commit 249bfb83cf8ba658955f0245ac3981d941f746ee upstream.
Devices are added to pci_pme_list when drivers use pci_enable_wake()
or pci_wake_from_d3(), but they aren't removed from the list unless
the driver explicitly disables wakeup. Many drivers never disable
wakeup, so their devices remain on the list even after they are
removed, e.g., via hotplug. A subsequent PME poll will oops when
it tries to touch the device.
This patch disables PME# on a device before removing it, which removes
the device from pci_pme_list. This is safe even if the device never
had PME# enabled.
This oops can be triggered by unplugging a Thunderbolt ethernet adapter
on a Macbook Pro, as reported by Daniel below.
[bhelgaas: changelog]
Reference: http://lkml.kernel.org/r/CAMVG2svG21yiM1wkH4_2pen2n+cr2-Zv7TbH3Gj+8MwevZjDbw@mail.gmail.com
Reported-and-tested-by: Daniel J Blueman <daniel@quora.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit d347e75847c1fb299c97736638f45e6ea39702d4 upstream.
Use non-ordered workqueue for attention button events.
Attention button events on each slot can be handled asynchronously. So
we should use non-ordered workqueue. This patch also removes ordered
workqueue in shpchp as a result.
486b10b9f4 ("PCI: pciehp: Handle push button event asynchronously") made
the same change to pciehp. I split this out from a patch by Yijing Wang
<wangyijing@huawei.com> so we fix one thing at a time and to make the
shpchp history correspond more closely with the pciehp history.
CC: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
commit c2be6f93b383c873a4f9d521afa49b1b67d06085 upstream.
When we have a hotplug-capable PCIe port with a second hotplug-capable
PCIe port below it, removing the device below the upstream port causes
a deadlock.
The deadlock happens because we use the pciehp_wq workqueue to run
pciehp_power_thread(), which uses pciehp_disable_slot() to remove devices
below the upstream port. When we remove the downstream PCIe port, we call
pciehp_remove(), the pciehp driver's .remove() method. That calls
flush_workqueue(pciehp_wq), which deadlocks because the
pciehp_power_thread() work item is still running.
This patch avoids the deadlock by creating a workqueue for every PCIe port
and removing the single shared workqueue.
Here's the call path that leads to the deadlock:
pciehp_queue_pushbutton_work
queue_work(pciehp_wq) # queue pciehp_power_thread
pciehp_power_thread
pciehp_disable_slot
remove_board
pciehp_unconfigure_device
pci_stop_and_remove_bus_device
pciehp_remove # pciehp driver .remove method
pciehp_release_ctrl
pcie_cleanup_slot
This is fairly urgent because it can be caused by simply unplugging a
Thunderbolt adapter, as reported by Daniel below.
Reference: http://lkml.kernel.org/r/CAMVG2ssiRgcTD1bej2tkUUfsWmpL5eNtPcNif9va2-Gzb2u8nQ@mail.gmail.com
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
commit 9e16721498b0c3d3ebfa0b503c63d35c0a4c0642 upstream.
Right now using pcie_aspm=force will not enable ASPM if the FADT indicates
ASPM is unsupported. However, the semantics of force should probably allow
for this, especially as they did before 3c076351c4 ("PCI: Rework ASPM
disable code")
This patch just skips the clearing of any ASPM setup that the firmware has
carried out on this bus if pcie_aspm=force is being used.
Reference: http://bugs.launchpad.net/bugs/962038
commit a82b6af37d20bfe6e99a4d890f1cf1d89059929f upstream.
The function aer_recover_queue() calls pci_get_domain_bus_and_slot(), which
requires that the caller decrement the reference count with pci_dev_put().
This patch adds the missing call to pci_dev_put().
Signed-off-by: Betty Dall <betty.dall@hp.com>
Reviewed-by: Shuah Khan <shuah.khan@hp.com>
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream.
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
commit 1965f66e7db08d1ebccd24a59043eba826cc1ce8 upstream.
For bridges with "secondary > subordinate", i.e., invalid bus number
apertures, we don't enumerate anything behind the bridge unless the
user specified "pci=assign-busses".
This patch makes us automatically try to reassign the downstream bus
numbers in this case (just for that bridge, not for all bridges as
"pci=assign-busses" does).
We don't discover all the devices on the Intel DP43BF motherboard
without this change (or "pci=assign-busses") because its BIOS configures
a bridge as:
pci 0000:00:1e.0: PCI bridge to [bus 20-08] (subtractive decode)
[bhelgaas: changelog, change message to dev_info]
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18412
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=625754
Reported-by: Brian C. Huffman <bhuffman@graze.net>
Reported-by: VL <vl.homutov@gmail.com>
Tested-by: VL <vl.homutov@gmail.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
commit dfb117b3e50c52c7b3416db4a4569224b8db80bb upstream.
Check whether we evaluated _ADR successfully. Previously we ignored
failure, so we would have used garbage data from the stack as the device
and function number.
We return AE_OK so that we ignore only this slot and continue looking
for other slots.
Found by Coverity (CID 113981).
commit 0b68c8e2c3afaf9807eb1ebe0ccfb3b809570aa4 upstream.
Commit dbf0e4c (PCI: EHCI: fix crash during suspend on ASUS
computers) added a workaround for an ASUS suspend issue related to
USB EHCI and a bug in a number of ASUS BIOSes that attempt to shut
down the EHCI controller during system suspend if its PCI command
register doesn't contain 0 at that time.
It turns out that the same workaround is necessary in the analogous
hibernation code path, so add it.
References: https://bugzilla.kernel.org/show_bug.cgi?id=45811
Reported-and-tested-by: Oleksij Rempel <bug-track@fisher-privat.net>
commit dbf0e4c7257f8d684ec1a3c919853464293de66e upstream.
Quite a few ASUS computers experience a nasty problem, related to the
EHCI controllers, when going into system suspend. It was observed
that the problem didn't occur if the controllers were not put into the
D3 power state before starting the suspend, and commit
151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during
suspend on ASUS computers) was created to do this.
It turned out this approach messed up other computers that didn't have
the problem -- it prevented USB wakeup from working. Consequently
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add
NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it
reverted the earlier commit and added a whitelist of known good board
names.
Now we know the actual cause of the problem. Thanks to AceLan Kao for
tracking it down.
According to him, an engineer at ASUS explained that some of their
BIOSes contain a bug that was added in an attempt to work around a
problem in early versions of Windows. When the computer goes into S3
suspend, the BIOS tries to verify that the EHCI controllers were first
quiesced by the OS. Nothing's wrong with this, but the BIOS does it
by checking that the PCI COMMAND registers contain 0 without checking
the controllers' power state. If the register isn't 0, the BIOS
assumes the controller needs to be quiesced and tries to do so. This
involves making various MMIO accesses to the controller, which don't
work very well if the controller is already in D3. The end result is
a system hang or memory corruption.
Since the value in the PCI COMMAND register doesn't matter once the
controller has been suspended, and since the value will be restored
anyway when the controller is resumed, we can work around the BIOS bug
simply by setting the register to 0 during system suspend. This patch
(as1590) does so and also reverts the second commit mentioned above,
which is now unnecessary.
In theory we could do this for every PCI device. However to avoid
introducing new problems, the patch restricts itself to EHCI host
controllers.
Finally the affected systems can suspend with USB wakeup working
properly.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728
Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Dâniel Fraga <fragabr@gmail.com>
Tested-by: Javier Marcet <jmarcet@gmail.com>
Tested-by: Andrey Rahmatullin <wrar@wrar.name>
Tested-by: Oleksij Rempel <bug-track@fisher-privat.net>
Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b upstream.
This patch (as1558) fixes a problem affecting several ASUS computers:
The machine crashes or corrupts memory when going into suspend if the
ehci-hcd driver is bound to any controllers. Users have been forced
to unbind or unload ehci-hcd before putting their systems to sleep.
After extensive testing, it was determined that the machines don't
like going into suspend when any EHCI controllers are in the PCI D3
power state. Presumably this is a firmware bug, but there's nothing
we can do about it except to avoid putting the controllers in D3
during system sleep.
The patch adds a new flag to indicate whether the problem is present,
and avoids changing the controller's power state if the flag is set.
Runtime suspend is unaffected; this matters only for system suspend.
However as a side effect, the controller will not respond to remote
wakeup requests while the system is asleep. Hence USB wakeup is not
functional -- but of course, this is already true in the current state
of affairs.
A similar patch has already been applied as commit
suspend on ASUS computers). The patch supersedes that one and reverts
it. There are two differences:
The old patch added the flag at the USB level; this patch
adds it at the PCI level.
The old patch applied to all chipsets with the same vendor,
subsystem vendor, and product IDs; this patch makes an
exception for a known-good system (based on DMI information).
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
Commit 1cc0c998fdf2 ("ACPI: Fix D3hot v D3cold confusion") introduced a
bug in __acpi_bus_set_power() and changed the behavior of
acpi_pci_set_power_state() in such a way that it generally doesn't work
as expected if PCI_D3hot is passed to it as the second argument.
First off, if ACPI_STATE_D3 (equal to ACPI_STATE_D3_COLD) is passed to
__acpi_bus_set_power() and the explicit_set flag is set for the D3cold
state, the function will try to execute AML method called "_PS4", which
doesn't exist.
Fix this by adding a check to ensure that the name of the AML method
to execute for transitions to ACPI_STATE_D3_COLD is correct in
__acpi_bus_set_power(). Also make sure that the explicit_set flag
for ACPI_STATE_D3_COLD will be set if _PS3 is present and modify
acpi_power_transition() to avoid accessing power resources for
ACPI_STATE_D3_COLD, because they don't exist.
Second, if PCI_D3hot is passed to acpi_pci_set_power_state() as the
target state, the function will request a transition to
ACPI_STATE_D3_HOT instead of ACPI_STATE_D3. However,
ACPI_STATE_D3_HOT is now only marked as supported if the _PR3 AML
method is defined for the given device, which is rare. This causes
problems to happen on systems where devices were successfully put
into ACPI D3 by pci_set_power_state(PCI_D3hot) which doesn't work
now. In particular, some unused graphics adapters are not turned
off as a result.
To fix this issue restore the old behavior of
acpi_pci_set_power_state(), which is to request a transition to
ACPI_STATE_D3 (equal to ACPI_STATE_D3_COLD) if either PCI_D3hot or
PCI_D3cold is passed to it as the argument.
This approach is not ideal, because generally power should not
be removed from devices if PCI_D3hot is the target power state,
but since this behavior is relied on, we have no choice but to
restore it at the moment and spend more time on designing a
better solution in the future.
References: https://bugzilla.kernel.org/show_bug.cgi?id=43228
Reported-by: rocko <rockorequin@hotmail.com>
Reported-by: Cristian Rodríguez <crrodriguez@opensuse.org>
Reported-and-tested-by: Peter <lekensteyn@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull an ACPI patch from Len Brown:
"It fixes a D3 issue new in 3.4-rc1."
By Lin Ming via Len Brown:
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
Before this patch, ACPI_STATE_D3 incorrectly referenced D3hot
in some places, but D3cold in other places.
After this patch, ACPI_STATE_D3 always means ACPI_STATE_D3_COLD;
and all references to D3hot use ACPI_STATE_D3_HOT.
ACPI's _PR3 method is used to enter both D3hot and D3cold states.
What distinguishes D3hot from D3cold is the presence _PR3
(Power Resources for D3hot) If these resources are all ON,
then the state is D3hot. If _PR3 is not present,
or all _PR0 resources for the devices are OFF,
then the state is D3cold.
This patch applies after Linux-3.4-rc1.
A future syntax cleanup may remove ACPI_STATE_D3
to emphasize that it always means ACPI_STATE_D3_COLD.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Reviewed-by: Aaron Lu <aaron.lu@amd.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull build fixes for less mainstream architectures from Paul Gortmaker:
"These are fixes for frv(1), blackfin(2), powerpc(1) and xtensa(4).
Fortunately the touches are nearly all specific to files just used by
the arch in question. The two touches to shared/common files
[kernel/irq/debug.h and drivers/pci/Makefile] are trivial to assess as
no risk to anyone.
Half of them relate to xtensa directly. It was only when I fixed the
last xtensa issue that I realized that the arch has been broken for a
significant time, and isn't a specific v3.4 regression. So if you
wanted, we could leave xtensa lying bleeding in the street for a
couple more weeks and queue those for 3.5. But given they are no risk
to anyone outside of xtensa, I figured to just leave them in.
If you are OK with taking the xtensa fixes, then please pull to get:
- one last implicit include uncovered by system.h that is in a file
specific to just one powerpc defconfig. (I'd sync'd with BenH).
- fix an oversight in the PCI makefile where shared code wasn't being
compiled for ARCH=frv
- fix a missing include for GPIO in blackfin framebuffer.
- audit and tag endif in blackfin ezkit board file, in order to find
and fix the misplaced endif masking a block of code.
- fix irq/debug.h choice of temporary macro names to be more internal
so they don't conflict with names used by xtensa.
- fix a reference to an undeclared local var in xtensa's signal.c
- fix an implicit bug.h usage in xtensa's asm/io.h uncovered by my
removing bug.h from kernel.h
- fix xtensa to properly indicate it is using asm-generic/hardirq.h
in order to resolve the link error - undefined ack_bad_irq
The xtensa still fails final link as my latest binutils does something
evil when ld forward-relocates unlikely() blocks, but in theory people
who have older/valid toolchains could now use the thing."
* 'for-v3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
xtensa: fix build fail on undefined ack_bad_irq
blackfin: fix ifdef fustercluck in mach-bf538/boards/ezkit.c
blackfin: fix compile error in bfin-lq035q1-fb.c
pci: frv architecture needs generic setup-bus infrastructure
irq: hide debug macros so they don't collide with others.
xtensa: fix build error in xtensa/include/asm/io.h
xtensa: fix build failure in xtensa/kernel/signal.c
powerpc: fix system.h fallout in sysdev/scom.c [chroma_defconfig]
Otherwise we get this link failure for frv's defconfig:
LD .tmp_vmlinux1
drivers/built-in.o: In function `pci_assign_resource':
(.text+0xbf0c): undefined reference to `pci_cardbus_resource_alignment'
drivers/built-in.o: In function `pci_setup':
pci.c:(.init.text+0x174): undefined reference to `pci_realloc_get_opt'
pci.c:(.init.text+0x1a0): undefined reference to `pci_realloc_get_opt'
make[1]: *** [.tmp_vmlinux1] Error 1
Some shortcomings introduced into pci_restore_state() by commit
26f41062f28d ("PCI: check for pci bar restore completion and retry")
have been fixed by recent commit ebfc5b802fa76 ("PCI: Fix regression in
pci_restore_state(), v3"), but that commit treats all PCI devices as
those with Type 0 configuration headers.
That is not entirely correct, because Type 1 and Type 2 headers have
different layouts. In particular, the area occupied by BARs in Type 0
config headers contains the secondary status register in Type 1 ones and
it doesn't make sense to retry the restoration of that register even if
the value read back from it after a write is not the same as the written
one (it very well may be different).
For this reason, make pci_restore_state() only retry the restoration
of BARs for Type 0 config headers. This effectively makes it behave
as before commit 26f41062f28d for all header types except for Type 0.
Tested-by: Mikko Vinni <mmvinni@yahoo.com>
Commit 26f41062f28d ("PCI: check for pci bar restore completion and
retry") attempted to address problems with PCI BAR restoration on
systems where FLR had not been completed before pci_restore_state() was
called, but it did that in an utterly wrong way.
First off, instead of retrying the writes for the BAR registers only, it
did that for all of the PCI config space of the device, including the
status register (whose value after the write quite obviously need not be
the same as the written one). Second, it added arbitrary delay to
pci_restore_state() even for systems where the PCI config space
restoration was successful at first attempt. Finally, the mdelay(10) it
added to every iteration of the writing loop was way too much of a delay
for any reasonable device.
All of this actually caused resume failures for some devices on Mikko's
system.
To fix the regression, make pci_restore_state() only retry the writes
for BAR registers and only wait if the first read from the register
doesn't return the written value. Additionaly, make it wait for 1 ms,
instead of 10 ms, after every failing attempt to write into config
space.
Reported-by: Mikko Vinni <mmvinni@yahoo.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull xen fixes from Konrad Rzeszutek Wilk:
"Two fixes for regressions:
* one is a workaround that will be removed in v3.5 with proper fix in
the tip/x86 tree,
* the other is to fix drivers to load on PV (a previous patch made
them only load in PVonHVM mode).
The rest are just minor fixes in the various drivers and some cleanup
in the core code."
* tag 'stable/for-linus-3.4-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/pcifront: avoid pci_frontend_enable_msix() falsely returning success
xen/pciback: fix XEN_PCI_OP_enable_msix result
xen/smp: Remove unnecessary call to smp_processor_id()
xen/x86: Workaround 'x86/ioapic: Add register level checks to detect bogus io-apic entries'
xen: only check xen_platform_pci_unplug if hvm
The original XenoLinux code has always had things this way, and for
compatibility reasons (in particular with a subsequent pciback
adjustment) upstream Linux should behave the same way (allowing for two
distinct error indications to be returned by the backend).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Since 3.2.12 and 3.3, some systems are failing to boot with a BUG_ON.
Some other systems using the pata_jmicron driver fail to boot because no
disks are detected. Passing pcie_aspm=force on the kernel command line
works around it.
The cause: commit 4949be16822e ("PCI: ignore pre-1.1 ASPM quirking when
ASPM is disabled") changed the behaviour of pcie_aspm_sanity_check() to
always return 0 if aspm is disabled, in order to avoid cases where we
changed ASPM state on pre-PCIe 1.1 devices.
This skipped the secondary function of pcie_aspm_sanity_check which was
to avoid us enabling ASPM on devices that had non-PCIe children, causing
trouble later on. Move the aspm_disabled check so we continue to honour
that scenario.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=42979 and
http://bugs.debian.org/665420
Reported-by: Romain Francoise <romain@orebokech.com> # kernel panic
Reported-by: Chris Holland <bandidoirlandes@gmail.com> # disk detection trouble
Cc: stable@vger.kernel.org
Tested-by: Hatem Masmoudi <hatem.masmoudi@gmail.com> # Dell Latitude E5520
Tested-by: janek <jan0x6c@gmail.com> # pata_jmicron with JMB362/JMB363
[jn: with more symptoms in log message]
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Pull ACPI & Power Management changes from Len Brown:
- ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup
- cpuidle evolving, more ARM use
- thermal sub-system evolving, ditto
- assorted other PM bits
Fix up conflicts in various cpuidle implementations due to ARM cpuidle
cleanups (ARM at91 self-refresh and cpu idle code rewritten into
"standby" in asm conflicting with the consolidation of cpuidle time
keeping), trivial SH include file context conflict and RCU tracing fixes
in generic code.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits)
ACPI throttling: fix endian bug in acpi_read_throttling_status()
Disable MCP limit exceeded messages from Intel IPS driver
ACPI video: Don't start video device until its associated input device has been allocated
ACPI video: Harden video bus adding.
ACPI: Add support for exposing BGRT data
ACPI: export acpi_kobj
ACPI: Fix logic for removing mappings in 'acpi_unmap'
CPER failed to handle generic error records with multiple sections
ACPI: Clean redundant codes in scan.c
ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed()
ACPI: consistently use should_use_kmap()
PNPACPI: Fix device ref leaking in acpi_pnp_match
ACPI: Fix use-after-free in acpi_map_lsapic
ACPI: processor_driver: add missing kfree
ACPI, APEI: Fix incorrect APEI register bit width check and usage
Update documentation for parameter *notrigger* in einj.txt
ACPI, APEI, EINJ, new parameter to control trigger action
ACPI, APEI, EINJ, limit the range of einj_param
ACPI, APEI, Fix ERST header length check
cpuidle: power_usage should be declared signed integer
acpi_dev_run_wake() is a generic function which can be used by
other subsystem too. Rename it to acpi_pm_device_run_wake, to be
consistent with acpi_pm_device_sleep_wake.
Then move it to ACPI core.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
Pull xen updates from Konrad Rzeszutek Wilk:
"which has three neat features:
- PV multiconsole support, so that there can be hvc1, hvc2, etc; This
can be used in HVM and in PV mode.
- P-state and C-state power management driver that uploads said power
management data to the hypervisor. It also inhibits cpufreq
scaling drivers to load so that only the hypervisor can make power
management decisions - fixing a weird perf bug.
There is one thing in the Kconfig that you won't like: "default y
if (X86_ACPI_CPUFREQ = y || X86_POWERNOW_K8 = y)" (note, that it
all depends on CONFIG_XEN which depends on CONFIG_PARAVIRT which by
default is off). I've a fix to convert that boolean expression
into "default m" which I am going to post after the cpufreq git
pull - as the two patches to make this work depend on a fix in Dave
Jones's tree.
- Function Level Reset (FLR) support in the Xen PCI backend.
Fixes:
- Kconfig dependencies for Xen PV keyboard and video
- Compile warnings and constify fixes
- Change over to use percpu_xxx instead of this_cpu_xxx"
Fix up trivial conflicts in drivers/tty/hvc/hvc_xen.c due to changes to
a removed commit.
* tag 'stable/for-linus-3.4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen kconfig: relax INPUT_XEN_KBDDEV_FRONTEND deps
xen/acpi-processor: C and P-state driver that uploads said data to hypervisor.
xen: constify all instances of "struct attribute_group"
xen/xenbus: ignore console/0
hvc_xen: introduce HVC_XEN_FRONTEND
hvc_xen: implement multiconsole support
hvc_xen: support PV on HVM consoles
xenbus: don't free other end details too early
xen/enlighten: Expose MWAIT and MWAIT_LEAF if hypervisor OKs it.
xen/setup/pm/acpi: Remove the call to boot_option_idle_override.
xenbus: address compiler warnings
xen: use this_cpu_xxx replace percpu_xxx funcs
xen/pciback: Support pci_reset_function, aka FLR or D3 support.
pci: Introduce __pci_reset_function_locked to be used when holding device_lock.
xen: Utilize the restore_msi_irqs hook.
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches for 3.4-rc1 from Greg KH:
"Here's the big driver core merge for 3.4-rc1.
Lots of various things here, sysfs fixes/tweaks (with the nlink
breakage reverted), dynamic debugging updates, w1 drivers, hyperv
driver updates, and a variety of other bits and pieces, full
information in the shortlog."
* tag 'driver-core-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (78 commits)
Tools: hv: Support enumeration from all the pools
Tools: hv: Fully support the new KVP verbs in the user level daemon
Drivers: hv: Support the newly introduced KVP messages in the driver
Drivers: hv: Add new message types to enhance KVP
regulator: Support driver probe deferral
Revert "sysfs: Kill nlink counting."
uevent: send events in correct order according to seqnum (v3)
driver core: minor comment formatting cleanups
driver core: move the deferred probe pointer into the private area
drivercore: Add driver probe deferral mechanism
DS2781 Maxim Stand-Alone Fuel Gauge battery and w1 slave drivers
w1_bq27000: Only one thread can access the bq27000 at a time.
w1_bq27000 - remove w1_bq27000_write
w1_bq27000: remove unnecessary NULL test.
sysfs: Fix memory leak in sysfs_sd_setsecdata().
intel_idle: Revert change of auto_demotion_disable_flags for Nehalem
w1: Fix w1_bq27000
driver-core: documentation: fix up Greg's email address
powernow-k6: Really enable auto-loading
powernow-k7: Fix CPU family number
In 5bfa14ed9f3c, I forgot to initialize res2.flags before calling
pcibios_bus_to_resource(), which depends on the resource type to locate the
correct aperture. This bug won't hurt x86, which currently never has an
offset between bus and CPU addresses, but will affect other architectures.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This was done to resolve a conflict in the drivers/base/cpu.c file.
Right now we won't touch ASPM state if ASPM is disabled, except in the case
where we find a device that appears to be too old to reliably support ASPM.
Right now we'll clear it in that case, which is almost certainly the wrong
thing to do. The easiest way around this is just to disable the blacklisting
when ASPM is disabled.
This patch recodes the MRRS cap for 5719 A0 devices as a PCI quirk.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
There are PCIe devices on the market that report ARI support but
then fail to initialize correctly when ARI is actually used. This
leads to situations in which kernels 2.6.34 and newer fail to handle
systems where the previous kernels worked without any apparent
problems. Unfortunately, it is currently unknown how many such
devices are there.
For this reason, introduce a new kernel command line option,
pci=noari, allowing users to disable PCIe ARI altogether if they
see problems with PCIe device initialization.
pci_stop_bus_device gets called before in the same loop.
Don't switch to pci_remove_bus_device yet, keep the __ prefix for now
(the behavior is still the same: remove without stopping first).
This allows other out of tree users or pending patches to get notified
from compiler warning.
The old pci_remove_behind_bridge actually do stop and remove.
Make the name reflect that to reduce confusion.
Suggested-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The old pci_remove_bus_device actually did stop and remove.
This patch is done by sed scripts and changes back some incorrect
__pci_remove_bus_device changes.
Makes it a little easier to figure out which device may have caused a
slow quirk.
Cc: Arjan van de Ven <arjan@infradead.org>
This isn't really a quirk; calling it directly from pci_add_device makes
more sense.
Recently added support to allow quirks to report duration also make the
boot log very crowded when initcall_debug is specified.
One thing we can to do mitigate this is to not call quirks unnecessarily
by adding a new quirk declaration macro that takes a class argument.
The new macro takes a class value and a class shift value (since it can
vary) so that quirks will be limited to certain device classes, greatly
reducing the number we call on every PCI device addition.
-v2: fix v1 that left over of sparated patch.
-v3: according to Jesse, change cls to class, cls_shift, to class_shift.
git://github.com/bjorn-helgaas/linux into linux-next
Add a new config option, PCI_REALLOC_ENABLE_AUTO, which will
automatically try to re-allocate PCI resources if PCI_IOV support is
enabled and the SR-IOV resources are unassigned. Behavior can still be
controlled using the pci=realloc= parameter.
-v2: According to Jesse, adding one CONFIG option for distribution to
disable it or enable it.
-v3: update Kconfig text (jbarnes)
let user know they could try if pci=realloc could help.
-v2: update suggestion text.
Let the user could enable and disable with pci=realloc=on or pci=realloc=off
Also
1. move variable and functions near the place they are used.
2. change macro to function
3. change related functions and variable to static and _init
4. update parameter description accordingly.
This will let us add a config option to control default behavior, and
still allow the user to turn off automatic reallocation if it fails on
their platform until a permanent solution is found.
-v2: still honor pci=realloc, and treat it as pci=realloc=on
also use enum instead of ...
-v3: update kernel-paramenters.txt according to Jesse.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
