path: root/drivers/pci/setup-bus.c
2015-06-01PCI: Preserve resource size during alignment reorderingYinghai Lu
In d74b9027a4da ("PCI: Consider additional PF's IOV BAR alignment in sizing and assigning"), we store additional alignment in realloc_head and take this into consideration for assignment. In __assign_resources_sorted(), we changed dev_res->res->start, then used resource_start() (which depends on res->start), so the recomputed res->end was completely bogus. Even if we'd had the correct size, the end would have been off by one. Preserve the resource size when we adjust its alignment. [bhelgaas: changelog] Fixes: d74b9027a4da ("PCI: Consider additional PF's IOV BAR alignment in sizing and assigning") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Wei Yang <weiyang@linux.vnet.ibm.com> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-05-27PCI: Fix IOV resource sorting by alignment requirementWei Yang
In d74b9027a4da ("PCI: Consider additional PF's IOV BAR alignment in sizing and assigning"), it stores additional alignment in realloc_head and takes this into consideration for assignment. After getting the additional alignment, it reorders the head list so resources with bigger alignment are ahead of resources with smaller alignment. It does this by iterating over the head list and inserting ahead of any resource with smaller alignment. This should be done for the first occurrence, but the code currently iterates over the whole list. Fix this by terminating the loop when we find the first smaller resource in the head list. [bhelgaas: changelog] Fixes: d74b9027a4da ("PCI: Consider additional PF's IOV BAR alignment in sizing and assigning") Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-04-16Merge tag 'powerpc-4.1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - Numerous minor fixes, cleanups etc. - More EEH work from Gavin to remove its dependency on device_nodes. - Memory hotplug implemented entirely in the kernel from Nathan Fontenot. - Removal of redundant CONFIG_PPC_OF by Kevin Hao. - Rewrite of VPHN parsing logic & tests from Greg Kurz. - A fix from Nish Aravamudan to reduce memory usage by clamping nodes_possible_map. - Support for pstore on powernv from Hari Bathini. - Removal of old powerpc specific byte swap routines by David Gibson. - Fix from Vasant Hegde to prevent the flash driver telling you it was flashing your firmware when it wasn't. - Patch from Ben Herrenschmidt to add an OPAL heartbeat driver. - Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan Stancek. - Some fixes for migration from Tyrel Datwyler. - A new syscall to switch the cpu endian by Michael Ellerman. - Large series from Wei Yang to implement SRIOV, reviewed and acked by Bjorn. - A fix for the OPAL sensor driver from Cédric Le Goater. - Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman. - Large series from Daniel Axtens to make our PCI hooks per PHB rather than per machine. - Small patch from Sam Bobroff to explicitly abort non-suspended transactions on syscalls, plus a test to exercise it. - Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu. - Small patch to enable the hard lockup detector from Anton Blanchard. - Fix from Dave Olson for missing L2 cache information on some CPUs. - Some fixes from Michael Ellerman to get Cell machines booting again. - Freescale updates from Scott: Highlights include BMan device tree nodes, an MSI erratum workaround, a couple minor performance improvements, config updates, and misc fixes/cleanup. * tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits) powerpc/powermac: Fix build error seen with powermac smp builds powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE powerpc: Remove PPC32 code from pseries specific find_and_init_phbs() powerpc/cell: Fix iommu breakage caused by controller_ops change powerpc/eeh: Fix crash in eeh_add_device_early() on Cell powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails powerpc/pseries: Correct memory hotplug locking powerpc: Fix missing L2 cache size in /sys/devices/system/cpu powerpc: Add ppc64 hard lockup detector support oprofile: Disable oprofile NMI timer on ppc64 powerpc/perf/hv-24x7: Add missing put_cpu_var() powerpc/perf/hv-24x7: Break up single_24x7_request powerpc/perf/hv-24x7: Define update_event_count() powerpc/perf/hv-24x7: Whitespace cleanup powerpc/perf/hv-24x7: Define add_event_to_24x7_request() powerpc/perf/hv-24x7: Rename hv_24x7_event_update powerpc/perf/hv-24x7: Move debug prints to separate function powerpc/perf/hv-24x7: Drop event_24x7_request() powerpc/perf/hv-24x7: Use pr_devel() to log message ... Conflicts: tools/testing/selftests/powerpc/Makefile tools/testing/selftests/powerpc/tm/Makefile
2015-04-08PCI: Export symbols required for loadable host driver modulesRay Jui
Export the following symbols so they can be referenced by a PCI host bridge driver compiled as a kernel loadable module: pci_common_swizzle pci_create_root_bus pci_stop_root_bus pci_remove_root_bus pci_assign_unassigned_bus_resources pci_fixup_irqs Signed-off-by: Ray Jui <rjui@broadcom.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2015-03-31PCI: Consider additional PF's IOV BAR alignment in sizing and assigningWei Yang
When sizing and assigning resources, we divide the resources into two lists: the requested list and the additional list. We don't consider the alignment of additional VF(n) BAR space. This is because the alignment required for the VF(n) BAR space is the size of an individual VF BAR, not the size of the space for *all* VFs. But we want additional alignment to support partitioning on PowerNV. Consider the additional IOV BAR alignment when sizing and assigning resources. When there is not enough system MMIO space to accomodate both the requested list and the additional list, the PF's IOV BAR alignment will not contribute to the bridge. When there is enough system MMIO space for both lists, the additional alignment will contribute to the bridge. The additional alignment is stored in the min_align of pci_dev_resource, which is stored in the additional list by add_to_list() at the end of pbus_size_mem(). The additional alignment is calculated in pci_resource_alignment(). For an IOV BAR, we have arch dependent function to get the alignment for different arch. [bhelgaas: changelog, printk cast] Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-01-16PCI: Add pci_claim_bridge_resource() to clip window if necessaryYinghai Lu
Add pci_claim_bridge_resource() to claim a PCI-PCI bridge window. This is like regular pci_claim_resource(), except that if we fail to claim the window, we check to see if we can reduce the size of the window and try again. This is for scenarios like this: pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff] pci 0000:00:01.0: bridge window [mem 0xbdf00000-0xddefffff 64bit pref] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff pref] The 00:01.0 window is illegal: it starts before the host bridge window, so we have to assume the [0xbdf00000-0xbfffffff] region is inaccessible. We can make it legal by clipping it to [mem 0xc0000000-0xddefffff 64bit pref]. Previously we discarded the 00:01.0 window and tried to reassign that part of the hierarchy from scratch. That is a problem because Linux doesn't always assign things optimally. For example, in this case, BIOS put the 01:00.0 device in a prefetchable window below 4GB, but after 5b28541552ef, Linux puts the prefetchable window above 4GB where the 32-bit 01:00.0 device can't use it. Clipping the 00:01.0 window is less intrusive than completely reassigning things and is sufficient to let us use most of the BIOS configuration. Of course, it's possible that devices below 00:01.0 will no longer fit. If that's the case, we'll have to reassign things. But that's a separate problem. [bhelgaas: changelog, split into separate patch] Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491 Reported-by: Marek Kordik <kordikmarek@gmail.com> Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.16+
2015-01-16PCI: Pass bridge device, not bus, when updating bridge windowsYinghai Lu
pci_setup_bridge_io(), pci_setup_bridge_mmio(), and pci_setup_bridge_mmio_pref() program the windows of PCI-PCI bridges. Previously they accepted a pointer to the pci_bus of the secondary bus, then looked up the bridge leading to that bus. Pass the bridge directly, which will make it more convenient for future callers. No functional change. [bhelgaas: changelog, split into separate patch] Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491 Reported-by: Marek Kordik <kordikmarek@gmail.com> Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.16+
2014-09-30PCI: Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources()Yinghai Lu
In 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources"), we added IORESOURCE_MEM_64 to the mask in pci_assign_unassigned_root_bus_resources(), but not to the mask in pci_assign_unassigned_bridge_resources(). Add IORESOURCE_MEM_64 to the pci_assign_unassigned_bridge_resources() type mask. Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.16+
2014-07-08PCI: Support BAR sizes up to 128GBYinghai Lu
Increase the maximum BAR size from 8GB to 128GB. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-10PCI: Merge multi-line quoted stringsRyan Desfosses
Merge quoted strings that are broken across lines into a single entity. The compiler merges them anyway, but checkpatch complains about it, and merging them makes it easier to grep for strings. No functional change. [bhelgaas: changelog, do the same for everything under drivers/pci] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-10PCI: Whitespace cleanupRyan Desfosses
Fix various whitespace errors. No functional change. [bhelgaas: fix other similar problems] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-28Merge branches 'pci/hotplug', 'pci/pci_is_bridge' and 'pci/virtualization' ↵Bjorn Helgaas
into next * pci/hotplug: PCI: cpqphp: Fix possible null pointer dereference NVMe: Implement PCIe reset notification callback PCI: Notify driver before and after device reset * pci/pci_is_bridge: pcmcia: Use pci_is_bridge() to simplify code PCI: pciehp: Use pci_is_bridge() to simplify code PCI: acpiphp: Use pci_is_bridge() to simplify code PCI: cpcihp: Use pci_is_bridge() to simplify code PCI: shpchp: Use pci_is_bridge() to simplify code PCI: rpaphp: Use pci_is_bridge() to simplify code sparc/PCI: Use pci_is_bridge() to simplify code powerpc/PCI: Use pci_is_bridge() to simplify code ia64/PCI: Use pci_is_bridge() to simplify code x86/PCI: Use pci_is_bridge() to simplify code PCI: Use pci_is_bridge() to simplify code PCI: Add new pci_is_bridge() interface PCI: Rename pci_is_bridge() to pci_has_subordinate() * pci/virtualization: PCI: Introduce new device binding path using pci_dev.driver_override Conflicts: drivers/pci/pci-sysfs.c
2014-05-27PCI: Use pci_is_bridge() to simplify codeYijing Wang
Use pci_is_bridge() to simplify code. No functional change. Requires: 326c1cdae741 PCI: Rename pci_is_bridge() to pci_has_subordinate() Requires: 1c86438c9423 PCI: Add new pci_is_bridge() interface Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-26Merge branches 'dma-api', 'pci/virtualization', 'pci/msi', 'pci/misc' and ↵Bjorn Helgaas
'pci/resource' into next * dma-api: iommu/exynos: Remove unnecessary "&" from function pointers DMA-API: Update dma_pool_create ()and dma_pool_alloc() descriptions DMA-API: Fix duplicated word in DMA-API-HOWTO.txt DMA-API: Capitalize "CPU" consistently sh/PCI: Pass GAPSPCI_DMA_BASE CPU & bus address to dma_declare_coherent_memory() DMA-API: Change dma_declare_coherent_memory() CPU address to phys_addr_t DMA-API: Clarify physical/bus address distinction * pci/virtualization: PCI: Mark RTL8110SC INTx masking as broken * pci/msi: PCI/MSI: Remove pci_enable_msi_block() * pci/misc: PCI: Remove pcibios_add_platform_entries() s390/pci: use pdev->dev.groups for attribute creation PCI: Move Open Firmware devspec attribute to PCI common code * pci/resource: PCI: Add resource allocation comments PCI: Simplify __pci_assign_resource() coding style PCI: Change pbus_size_mem() return values to be more conventional PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources PCI: Support BAR sizes up to 8GB resources: Clarify sanity check message PCI: Don't add disabled subtractive decode bus resources PCI: Don't print anything while decoding is disabled PCI: Don't set BAR to zero if dma_addr_t is too small PCI: Don't convert BAR address to resource if dma_addr_t is too small PCI: Reject BAR above 4GB if dma_addr_t is too small PCI: Fail safely if we can't handle BARs larger than 4GB x86/gart: Tidy messages and add bridge device info x86/gart: Replace printk() with pr_info() x86/PCI: Move pcibios_assign_resources() annotation to definition x86/PCI: Mark ATI SBx00 HPET BAR as IORESOURCE_PCI_FIXED x86/PCI: Don't try to move IORESOURCE_PCI_FIXED resources x86/PCI: Fix Broadcom CNB20LE unintended sign extension
2014-05-23PCI: Add resource allocation commentsBjorn Helgaas
Add comments in the code to match the allocation strategy of 7c671426dfc3 ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources"). No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-23PCI: Change pbus_size_mem() return values to be more conventionalBjorn Helgaas
pbus_size_mem() previously returned 0 for failure and 1 for success. Change it to return -ENOSPC for failure and 0 for success. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-23PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resourcesYinghai Lu
This patch changes the way we handle 64-bit prefetchable bridge windows to make it more likely that we can assign space to all devices. Previously we put all prefetchable resources in the prefetchable bridge window. If any of those resources was 32-bit only, we restricted the window to be below 4GB. After this patch, we only put 64-bit prefetchable resources in a 64-bit prefetchable window. We put all 32-bit prefetchable resources in the non-prefetchable window, even if there are no 64-bit prefetchable resources. With the previous approach, if there was a 32-bit prefetchable resource behind a bridge, we forced the bridge's prefetchable window below 4GB, which meant that even if there was plenty of space above 4GB available, we couldn't use it, and assignment of large 64-bit resources could fail, as in the bugzilla below. The new strategy is: 1) If the prefetchable window is 64 bits wide, we put only 64-bit prefetchable resources in it. Any 32-bit prefetchable resources go in the non-prefetchable window. 2) If the prefetchable window is 32 bits wide, we put both 32- and 64-bit prefetchable resources in it. 3) If there is no prefetchable window, all MMIO resources go in the non-prefetchable window. This reduces performance for 32-bit prefetchable resources below a bridge with a 64-bit prefetchable window. We previously assigned prefetchable space, but now we'll assign non-prefetchable space. This is the case even if there are no 64-bit prefetchable resources, or if they would all fit below 4GB. In those cases, the old strategy would work and would have better performance. [bhelgaas: write changelog, add bugzilla link, fold in mem64_mask removal] Link: https://bugzilla.kernel.org/show_bug.cgi?id=74151 Tested-by: Guo Chao <yan@linux.vnet.ibm.com> Tested-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-23PCI: Support BAR sizes up to 8GBAlan
This is needed for some of the Xeon Phi type systems. [bhelgaas: added Nikhil, use ARRAY_SIZE() to connect with decl, folded in Kevin's "order < 0" fix to ARRAY_SIZE() usage] Signed-off-by: Nikhil P Rao <nikhil.rao@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-04-29PCI: Remove unnecessary __ref annotationsBjorn Helgaas
Some PCI functions used to be marked __devinit. When CONFIG_HOTPLUG was not set, these functions were discarded after boot. A few callers of these __devinit functions were marked __ref to indicate that they could safely call the __devinit functions even though the callers were not __devinit. But CONFIG_HOTPLUG and __devinit are now gone, and the need for the __ref annotations is also gone, so remove them. Relevant historical commits: 54b956b90360 Remove __dev* markings from init.h a8e4b9c101ae PCI: add generic pci_hp_add_bridge() 0ab2b57f8db8 PCI: fix section mismatch warning in pci_scan_child_bus 451124a7cc6c PCI: fix 4x section mismatch warnings Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-01-10Merge branch 'pci/resource' into nextBjorn Helgaas
* pci/resource: PCI: Allocate 64-bit BARs above 4G when possible PCI: Enforce bus address limits in resource allocation PCI: Split out bridge window override of minimum allocation address agp/ati: Use PCI_COMMAND instead of hard-coded 4 agp/intel: Use CPU physical address, not bus address, for ioremap() agp/intel: Use pci_bus_address() to get GTTADR bus address agp/intel: Use pci_bus_address() to get MMADR bus address agp/intel: Support 64-bit GMADR agp/intel: Rename gtt_bus_addr to gtt_phys_addr drm/i915: Rename gtt_bus_addr to gtt_phys_addr agp: Use pci_resource_start() to get CPU physical address for BAR agp: Support 64-bit APBASE PCI: Add pci_bus_address() to get bus address of a BAR PCI: Convert pcibios_resource_to_bus() to take a pci_bus, not a pci_dev PCI: Change pci_bus_region addresses to dma_addr_t
2013-12-21PCI: Convert pcibios_resource_to_bus() to take a pci_bus, not a pci_devYinghai Lu
These interfaces: pcibios_resource_to_bus(struct pci_dev *dev, *bus_region, *resource) pcibios_bus_to_resource(struct pci_dev *dev, *resource, *bus_region) took a pci_dev, but they really depend only on the pci_bus. And we want to use them in resource allocation paths where we have the bus but not a device, so this patch converts them to take the pci_bus instead of the pci_dev: pcibios_resource_to_bus(struct pci_bus *bus, *bus_region, *resource) pcibios_bus_to_resource(struct pci_bus *bus, *resource, *bus_region) In fact, with standard PCI-PCI bridges, they only depend on the host bridge, because that's the only place address translation occurs, but we aren't going that far yet. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-13PCI: Stop clearing bridge Secondary Status when setting up I/O apertureBjorn Helgaas
pci_setup_bridge_io() accessed PCI_IO_BASE and PCI_IO_LIMIT using dword (32-bit) reads and writes, which also access the Secondary Status register. Since the Secondary Status register is in the upper 16 bits of the dword, and we preserved those upper 16 bits, this had the effect of clearing any of the write-1-to-clear bits that happened to be set in the Secondary Status register. That's not what we want, so use word (16-bit) accesses to update only PCI_IO_BASE and PCI_IO_LIMIT. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-13PCI: Prevent bus conflicts while checking for bridge aperturesBjorn Helgaas
pci_bridge_check_ranges() determines whether the bridge supports an I/O aperture and a prefetchable memory aperture. Previously, if the I/O aperture was unsupported, disabled, or configured at [io 0x0000-0x0fff], we wrote 0xf0 to PCI_IO_BASE and PCI_IO_LIMIT, which, if the bridge supports it, enables the I/O aperture at [io 0xf000-0xffff]. The enabled aperture may conflict with other devices in the system. Similarly, we wrote 0xfff0 to PCI_PREF_MEMORY_BASE and PCI_PREF_MEMORY_LIMIT, which enables the prefetchable memory aperture at [mem 0xfff00000-0xffffffff], and that may also conflict with other devices. All we need to know is whether the base and limit registers are writable, so we can use values that leave the apertures disabled, e.g., PCI_IO_BASE = 0xf0, PCI_IO_LIMIT = 0xe0, PCI_PREF_MEMORY_BASE = 0xfff0, PCI_PREF_MEMORY_LIMIT = 0xffe0. Writing non-zero values to both the base and limit registers means we detect whether either or both are writable, as we did before. Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Based-on-patch-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-11-14PCI: Fix whitespace, capitalization, and spelling errorsBjorn Helgaas
Fix whitespace, capitalization, and spelling errors. No functional change. I know "busses" is not an error, but "buses" was more common, so I used it consistently. Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus()) Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-25PCI: Pass type, width, and prefetchability for window alignmentWei Yang
When calculating window_alignment(), type information like IORESOURCE_MEM and IORESOURCE_PREFETCH may not be enough. For example, on powernv, we need to know whether the window is 64-bit or not. This patch passes the full resource type (res->flags) for window alignment. [bhelgaas: changelog] Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Gavin Shan <shangw@linux.vnet.ibm.com>
2013-09-25PCI: Use pci_is_root_bus() to check for root busWei Yang
In __pci_bus_size_bridges() we check whether a bus is a root bus by testing bus->self. As indicated by commit 79af72d7 ("PCI: pci_is_root_bus helper"), bus->self == NULL is not a proper way to check for a root bus. One issue is that "virtual" buses added for SR-IOV (via virtfn_add_bus()) have bus->self == NULL but are not root buses. This patch changes it to pci_is_root_bus() to check whether it is a root bus. [bhelgaas: changelog] Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-09-03Merge tag 'pci-v3.12-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: PCI device hotplug: - Use PCIe native hotplug, not ACPI hotplug, when possible (Neil Horman) - Assign resources on per-host bridge basis (Yinghai Lu) MPS (Max Payload Size): - Allow larger MPS settings below hotplug-capable Root Port (Yijing Wang) - Add warnings about unsafe MPS settings (Yijing Wang) - Simplify interface and messages (Bjorn Helgaas) SR-IOV: - Return -ENOSYS on non-SR-IOV devices (Stefan Assmann) - Update NumVFs register when disabling SR-IOV (Yijing Wang) Virtualization: - Add bus and slot reset support (Alex Williamson) - Fix ACS (Access Control Services) issues (Alex Williamson) Miscellaneous: - Simplify PCIe Capability accessors (Bjorn Helgaas) - Add pcibios_pm_ops for arch-specific hibernate stuff (Sebastian Ott) - Disable decoding during BAR sizing only when necessary (Zoltan Kiss) - Delay enabling bridges until they're needed (Yinghai Lu) - Split Designware support into Synopsys and Exynos parts (Jingoo Han) - Convert class code to use dev_groups (Greg Kroah-Hartman) - Cleanup Designware and Exynos I/O access wrappers (Seungwon Jeon) - Fix bridge I/O window alignment (Bjorn Helgaas) - Add pci_wait_for_pending_transaction() (Casey Leedom) - Use devm_ioremap_resource() in Marvell driver (Tushar Behera) * tag 'pci-v3.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits) PCI/ACPI: Fix _OSC ordering to allow PCIe hotplug use when available PCI: exynos: Add I/O access wrappers PCI: designware: Drop "addr" arg from dw_pcie_readl_rc()/dw_pcie_writel_rc() PCI: Remove pcie_cap_has_devctl() PCI: Support PCIe Capability Slot registers only for ports with slots PCI: Remove PCIe Capability version checks PCI: Allow PCIe Capability link-related register access for switches PCI: Add offsets of PCIe capability registers PCI: Tidy bitmasks and spacing of PCIe capability definitions PCI: Remove obsolete comment reference to pci_pcie_cap2() PCI: Clarify PCI_EXP_TYPE_PCI_BRIDGE comment PCI: Rename PCIe capability definitions to follow convention PCI: Warn if unsafe MPS settings detected PCI: Fix MPS peer-to-peer DMA comment syntax PCI: Disable decoding for BAR sizing only when it was actually enabled PCI: Add comment about needing pci_msi_off() even when CONFIG_PCI_MSI=n PCI: Add pcibios_pm_ops for optional arch-specific hibernate functionality PCI: Don't restrict MPS for slots below Root Ports PCI: Simplify MPS test for Downstream Port PCI: Remove unnecessary check for pcie_get_mps() failure ...
2013-08-26Merge branch 'pci/yinghai-assign-unassigned-v6' into nextBjorn Helgaas
* pci/yinghai-assign-unassigned-v6: PCI: Assign resources for hot-added host bridge more aggressively PCI: Move resource reallocation code to non-__init PCI: Delay enabling bridges until they're needed PCI: Assign resources on a per-bus basis PCI: Enable unassigned resource reallocation on per-bus basis PCI: Turn on reallocation for unassigned resources with host bridge offset PCI: Look for unassigned resources on per-bus basis PCI: Drop temporary variable in pci_assign_unassigned_resources()
2013-08-05PCI: Align bridge I/O windows as required by downstream devices & bridgesBjorn Helgaas
An upstream bridge's I/O window must be at least as aligned as any downstream device or bridge requires. In particular, if the upstream bridge supports 1K alignment but a downstream bridge requires 4K alignment, the upstream window must also be 4K aligned. Therefore, do not reduce the required alignment ("min_align") based on the upstream bridge's capabilities. Reported-by: Wei Yang <weiyang@linux.vnet.ibm.com> Suggested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-08-02PCI: Fix types in pbus_size_io()Wei Yang
This patch changes the type of "size" to resource_size_t and makes the corresponding dev_printk() change. [bhelgaas: changelog] Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-08-02PCI: Add comments for pbus_size_mem() parametersWei Yang
This patch fills in the missing description for two parameters of pbus_size_mem(). Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-08-02PCI: Enumerate subordinate buses, not devices, in pci_bus_get_depth()Wei Yang
Normally, on one PCI bus there would be more devices than bridges. When calculating the depth of a PCI bus, it would be more time efficient to enumerating through the child buses instead of the child devices. Also by doing so, the code seems more self explaining. Previously, it went through the devices and checked whether a bridge introduced a child bus or not, which needs more background knowledge to understand it. This patch calculates the depth by enumerating the bus hierarchy. Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-26PCI: Retry allocation of only the resource type that failedYinghai Lu
Ben Herrenschmidt reported the following problem: - The bus has space for all desired MMIO resources, including optional space for SR-IOV devices - We attempt to allocate I/O port space, but it fails because the bus has no I/O space - Because of the I/O allocation failure, we retry MMIO allocation, requesting only the required space, without the optional SR-IOV space This means we don't allocate the optional SR-IOV space, even though we could. This is related to 0c5be0cb0e ("PCI: Retry on IORESOURCE_IO type allocations"). This patch changes how we handle allocation failures. We will now retry allocation of only the resource type that failed. If MMIO allocation fails, we'll retry only MMIO allocation. If I/O port allocation fails, we'll retry only I/O port allocation. [bhelgaas: changelog] Reference: https://lkml.kernel.org/r/1367712653.11982.19.camel@pasglop Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.10+
2013-07-25PCI: Assign resources for hot-added host bridge more aggressivelyYinghai Lu
When hot-adding an ACPI host bridge, use pci_assign_unassigned_root_bus_resources() instead of pci_assign_unassigned_bus_resources(). The former is more aggressive and will release and reassign existing resources if necessary. This is safe at hot-add time because no drivers are bound to devices below the new host bridge yet. [bhelgaas: changelog, split __init changes out for reviewability] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Move resource reallocation code to non-__initYinghai Lu
Resource reallocation is currently done only at boot-time, but will soon be done when host bridge is hot-added. This patch removes the __init annotations so the code will still be present after boot. [bhelgaas: split __init changes out] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Delay enabling bridges until they're neededYinghai Lu
We currently enable PCI bridges after scanning a bus and assigning resources. This is often done in arch code. This patch changes this so we don't enable a bridge until necessary, i.e., until we enable a PCI device behind the bridge. We do this in the generic pci_enable_device() path, so this also removes the arch-specific code to enable bridges. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Assign resources on a per-bus basisYinghai Lu
Previously, we did resource assignment globally. This patch splits up pci_assign_unassigned_resources() so assignment is done for each root bus in turn. We check each root bus individually to see whether it needs any reassignment, and if it does, we assign resources for just that bus. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Enable unassigned resource reallocation on per-bus basisYinghai Lu
pci_realloc_detect() turns on automatic resource allocation when it finds unassigned SR-IOV resources. Previously it did this on a global basis, so we enabled reallocation if any PCI device anywhere had an unassigned SR-IOV resource. This patch changes pci_realloc_detect() so it looks at a single bus, so we can do this when a host bridge is hot-added. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Turn on reallocation for unassigned resources with host bridge offsetYinghai Lu
Previously we did not turn on automatic PCI resource reallocation for unassigned IOV resources behind a host bridge with address offset. This patch fixes that bug. The intent was that "!r->start" would check for a BAR containing zero. But that check is incorrect for host bridges that apply an offset, because in that case the resource address is not the same as the bus address. This patch fixes that by converting the resource address back to a bus address before checking for zero. [bhelgaas: changelog] Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Look for unassigned resources on per-bus basisYinghai Lu
When CONFIG_PCI_REALLOC_ENABLE_AUTO=y, pci_realloc_detect() looks at PCI devices to see if any have SR-IOV resources that need to be assigned. If it finds any, it turns on automatic resource reallocation. This patch changes pci_realloc_detect() so it uses pci_walk_bus() on each root bus instead of using for_each_pci_dev(). This is a step toward doing reallocation on a per-bus basis, so we can do it for a hot-added host bridge. [bhelgaas: changelog, rename callback to iov_resources_unassigned(), use boolean for "unassigned"] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Drop temporary variable in pci_assign_unassigned_resources()Yinghai Lu
Drop the "bus" temporary variable. No functional change, but simplifies later patch slightly. [bhelgaas: changelog, make same change in pci_assign_unassigned_bridge_resources() to keep it parallel with pci_assign_unassigned_resources()] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-06-23PCI / ACPI: Use boot-time resource allocation rules during hotplugJiang Liu
On x86 platforms, the kernel respects PCI resource assignments from the BIOS and only reassigns resources for unassigned BARs at boot time. However, with the ACPI-based hotplug (acpiphp), it ignores the BIOS' PCI resource assignments completely and reassigns all resources by itself. This causes differences in PCI resource allocation between boot time and runtime hotplug to occur, which is generally undesirable and sometimes actively breaks things. Namely, if there are enough resources, reassigning all PCI resources during runtime hotplug should work, but it may fail if the resources are constrained. This may happen, for instance, when some PCI devices with huge MMIO BARs are involved in the runtime hotplug operations, because the current PCI MMIO alignment algorithm may waste huge chunks of MMIO address space in those cases. On the Alexander's Sony VAIO VPCZ23A4R the BIOS allocates limited MMIO resources for the dock station which contains a device (graphics adapter) with a 256MB MMIO BAR. An attempt to reassign that during runtime hotplug causes the dock station MMIO window to be exhausted and acpiphp fails to allocate resources for the majority of devices on the dock station as a result. To prevent that from happening, modify acpiphp to follow the boot time resources allocation behavior so that the BIOS' resource assignments are respected during runtime hotplug too. [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=56531 Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com> Tested-by: Illya Klymov <xanf@xanf.me> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: 3.9+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-17PCI: Warn about failures instead of "must_check" functionsBjorn Helgaas
These places capture return values to avoid "must_check" warnings, but we didn't *do* anything with the return values, which causes "set but not used" warnings. We might as well do something instead of just trying to evade the "must_check" warnings. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-12PCI: Make local functions/structs staticBjorn Helgaas
This fixes "no previous prototype" warnings found via "make W=1". Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-01-25PCI: Add root bus children dev's res to fail listYinghai Lu
We can stop trying according to try_number now and do not need to use root_bus checking as stop sign. In extreme case we could need to reallocate resource for device just under root bus. For PCI root bus hot-add, we need to retry to assign resources to PCI devices just under pci root bus. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-03PCI: Move out pci_enable_bridges out of assign_unsigned_bus_resYinghai Lu
So could use assign_unassigned_bus_res pci root bus add Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-03PCI: Move pci_rescan_bus() back to probe.cYinghai Lu
We have pci_assign_unassigned_bus_resources() in as global function now. Move pci_rescan_bus() back to probe.c where it should be. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-10-30PCI: Separate out pci_assign_unassigned_bus_resources()Yinghai Lu
It is main portion of pci_rescan_bus(). Separate it out and prepare to use it for PCI root bus hot add later. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-09-11PCI: Refactor pbus_size_mem()Gavin Shan
The original idea comes from Ram Pai. This patch puts the chunk of code for calculating the minimal alignment of memory window into a separate inline function. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-09-11PCI: Align P2P windows using pcibios_window_alignment()Gavin Shan
This patch changes pbus_size_io() and pbus_size_mem() to do window (I/O, memory and prefetchable memory) reassignment based on the minimal alignments for the P2P bridge, which was retrieved by window_alignment(). [bhelgaas: changelog] Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
