path: root/drivers/pci
2006-12-08revert the quirk_via_irq changesAdrian Bunk
This patch reverts the quirk_via_irq changes in 2.6.16.17 that caused regressions for several people. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08PCI: add ICH7/8 ACPI/GPIO io resource quirksDaniel Ritz
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08PCI: fix ICH6 quirksDaniel Ritz
- add the ICH6(R) LPC to the ICH6 ACPI quirks. currently only the ICH6-M is handled. [ PCI_DEVICE_ID_INTEL_ICH6_1 is the ICH6-M LPC, ICH6_0 is the ICH6(R) ] Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08PCI: Unhide the SMBus on Asus PU-DLSJean Delvare
Unhide the SMBus controller on the Asus PU-DLS board. This fixes bug #6763. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08PCI: quirk to disable e100 interrupt if RESET failed toBjorn Helgaas
Without this quirk, e100 can be pulling on a shared interrupt line when another device (eg. USB) loads, causing the interrupt to scream and get disabled. http://bugzilla.kernel.org/show_bug.cgi?id=5918 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08Add PIIX4 APCI quirk for the 440MX chipset tooLinus Torvalds
This is confirmed to fix a hang due to PCI resource conflicts with setting up the Cardbus bridge on old laptops with the 440MX chipsets. Original report by Alessio Sangalli, lspci debugging help by Pekka Enberg, and trial patch suggested by Daniel Ritz: "From the docs available i would _guess_ this thing is really similar to the 82443BX/82371AB combination. at least the SMBus base address register is hidden at the very same place (32bit at 0x90 in function 3 of the "south" brigde)" The dang thing is largely undocumented, but the patch was corroborated by Asit Mallick: "I am trying to find the register information. 440MX is an integration of 440BX north-bridge without AGP and PIIX4E (82371EB). PIIX4 quirk should cover the ACPI and SMBus related I/O registers." and verified to fix the problem by Alessio. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08PCI: nVidia quirk to make AER PCI-E extended capability visibleBrice Goglin
The nVidia CK804 PCI-E chipset supports the AER extended capability but sometimes fails to link it (with some BIOS or after a warm reboot). It makes the AER cap invisible to pci_find_ext_capability(). The patch adds a quirk to set the missing bit that controls the linking of the capability. By the way, it removes the corresponding code in the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-08pci_ids.h: correct naming of 1022:7450 (AMD 8131 Bridge)John W. Linville
The naming of the constant defined for PCI ID 1022:7450 does not seem to match the information at http://pciids.sourceforge.net/: http://pci-ids.ucw.cz/iii/?i=1022 There 1022:7450 is listed as "AMD-8131 PCI-X Bridge" while 1022:7451 is listed as "AMD-8131 PCI-X IOAPIC". Yet, the current definition for 0x7450 is PCI_DEVICE_ID_AMD_8131_APIC. It seems to me like that name should map to 0x7451, while a name like PCI_DEVICE_ID_AMD_8131_BRIDGE should map to 0x7450. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-20[PATCH] VIA quirk fixup, additional PCI IDsChris Wedgwood
An earlier commit (75cf7456dd87335f574dcd53c4ae616a2ad71a11) changed an overly-zealous PCI quirk to only poke those VIA devices that need it. However, some PCI devices were not included in what I hope is now the full list. Consequently we're failing to run the quirk on all machines which need it, causing IRQ routing failures. This should I hope correct this. Thanks to Masoud Sharbiani <masouds@masoud.ir> for pointing this out and testing the fix. Signed-off-by: Chris Wedgwood <cw@f00f.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] PCI quirk: VIA IRQ fixup should only run for VIA southbridgesChris Wedgwood
Alan Cox pointed out that the VIA 'IRQ fixup' was erroneously running on my system which has no VIA southbridge (but I do have a VIA IEEE 1394 device). This should address that. I also changed "Via IRQ" to "VIA IRQ" (initially I read Via as a capitalized via (by way/means of). Signed-off-by: Chris Wedgwood <cw@f00f.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] PCI: correctly allocate return buffers for osc callsKristen Accardi
The OSC set and query functions do not allocate enough space for return values, and set the output buffer length to a false, too large value. This causes the acpi-ca code to assume that the output buffer is larger than it actually is, and overwrite memory when copying acpi return buffers into this caller provided buffer. In some cases this can cause kernel oops if the memory that is overwritten is a pointer. This patch will change these calls to use a dynamically allocated output buffer, thus allowing the acpi-ca code to decide how much space is needed. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-20[PATCH] smbus unhiding kills thermal managementCarl-Daniel Hailfinger
Do not enable the SMBus device on Asus boards if suspend is used. We do not reenable the device on resume, leading to all sorts of undesirable effects, the worst being a total fan failure after resume on Samsung P35 laptop. This fixes bug #6449 at bugzilla.kernel.org. Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-02-01[PATCH] PowerPC/PCI Hotplug build breakLinas Vepstas
Build break: Building PCI hotplug on PowerPC results in a build break, due to failure to export symbols. Reported today by Dave Jones <davej@redhat.com>: drivers/pci/hotplug/rpaphp.ko needs unknown symbol pcibios_add_pci_devices This patch fixes same problem in drivers/pci tree Previous patch fixes the break in the arch/powerpc tree. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] powerpc/PCI hotplug: shuffle error checking to better location.linas@austin.ibm.com
Error checking is scattered through various layers of the dlpar code, leading to a somewhat opaque code structure. This patch consolidates error checking in one routine, simplifying the code a tad. There's also some whitespace cleanup here too. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: minor cleanup forward declslinas@austin.ibm.com
Minor cleanup. Move structure initializer to bottom of file, this allows elimination of eyeball-strain-inducing forward declarations. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: cleanup: add prefixlinas@austin.ibm.com
Minor cleanup. Add the prefix rpaphp_* to several generic-sounding routines. Remove rpaphp_remove_slot(), which is a one-liner. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: merge rpaphp_enable_pci_slot()linas@austin.ibm.com
Remove general baroqueness. The function rpaphp_enable_pci_slot() has a fairly simple logic structure, once all of the debug printk's are removed. Its called from only one place, and that place also has a very simple structure once he printk's are removed. Merge the two together. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: de-convolute rpaphp_unconfig_pci_adaplinas@austin.ibm.com
Remove general baroqueness. The function rpaphp_unconfig_pci_adapter() is really just three lines of code, once all the dbg printks are removed. And its called in only one place. So replace the call by the thre lines. Also, provide proper semaphore locking in the affected function disable_slot() Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove remove_bus_device()linas@austin.ibm.com
The function rpaphp_eeh_remove_bus_device() is a dupe of eeh_remove_bus_device(). Remove it. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: merge config_pci_adapterlinas@austin.ibm.com
Remove general baroqueness. The function rpaphp_config_pci_adapter() is really just one line of code, once all the dbg printks are removed. And its called in only one place. So replace the call by the one line. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove rpaphp_fixup_new_pci_devices()linas@austin.ibm.com
The function rpaphp_fixup_new_pci_devices() has been migrated to pcibios_fixup_new_pci_devices() in arch/powerpc/platforms/pseries/pci_dlpar.c This patch removes the old version. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove rpaphp_find_bus()linas@austin.ibm.com
The function rpaphp_find_pci_bus() has been migrated to pcibios_find_pci_bus() in arch/powerpc/platforms/pseries/pci_dlpar.c This patch removes the old version. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI Hotplug: shpchp: AMD POGO errata fixKeck, David
This patch fixes the AMD POGO errata on the hotplug controller where the platform will lock up or reboot if PERR/SERR generation is enabled and a slot is sent an enable command. This fix disables PERR/SERR generation before a slot is sent the enable command by first saving related registers, turning off SERR/PERR generation, enabling the slot, then restoring the registers. Signed-off-by: David Keck <david.keck@amd.com> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI Hotplug: PCI panic on dlpar add (add pci slot to running partition)linas
Removing and then adding a PCI slot to a running partition results in a kernel panic. The current code attempts to add iospace for an entire root bus, which is inappropriate, and silently fails. When a pci device tries to use the iospace, a page fault is taken, as the iospace had not been mapped, and of course the page fault cannot be resolved. This only occurs for PCI adapters using pio, which may be why it hadn't been seen earlier (this seems to have been broken for a while). This patch has survived testing of dozens of slot add and removes. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI Hotplug/powerpc: module build breaklinas
The RPAPHP hoplug driver will not build as a module, because it calls on pci_claim_resource(), which is not exported. This exports the symbol. Problem reported by Olaf Hering <olh@suse.de> A grep indicates that building drivers/parisc/lba_pci.c would have trouble building as a module for the same reason. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI Hotplug: fix up Kconfig help textPavel Machek
Remove reference to pcihpfs that no longer exists. Signed-off-by: Pavel Machek <pavel@suse.cz>
2006-01-31[PATCH] PCI Hotplug: fix up coding style issuesPavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI: make it easier to see that set_msi_affinity() is usedGrant Grundler
I missed this usage in drivers/pci/msi.h: #ifdef CONFIG_SMP #define set_msi_irq_affinity set_msi_affinity #else #define set_msi_irq_affinity NULL #endif set_msi_affinity() is declared and exclusively used in msi.c. Here's a better way so (hopefully) history doesn't repeat itself. Signed-off-by: Grant Grundler <iod00d@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] PCI: drivers/pci/pci.c: #if 0 pci_find_ext_capability()Adrian Bunk
This patch #if 0's the unused global function pci_find_ext_capability(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] fix deadlock in drivers/pci/msi.cIngo Molnar
The lock validator caught another one: drivers/pci/msi.c is accessing &irq_desc[i].lock with interrupts enabled (!). The fix is to disable interrupts properly. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-17[PATCH] Intel ICH8 SATA: add PCI device IDsJason Gaston
Signed-off-by:  Jason Gaston <Jason.d.gaston@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-13[PATCH] Add pci_bus_type probe and remove methodsRussell King
Move the PCI bus device probe/remove methods to the bus_type structure. We leave the shutdown method alone since there are compatibility issues with that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-09[PATCH] PCI: drivers/pci: some cleanupsAdrian Bunk
This patch contains the following cleanups: - hotplug/pciehp_core.c: make the needlessly global hpdriver_context static - #if 0 the following unused functions: - pci.c: pci_bus_max_busnr() - pci.c: pci_max_busnr() - proc.c: pci_proc_attach_bus() - remove.c: pci_remove_device_safe Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] acpiphp: only size new busKristen Accardi
Only size the bus that has been added. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Hotplug: fix up the sysfs file in the compaq pci hotplug driverGreg Kroah-Hartman
The Compaq PCI Hotplug driver was creating 2 sysfs files that contained nothing but debug information, and had way more than "one value" in them. This patch converts the code to use debugfs for these files instead. Compile tested only. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Reduce nr of ptr derefs in drivers/pci/hotplug/pciehp_core.cJesper Juhl
Here's a small patch to reduce the nr. of pointer dereferences in drivers/pci/hotplug/pciehp_core.c Benefits: - micro speed optimization due to fewer pointer derefs - generated code is slightly smaller - small line length cleanup - better readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Reduce nr of ptr derefs in drivers/pci/hotplug/pciehprm_acpi.cJesper Juhl
Here's a small patch to reduce the nr. of pointer dereferences in drivers/pci/hotplug/pciehprm_acpi.c Benefits: - micro speed optimization due to fewer pointer derefs - generated code is slightly smaller - better readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Reduce nr of ptr derefs in drivers/pci/hotplug/rpaphp_pci.cJesper Juhl
Here's a small patch to reduce the nr. of pointer dereferences in drivers/pci/hotplug/rpaphp_pci.c Benefits: - micro speed optimization due to fewer pointer derefs - generated code should be slightly smaller - better readability note: due to lack of both hardware and cross-compile tools this patch is, unfortunately, completely untested. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Reduce nr of ptr derefs in drivers/pci/hotplug/cpqphp_core.cJesper Juhl
Here's a small patch to reduce the nr of pointer dereferences in drivers/pci/hotplug/cpqphp_core.c Benefits of this patch: - micro speed optimization due to fewer pointer derefs - generated code is slightly smaller - tiny line length and whitespace cleanup - better readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Export pci_cfg_space_sizeBenjamin Herrenschmidt
The powerpc PCI code sets up the PCI tree without doing config space accesses in most cases, from the firmware tree. However, it still wants to call pci_cfg_space_size() under some conditions, thus it needs to be made non-static (though I don't see a point to export it to modules). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: use bus numbers sparsely, if necessaryDominik Brodowski
Add a warning if a child bus may be inaccessible because the parent bridge has wrong secondary or subordinate bus numbers. Note that this may or may not happen on "transparent" bridges, as can be seen in bug #5557. Also, if we do not fix up the assignment of bus numbers, try to make use of the bus number space available. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] pciehp: allow bridged card hotplugRajesh Shah
This patch fixes bugs in the pciehp driver that prevent hot-add of a card with PCI bridges on it. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] pciehp: handle sticky power-fault statusThomas Schaefer
This patch disables power fault, MRL sensor and presence detection interrupts when a PCIe slot is powered-off and enables those interrupts when it is powered-on again. This is necessary to prevent the associated events from causing an endless cycle of interrupts due to the power-fault bit, which stays set till power is restored to the slot. Signed-off-by: Thomas Schaefer <thomas.schaefer@kontron.com> Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Quirk: 1K I/O space granularity on Intel P64H2Daniel Yeisley
I've implemented a quirk to take advantage of the 1KB I/O space granularity option on the Intel P64H2 PCI Bridge. I had to change probe.c because it sets the resource start and end to be aligned on 4k boundaries (after the quirk sets them to 1k boundaries). I've tested this patch on a Unisys ES7000-600 both with and without the 1KB option enabled. I also tested this on a 2 processor Dell box that doesn't have a P64H2 to make sure there were no negative affects there. Signed-off-by: Dan Yeisley <dan.yeisley@unisys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] shpchp: Implement get_address callbackKenji Kaneshige
The following patch implements .get_address callback of hotplug_slot_ops for SHPCHP driver. With this patch, we can see bus address of hotplug slots as follows: $ cat address 0000:0b:01 Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Hotplug/powerpc: more removal of duplicated codelinas@austin.ibm.com
The RPAPHP code contains two routines that appear to be gratuitous copies of very similar pci code. In particular, rpaphp_claim_resource ~~ pci_claim_resource (there is a minor, non-functional difference) rpadlpar_claim_one_bus == pcibios_claim_one_bus (the code is identical) This patch removes the rpaphp versions of the code. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Hotplug/powerpc: remove duplicated codelinas@austin.ibm.com
The RPAPHP code contains a routine that duplicates some existing code. This patch removes the rpaphp version of the code. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] shpchp: fix improper wait for command completionKenji Kaneshige
Current SHPCHP driver uses msleep_interruptible() function to wait for a command completion event. But I think this would cause an unnecessary long wait until timeout, if command completion interrupt came before task state was changed to TASK_INTERRUPTIBLE. This patch fixes this issue. With this patch, command completion becomes faster as follows: o Without this patch # time echo 1 > power real 0m4.708s user 0m0.000s sys 0m0.524s o With this patch # time echo 1 > power real 0m2.221s user 0m0.000s sys 0m0.532s Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
