Distributions may wish to provide different defaults for PCIE ASPM
depending on their target audience. Provide a configuration option for
choosing the default policy.
Bug 815499
(cherry picked from commit ad71c96213a68dfe6d761e3ff7ac7ac267fd612a
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;
a=commitdiff;h=ad71c96213a68dfe6d761e3ff7ac7ac267fd612a)
Change-Id: I36bd72517af0cf8d637552e66b18afe576e72c20
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Vidya Sagar <vidyas@nvidia.com>
Reviewed-on: http://git-master/r/109739
GVS: Gerrit_Virtual_Submit
android-tegra-nv-3.1
Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent
with the other IOMMU options.
Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the
irq subsystem name.
And define the CONFIG_DMAR_TABLE for the common ACPI DMAR
routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: youquan.song@intel.com
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com
arch/x86/include/asm/irq_remapping.h
arch/x86/kernel/apic/io_apic.c
drivers/iommu/Makefile
Change-Id: I3f09baf327e59d94f38801d107268f4e20c1da8e
commit a776c491ca5e38c26d9f66923ff574d041e747f4 upstream.
I traced a nasty kexec on panic boot failure to the fact that we had
screaming msi interrupts and we were not disabling the msi messages at
kernel startup. The booting kernel had not enabled those interupts so
was not prepared to handle them.
I can see no reason why we would ever want to leave the msi interrupts
enabled at boot if something else has enabled those interrupts. The pci
spec specifies that msi interrupts should be off by default. Drivers
are expected to enable the msi interrupts if they want to use them. Our
interrupt handling code reprograms the interrupt handlers at boot and
will not be be able to do anything useful with an unexpected interrupt.
This patch applies cleanly all of the way back to 2.6.32 where I noticed
the problem.
commit 4cac2eb158c6da0c761689345c6cc5df788a6292 upstream.
Previously we claimed device ID 0x7450, regardless of the vendor, which is
clearly wrong. Now we'll claim that device ID only for AMD.
I suspect this was just a typo in the original code, but it's possible this
change will break shpchp on non-7450 AMD bridges. If so, we'll have to fix
them as we find them.
Reference: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=638863
Reported-by: Ralf Jung <ralfjung-e@gmx.de>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 917e3e65c35459d52f0d0b890aa5df0cad07a051 upstream.
With Xen changeset 23428 "libxl: Add 'e820_host' option to config file"
the E820 as seen from the host can now be passed into the guest.
This means that a PV guest can now:
- Use the correct PCI I/O gap. Before these patches, Linux guest would
boot up and would tell:
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:c0000000)
while in actuality the PCI I/O gap should have been:
[ 0.000000] Allocating PCI resources starting at b0000000 (gap: b0000000:4c000000)
- The PV domain with PCI devices was limited to 3GB. It now can be booted
with 4GB, 8GB, or whatever number you want. The PCI devices will now _not_ conflict
with System RAM. Meaning the drivers can load.
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
CC: linux-pci@vger.kernel.org
[v2: Made the string less broken up. Suggested by Joe Perches]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 3e309cdf07c930f29a4e0f233e47d399bea34c68 upstream.
Commit 15bed0f2f added a quirk for the e823 Ricoh card reader to lower the
base frequency. However, the quirk first checks to see if the proprietary
MMC controller is disabled, and returns if so. On some devices, such as the
Lenovo X220, the MMC controller is already disabled by firmware it seems,
but the frequency change is still needed so sdhci-pci can talk to the cards.
Since the MMC controller is disabled, the frequency fixup was never being run
on these machines.
This moves the e823 check above the MMC controller check so that it always
gets run.
This fixes https://bugzilla.redhat.com/show_bug.cgi?id=722509
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Add the ability to disable PCI-E MPS turning and using the BIOS
configured MPS defaults. Due to the number of issues recently
discovered on some x86 chipsets, make this the default behavior.
Also, add the option for peer to peer DMA MPS configuration. Peer to
peer DMA is outside the scope of this patch, but MPS configuration could
prevent it from working by having the MPS on one root port different
than the MPS on another. To work around this, simply make the system
wide MPS the smallest possible value (128B).
Signed-off-by: Jon Mason <mason@myri.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
In pcie_find_smpss(), we have the following statement:
if (dev->is_hotplug_bridge && (!list_is_singular(&dev->bus->devices) ||
dev->bus->self->pcie_type != PCI_EXP_TYPE_ROOT_PORT))
The problem is that at least on my machine, this gets called for the
root complex (virtual P2P bridge), and dev->bus->self is NULL since
the parent bus for this is not itself anchor to a PCI device.
This adds the necessary NULL check.
Acked-by: Jon Mason <mason@myri.com>
Modifying the Maximum Read Request Size to 0 (value of 128Bytes) has
massive negative ramifications on some devices. Without knowing which
devices have this issue, do not modify from the default value when
walking the PCI-E bus in pcie_bus_safe mode. Also, make pcie_bus_safe
the default procedure.
Tested-by: Sven Schnelle <svens@stackframe.org>
Tested-by: Simon Kirby <sim@hostway.ca>
Tested-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-and-tested-by: Niels Ole Salscheider <niels_ole@salscheider-online.de>
References: https://bugzilla.kernel.org/show_bug.cgi?id=42162
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Commit b03e7495a862 ("PCI: Set PCI-E Max Payload Size on fabric")
introduced a potential NULL pointer dereference in calls to
pcie_bus_configure_settings due to attempts to access pci_bus self
variables when the self pointer is NULL.
To correct this, verify that the self pointer in pci_bus is non-NULL
before dereferencing it.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Shyam Iyer <shyam_iyer@dell.com>
Fix new kernel-doc warning in pci.c:
Warning(drivers/pci/pci.c:3259): No description found for parameter 'mps'
Warning(drivers/pci/pci.c:3259): Excess function parameter 'rq' description in 'pcie_set_mps'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: OF: Don't crash when bridge parent is NULL.
PCI: export pcie_bus_configure_settings symbol
PCI: code and comments cleanup
PCI: make cardbus-bridge resources optional
PCI: make SRIOV resources optional
PCI : ability to relocate assigned pci-resources
PCI: honor child buses add_size in hot plug configuration
In pcibios_get_phb_of_node(), we will crash while booting if
bus->bridge->parent is NULL.
Check for this case and avoid dereferencing the NULL pointer.
Signed-off-by: David Daney <david.daney@cavium.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (28 commits)
ACPI: delete stale reference in kernel-parameters.txt
ACPI: add missing _OSI strings
ACPI: remove NID_INVAL
thermal: make THERMAL_HWMON implementation fully internal
thermal: split hwmon lookup to a separate function
thermal: hide CONFIG_THERMAL_HWMON
ACPI print OSI(Linux) warning only once
ACPI: DMI workaround for Asus A8N-SLI Premium and Asus A8N-SLI DELUX
ACPI / Battery: propagate sysfs error in acpi_battery_add()
ACPI / Battery: avoid acpi_battery_add() use-after-free
ACPI: introduce "acpi_rsdp=" parameter for kdump
ACPI: constify ops structs
ACPI: fix CONFIG_X86_REROUTE_FOR_BROKEN_BOOT_IRQS
ACPI: fix 80 char overflow
ACPI / Battery: Resolve the race condition in the sysfs_remove_battery()
ACPI / Battery: Add the check before refresh sysfs in the battery_notify()
ACPI / Battery: Add the hibernation process in the battery_notify()
ACPI / Battery: Rename acpi_battery_quirks2 with acpi_battery_quirks
ACPI / Battery: Change 16-bit signed negative battery current into correct value
ACPI / Battery: Add the power unit macro
pcie_bus_configure_settings needs to be exported if the PCI hotplug
driver is being compiled as a module.
a) adjust_resource_sorted() is now called reassign_resource_sorted()
b) nice-to-have is now called optional
c) add_list is now called realloc_list.
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
Allocate resources to cardbus bridge only after all other genuine
resources requests are satisfied. Dont retry if resource allocation
for cardbus-bridges fail.
Allocate resources to SRIOV BARs only after all other required
resource-requests are satisfied. Dont retry if resource allocation for SRIOV
BARs fail.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Currently pci-bridges are allocated enough resources to satisfy their immediate
requirements. Any additional resource-requests fail if additional free space,
contiguous to the one already allocated, is not available. This behavior is not
reasonable since sufficient contiguous resources, that can satisfy the request,
are available at a different location.
This patch provides the ability to expand and relocate a allocated resource.
v2: Changelog: Fixed size calculation in pci_reassign_resource()
v3: Changelog : Split this patch. The resource.c changes are already
upstream. All the pci driver changes are in here.
git commit c8adf9a3e873eddaaec11ac410a99ef6b9656938
"PCI: pre-allocate additional resources to devices only after
successful allocation of essential resources."
fails to take into consideration the optional-resources needed by children
devices while calculating the optional-resource needed by the bridge.
This can be a problem on some setup. For example, if a hotplug bridge has 8
children hotplug bridges, the bridge should have enough resources to accomodate
the hotplug requirements for each of its children hotplug bridges. Currently
this is not the case.
This patch fixes the problem.
Reviewed-by: Ram Pai <linuxram@us.ibm.com>
On a given PCI-E fabric, each device, bridge, and root port can have a
different PCI-E maximum payload size. There is a sizable performance
boost for having the largest possible maximum payload size on each PCI-E
device. However, if improperly configured, fatal bus errors can occur.
Thus, it is important to ensure that PCI-E payloads sends by a device
are never larger than the MPS setting of all devices on the way to the
destination.
This can be achieved two ways:
- A conservative approach is to use the smallest common denominator of
the entire tree below a root complex for every device on that fabric.
This means for example that having a 128 bytes MPS USB controller on one
leg of a switch will dramatically reduce performances of a video card or
10GE adapter on another leg of that same switch.
It also means that any hierarchy supporting hotplug slots (including
expresscard or thunderbolt I suppose, dbl check that) will have to be
entirely clamped to 128 bytes since we cannot predict what will be
plugged into those slots, and we cannot change the MPS on a "live"
system.
- A more optimal way is possible, if it falls within a couple of
constraints:
* The top-level host bridge will never generate packets larger than the
smallest TLP (or if it can be controlled independently from its MPS at
least)
* The device will never generate packets larger than MPS (which can be
configured via MRRS)
* No support of direct PCI-E <-> PCI-E transfers between devices without
some additional code to specifically deal with that case
Then we can use an approach that basically ignores downstream requests
and focuses exclusively on upstream requests. In that case, all we need
to care about is that a device MPS is no larger than its parent MPS,
which allows us to keep all switches/bridges to the max MPS supported by
their parent and eventually the PHB.
In this case, your USB controller would no longer "starve" your 10GE
Ethernet and your hotplug slots won't affect your global MPS.
Additionally, the hotplugged devices themselves can be configured to a
larger MPS up to the value configured in the hotplug bridge.
To choose between the two available options, two PCI kernel boot args
have been added to the PCI calls. "pcie_bus_safe" will provide the
former behavior, while "pcie_bus_perf" will perform the latter behavior.
By default, the latter behavior is used.
NOTE: due to the location of the enablement, each arch will need to add
calls to this function. This patch only enables x86.
This patch includes a number of changes recommended by Benjamin
Herrenschmidt.
Tested-by: Jordan_Hargrave@dell.com
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: remove printks about disabled bridge windows
PCI: fold pci_calc_resource_flags() into decode_bar()
PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR
PCI: correct pcie_set_readrq write size
PCI: pciehp: change wait time for valid configuration access
x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems
PCI: ARI is a PCIe v2 feature
x86/PCI: quirks: Use pci_dev->revision
PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.
PCI hotplug: cpqphp: use pci_dev->vendor
PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device}
x86/PCI: config space accessor functions should not ignore the segment argument
PCI: Assign values to 'pci_obff_signal_type' enumeration constants
x86/PCI: reduce severity of host bridge window conflict warnings
PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI
PCI: PCIe AER: add aer_recover_queue
x86/PCI: select direct access mode for mmconfig option
PCI hotplug: Rename is_ejectable which also exists in dock.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
merge fchmod() and fchmodat() guts, kill ancient broken kludge
xfs: fix misspelled S_IS...()
xfs: get rid of open-coded S_ISREG(), etc.
vfs: document locking requirements for d_move, __d_move and d_materialise_unique
omfs: fix (mode & S_IFDIR) abuse
btrfs: S_ISREG(mode) is not mode & S_IFREG...
ima: fmode_t misspelled as mode_t...
pci-label.c: size_t misspelled as mode_t
jffs2: S_ISLNK(mode & S_IFMT) is pointless
snd_msnd ->mode is fmode_t, not mode_t
v9fs_iop_get_acl: get rid of unused variable
vfs: dont chain pipe/anon/socket on superblock s_inodes list
Documentation: Exporting: update description of d_splice_alias
fs: add missing unlock in default_llseek()
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
no, really, strlen() and snprintf() do not return mode_t values...
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
iommu/core: Fix build with INTR_REMAP=y && CONFIG_DMAR=n
iommu/amd: Don't use MSI address range for DMA addresses
iommu/amd: Move missing parts to drivers/iommu
iommu: Move iommu Kconfig entries to submenu
x86/ia64: intel-iommu: move to drivers/iommu/
x86: amd_iommu: move to drivers/iommu/
msm: iommu: move to drivers/iommu/
drivers: iommu: move to a dedicated folder
x86/amd-iommu: Store device alias as dev_data pointer
x86/amd-iommu: Search for existind dev_data before allocting a new one
x86/amd-iommu: Allow dev_data->alias to be NULL
x86/amd-iommu: Use only dev_data in low-level domain attach/detach functions
x86/amd-iommu: Use only dev_data for dte and iotlb flushing routines
x86/amd-iommu: Store ATS state in dev_data
x86/amd-iommu: Store devid in dev_data
x86/amd-iommu: Introduce global dev_data_list
x86/amd-iommu: Remove redundant device_flush_dte() calls
iommu-api: Add missing header file
Fix up trivial conflicts (independent additions close to each other) in
drivers/Makefile and include/linux/pci.h
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (51 commits)
PM: Improve error code of pm_notifier_call_chain()
PM: Add "RTC" to PM trace time stamps to avoid confusion
PM / Suspend: Export suspend_set_ops, suspend_valid_only_mem
PM / Suspend: Add .suspend_again() callback to suspend_ops
PM / OPP: Introduce function to free cpufreq table
ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active
PM / Domains: Take .power_off() error code into account
ARM / shmobile: Use genpd_queue_power_off_work()
ARM / shmobile: Use pm_genpd_poweroff_unused()
PM / Domains: Introduce function to power off all unused PM domains
OMAP: PM: disable idle on suspend for GPIO and UART
OMAP: PM: omap_device: add API to disable idle on suspend
OMAP: PM: omap_device: add system PM methods for PM domain handling
OMAP: PM: omap_device: conditionally use PM domain runtime helpers
PM / Runtime: Add new helper function: pm_runtime_status_suspended()
PM / Domains: Queue up power off work only if it is not pending
PM / Domains: Improve handling of wakeup devices during system suspend
PM / Domains: Do not restore all devices on power off error
PM / Domains: Allow callbacks to execute all runtime PM helpers
PM / Domains: Do not execute device callbacks under locks
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'of-pci' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
pci/of: Consolidate pci_bus_to_OF_node()
pci/of: Consolidate pci_device_to_OF_node()
x86/devicetree: Use generic PCI <-> OF matching
microblaze/pci: Move the remains of pci_32.c to pci-common.c
microblaze/pci: Remove powermac originated cruft
pci/of: Match PCI devices to OF nodes dynamically
I don't think there's enough value in the fact of a bridge window
being disabled to justify cluttering the dmesg log with it.
decode_bar() and pci_calc_resource_flags() both looked at the PCI BAR
type information, and it's simpler to just do it all in one place.
decode_bar() sets IORESOURCE_IO, IORESOURCE_MEM, and IORESOURCE_MEM_64
as appropriate, so res->flags contains all the information pci_bar_type
does, so we don't need to test the pci_bar_type return value.
decode_bar() used to return pci_bar_type, which we no longer need. We
can simplify it a bit by returning the struct resource flags rather than
updating them internally.
In pci_update_resource(), there's no need to decode the BAR type bits
again; we can just test for IORESOURCE_MEM_64 directly.
This fixes a minor regression where broken PCI devices that use the
reserved "11" memory BAR type worked before e354597cce but not after.
The low four bits of a memory BAR are "PTT0" where P=1 for prefetchable
BARs, and TT is as follows:
00 32-bit BAR, anywhere in lower 4GB
01 anywhere below 1MB (reserved as of PCI 2.2)
10 64-bit BAR
11 reserved
Prior to e354597cce, we treated "0100" as a 64-bit BAR and all others,
including prefetchable 64-bit BARs ("1100") as 32-bit BARs. The e354597cce
fix, which appeared in 2.6.28, treats "x1x0" as 64-bit BARs, so the
reserved "x110" types are treated as 64-bit instead of 32-bit.
This patch returns to treating the reserved "11" type as a 32-bit BAR and
adds a warning if we see it.
It also logs a note if we see a 1M BAR. This is not a warning, because
such hardware conforms to pre-PCI 2.2 spec, but I think it's worth noting
because Linux ignores the 1M restriction if it ever has to assign the BAR.
CC: Peter Chubb <peterc@gelato.unsw.edu.au>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=35952
Reported-by: Jan Zwiegers <jan@radicalsystems.co.za>
When setting the PCI-E MRRS, pcie_set_readrq queries the current
settings via a pci_read_config_word call but writes the modified result
via a pci_write_config_dword. This results in writing 16 more bits than
were queried.
Also, the function description comment is slightly incorrect.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Naoki Yanagimoto reported that configuration read on some hot-added
PCIe device returns invalid value. This patch fixes this problem.
According to the PCIe spec, software must wait for at least 1 second
to judge if the hot-added device is broken after Data Link Layer State
Changed Event. This patch changes pciehp driver to wait for 1 second
after the Data Link Layer State Changed Event is detected before
initiating a configuration access instead of 100 ms.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Tested-by: Naoki Yanagimoto <yanagimoto@np.css.fujitsu.com>
The function pci_enable_ari() may mistakenly set the downstream port
of a v1 PCIe switch in ARI Forwarding mode. This is a PCIe v2 feature,
and with an SR-IOV device on that switch port believing the switch above
is ARI capable it may attempt to use functions 8-255, translating into
invalid (non-zero) device numbers for that bus. This has been seen
to cause Completion Timeouts and general misbehaviour including hangs
and panics.
Cc: stable@kernel.org
Acked-by: Don Dutile <ddutile@redhat.com>
Tested-by: Don Dutile <ddutile@redhat.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
The driver reads PCI vendor ID from the PCI configuration register while it is
already stored by the PCI subsystem in the 'vendor' field of 'struct pci_dev'...
The driver reads PCI subsystem IDs from the PCI configuration registers while
they are already stored by the PCI subsystem in the 'subsystem_{vendor|device}'
fields of 'struct pci_dev'...
re-scanning PCI
When hot-plugging a root bridge, we always prevent assigning a bus number
that already exists. This makes sure we don't step over an existing bus.
But sometimes we only remove PCI device in PCI hieratchy of OS, i,e.
echo 1 > /sys/bus/pci/devices/.../remove
but actually don't hotplug this device out the platform, so in this case
we still should re-scan this bus to enumerate this device when re-scanning
PCI again.
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
In addition to native PCIe AER, now APEI (ACPI Platform Error
Interface) GHES (Generic Hardware Error Source) can be used to report
PCIe AER errors too. To add support to APEI GHES PCIe AER recovery,
aer_recover_queue is added to export the recovery function in native
PCIe AER driver.
Recoverable PCIe AER errors are reported via NMI in APEI GHES. Then
APEI GHES uses irq_work to delay the error processing into an IRQ
handler. But PCIe AER recovery can be very time-consuming, so
aer_recover_queue, which can be used in IRQ handler, delays the real
recovery action into the process context, that is, work queue.
Signed-off-by: Huang Ying <ying.huang@intel.com>
While it's declared static, etags points you to the wrong function
in drivers/acpi/dock.c and acpiphp_glue.c for example also makes
use of some (exported..) functions from this file.
If you trust etags and oversee the static declaration (what happened
to me) one gets totally confused...
Signed-off-by: Thomas Renninger <trenn@suse.de>
Ricoh 1180:e823 does not recognize certain types of SD/MMC cards,
as reported at http://launchpad.net/bugs/773524. Lowering the SD
base clock frequency from 200Mhz to 50Mhz fixes this issue. This
solution was suggest by Koji Matsumuro, Ricoh Company, Ltd.
This change has no negative performance effect on standard SD
cards, though it's quite possible that there will be one on
UHS-1 cards.
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Tested-by: Daniel Manrique <daniel.manrique@canonical.com>
Cc: Koji Matsumuro <matsumur@nts.ricoh.co.jp>
Cc: <stable@kernel.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
Structs battery_file, acpi_dock_ops, file_operations,
thermal_cooling_device_ops, thermal_zone_device_ops, kernel_param_ops
are not changed in runtime. It is safe to make them const.
register_hotplug_dock_device() was altered to take const "ops" argument
to respect acpi_dock_ops' const notion.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Signed-off-by: Len Brown <len.brown@intel.com>
* pm-runtime:
PM / Runtime: Consistent utilization of deferred_resume
PM / Runtime: Prevent runtime_resume from racing with probe
PM / Runtime: Replace "run-time" with "runtime" in documentation
PM / Runtime: Improve documentation of enable, disable and barrier
PM: Limit race conditions between runtime PM and system sleep (v2)
PCI / PM: Detect early wakeup in pci_pm_prepare()
PM / Runtime: Return special error code if runtime PM is disabled
PM / Runtime: Update documentation of interactions with system sleep
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Multiple attempts to dynamically reallocate pci resources have
unfortunately lead to regressions. Though we continue to fix the
regressions and fine tune the dynamic-reallocation behavior, we have not
reached a acceptable state yet.
This patch provides a interim solution. It disables dynamic reallocation
by default, but adds the ability to enable it through pci=realloc kernel
command line parameter.
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu into core/iommu
A subsequent patch is going to move the invocation of
pm_runtime_barrier() from dpm_prepare() to __device_suspend().
Consequently, early wakeup events resulting from runtime resume
requests for wakeup devices queued up right before system suspend
will only be detected after all of the subsystem-level .prepare()
callbacks have run. However, the PCI bus type calls
pm_runtime_get_sync() from its pci_pm_prepare() callback routine,
so it would destroy the early wakeup events information regarding PCI
devices. To prevent this from happening add an early wakeup
detection mechanism, analogous to the one currently in dpm_prepare(),
to pci_pm_prepare().
Merriam-Webster tells us that the word exists. However ...
* Google suggests `forcibly' because it doesn't recognize `forcedly'.
* Google lists 494 thousand results for `forcedly'.
* Google lists 13.7 million results for `forcibly'.
* Linus's repo contains 1 occurrence of `forcedly' ( 0 after my change).
* Linus's repo contains 60 occurrences of `forcibly' (61 after my change).
Signed-off-by: Michael Witten <mfwitten@gmail.com>
