This patch works around a problem in the fakephp driver when a process
writing "0" to a "power" sysfs file to fake removal of a PCI device ends
up deadlocking itself in the sysfs code.
The patch is functionally identical to the one in Linus' tree post 2.6.24:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=5c796ae7a7ebe56967ed9b9963d7c16d733635ff
I have tested it on a 2.6.23 kernel.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
patch d1ec7298fcefd7e4d1ca612da402ce9e5d5e2c13 in mainline.
It is important that these resources be reserved
to avoid conflicts with well known ACPI registers.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
patch cbf5d9e6b9bcf03291cbb51db144b3e2773a8a2d in mainline.
While reading the MSI code trying to find a reason why MSI wouldn't
work for devices that have a 32-bit MSI address capability, I noticed
that read_msi_msg() seems to read the message data from the wrong
offset in this case.
Signed-off-by: Roland Dreier <roland@digitalvampire.org>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Linas reported me that some machines were crashing at boot in
quirk_e100_interrupt. It appears that this quirk is doing an ioremap
directly on a PCI BAR value, which isn't legal and will cause all sorts
of bad things to happen on architectures where PCI BARs don't directly
match processor bus addresses.
This fixes it by using the proper PCI resources instead which is possible
since the quirk has been moved by a previous commit to happen late enough
for that.
Acked-by: Linas Vepstas <linas@austin.ibm.com>
PCI quirk to unhide SMBus on Compaq Deskpro EP 401963-001 (PCA# 010174) motherboard.
Signed-off-by: Greg White <gw.kernel@tnode.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
On MIPS with PCI && !HOTPLUG, I'm currently getting the following modpost
warning:
MODPOST vmlinux.o
WARNING: vmlinux.o(.text+0x1ce128): Section mismatch: reference to .init.text:pci_read_bridge_bases (between 'pcibios_fixup_bus' and 'pcibios_enable_device')
On MIPS I have the call chains pci_scan_child_bus -> pcibios_fixup_bus ->
pci_read_bridge_bases. pci_scan_child_bus can't be __devinit because it
it is an exported symbol, thus pcibios_fixup_bus and pci_read_bridge_bases
can't be either.
For some reason I don't see this issue on x86; I blame compiler differences.
drivers/acpi/video.c
Add missing \n to error in ibm_find_acpi_device.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Adrian Bunk <trivial@kernel.org>
Schedule /proc/acpi/event for removal in 6 months.
Re-name acpi_bus_generate_event() to acpi_bus_generate_proc_event()
to make sure there is no confusion that it is for /proc/acpi/event only.
Add CONFIG_ACPI_PROC_EVENT to allow removal of /proc/acpi/event.
There is no functional change if CONFIG_ACPI_PROC_EVENT=y
The previous events patch added a netlink event for every
user of the legacy /proc/acpi/event interface.
However, some users of /proc/acpi/event are really input events,
and they already report their events via the input layer.
Introduce a new interface, acpi_bus_generate_netlink_event(),
which is explicitly called by devices that want to repoprt
events via netlink. This allows the input-like events
to opt-out of generating netlink events. In summary:
events that are sent via netlink:
ac/battery/sbs
thermal
processor
thinkpad_acpi dock/bay
events that are sent via input layer:
button
video hotkey
thinkpad_acpi hotkey
asus_acpi/asus-laptop hotkey
sonypi/sonylaptop
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
The k8t_sound_hostbridge PCI quick fires on my motherboard (Jetway
K8M8MS) while it shouldn't: the on-board sound chip is not disabled
and is working just fine. Looking at the code, I see that we are
running the quirk for two distinct register values (0x88 and 0xc8)
and then clear bit 6 (0x40). However value 0x88 already has bit 6
cleared so this is a no-op. This is what happens on my board. Thus I
believe that the quirk should only be run for register value 0xc8.
RX790 can't do MSI like its predecessors. Disable MSI on RX790.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: stable <stable@kernel.org>
RD580 can't do MSI like its predecessors. Disable MSI on RD580.
Signed-off-by: Tejun Heo <teheo@suse.de>
CC: stable <stable@kernel.org>
RS690 can't do MSI like its predecessors. Disable MSI on RS690.
Cc: Henry Su <henry.su@amd.com>
Adrian Bunk wrote:
> Alois Nešpor wrote
>> PCI: Bus #0b (-#0e) is hidden behind transparent bridge #0a (-#0b) (try 'pci=assign-busses')
>> Please report the result to linux-kernel to fix this permanently"
>> dmesg:
>> "Yenta: Raising subordinate bus# of parent bus (#0a) from #0b to #0e"
>> without pci=assign-busses and nothing with pci=assign-busses.
> Bernhard?
Ok, lets kill the message. As Alois Nešpor also saw, that's fixed up by Yenta,
so PCI does not have to warn about it. PCI could still warn about it if
is_cardbus is 0 in that instance of pci_scan_bridge(), but so far I have
not seen a report where this would have been the case so I think we can
spare the kernel of that check (removes ~300 lines of asm) unless debugging
is done.
History: The whole check was added in the days before we had the fixup
for this in Yenta and pci=assign-busses was the only way to get CardBus
cards detected on many (not all) of the machines which give this warning.
In theory, there could be cases when this warning would be triggered and
it's not cardbus, then the warning should still apply, but I think this
should only be the case when working on a completely broken PCI setup,
but one may have already enabled the debug code in drivers/pci and the
patched check would then trigger.
I do not sign this off yet because it's completely untested so far, but
everyone is free to test it (with the #ifdef DEBUG replaced by #if 1 and
pr_debug( changed to printk(.
We may also dump the whole check (remove everything within the #ifdef from
the source) if that's perferred.
On Alois Nešpor's machine this would then (only when debugging) this message:
"PCI: Bus #0b (-#0e) is partially hidden behind transparent bridge #0a (-#0b)"
"partially" should be in the message on his machine because #0b of #0b-#0e
is reachable behind #0a-#0b, but not #0c-#0e.
But that differentiation is now moot anyway because the fixup in Yenta takes
care of it as far as I could see so far, which means that unless somebody
is debugging a totally broken PCI setup, this message is not needed anymore,
not even for debugging PCI.
Ok, here the patch with the following changes:
* Refined to say that the bus is only partially hidden when the parent
bus numbers are not totally way off (outside of) the child bus range
* remove the reference to pci=assign-busses and the plea to report it
We could add a pure source code-only comment to keep a reference to
pci=assign-busses the in case when this is triggered by someone who
is debugging the cause of this message and looking the way to solve it.
remove stale BKL use from drivers/pci/hotplug/cpqphp_ctrl.c.
quirk_e100_interrupts() is called after PCI controller is initialized
and before PCI bus enumeration is performed. On some powerpc platforms
which modify PCI controller configuration and set different MEM and IO
windows than those set by firmware quirk_e100_interrupt() is causing
kernel panic as it tries to read from device BAR0 offets which at this
time points to a invalid PCI window (set by firmware).
This patch delays the quirk_100_interrupt() to pci_fixup_final phase,
which happens after bus enumeration and before PCI enable and
device driver initialization.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
We need pci_bus_find_capability() in some arch/powerpc code so move
the prototype into a header accessible to it.
Also kill the duplicate prototype for pci_bus_alloc_resource().
Rename __pci_reenable_device() to pci_reenable_device().
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Fix undocumented function parameters in PCI and drivers/base.
Warning(linux-2.6.23-rc1//drivers/pci/pci.c:1526): No description found for parameter 'rq'
Warning(linux-2.6.23-rc1//drivers/base/firmware_class.c:245): No description found for parameter 'bin_attr'
Restore the 2.6.22 CONFIG_ACPI_SLEEP build option, but now shadowing the
new CONFIG_PM_SLEEP option.
[ Modified to work with the PM config setup changes. ]
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: Kconfig: remove CONFIG_ACPI_SLEEP from source
ACPI: quiet ACPI Exceptions due to no _PTC or _TSS
ACPI: Remove references to ACPI_STATE_S2 from acpi_pm_enter
ACPI: Kconfig: always enable CONFIG_ACPI_SLEEP on X86
ACPI: Kconfig: fold /proc/acpi/sleep under CONFIG_ACPI_PROCFS
ACPI: Kconfig: CONFIG_ACPI_PROCFS now defaults to N
ACPI: autoload modules - Create __mod_acpi_device_table symbol for all ACPI drivers
ACPI: autoload modules - Create ACPI alias interface
ACPI: autoload modules - ACPICA modifications
ACPI: asus-laptop: Fix failure exits
ACPI: fix oops due to typo in new throttling code
ACPI: ignore _PSx method for hotplugable PCI devices
ACPI: Use ACPI methods to select PCI device suspend state
ACPI, PNP: hook ACPI D-state to PNP suspend/resume
ACPI: Add acpi_pm_device_sleep_state helper routine
ACPI: Implement the set_target() callback from pm_ops
Some odd ACPI implementations choke if certain controller is disabled
when ACPI suspend is invoked but we still need to make sure the PCI
device is enabled during resume. Simply using pci_enable_device()
unbalances device enable count. Export __pci_reenable_device().
If the ACPI device has _EJ0, ignore the device.
_PSx will set power for the slot,
and the hotplug driver will take care of _PSx.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
applied after Rafel's 'PM: Update global suspend and hibernation
operations framework' patch set
Signed-off-by: Shaohua Li<shaohua.li@intel.com>
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (209 commits)
[POWERPC] Create add_rtc() function to enable the RTC CMOS driver
[POWERPC] Add H_ILLAN_ATTRIBUTES hcall number
[POWERPC] xilinxfb: Parameterize xilinxfb platform device registration
[POWERPC] Oprofile support for Power 5++
[POWERPC] Enable arbitary speed tty ioctls and split input/output speed
[POWERPC] Make drivers/char/hvc_console.c:khvcd() static
[POWERPC] Remove dead code for preventing pread() and pwrite() calls
[POWERPC] Remove unnecessary #undef printk from prom.c
[POWERPC] Fix typo in Ebony default DTS
[POWERPC] Check for NULL ppc_md.init_IRQ() before calling
[POWERPC] Remove extra return statement
[POWERPC] pasemi: Don't auto-select CONFIG_EMBEDDED
[POWERPC] pasemi: Rename platform
[POWERPC] arch/powerpc/kernel/sysfs.c: Move NUMA exports
[POWERPC] Add __read_mostly support for powerpc
[POWERPC] Modify sched_clock() to make CONFIG_PRINTK_TIME more sane
[POWERPC] Create a dummy zImage if no valid platform has been selected
[POWERPC] PS3: Bootwrapper support.
[POWERPC] powermac i2c: Use mutex
[POWERPC] Schedule removal of arch/ppc
Fixed up conflicts manually in:
Documentation/feature-removal-schedule.txt
arch/powerpc/kernel/pci_32.c
arch/powerpc/kernel/pci_64.c
include/asm-powerpc/pci.h
and asked the powerpc people to double-check the result..
I forgot to remove capability.h from mm.h while removing sched.h! This
patch remedies that, because the only inline function which was using
CAP_something was made out of line.
Cross-compile tested without regressions on:
all powerpc defconfigs
all mips defconfigs
all m68k defconfigs
all arm defconfigs
all ia64 defconfigs
alpha alpha-allnoconfig alpha-defconfig alpha-up
arm
i386 i386-allnoconfig i386-defconfig i386-up
ia64 ia64-allnoconfig ia64-defconfig ia64-up
m68k
mips
parisc parisc-allnoconfig parisc-defconfig parisc-up
powerpc powerpc-up
s390 s390-allnoconfig s390-defconfig s390-up
sparc sparc-allnoconfig sparc-defconfig sparc-up
sparc64 sparc64-allnoconfig sparc64-defconfig sparc64-up
um-x86_64
x86_64 x86_64-allnoconfig x86_64-defconfig x86_64-up
as well as my two usual configs.
We have an API function for this now.
Cc: Zhang Yanmin <yanmin.zhang@intel.com>
Cc: Greg KH <greg@kroah.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Before calling init_hwif_default, ide_unregister gets lock ide_lock and
disables irq. init_hwif_default calls ide_default_io_base which calls
pci_get_device and later pci_get_subsys tries to apply for semaphore
pci_bus_sem and goes to sleep.
Mostly, pci_get_device should be called when irq is turned on.
ide_default_io_base just needs find if list pci_devices is empty.
Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Support multiple CPUs going through OS_MCA
[IA64] silence GCC ia64 unused variable warnings
[IA64] prevent MCA when performing MMIO mmap to PCI config space
[IA64] add sn_register_pmi_handler oemcall
[IA64] Stop bit for brl instruction
[IA64] SN: Correct ROM resource length for BIOS copy
[IA64] Don't set psr.ic and psr.i simultaneously
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits)
PCI: Only build PCI syscalls on architectures that want them
PCI: limit pci_get_bus_and_slot to domain 0
PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure
PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge
PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3
PCI: hotplug: pciehp: wait for 1 second after power off slot
PCI: pci_set_power_state(): check for PM capabilities earlier
PCI: cpci_hotplug: Convert to use the kthread API
PCI: add pci_try_set_mwi
PCI: pcie: remove SPIN_LOCK_UNLOCKED
PCI: ROUND_UP macro cleanup in drivers/pci
PCI: remove pci_dac_dma_... APIs
PCI: pci-x-pci-express-read-control-interfaces cleanups
PCI: Fix typo in include/linux/pci.h
PCI: pci_ids, remove double or more empty lines
PCI: pci_ids, add atheros and 3com_2 vendors
PCI: pci_ids, reorder some entries
PCI: i386: traps, change VENDOR to DEVICE
PCI: ATM: lanai, change VENDOR to DEVICE
PCI: Change all drivers to use pci_device->revision
sysfs binary attributes
Well, first of all, I don't want to change so many files either.
What I do:
Adding a new parameter "struct bin_attribute *" in the
.read/.write methods for the sysfs binary attributes.
In fact, only the four lines change in fs/sysfs/bin.c and
include/linux/sysfs.h do the real work.
But I have to update all the files that use binary attributes
to make them compatible with the new .read and .write methods.
I'm not sure if I missed any. :(
Why I do this:
For a sysfs attribute, we can get a pointer pointing to the
struct attribute in the .show/.store method,
while we can't do this for the binary attributes.
I don't know why this is different, but this does make it not
so handy to use the binary attributes as the regular ones.
So I think this patch is reasonable. :)
Who benefits from it:
The patch that exposes ACPI tables in sysfs
requires such an improvement.
All the table binary attributes share the same .read method.
Parameter "struct bin_attribute *" is used to get
the table signature and instance number which are used to
distinguish different ACPI table binary attributes.
Without this parameter, we need to offer different .read methods
for different ACPI table binary attributes.
This is impossible as there are various ACPI tables on different
platforms, and we don't know what they are until they are loaded.
sysfs is now completely out of driver/module lifetime game. After
deletion, a sysfs node doesn't access anything outside sysfs proper,
so there's no reason to hold onto the attribute owners. Note that
often the wrong modules were accounted for as owners leading to
accessing removed modules.
This patch kills now unnecessary attribute->owner. Note that with
this change, userland holding a sysfs node does not prevent the
backing module from being unloaded.
For more info regarding lifetime rule cleanup, please read the
following message.
http://article.gmane.org/gmane.linux.kernel/510293
(tweaked by Greg to not delete the field just yet, to make it easier to
merge things properly.)
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
The PCI syscalls are built on every architecture except X86, but only
a few have ever hooked them up. Use a new Kconfig symbol to save a
couple of kB on the architectures that have never used the syscalls.
Tested on x86 and ia64 only.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Limit pci_get_bus_and_slot() to domain (segment) 0 since domain is not
specified in the function call and defaulting to domain 0 is the only
reasonable thing to do (rather than returning a device from some other
unknown domain).
Acked-by: H. Peter Anvin <hpa@zytor.com>
failure
On some systems, the ACPI bus check event can reference a bridge that is
higher in the ACPI hierarchy than the bridge immediately above the
hotplug PCI slot into which an adapter was just inserted. The current
'acpiphp' code expects the bus check event to reference the bridge
immediately above the slot that received the adapter so the hotplug
operation can fail on these systems with the message "acpiphp_glue:
cannot get bridge info". This change fixes the problem by
re-enumerating all slots that lie below the bridge referenced by the bus
check event, including those slots that may be located under lower level
PCI-to-PCI bridge(s).
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Cc: <lcm@us.ibm.com>
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
acpiphp is writing hot plug parameters to the PCI host bridge
PCI config space. This patch removes the incorrect operation.
On systems where the optional _PS3 ACPI object is not implemented
acpiphp fails to power off the slot. This is happening because the
current code does not attempt to remove power using the _EJ0 ACPI
object. This patch restores the _EJ0 evaluation attempt which was
apparently inadvertently removed from the power-off sequence when the
_EJ0 evaluation code was relocated from power_off_slot() to
acpiphp_eject_slot().
According to the specification, we must wait for at least 1 second
after turning power off before taking any action that relies on power
having been removed from the slot/adapter.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Check for PCI_CAP_ID_PM before checking the device state. Apparently fixes
some log spam via the 3c59x driver.
Signed-off-by: Andrew Lunn <andrew.lunn@ascom.ch>
Signed-off-by: Scott Murray <scottm@somanetworks.com>
Acked-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
As suggested by Andrew, add pci_try_set_mwi(), which does not require
return-value checking.
- add pci_try_set_mwi() without __must_check
- make it return 0 on success, errno if the "try" failed or error
- review callers
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
ROUND_UP macro cleanup, use ALIGN where ever appropriate
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Acked-by: Scott Murray <scottm@somanetworks.com>
- remove unneeded local
- 80-col fix
Cc: Peter Oruba <peter.oruba@amd.com>
Cc: Roland Dreier <rolandd@cisco.com>
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Currently there are 97 occurrences where drivers need the pci
revision ID. We can do this once for all devices. Even the pci
subsystem needs the revision several times for quirks. The extra
u8 member pads out nicely in the pci_dev struct.
On Mon, Apr 02, 2007 at 10:47:45PM -0700, Andrew Morton wrote:
> Changes since 2.6.21-rc5-mm3:
> +fix-82875-pci-setup.patch
> Misc
pci_proc_attach_device() no longer has any modular user.
Function to clear bogus correctable errors. Analog to pci_aer_uncorrect_are_status.
The Marvell chips seem to start out with a bogus value that needs to be
cleared.
Yanmin ported it to 2.6.22-rc4 by fixing a fuzz patch applying info.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Acked-by: Zhang Yanmin <yanmin.zhang@intel.com>
