16002af2 ("ACPI/PCI: PCIe ASPM _OSC support
capabilities called when root bridge added"), removing this interface:
pcie_aspm_enabled()
[bhelgaas: split to separate patch]
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
CC: Andrew Patterson <andrew.patterson@hp.com>
* pci/msi:
PCI/MSI: Add pci_enable_msi_range() and pci_enable_msix_range()
PCI/MSI: Add pci_msix_vec_count()
PCI/MSI: Remove pci_enable_msi_block_auto()
PCI/MSI: Add pci_msi_vec_count()
This creates an MSI-X counterpart for pci_msi_vec_count(). Device drivers
can use this function to obtain maximum number of MSI-X interrupts the
device supports and use that number in a subsequent call to
pci_enable_msix().
pci_msix_vec_count() supersedes pci_msix_table_size() and returns a
negative errno if device does not support MSI-X interrupts. After this
update, callers must always check the returned value.
The only user of pci_msix_table_size() was the PCI-Express port driver,
which is also updated by this change.
Reviewed-by: Tejun Heo <tj@kernel.org>
* pci/deletion:
PCI/portdrv: Remove extra get_device()/put_device() for pcie_device
PCI/portdrv: Add put_device() after device_register() failure
PCI/portdrv: Cleanup error paths
Previously pcie_device_init() called get_device() if device_register() for
the new pcie_device succeeded, and remove_iter() called put_device() when
removing before unregistering the device.
But device_register() already increments the reference count in
device_add(), so we don't need to do it again here.
This is required so that we give up the last reference to the device.
Removed the kfree() as put_device will result in release_pcie_device()
being called and hence the container of the device will be kfree'd.
[bhelgaas: fix conflict after my previous cleanup]
Signed-off-by: Levente Kurusa <levex@linux.com>
Make the straightline path the normal no-error path. Check for errors and
return them directly, instead of checking for success and putting the
normal path in an "if" body.
* pci/aer:
PCI/AER: Consolidate HEST error source parsers
PCI/AER: Ignore non-PCIe AER error sources in aer_hest_parse()
PCI/AER: Clean up error printing code a bit
aer_hest_parse() and aer_hest_parse_aff() are almost identical. We use
aer_hest_parse() to check the ACPI_HEST_FIRMWARE_FIRST flag for a specific
device, and we use aer_hest_parse_aff() to check to see if any device sets
the flag.
This drops aer_hest_parse_aff() and enhances aer_hest_parse() so it
collects the union of the PCIe ACPI_HEST_FIRMWARE_FIRST flag settings when
no specific device is supplied.
Reviewed-by: Betty Dall <betty.dall@hp.com>
aer_set_firmware_first() searches the HEST for an error source descriptor
matching the specified PCI device. It uses the apei_hest_parse() iterator
to call aer_hest_parse() for every descriptor in the HEST.
Previously, aer_hest_parse() incorrectly assumed every descriptor was for a
PCIe error source. This patch adds a check to avoid that error.
[bhelgaas: factor check into helper, use in aer_hest_parse_aff(), changelog]
Save one indentation level in aer_print_error() for the generic case where
we have info->status of an error, disregard 80 cols rule a bit for the sake
of better readability, fix alignment.
No functionality change.
... and call it instead of duplicating the large printk format
statement.
device_driver.name is "const char *"
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Miscellaneous
- Remove duplicate disable from pcie_portdrv_remove() (Yinghai Lu)
- Fix whitespace, capitalization, and spelling errors (Bjorn Helgaas)"
* tag 'pci-v3.13-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
PCI: Fix whitespace, capitalization, and spelling errors
The pcie_portdrv .probe() method calls pci_enable_device() once, in
pcie_port_device_register(), but the .remove() method calls
pci_disable_device() twice, in pcie_port_device_remove() and in
pcie_portdrv_remove().
That causes a "disabling already-disabled device" warning when removing a
PCIe port device. This happens all the time when removing Thunderbolt
devices, but is also easy to reproduce with, e.g.,
"echo 0000:00:1c.3 > /sys/bus/pci/drivers/pcieport/unbind"
This patch removes the disable from pcie_portdrv_remove().
[bhelgaas: changelog, tag for stable]
Reported-by: David Bulkow <David.Bulkow@stratus.com>
Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
CC: stable@vger.kernel.org # v2.6.32+
This patch enhances the type safety for the kfifo API. It is now safe
to put const data into a non const FIFO and the API will now generate a
compiler warning when reading from the fifo where the destination
address is pointing to a const variable.
As a side effect the kfifo_put() does now expect the value of an element
instead a pointer to the element. This was suggested Russell King. It
make the handling of the kfifo_put easier since there is no need to
create a helper variable for getting the address of a pointer or to pass
integers of different sizes.
IMHO the API break is okay, since there are currently only six users of
kfifo_put().
The code is also cleaner by kicking out the "if (0)" expressions.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Fix whitespace, capitalization, and spelling errors. No functional change.
I know "busses" is not an error, but "buses" was more common, so I used it
consistently.
Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus())
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
The pcie_ports parameter, which defaults to 'auto', allows a user
to specify if PCIe port services are disabled ('compat'), always
enabled ('native'), or only used when allowed by the BIOS
('auto').
Where CONFIG_ACPI isn't enabled, as is often the case for non
x86/ia64 platforms, the 'auto' behavior results in that of
'compat'. Thus in order to use port services on these platforms
'pcie_ports=native' must be added to the kernel command line.
This patch results in the 'native' behavior being followed where
'auto' is selected and ACPI is not enabled.
Signed-off-by: Andrew Murray <amurray@embedded-bits.co.uk>
Pull PCI changes from Bjorn Helgaas:
PCI device hotplug:
- Use PCIe native hotplug, not ACPI hotplug, when possible (Neil Horman)
- Assign resources on per-host bridge basis (Yinghai Lu)
MPS (Max Payload Size):
- Allow larger MPS settings below hotplug-capable Root Port (Yijing Wang)
- Add warnings about unsafe MPS settings (Yijing Wang)
- Simplify interface and messages (Bjorn Helgaas)
SR-IOV:
- Return -ENOSYS on non-SR-IOV devices (Stefan Assmann)
- Update NumVFs register when disabling SR-IOV (Yijing Wang)
Virtualization:
- Add bus and slot reset support (Alex Williamson)
- Fix ACS (Access Control Services) issues (Alex Williamson)
Miscellaneous:
- Simplify PCIe Capability accessors (Bjorn Helgaas)
- Add pcibios_pm_ops for arch-specific hibernate stuff (Sebastian Ott)
- Disable decoding during BAR sizing only when necessary (Zoltan Kiss)
- Delay enabling bridges until they're needed (Yinghai Lu)
- Split Designware support into Synopsys and Exynos parts (Jingoo Han)
- Convert class code to use dev_groups (Greg Kroah-Hartman)
- Cleanup Designware and Exynos I/O access wrappers (Seungwon Jeon)
- Fix bridge I/O window alignment (Bjorn Helgaas)
- Add pci_wait_for_pending_transaction() (Casey Leedom)
- Use devm_ioremap_resource() in Marvell driver (Tushar Behera)
* tag 'pci-v3.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits)
PCI/ACPI: Fix _OSC ordering to allow PCIe hotplug use when available
PCI: exynos: Add I/O access wrappers
PCI: designware: Drop "addr" arg from dw_pcie_readl_rc()/dw_pcie_writel_rc()
PCI: Remove pcie_cap_has_devctl()
PCI: Support PCIe Capability Slot registers only for ports with slots
PCI: Remove PCIe Capability version checks
PCI: Allow PCIe Capability link-related register access for switches
PCI: Add offsets of PCIe capability registers
PCI: Tidy bitmasks and spacing of PCIe capability definitions
PCI: Remove obsolete comment reference to pci_pcie_cap2()
PCI: Clarify PCI_EXP_TYPE_PCI_BRIDGE comment
PCI: Rename PCIe capability definitions to follow convention
PCI: Warn if unsafe MPS settings detected
PCI: Fix MPS peer-to-peer DMA comment syntax
PCI: Disable decoding for BAR sizing only when it was actually enabled
PCI: Add comment about needing pci_msi_off() even when CONFIG_PCI_MSI=n
PCI: Add pcibios_pm_ops for optional arch-specific hibernate functionality
PCI: Don't restrict MPS for slots below Root Ports
PCI: Simplify MPS test for Downstream Port
PCI: Remove unnecessary check for pcie_get_mps() failure
* pci/aw-reset-v5:
PCI: Add pci_probe_reset_slot() and pci_probe_reset_bus()
PCI: Remove aer_do_secondary_bus_reset()
PCI: Tune secondary bus reset timing
PCI: Wake-up devices before saving config space for reset
PCI: Add pci_reset_slot() and pci_reset_bus()
PCI: Split out pci_dev lock/unlock and save/restore
PCI: Add slot reset option to pci_dev_reset()
PCI: pciehp: Add reset_slot() method
PCI: Add hotplug_slot_ops.reset_slot()
PCI: Add pci_reset_bridge_secondary_bus()
One PCI bus reset function to rule them all.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Convert pciehp to be builtin only, with no module option.
Acked-by: Yinghai Lu <yinghai@kernel.org>
The previous option title "PCI Express support" is confusing. The name
seems to imply this option is required to get PCIe support, which is not
true.
Fix it to "PCI Express Port Bus support" which is more accurate.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
"PCI device hotplug
- Add pci_alloc_dev() interface (Gu Zheng)
- Add pci_bus_get()/put() for reference counting (Jiang Liu)
- Fix SR-IOV reference count issues (Jiang Liu)
- Remove unused acpi_pci_roots list (Jiang Liu)
MSI
- Conserve interrupt resources on x86 (Alexander Gordeev)
AER
- Force fatal severity when component has been reset (Betty Dall)
- Reset link below Root Port as well as Downstream Port (Betty Dall)
- Fix "Firmware first" flag setting (Bjorn Helgaas)
- Don't parse HEST for non-PCIe devices (Bjorn Helgaas)
ASPM
- Warn when we can't disable ASPM as driver requests (Bjorn Helgaas)
Miscellaneous
- Add CircuitCo PCI IDs (Darren Hart)
- Add AMD CZ SATA and SMBus PCI IDs (Shane Huang)
- Work around Ivytown NTB BAR size issue (Jon Mason)
- Detect invalid initial BAR values (Kevin Hao)
- Add pcibios_release_device() (Sebastian Ott)
- Fix powerpc & sparc PCI_UNKNOWN power state usage (Bjorn Helgaas)"
* tag 'pci-v3.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci
PCI: Add CircuitCo vendor ID and subsystem ID
PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
PCI: Return early on allocation failures to unindent mainline code
PCI: Simplify IOV implementation and fix reference count races
PCI: Drop redundant setting of bus->is_added in virtfn_add_bus()
unicore32/PCI: Remove redundant call of pci_bus_add_devices()
m68k/PCI: Remove redundant call of pci_bus_add_devices()
PCI / ACPI / PM: Use correct power state strings in messages
PCI: Fix comment typo for pcie_pme_remove()
PCI: Rename pci_release_bus_bridge_dev() to pci_release_host_bridge_dev()
PCI: Fix refcount issue in pci_create_root_bus() error recovery path
ia64/PCI: Clean up pci_scan_root_bus() usage
PCI/AER: Reset link for devices below Root Port or Downstream Port
ACPI / APEI: Force fatal AER severity when component has been reset
PCI/AER: Remove "extern" from function declarations
PCI/AER: Move AER severity defines to aer.h
PCI/AER: Set dev->__aer_firmware_first only for matching devices
PCI/AER: Factor out HEST device type matching
PCI/AER: Don't parse HEST table for non-PCIe devices
* pci/misc:
PCI: Add pcibios_release_device()
Fix trivial comment typo for pcie_pme_remove().
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
* pci/betty-aer-v3:
When a PCIe device reports a fatal error, we reset the link leading
to it. Previously we only did this for devices below Downstream Ports,
not for devices directly below Root Ports.
This patch changes that so we reset the link leading to devices below
Root Ports just like we do for those below Downstream Ports.
[bhelgaas: changelog, keep dev_printk(KERN_DEBUG)]
