path: root/drivers/pci/rom.c
2011-10-31pci: Fix files needing export.h for EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
They were implicitly getting it from device.h --> module.h but we want to clean that up. So add the minimal header for these macros. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-02-13PCI: fix rom.c kernel-doc warningRandy Dunlap
Fix PCI kernel-doc warning: Warning(linux-2.6.29-rc4-git1/drivers/pci/rom.c:67): No description found for parameter 'pdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-11-03PCI: remove excess kernel-doc notationRandy Dunlap
Fix pci/rom.c kernel-doc function notation: Warning(drivers/pci/rom.c:110): Excess function parameter or struct member 'return' description in 'pci_map_rom' Warning(drivers/pci/rom.c:177): Excess function parameter or struct member 'return' description in 'pci_map_rom_copy' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-09-26Export the ROM enable/disable helpersAlan Cox
.... so that they can be used by MTD map drivers. Lets us close #9420 Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-03-03docbook: fix kernel-api source filesRandy Dunlap
Fix docbook problems in kernel-api.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01PCI: drivers/pci/rom.c: #if 0 two functionsAdrian Bunk
This patch #if 0's the following unused global functions: - rom.c: pci_map_rom_copy() - rom.c: pci_remove_rom() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-09[IA64] SN: Correct ROM resource length for BIOS copyJohn Keller
On SN systems, when setting the IORESOURCE_ROM_BIOS_COPY resource flag, the resource length should be set to the actual size of the ROM image so that a call to pci_map_rom() returns the correct size. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-01Altix: Initial ACPI support - ROM shadowing.John Keller
Support a shadowed ROM when running with an ACPI capable PROM. Define a new dev.resource flag IORESOURCE_ROM_BIOS_COPY to describe the case of a BIOS shadowed ROM, which can then be used to avoid pci_map_rom() making an unneeded call to pci_enable_rom(). Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-27PCI: fix pci_fixup_video as it blows up on sparc64Eiichiro Oiwa
This reverts much of the original pci_fixup_video change and makes it work for all arches that need it. fixed, and tested on x86, x86_64 and IA64 dig. Signed-off-by: Eiichiro Oiwa <eiichiro.oiwa.nm@hitachi.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18PCI: Turn pci_fixup_video into generic for embedded VGAeiichiro.oiwa.nm@hitachi.com
pci_fixup_video turns into generic code because there are many platforms need this fixup for embedded VGA as well as x86. The Video BIOS integrates into System BIOS on a machine has embedded VGA although embedded VGA generally don't have PCI ROM. As a result, embedded VGA need the way that the sysfs rom points to the Video BIOS of System RAM (0xC0000). PCI-to-PCI Bridge Architecture specification describes the condition whether or not PCI ROM forwards VGA compatible memory address. fixup_video suits this specification. Although the Video ROM generally implements in x86 code regardless of platform, some application such as X Window System can run this code by dosemu86. Therefore, pci_fixup_video should turn into generic code. Signed-off-by: Eiichiro Oiwa <eiichiro.oiwa.nm@hitachi.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: change pci core and arch code to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[PATCH] Fix PCI ROM mappingBenjamin Herrenschmidt
This fixes a problem with pci_map_rom() which doesn't properly update the ROM BAR value with the address thas allocated for it by the PCI code. This problem, among other, breaks boot on Mac laptops. It'ss a new version based on Linus latest one with better error checking. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] PCI: Adjust PCI rom code to handle more broken ROMsJon Smirl
There are ROMs reporting that their size exceeds their PCI ROM resource window. This patch returns the minimum of the resource window size or the size in the ROM. An example of this breakage is the XGI Volari Z7. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
