path: root/drivers/pcmcia/pxa2xx_base.c
2012-09-21ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe()Wei Yongjun
In case of error, the function clk_get() returns ERR_PTR() and never returns NULL pointer. The NULL test in the error handling should be replaced with IS_ERR(). dpatch engine is used to auto generated this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23Merge branch 'pcmcia' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #3 ARM updates from Russell King: "This adds gpio support to soc_common, allowing an amount of code to be deleted from each PCMCIA socket driver for the PXA/SA11x0 SoCs." * 'pcmcia' of git://git.linaro.org/people/rmk/linux-arm: PCMCIA: sa1111: rename sa1111 socket drivers to have sa1111_ prefix. PCMCIA: make lubbock socket driver part of sa1111_cs PCMCIA: add Kconfig control for building sa11xx_base.c PCMCIA: sa1111: jornada720: no need to disable IRQs around sa1111_set_io PCMCIA: sa1111: pass along sa1111_pcmcia_configure_socket() failure code PCMCIA: soc_common: remove explicit wrprot initialization in socket drivers PCMCIA: soc_common: remove soc_pcmcia_*_irqs functions PCMCIA: sa11x0: h3600: convert to use new irq/gpio management PCMCIA: sa11x0: simpad: convert to use new irq/gpio management PCMCIA: sa11x0: shannon: convert to use new irq/gpio management PCMCIA: sa11x0: nanoengine: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: nanoengine: convert to use new irq/gpio management PCMCIA: sa11x0: cerf: convert reset handling to use GPIO subsystem PCMCIA: sa11x0: cerf: convert to use new irq/gpio management PCMCIA: sa11x0: assabet: convert to use new irq/gpio management PCMCIA: sa1111: use new per-socket irq/gpio infrastructure PCMCIA: pxa: convert PXA socket drivers to use new irq/gpio management PCMCIA: soc_common: add GPIO support for card status signals PCMCIA: soc_common: move common initialization into soc_common
2012-02-16ARM: pxa: fix error handling in pxa2xx_drv_pcmcia_probeAxel Lin
If pxa2xx_drv_pcmcia_add_one fails, it will go to err1 error path. Add a missing clk_put in the error path. Checking the ret value after the for loop is redundant, it is always false. Thus remove the redundant checking. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-01-26PCMCIA: soc_common: move common initialization into soc_commonRussell King
Move common socket initialization into soc_common.c. Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-05ARM: PXA: fix lubbock PCMCIA driver build errorRussell King
Fix: ERROR: "pxa2xx_configure_sockets" [drivers/pcmcia/pxa2xx_lubbock_cs.ko] undefined! by exporting the required function. Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19pcmcia vs. MECR on pxa25x/sa1111Pavel Machek
After 2.6.34 changes, __pxa2xx_drv_pcmcia_probe() was replaced by sa1111_pcmcia_add(). That unfortunately means that configure_sockets() is not called, leading to MECR not being set properly, leading to strange crashes. Tested on pxa255+sa1111, I do not have lubbock board nearby. Perhaps cleaner solution exists? Signed-off-by: Pavel Machek <pma@sysgo.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-12-20ARM: pxa: Add pxa320 PCMCIA checkMarek Vasut
On PXA320, there's only one PCMCIA slot available. Check for cases where the user would want to register multiple. Also, rework failpath. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: remove get_memclk_frequency_10khz()Eric Miao
Introduce 'struct clk' for memory and remove get_memclk_frequency_10khz(). Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Access SMEMC via virtual addressesMarek Vasut
This is important because on PXA3xx, the physical mapping of SMEMC registers differs from the one on PXA2xx. In order to get PCMCIA working on both PXA2xx and PXA320, the PCMCIA driver was adjusted accordingly as well. Also, various places in the kernel had to be patched to use __raw_read/__raw_write. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq pcmcia: do not request windows if you don't need to pcmcia: insert PCMCIA device resources into resource tree pcmcia: export resource information to sysfs pcmcia: use struct resource for PCMCIA devices, part 2 pcmcia: remove memreq_t pcmcia: move local definitions out of include/pcmcia/cs.h pcmcia: do not use io_req_t when calling pcmcia_request_io() pcmcia: do not use io_req_t after call to pcmcia_request_io() pcmcia: use struct resource for PCMCIA devices pcmcia: clean up cs.h pcmcia: use pcmica_{read,write}_config_byte pcmcia: remove cs_types.h pcmcia: remove unused flag, simplify headers pcmcia: remove obsolete CS_EVENT_ definitions pcmcia: split up central event handler pcmcia: simplify event callback pcmcia: remove obsolete ioctl Conflicts in: - drivers/staging/comedi/drivers/* - drivers/staging/wlags49_h2/wl_cs.c due to dev_info_t and whitespace changes
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-13[ARM] pxa: fix frequency scaling for pcmcia/pxa2xx_baseMarek Vasut
The MCxx values must be based off memory clock, not CPU core clock. This also fixes the bug where on some machines the LCD went crazy while using PCMCIA. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Nicolas Pitre <nico@fluxnic.net> Reviewed-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24pcmcia: use dev_pm_ops for class pcmcia_socket_classDominik Brodowski
Instead of requiring PCMCIA socket drivers to call various functions during their (bus) resume and suspend functions, register an own dev_pm_ops for this class. This fixes several suspend/resume bugs seen on db1xxx-ss, and probably on some other socket drivers, too. With regard to the asymmetry with only _noirq suspend, but split up resume, please see bug 14334 and commit 9905d1b411946fb3 . Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-12-16PCMCIA: fix pxa2xx_lubbock modular build errorMarc Zyngier
Commit d0d26c33b63c7ec10c3fdf9c7ce0aa035f0b3200 broke the driver by propagating a pointer to the platform_device where a pointer to the generic device was expected, leading to a spectacular crash... Signed-off-by: Marc Zyngier <maz@misterjones.org> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-13Merge branch 'master' into develRussell King
2009-12-13[ARM] pxa/zeus: make Viper pcmcia support more generic to support ZeusMarc Zyngier
The Arcom Zeus CF slot requires the same kind of support as the Viper. To avoid code duplication, introduce a platform device that abstracts the differences. This also allows for the removal of the ugly export of viper_cf_rst(). Signed-off-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-12-12PCMCIA: fix pxa2xx_lubbock modular build errorRussell King
ERROR: "pxa2xx_drv_pcmcia_ops" [drivers/pcmcia/pxa2xx_lubbock_cs.ko] undefined! ERROR: "pxa2xx_drv_pcmcia_add_one" [drivers/pcmcia/pxa2xx_lubbock_cs.ko] undefined! We also remove __pxa2xx_drv_pcmcia_probe and its export, since this is no longer required. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-09PCMCIA: stop duplicating pci_irq in soc_pcmcia_socketRussell King - ARM Linux
skt->irq is a mere duplication of pcmcia_socket's pci_irq member. Get rid of it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socketRussell King - ARM Linux
The 'dev' member is now only ever written, so we can safely remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific dataRussell King - ARM Linux
2009-11-09PCMCIA: soc_common: push socket probe down into SoC specific supportRussell King - ARM Linux
Move the individual socket probing and initialization down into the SoC specific support files, thereby allowing soc_common_drv_pcmcia_probe to be eliminated. soc_common.c now no longer deals with distinct groups of sockets. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: soc_common: push socket removal down to SoC specific supportRussell King - ARM Linux
Mechanically transplant the removal code from soc_common into each SoC specific base support file, thereby allowing soc_common_drv_pcmcia_remove to be removed. No other changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-09-29PM / PCMCIA: Drop second argument of pcmcia_socket_dev_suspend()Rafael J. Wysocki
pcmcia_socket_dev_suspend() doesn't use its second argument, so it may be dropped safely. This change is necessary for the subsequent yenta suspend/resume fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2009-09-10[ARM] pxa: update pcmcia/pxa2xx_base.c to use 'struct dev_pm_ops'Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-28[ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: move PCMCIA definitions out of pxa-regs.h into pxa2xx_base.cEric Miao
Move the processor specific initialization (largely resources initialization) out of soc_common_drv_pcmcia_probe() into dedicated sa11xx_drv_pcmcia_probe() and __pxa2xx_drv_pcmcia_probe(). By doing this, we are now able to move the PCMCIA related definitions out of pxa-regs.h and back into pxa2xx_base.c. As a result, remove that reference of _PCMCIA1IO in arch/arm/mach-pxa/viper.c. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: remove unnecessary #include of pxa-regs.h and hardware.hEric Miao
pxa-regs.h and hardware.h are not intended for use directly in driver code, remove those unnecessary references. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: ioctl-internal definitions pcmcia: cistpl header cleanup pcmcia: remove unused argument to pcmcia_parse_tuple() pcmcia: card services header cleanup pcmcia: device_id header cleanup pcmcia: encapsulate ioaddr_t pcmcia: cleanup device driver header file pcmcia: cleanup socket services header file pcmcia: merge ds_internal.h into cs_internal.h pcmcia: cleanup cs_internal.h pcmcia: cs_internal.h is internal pcmcia: use dev_printk for cs_error() pcmcia: remove CS_ error codes alltogether pcmcia: deprecate CS_BAD_TUPLE pcmcia: deprecate CS_BAD_ARGS pcmcia: deprecate CS_BAD_BASE, CS_BAD_IRQ, CS_BAD_OFFSET and CS_BAD_SIZE pcmcia: deprecate CS_BAD_ATTRIBUTE, CS_BAD_TYPE and CS_BAD_PAGE pcmcia: deprecate CS_NO_MORE_ITEMS pcmcia: deprecate CS_IN_USE pcmcia: deprecate CS_CONFIGURATION_LOCKED ... Fix trivial conflict in drivers/pcmcia/ds.c manually
2008-09-09Add support for the Arcom/Eurotech Viper SBC CompactFlash card slotMarc Zyngier
The Arcom/Eurotech Viper needs some extra care to run. On this board, the PC104 connector is actually wired to the second PCMCIA slot. Therefore, this second socket needs to be enabled, despite not being managed by the PCMCIA code. I'd rather have the MECR setup in the platform support code so I could, for example, use the PC104 bus without having the PCMCIA module loaded. Signed-off-by: Marc Zyngier <marc.zyngier@altran.com>
2008-08-25pcmcia: cs_internal.h is internalDominik Brodowski
cs_internal.h is meant for definitions internal to the PCMCIA core modules. It must not be included by PCMCIA socket drivers or by PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-24pcmcia: remove unused bulkmem.hMagnus Damm
The code in include/pcmcia/bulkmem.h was only kept for compatibility reasons. Therefore, move the remaining region_info_t definition to ds.h [linux@dominikbrodowski.net: do not modify the IOCTL, move definition to ds.h, and update changelog] Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-04-15pcmcia: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable PCMCIA platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-26[ARM] pxa: move memory controller registers into pxa2xx-regs.hRussell King
PXA3 has a different memory controller from PXA2 platforms. Avoid clashing definitions by moving the PXA2 definitions to pxa2xx-regs.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-16pxa2xx PCMCIA timing issue on iPAQ H5550Milan Plzik
Recently I've been trying to get working PCMCIA interface on H5000 ipaq series, using dual PCMCIA sleeve. So far things work correctly, but I had to do one modification to drivers/pcmcia/pxa2xx_base.c to get the interface working with orinoco gold PCMCIA card (wired pcnet_cs ethernet card worked even without this modification). The issue has something to do with assert time on PCMCIA bus, but I'm not really sure what -- I found the working value just by trial&error approach. I'm not sure how is the assert value in pxa2xx_mcxx_asst calculated (I know, simple formula, but the reason why is it calculated that way is not obvious for me), neither that my modification is correct. It just works with iPAQ. Cc: Russell King <rmk@arm.linux.org.uk> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-28[ARM] Fix suspend oops caused by PXA2xx PCMCIA driverRussell King
The PXA2xx PCMCIA driver was registering a device_driver with the platform_bus_type. Unfortunately, this causes data outside the device_driver structure to be dereferenced as if it were a platform_driver structure, causing an oops. Convert the PXA2xx core driver to use the proper platform_driver structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-03[ARM] 2873/1: PCMCIA soc: Allow access to filesystems on CF at boot timeRichard Purdie
Patch from Richard Purdie This change makes the soc pcmcia interfaces available earlier in the boot process meaning devices like CF microdrives can be used for the root filesystem. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-16[PATCH] fix u32 vs. pm_message_t in pcmciaPavel Machek
This fixes u32 vs. pm_message_t in pcmcia. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
