path: root/drivers/pci/remove.c
2008-04-20PCI: add PCI Express ASPM supportShaohua Li
PCI Express ASPM defines a protocol for PCI Express components in the D0 state to reduce Link power by placing their Links into a low power state and instructing the other end of the Link to do likewise. This capability allows hardware-autonomous, dynamic Link power reduction beyond what is achievable by software-only controlled power management. However, The device should be configured by software appropriately. Enabling ASPM will save power, but will introduce device latency. This patch adds ASPM support in Linux. It introduces a global policy for ASPM, a sysfs file /sys/module/pcie_aspm/parameters/policy can control it. The interface can be used as a boot option too. Currently we have below setting: -default, BIOS default setting -powersave, highest power saving mode, enable all available ASPM state and clock power management -performance, highest performance, disable ASPM and clock power management By default, the 'default' policy is used currently. In my test, power difference between powersave mode and performance mode is about 1.3w in a system with 3 PCIE links. Note: some devices might not work well with aspm, either because chipset issue or device issue. The patch provide API (pci_disable_link_state), driver can disable ASPM for specific device. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: remove global list of PCI devicesGreg Kroah-Hartman
This patch finally removes the global list of PCI devices. We are relying entirely on the list held in the driver core now, and do not need a separate "shadow" list as no one uses it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: add is_added flag to struct pci_devGreg Kroah-Hartman
This lets us check if the device is really added to the driver core or not, which is what we need when walking some of the bus lists. The flag is there in anticipation of getting rid of the other PCI device list, which is what we used to check in this situation. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-02Revert "PCI: PCIE ASPM support"Greg Kroah-Hartman
This reverts commit 6c723d5bd89f03fc3ef627d50f89ade054d2ee3b. It caused build errors on non-x86 platforms, config file confusion, and even some boot errors on some x86-64 boxes. All around, not quite ready for prime-time :( Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: make pci_bus a struct deviceGreg Kroah-Hartman
This moves the pci_bus class device to be a real struct device and at the same time, place it in the device tree in the correct location. Note, the old "bridge" symlink is now gone, but this was a non-standard link and no userspace program used it. If you need to determine the device that the bus is on, follow the standard device symlink, or walk up the device tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: PCIE ASPM supportShaohua Li
PCI Express ASPM defines a protocol for PCI Express components in the D0 state to reduce Link power by placing their Links into a low power state and instructing the other end of the Link to do likewise. This capability allows hardware-autonomous, dynamic Link power reduction beyond what is achievable by software-only controlled power management. However, The device should be configured by software appropriately. Enabling ASPM will save power, but will introduce device latency. This patch adds ASPM support in Linux. It introduces a global policy for ASPM, a sysfs file /sys/module/pcie_aspm/parameters/policy can control it. The interface can be used as a boot option too. Currently we have below setting: -default, BIOS default setting -powersave, highest power saving mode, enable all available ASPM state and clock power management -performance, highest performance, disable ASPM and clock power management By default, the 'default' policy is used currently. In my test, power difference between powersave mode and performance mode is about 1.3w in a system with 3 PCIE links. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: add pci_stop_bus_deviceSatoru Takeuchi
This patch adds pci_stop_bus_device() which stops a PCI device (detach the driver, remove from the global list and so on) and any children. This is needed for ACPI based PCI-to-PCI bridge hot-remove, and it will be also needed for ACPI based PCI root bridge hot-remove. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com> Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] PCI: fix race with pci_walk_bus and pci_destroy_devZhang Yanmin
pci_walk_bus has a race with pci_destroy_dev. When cb is called in pci_walk_bus, pci_destroy_dev might unlink the dev pointed by next. Later on in the next loop, pointer next becomes NULL and cause kernel panic. Below patch against 2.6.17-rc4 fixes it by changing pci_bus_lock (spin_lock) to pci_bus_sem (rw_semaphore). Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: drivers/pci: some cleanupsAdrian Bunk
This patch contains the following cleanups: - hotplug/pciehp_core.c: make the needlessly global hpdriver_context static - #if 0 the following unused functions: - pci.c: pci_bus_max_busnr() - pci.c: pci_max_busnr() - proc.c: pci_proc_attach_bus() - remove.c: pci_remove_device_safe Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] acpi bridge hotadd: Make the PCI remove routines safe for failed ↵Rajesh Shah
hot-plug When a root bridge hierarchy is hot-plugged, resource requirements for the new devices may be greater than what the root bridge is decoding. In this case, we want to remove devices that did not get needed resources. These devices have been scanned into bus specific lists but not yet added to the global device list. Make sure the pci remove functions can handle this case. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
