path: root/drivers/pcmcia/i82092.c
2008-05-01pcmcia: silence section mismatch warnings from pci_driver variablesSam Ravnborg
Silence following warnings: WARNING: drivers/pcmcia/built-in.o(.data+0x14e0): Section mismatch in reference from the variable pd6729_pci_drv to the function .devinit.text:pd6729_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x14e8): Section mismatch in reference from the variable pd6729_pci_drv to the function .devexit.text:pd6729_pci_remove() WARNING: drivers/pcmcia/built-in.o(.data+0x16c0): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devinit.text:i82092aa_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x16c8): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devexit.text:i82092aa_pci_remove() Rename the variables from *_drv to *_driver so modpost ignore the OK references to __devinit/__devexit functions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21PCI: drivers/pcmcia/i82092.c: fix up after pci_bus_region changesAndrew Morton
drivers/pcmcia/i82092.c: In function 'i82092aa_set_mem_map': drivers/pcmcia/i82092.c:650: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' drivers/pcmcia/i82092.c:650: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-05pcmcia: replace kio_addr_t with unsigned int everywhereOlof Johansson
Remove kio_addr_t, and replace it with unsigned int. No known architecture needs more than 32 bits for IO addresses and ports and having a separate type for it is just messy. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07Driver core: convert pcmcia code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Cc: <linux-pcmcia@lists.infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-25[PATCH] i82092: wire up errors from pci_register_driver()Alexey Dobriyan
debugging goo removed to not leave assymetry in it after possible "leave" removal. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-10-25[PATCH] CONFIG_PM=n slim: drivers/pcmcia/*Alexey Dobriyan
Remove some code which is unneeded if CONFIG_PM=n. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: remove include of config.hDominik Brodowski
Remove the inclusion of include/config.h as it isn't needed any longer. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: remove get_socket callbackDominik Brodowski
The .get_socket callback is never used by the PCMCIA core, therefore remove it. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
