commit 827b4649d4626bf97b203b4bcd69476bb9b4e760 upstream.
pcmcia_socket_dev_suspend() doesn't use its second argument, so it
may be dropped safely.
This change is necessary for the subsequent yenta suspend/resume fix.
device_driver'
This patch fixes the bug reported in
http://bugzilla.kernel.org/show_bug.cgi?id=11681.
"Lots of device drivers register a 'struct device_driver' with
the '.bus' member set to '&platform_bus_type'. This is wrong,
since the platform_bus functions expect the 'struct device_driver'
to be wrapped up in a 'struct platform_driver' which provides
some additional callbacks (like suspend_late, resume_early).
The effect may be that platform_suspend_late() uses bogus data
outside the device_driver struct as a pointer pointer to the
device driver's suspend_late() function or other hard to
reproduce failures."(Lothar Wassmann)
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
By now, ioaddr_t should only be used by the deprecated ioctl, as it does not
correctly reflect the maximum ioport range at least on some architectures.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Alchemy Semi Au1000 pcmcia driver: The semaphore pcmcia_sockets_lock
is used as a mutex, convert it to the mutex API
(akpm: make it static too)
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
drivers/pcmcia/au1000_generic.c: In function 'au1x00_pcmcia_socket_probe':
drivers/pcmcia/au1000_generic.c:375: error: 'struct device' has no member named 'dev'
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Greg KH <greg@kroah.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
ioremap must be balanced by an iounmap and failing to do so can result
in a memory leak.
Signed-off-by: Amol Lad <amol@verismonetworks.com>
The previous code did something like,
if (error) goto out_err;
do {
struct au1000_pcmcia_socket *skt = PCMCIA_SOCKET(i);
del_timer_sync(&skt->poll_timer);
pcmcia_unregister_socket(&skt->socket);
out_err:
flush_scheduled_work();
ops->hw_shutdown(skt);
i--;
} while (i > 0)
- On the error path, skt would not contain a valid value for the first
iteration (skt is masked by uninitialized automatic skt)
- Does not do hw_shutdown() for 0th element of PCMCIA_SOCKET
Signed-off-by: Om Narasimhan <om.turyx@gmail.com>
Cc: "Yoichi Yuasa" <yoichi_yuasa@tripeaks.co.jp>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Convert users of kmalloc and memset to kzalloc
The .get_socket callback is never used by the PCMCIA core, therefore remove
it.
Manual #include fixups for clashes - there may be some unnecessary
- fixed an iounmap warning
- export fixup_xx, needed by the module
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Get the au1000 PCMCIA socket drivers to work.
This fixes u32 vs. pm_message_t in pcmcia.
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
